VWVortex.com - Custom camper trailer build
    The Car Lounge
    Page 1 of 5 12345 LastLast
    Results 1 to 25 of 125
    Thread: Custom camper trailer build
    1. Member Rob Cote's Avatar
      Dec 6th, 2006
      Beverly, MA
      06A3 & 99TJ & 03 Tacocat
      02-03-2017 12:27 PM #1
      Hi. Is there any interest in a build thread for a camper/trailer here? I remember a trailer restoration that was allowed, but I understand it's not a car, so maybe it's not strictly allowed. I'm not sure. Well, anyway I'll give it a shot, and mods can just delete it if it's against the rules. I tried to PM one to ask, but there was no response, so fuggit.
      So it's like a teardrop style camper in that the only "inside" part is the bed. The galley is outside and all that. But it's an off-road trailer. And it's rather a different design than the majority of teardrops. So yea, the design is mine and the fabrication is mine, except as noted.
      I went through several design concepts:
      2017-02-01_11-29-50 by Rob Mandy, on Flickr
      IMG_20161013_142909221 by Rob Mandy, on Flickr
      IMG_20161006_202849992 by Rob Mandy, on Flickr
      2017-02-01_09-49-40 by Rob Mandy, on Flickr
      But this is closest to what I'm working towards:
      IMG_20161028_194439339 by Rob Mandy, on Flickr
      So there was an ad on Craigslist for steel tubing. A crew was tearing down the old horse stalls at Rockingham Park up in Salem, NH. I got a bunch of 1.5" square and 2" square lengths, enough for the frame. Obviously it had been exposed to the weather, so it needed cleaning. I gave each tube a soak in Evapo-Rust, which worked quite well. After a rinse, I taped up the ends and filled it with paint and rolled it all around to coat the inside surfaces and then dumped out the excess and let it dry. Then, with an abrasive wheel in the drill press, I cleaned the rest of the crud off the outsides.
      Evaporust bath:
      2017-02-01_01-50-04 by Rob Mandy, on Flickr
      This part sucked because each tube would sit overnight. It was super slow, and seemed to take forever, with no real progress to show for it.
      Before - after - during:
      2017-02-01_02-34-35 by Rob Mandy, on Flickr
      The tube on the left is pretty representative of the lot of tubing I picked up. The far right is what they looked like coming out of the Evaporust bath, after a rinse. In the middle is one that's been painted inside and abrasive-wheeled on the outside.
      So, I cut them all to length and laid them out on the floor to tack a basic ladder frame together:
      2017-02-01_09-58-56 by Rob Mandy, on Flickr
      We ordered a custom-length 3500lb idler axle from Redneck Trailer. It's got provisions for brakes, but no brakes installed. Future upgrade if it's necessary, but I doubt it. So once that came in, it began to sort of look like something when I mocked up all the suspension parts:
      IMG_20161119_155910026 by Rob Mandy, on Flickr
      2017-02-01_09-57-40 by Rob Mandy, on Flickr
      2000lb. springs for now because they were cheap and available from a friend, but those might go away later on. I don't know what the final weight will be but I suspect it's less than a ton. We'll see.
      Quote Originally Posted by Hudsone View Post
      No one knows what and where I have to go to them?
    2. Member Crispyfritter's Avatar
      Nov 21st, 2001
      SW KS
      02-03-2017 12:34 PM #2
      I can't speak for anyone else, but I'm in. Looks awesome!
      Chris
      | 2017 Korean Appliance SE | 2008 Suburban LTZ | 2003 Dodge Ram | 2002 BMW 530i con mañuel | 1974 SuperBeetle x 2 | 1979 Camaro | 1975 Scout |
      The poster formerly known as 200HP4dr
      Apr 13th, 2004
      WNY
      MkVII GTI / 85 Westy Weekender
      02-03-2017 12:34 PM #3
      Like!
      More, more, more!
    4. Member VW...vw...wv...WV's Avatar
      Sep 7th, 2005
      Twitter: @ARQLIZCANO
      2012 AWD Nissan Rogue (again, you dumb ass!)
      02-03-2017 12:40 PM #4
      mucho bueno
      Satan´s nopemares...
    5. Member Rob Cote's Avatar
      Dec 6th, 2006
      Beverly, MA
      02-03-2017 12:44 PM #5
      So here's the basic method for brackets to mount stuff to the frame. Take some angle, and cut it to the desired length of your bracket. Generally ~2" for 1 fastener, ~6" for 2 fasteners.
      IMG_20161128_191501302 by Rob Mandy, on Flickr
      Then you want to weld on nuts in the middle of the flange face (right of picture). I'm using 3/8-16 fasteners just about everywhere. Then you want to use the nut as a drill guide to locate the center of your hole (left of picture). You don't have to drill all the way through on this operation, just enough so you can locate the bump on the other side, just before the drill breaks through.
      IMG_20161128_194231374 by Rob Mandy, on Flickr
      Center punch that from the side opposite the nut, and then drill through with a clearance drill (in this case, 3/8" is snug, but clears a 3/8" bolt) just down to the nut. Remember, you don't want to drill into the nut or you'll remove all the threads.
      IMG_20161128_200749181 by Rob Mandy, on Flickr
      Lather rinse repeat ad infinitum. Not really, but it seemed like I made a gajillion of these. Weld them onto your frame any old place:
      2017-02-01_10-20-52 by Rob Mandy, on Flickr
      Note- the above picture was before I learned that it's much easier to make the bracket before it's on the frame. Don't do it this way. This is just to show that they get welded on.
      2017-02-01_10-21-02 by Rob Mandy, on Flickr
      The brackets allowed me to start installing the floor sections and stuff:
      IMG_20161224_154705359 by Rob Mandy, on Flickr
      IMG_20161224_154656565 by Rob Mandy, on Flickr
      And walls:
      IMG_20161224_154716884 by Rob Mandy, on Flickr
    6. Junior Member
      Sep 1st, 2016
      Central Ohio
      2015 Sonique, 1988 Turbo VW Fox PickUp
      02-03-2017 12:46 PM #6
      I did a similar build thread when I built my hand-built TearDrop camper...my build thread is over at TnTT http://tnttt.com/
      anyway, great to see another TearDrop camper builder on the 'tex!
      Pre-PasswordGate, I was DasBaldGuy
      I for one, welcome our new TrumpOverlord
      #ImWithHim
    7. Member gnavs's Avatar
      Jun 9th, 2006
      CGY
      '04 Saab 9-3, '83 VW Rabbit
      02-03-2017 12:49 PM #7
      Cool!
      Subscribed
      Sent from a place using a thing
    8. Member Rob Cote's Avatar
      Dec 6th, 2006
      Beverly, MA
      02-03-2017 12:56 PM #8
      Sweet well I'm glad there's some positive feedback. Thanks people.
      Quote Originally Posted by DerBaldGuy View Post
      I put it on ExPo but that place doesn't have much traffic.
    9. Member jon_570's Avatar
      May 18th, 2010
      Cumberland,MD
      2013 Gti
      02-03-2017 12:56 PM #9
      I love this. I was wanting to do something similar this summer for camping and this is great inspiration. SUBD
    10. Member Stevo12's Avatar
      Jul 27th, 2015
      Hartford, CT
      '14 WRB Frontier, '97 M3, '92 GTI project
      02-03-2017 01:12 PM #10
      Sub'd
      I did an 'expansion' on my 4x8 trailer this fall - it is now a 5.5x8. I'd love to turn it into something else down the road, as well as build some sort of trailer (be it another utility trailer) or a car hauler/flatbed
      Oh and nice welder - I've got a Hobart as well
    11. Senior Member
      Aug 5th, 2004
      Southern Indiana
      '66 Beetle (X2) '08 Fit
      02-03-2017 01:15 PM #11
      In.
      If you could fit a private bathroom in one my wife would actually go camping!
    12. Member whiteboy1's Avatar
      Nov 14th, 2001
      Seattle
      1962 Lincoln Continental
      02-03-2017 01:25 PM #12
      cool!
      In.
      Quote Originally Posted by uncleho
      Before you take the tact of denigrating a group, you should empathize with the situation/history and understand the facts. It might not make for great debate on forums, but it helps with personal awareness.
      Quote Originally Posted by Cousin Eddie
      Empathy isn't hard. You don't have to feel what other people feel to be understanding or trust that not everyone has the same perspective.
    13. Member Rob Cote's Avatar
      Dec 6th, 2006
      Beverly, MA
      02-03-2017 01:51 PM #13
      Quote Originally Posted by Stevo12 View Post
      Sub'd
      Nice work!!
      Quote Originally Posted by Air and water do mix View Post
      In.
      It could be done, but I wouldn't recommend it. That's the sleeping area! How about a shower curtain that attaches to the outside, and a cartridge toilet or something?
    14. Member
      Feb 1st, 2012
      MI
      2005 Acura TSX
      02-03-2017 02:02 PM #14
      Very cool. Keep us posted on progress.
    15. Member Rob Cote's Avatar
      Dec 6th, 2006
      Beverly, MA
      02-03-2017 02:36 PM #15
      The trailer gets a 20 gallon water tank for the sink and shower. So we can wash dishes and our dirty-ass-selves. It's not a TON of water (actually only ~160 pounds of it!), but it should be sufficient if we are conservative. The frame was designed around the water tank, actually. It sits down in between two of the frame crossmembers on angles which are welded to the frame. It's a little tricky to explain so hopefully the pictures help. Here you can see how it sits between the frame crossmembers:
      2017-02-01_10-23-21 by Rob Mandy, on Flickr
      Then (I realize this is a little bit out of order) you can see how the support angles are oriented here:
      IMG_20161111_125011885 by Rob Mandy, on Flickr
      Since the water tank vendor stated the entire bottom face of the water tank must be supported I cut the skid plate/support sheet you see above:
      IMG_20161111_114519320 by Rob Mandy, on Flickr
      This part was so tedious with my available tooling:
      IMG_20161111_120259673 by Rob Mandy, on Flickr
      Put some drainage holes in it and stitch-welded it on:
      IMG_20161111_143952650 by Rob Mandy, on Flickr
      Then the top of the tank just gets a simple tie-down frame sort of thing, again made out of angle:
      2017-02-01_10-24-05 by Rob Mandy, on Flickr
      Do work son
      IMG_20161005_180826425_BURST004 by Rob Mandy, on Flickr
      I welded some short sections of tube that fits over 3/8" threaded rod to the base and to the tie-down frame so I can clamp the tank in place:
      IMG_20161009_111212602 by Rob Mandy, on Flickr
      So there you have it.
    16. Member
      Aug 17th, 2007
      San Francisco, CA
      Beige C230
      02-03-2017 02:44 PM #16
      Awesome progress so far. Will the TJ be towing this?
    17. Member Rob Cote's Avatar
      Dec 6th, 2006
      Beverly, MA
      02-03-2017 02:46 PM #17
      Quote Originally Posted by DEZL_DUB View Post
      Probably, as well as the Taco. Probably both will want a regear, but I'm gonna try it and see. Ideally, they'll both be setup as tow rigs, though.
    18. Member yeayeayea's Avatar
      May 29th, 2005
      So MD
      2002 M5, 2002 325Xi Touring, 1992 Toyota 4WD Pickup, 1995 gsx600
      02-03-2017 02:55 PM #18
      I like fabrication threads, count me in!
      You using flux core MIG wire I'm guessing?
    19. Member Rob Cote's Avatar
      Dec 6th, 2006
      Beverly, MA
      02-03-2017 02:56 PM #19
      Quote Originally Posted by yeayeayea View Post
      Yeah, solid core was too cold I didn't like it.
    20. Member GroovOn-SLC's Avatar
      Jul 25th, 2003
      Titletown WI
      93 Corrado & Band Van
      02-03-2017 03:00 PM #20
      I work in the RV industry so I'll be following.
      But that fresh tank is overkill. You wouldn't believe how the OEM's do it. But then their tanks have flanges to ride on so simple banding straps are just to "catch" the tank if it should fall.
    21. Member Rob Cote's Avatar
      Dec 6th, 2006
      Beverly, MA
      02-03-2017 03:02 PM #21
      Quote Originally Posted by GroovOn-SLC View Post
      Cool! Feel free to offer any guidance if you like. I'm glad that the tank mount is overkill I intend to beat it up a fair amount off road, so I'm trying to go overkill wherever I can. I wasn't originally planning to put the full skid plate in, but they said it has to be fully supported so I just rolled with it.
    22. Senior Member
      Aug 5th, 2004
      Southern Indiana
      02-03-2017 03:08 PM #22
      Quote Originally Posted by Rob Cote View Post
      I'm glad that the tank mount is overkill.
      I'm with you. Sure, an engineer would come up with the lightest setup, but for a home-built job? Give me overbuilt any day of the week.
    23. Member G0to60's Avatar
      Jun 23rd, 2003
      Milwaukie, OR
      1990 VW Corrado, 2002 Audi allroad, 2015 Fiat 500e
      02-03-2017 04:01 PM #23
      In for this! I love tear drop style trailers. Looking good so far.
    24. Member MontoyaF1's Avatar
      Apr 6th, 2004
      Nashville, TN USA
      2011 SAAB 9-5, 2013 Ford Fusion
      02-03-2017 04:04 PM #24
      I came in for the VigorousZX content? What's going on?
      Learn what the bible really says about the End Times:
      http://www.bibleprophecytruth.com
    25. Member dcmix5's Avatar
      Apr 7th, 2006
      Grand Rapids, MI
      Hondas
      02-03-2017 04:05 PM #25
      I thought this was a Vigorous thread too.
      I think it would be cool to be able to do this kind of ****. I can't do any of this ****.
      Quote Originally Posted by Hawk View Post
      I'm filming this thread. Just thought I'd let everyone know. I've had some bad experiences with threads in the past.
      I like when dumb people quote mechanical grip as a metric of whether or not a car is fun to drive. It's like saying McDonald's is the best restaurant because you get a lot of calories for your money.
