Page 1 of 7 1 2 3 4 5 ... LastLast
Results 1 to 35 of 244
Thread: The turbo project begins....
  1. Forum Sponsor 2kjettaguy's Avatar
    Dec 24th, 2000
    Millersville, MD
    96 Jetta VR6, 01 TT 225, 07 GTI 4dr
    05-11-2003 10:51 PM #1
    I finally got most of what I need in to start building my kit. Still waiting on the split second PSC1-001 but I doubt I'll be anywhere near done when that arrives.
    My setup:
    ATP manifold
    T3 from killa, .48ar hot / .60 cold
    ATP oil lines
    Custom downpipe / Magnaflow 2.5" high flow Cat
    Custom 2" boost piping / 2.5" intake piping
    PWR Air-water intercooler
    Jabsco pump / 16 x 10 Tranny cooler front mounted
    30# injectors & Split second fueling controller
    Turboxs boost controller
    Greddy Type S BOV
    Lots of miscellaneous stuff
    So far the problems I have run into include.... My compressor inlet is flanged, so I had to machine a custom 2.5" inlet flange. It came out awesome. I ordered a T3 discharge flange from ATP and its way too small for my turbo. The ATP holes are 2.9" on center and mine are 3.350. Likewise, I made that flange too. Took forever to mill Also, I have no idea why in the hell ATP puts a 45 degree fitting on the bottom of their oil return line. I've got all my oil pan bolts out just waigint to get the turbo on to size it all up. Also, I have to make something to cover the secondary air injection holes in the head. I figure I'll just make some aluminum "gaskets" and see if they melt...
    The huge water cooler pictured is something i made from my Grandfather's EXepdition's Air conditioning condensor. It got a hole right in the middle so I cut it down to about 8" high. Very unfortunately I found its way too long to fit. I'd have to gut my front spoiler and remove the 2 main mounting clips on the front bumper to get it in there. That was free, so no biggie. I am back to plan A with the NAPA tranny cooler. If that turns out to not be efficient enough I'll add another one. Why not?
    Here's some pics so far:
    The inlet flange I made w/ gasket
    The discharge flange I made
    half ass polishing job...
    Notching the bumper support (damn thing)
    The plan A water cooler. It sits 1" away from the condensor at the bottom and 1.5" at the top.
    More pics as I get time to work on this more
  2. Member turbodub's Avatar
    Jul 6th, 2000
    garden state
    94 golf
    05-11-2003 11:14 PM #2
    you need the 45 off the turbo cause if it goes straight down the line will hit the axel
  3. Forum Sponsor 2kjettaguy's Avatar
    Dec 24th, 2000
    Millersville, MD
    05-11-2003 11:17 PM #3
    Oh, so the 45 goes off the turbo? I haven't had the turbo mounted long enough to check it all out. Does the return line go in between the axle and the motor, or around the axle?
  4. Member speed51133!'s Avatar
    Aug 5th, 2002
    alexandria va/milwaukee wi
    02 audi tt 225 / mk3 jetta /audi 5000s turbo
    05-11-2003 11:37 PM #4
    i dont know why they use 45 deg. bend either.
    i have a straight fitting on the turbo, and a straight fitting on the oil pan. the oil line has a 90 bend on it at the oil pan.
    never touched the axle.
    looks good so far man.
  5. Forum Sponsor 2kjettaguy's Avatar
    Dec 24th, 2000
    Millersville, MD
    05-11-2003 11:41 PM #5
    I have my turbo cartride clocked square with the T3 flange. I even used a square.... Yeh I am a perfectionist. It doesn't make sense to have the 45.
    I might have to source the straight from somewhere. I wish i had a 1/2" NPT pipe Die cause I'd just make one to be welded to the aluminum oil pan.
  6. 05-11-2003 11:48 PM #6
    looks like fun...keep us updated How much HP are you guestimating this will produce?
  7. Forum Sponsor 2kjettaguy's Avatar
    Dec 24th, 2000
    Millersville, MD
    05-11-2003 11:52 PM #7
    Well, you all know I previously had a 137whp supercharged monster
    I am hoping 180-200 whp without breaking stuff yet
    Question - should I water cool this turbo? Its got the holes, just wondering if I should do it? I was thinking of just running the throttle body hoses to the turbo instead of the throttle body. The fittings in the turbo are like a 3/8" NPT but without the taper. That's a standard thread, 5/8"-18 I think. Anywho, I don't know where to get a hose bard with straight threads! I am thinking about runnning my 3/8" NPT tap down in there and tapering the threads. Then I can use a regular 3/8" male barb / male threads. Any ideas?
  8. Former Advertiser Anand@4induktion.com's Avatar
    Aug 25th, 2001
    Annapolis, MD
    '06 Touareg V8
    05-12-2003 12:06 AM #8
    woo woo i can say i helped work on this beast
    evan, you know my opinion on the watercoolage.... just run the lines off the TB into 3/8"NPT (rethreaded)... i guess i'll swing by after school tomorrow for the work to continue!
    P.S. post a pic of the drawing!!
    Modified by Anand20v at 12:07 AM 5-12-2003
  9. Member g60vwr's Avatar
    Apr 9th, 2000
    LI NY USA
    6 and happily going down
    05-12-2003 12:21 AM #9
    Quote, originally posted by 2kjettaguy »
    i know that problem well- Im guessing Killa's turbo supplier is MJM turbos... can this be confirmed?
    Cry once....
  10. Forum Sponsor 2kjettaguy's Avatar
    Dec 24th, 2000
    Millersville, MD
    05-12-2003 12:29 AM #10
    Not sure, but I am not worried about it. I got around the issue quite well I think. I designed my flange to allow the first section of 2.5" pipe to go inside the flange. That way I can do a fillet weld and a weld on the outside.
  11. Forum Sponsor blkjettavr6's Avatar
    Nov 7th, 2001
    Millersville
    VR's
    05-12-2003 12:49 AM #11
    yeh you suck....while you did all the easy bumper cutting crap i was take the flipping ehaust crap off. What a pain.
    42 Draft Designs
  12. Banned
    Feb 26th, 2002
    05-12-2003 01:02 AM #12
    due, you got a cnc machine, hot as arts
    now that your mani os off i suggest tapping it fo regt and extenal just to have it fo rthe future, i mean you have water ic, why not go tial route?
  13. Banned
    May 16th, 2002
    05-12-2003 01:25 AM #13
    That is going to be a sick setup..Put drain line between axle and block,the atp one is the perfect length.45 is at the oil pan end.6 turbo cars built this way and no problems.
  14. Banned
    Feb 26th, 2002
    05-12-2003 01:41 AM #14
    i ahd a problem with atp stuff fittig my mjm turbo,
    the mk4 oil line is straight, if its form ato, i tried the one with a 90, its the wrong one
    are you ready for power? welcome to turbo ,cough ns sucks cough
    Modified by evoeone at 1:42 AM 5-12-2003
  15. Member
    Feb 27th, 2002
    Cape Cod
    91 Golf GL 4 Door, 95 Eclipse GSX
    05-12-2003 01:46 AM #15
    nice machine work. can i suggest for future reference to get different bends than the dynomax ones. i personally use hooker mild bends, they are much cleaner and more consistant than the dynomax and others i've tried.
    Sell me your stock front sway bar and hardware, 15mm preferred. PM for details.
  16. 05-12-2003 02:44 AM #16
    Man, you're getting me all excited! I'm doing the same thing as you and our setups look eerily similar!
    I'm just waiting on the intercooler to start putting it all together.
    I'm having a real rough time choosing the "right" turbo ...
    I hope your setup works well, can't wait to hear how it turns out!
    Modified by Agtronic at 11:44 PM 5-11-2003
    Markku Kivinen | Agtronic Motorsport
  17. 05-12-2003 07:52 AM #17
    evan, i cant wait to see it when your done!!! maybe i can get a ride in the 2.0TTT!!! you definatlly are a perfectionist its obvious in your gauges!!! let me know when your done! would love to check it out!!
  18. Banned
    May 16th, 2002
    05-12-2003 08:03 AM #18
    Wow!Talk about facilities!Are you going to have a big water reservoir.With water cooled IC's I understand that water does absorb way more heat than air (when the water is cool),but in a daily driver car,when you turn it off the water will heat soak and abrsorb a lot of heat,so when you get back into your car and drive,it takes a long time to cool down the water in the system so it can do it's job and cool down the charge air.I have IAT sensor and my air-air IC cools charge air quickly (about 3min.driving)from stop and go traffic.That is why I recommend a big reservoir or a constantly running pump to keep it circulating,even for a little while after you park.That is my only reason I don't personally like water-air IC,is due to the "heatsoak" when parking,I think your car is gonna rock! Not too late for front mount!
  19. Forum Sponsor 2kjettaguy's Avatar
    Dec 24th, 2000
    Millersville, MD
    05-12-2003 09:36 AM #19
    Quote, originally posted by blkjettavr6 »
    Hey, you wanted to
    What do you guys suggest for a water tank? I might just fab one up to fit where I want it
  20. Former Advertiser Anand@4induktion.com's Avatar
    Aug 25th, 2001
    Annapolis, MD
    '06 Touareg V8
    05-12-2003 10:01 AM #20
    1 Gallon plastic milk jug... perfect idea, i dunno why i didn't think of it earlier!!!
    or better yet... a 64oz Wawa Iced Tea
    btw, i'm off school tomorrow, so you can work, i'll work on your car
  21. Member
    Dec 29th, 2002
    Boston, MA
    2010 VW GTI
    05-12-2003 10:18 AM #21
    awesome. please take lots of pics and make lots of nice diagrams for us all to follow in your footsteps
    APR Stage II ECU
    UR DP
    S3 Intercooler
    Hotchkis swaybars
    Stoptech BBK
  22. Member g60vwr's Avatar
    Apr 9th, 2000
    LI NY USA
    05-12-2003 10:19 AM #22
    ...toss the atp drain line.... I made one out of scrap -10 I had lying around.. it fit better than the atp. All you need is a straight fitting and a 90 or 45
    If you tapped you own pan- then the ATP line wont fit. it will be too short
    Cry once....
  23. 05-12-2003 10:29 AM #23
    looks like you are going to have a really nice setup when you are all done.
    keep us posted for sure
  24. Senior Member
    Feb 28th, 2002
    chicagoland
    91 GTI 1.8t, 07 Rabbit
    05-12-2003 11:00 AM #24
    Could you do a quick rundown on prices and where you got everything?
    Quote Originally Posted by VikingVR6GTI View Post
    Yep, that was my first thought too. A nice set does not automatically make a chick attractive. Especially when that "chick" is a dude.
    Buy my 1954 GMC Truck
  25. Forum Sponsor 2kjettaguy's Avatar
    Dec 24th, 2000
    Millersville, MD
    05-12-2003 11:08 AM #25
    So far I am up to $2500. I got $1900 for the charger, so all is well
    I'll do a price breakdown when i have some more time later on. The important part is that I got all this brand new for under the price of a stage 2 kit with more components and no "holes" in the system. The only thing I need now is a water tank. Otherwise I feel I am good to go.
    In the future though I could spend $$ on this motor
  26. Member
    Sep 12th, 2002
    Portland, OR
    98 Audi A4 and 2012 Tiguan SE 4Motion
    05-12-2003 01:54 PM #26
    very sweet glad to see you ditched the no speed charger
  27. Member
    Aug 9th, 2001
    3rd gen milk carton
    05-12-2003 02:36 PM #27
    that makes two of us. it surprized me that jettared switched over too, but not completely . funny where all of us NS believers were last spring haha. Im next
  28. Forum Sponsor 2kjettaguy's Avatar
    Dec 24th, 2000
    Millersville, MD
    05-12-2003 07:22 PM #28
    I was a believer until I added a smaller charger pulley, 268/260 cam, intake and a turn 2 lightened crank pulley and saw no torque increase and 2 more horsepower. Those mods would have made more than 2 hp on a N/A car. My thinking went pretty much like this. I have 137whp and I'll never have any more. Project Time!!
    I got good money for it
  29. Member g60vwr's Avatar
    Apr 9th, 2000
    LI NY USA
    05-12-2003 09:49 PM #29
    really?! Thats it? A buddy of mine pulled 141 on a N/A 2.0 '98 weird- I thought it would have done better than that...
    Cry once....
  30. Forum Sponsor 2kjettaguy's Avatar
    Dec 24th, 2000
    Millersville, MD
    05-13-2003 12:43 AM #30
    no way
  31. Forum Sponsor 2kjettaguy's Avatar
    Dec 24th, 2000
    Millersville, MD
    05-13-2003 12:59 AM #31
    So tonight i worked a few hours on the car. First task was tooling and cutting gaskets to cover the secondary air injection holes in the head. I split the stock gasket and put these in between. They are .080 aluminum cut on the ol' CNC.
    Then, I had to clock the turbo 45 degrees to accept the ATP oil drain line. That actually worked out very well. I like the results, though i haven't been able to fully break the seal on the oil pan
    Also, with the turbo loose I ran my 3/8"-18 NPT tap down into the water holes. The threads were previously straight, but now have a nice taper to them and I can use standard water fittings. I ran the tap on the fitting closest to the manifold down all the way so my barb would sink as far as possible.
    I mounted my gaksets and the turbo up. Everything's coming together very nicely. I hooked up the oil feed and the 45 to the return flange. I marked my oil pan and am trying to remove it. I found that at some point I smaked something good with my oil pan. Its got a good bit of cracks in it from a speedbump or something. Cup kit
    Hopefully I don't have to replace it. Its not leaking, but sucks anyways. Maybe I'll make a skid plate
  32. Member
    Aug 9th, 2001
    3rd gen milk carton
    05-13-2003 01:16 AM #32
    nice progress im a big fan of the ol' CNC
  33. Member speed51133!'s Avatar
    Aug 5th, 2002
    05-13-2003 01:26 AM #33
    man, i must say i would have never guessed a neuspeed supercharged guy would be so hands on an able to "make things".
    nice job. looks like you take your time to do things correctly.
    cant wait to see the split second thing get put in.
  34. Forum Sponsor 2kjettaguy's Avatar
    Dec 24th, 2000
    Millersville, MD
    05-13-2003 01:33 AM #34
    Thanks Speed
    "making stuff" is what I do for a living.
    I played with the supercharger and you saw the results. I very much considered cutting it open to intercool it but decided that even though this has 10 times more "parts" its so much easier. All i wanted was an intercooler so my timing could come back into the real world and my motor run smoother I think I'll be happier with this
    The split second should be here soon. I hope I should have everything worked out by the end of the week and get this running!
  35. 05-13-2003 01:34 AM #35
    Quote, originally posted by speed51133! »
    Heh, hate to say it, but I agree ...
    Those are some amazing fab skills! The flange for the inlet is nuts! I'd love to be able to make ish!
