VWVortex.com - loud humming noise while driving...wheel bearings or not???
    Results 1 to 22 of 22
    Thread: loud humming noise while driving...wheel bearings or not???
    1. 05-16-2003 10:00 PM #1
      I have this loud humming noise while I'm driving. if I turn the wheel to the left at all it goes away but straight or right it still hums. it sounds like a wheel bearing but I didnt think those went away when you were turning . could it just be my tires? they dont have too much tread on them.
    2. Member Dubsport Inc's Avatar
      Oct 12th, 2002
      Edmonton
      '61 Beetle '09 Rabbit '12 Ram 1500
      05-16-2003 10:23 PM #2
      It sure sounds like a wheel bearing, jack up the front of the car and spin the wheels by hand while holding the spring, the one that is gone should show up as a vibration in the spring.
      Hope this helps
      Richard
    3. 05-16-2003 10:50 PM #3
      awesome. I'll give that a try in the AM.
    4. Member Dubsport Inc's Avatar
      Oct 12th, 2002
      Edmonton
      05-16-2003 10:52 PM #4
      Let me know how it goes
      Richard
    5. Member volcomvw's Avatar
      Dec 25th, 2001
      San Diego, CA
      2012 MS3
      05-16-2003 11:07 PM #5
      when my right rear bearings went bad last year i had more of a squeaky / metal-to-metal grinding type noise. and it wasnt a constant sound.. more like a squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak.
    6. 05-16-2003 11:48 PM #6
      mine sounded like I had a flat spot in the front tire. It's in the shop currently
    7. 05-17-2003 12:32 AM #7
      yeah my right front wheel bearing was replaced last week...it wasnt a humming i would say it was almost a churning... and it didnt go away when i turned
    8. Member Air_Cooled_Nut's Avatar
      Mar 15th, 2000
      Portland, Oregon
      2013 Touareg Executive; '95 Jetta GL; '76 Riviera Bus; '72 Squareback; a couple Ducati
      05-17-2003 01:34 AM #8
      Doesn't sound like a wheel bearing at all. Check your power steering fluid level; make sure it's not low. Look for any signs of fluid leakage if it is low. However, if it is only while driving it's probably not that, unless you hear it only at a certain rpm or higher...?
      Do you hear the hum while stopped but while reving the engine? Have you looked under the car to see if something is rubbing?
      95 Jetta GL 2.0L, chipped, intake, exhaust, compression, cam, close-ratio w/Peloquin, etc.
      72 VW Squareback, rag top, 2.0L, parents original owners
      76 VW Riviera Bus, the family camper -- '13 Touareg Executive
      06 Ducati Sport Classic 1000...only motorcycles can feed the need for speed
    9. 05-17-2003 02:09 AM #9
      i had the exact same thing, and it was the right front wheel bearing. mine was a really rough sound, and i could feel it in the ride of the car as it deteriorated...
    10. Member Air_Cooled_Nut's Avatar
      Mar 15th, 2000
      Portland, Oregon
      05-17-2003 02:17 AM #10
      Quote, originally posted by andyveedub »
      ... could it just be my tires? they dont have too much tread on them.
      How much tread is left on your tires? Why don't you rotate your wheels, if there's more tread on the rears, and see if that 'fixes' the problem.
    11. 05-17-2003 09:07 PM #11
      if i shut the engine off while i'm driving, i still hear the noise and it still goes away when i turn to the left
    12. Member exboy99's Avatar
      May 14th, 2002
      Long Island
      2004 TT 225 quattro coupe
      05-17-2003 09:43 PM #12
      I found out what my hum was, I'm on coilovers and the drop pulled the
      wheel in to the coil too much and it was actually rubbing, my new wheels
      have enough offset to avoid rubbing and I'll get it aligned and that should also help it some.....check to see if you're rubbing a tire on a spring. I was rubbing both rears. What should I do about the shiny spots on the springs, yes it's bare metal where it rubbed....... I feel like I should seal the area with something, is it bad to leave it alone?
    13. 05-18-2003 12:11 AM #13
      I'm only riding on H&R sports
    14. 05-18-2003 09:47 AM #14
      ok I rotated my tires but I dont think I can really tell a difference. maybe a TINY bit. but my tires kinda suck so I dunno. front wheel bearings f-en suck!!! I dont wanna spent $60 on a front wb and have it not be that....
    15. 05-18-2003 11:01 AM #15
      If it goes away when turning right, its your right bearing. Goes away when left, its your left bearing. Turning in that direction takes the stress off of them. I just replaced both of mine about a month ago. Not fun!
    16. 05-19-2003 05:39 PM #16
      Quote, originally posted by leebro61 »
      it seems like its a lot louder on the right side though? even though when I turn left it goes away...
    17. 05-19-2003 06:35 PM #17
      I vote "it's your tires"
      are they cheapies? like cooper cobra's, I went through the whole bearing replace and even strut mounts etc, before putting the winter tires on and finding the damm humm was gone
      borrow a friends wheels and see if it helps before you lay out the $$$ chasing a mystery problem
    18. 05-19-2003 08:21 PM #18
      eh I dunno, I have dunlop's which I thought were pretty nice. they're not bald as hell so I dont really think its my tires. when I rotated them it raelly didnt do anything. sounds like a wb to me I just wanted to double check before I go ahead and spend $50ish a side for the kits.
    19. 05-19-2003 08:23 PM #19
      Wheel bearing failures and A3' go hand-in-hand
    20. 05-19-2003 09:47 PM #20
      damn the A3...window regulators, wheel bearings. what else??? (even though I wouldnt trade my gti for anything haha)
    21. Member vdubracer83's Avatar
      Apr 22nd, 2002
      98 Jetta Stage 3 VRT, 350K+miles 95 Passat, 99 Golf Wolfsburg, 93 Corrado SLC, 82 Diesel Jetta
      06-19-2004 04:07 PM #21
      i got the same problem.. when i take a left turn it goes completely away till i straighten out it comes right back it gets a lot worse when i'm at higher speeds (70-100 mph) today i pulled the ebrake up- some on the highway the sound pretty much went away. when i replaced the wheel bearing about a year ago it was fine till march and its been making this humming noise...do i have to re tighten the retaining nut on the bearing b/c its worn in???
    22. Banned Pfeil's Avatar
      Apr 13th, 2003
      06-19-2004 06:15 PM #22
      how recently have you had the car aligned? my bet is that the car is slightly out of alignment, and that it's the tires making the noise.
