VWVortex.com - Whole lotta shakin goin on - but it's not the tires, wheels, or alignment (maybe)
    The Car Lounge
    Page 3 of 3 FirstFirst 123
    Results 51 to 61 of 61
    Thread: Whole lotta shakin goin on - but it's not the tires, wheels, or alignment (maybe)
    1. Member NeverEnoughCars's Avatar
      Aug 2nd, 2013
      Below the glide path to KAUS
      Dodge, Toyota, VW, Ford
      03-19-2017 11:57 AM #51
      Quote Originally Posted by 7GIRLS3CUPS View Post
      What are the speed limits on the roads you're driving/ why are you going that fast anyways?
      Pedantry: winning arguments through exasperation since 1651. An Old World Tradition!
      "Now i am become death the destroyer of worlds."-bhagavad gita
      “Only those who will risk going too far can possibly find out how far one can go.” -T.S. Eliot
    2. Member WRXGuy's Avatar
      Feb 20th, 2002
      Texas
      2017 Cruze Hatch
      03-19-2017 12:14 PM #52
      It's the Texas Autobahn!
      Sent from my Nexus 6P using Tapatalk
    3. 03-19-2017 12:16 PM #53
      Since when is 70mph fast? Vast majority of highway speeds limits around the country are 65-70mph. Some even 85mph, heck only a few years ago did they finally put speed limits on some roads out west.
      Quote Originally Posted by NeverEnoughCars View Post
      I miss those speed limits! Although in Alabama I've never had a problem 80mph in 70mph zones.
      Sent from my SM-G930V using Tapatalk
    4. Member BUJonathan's Avatar
      Mar 2nd, 2004
      Chicagoland, IL
      '17 Subaru Legacy Sport
      03-19-2017 01:09 PM #54
      In IL we have 70 mph speed limits on I-90 once you get past the Chicago suburbs. Even on sections where the speed limit is 65 or eve 55 mph, 70-75 mph is just going with the flow of traffic.
    5. Member Elite_Deforce's Avatar
      Nov 18th, 2012
      Montreal, Quebec
      2012 Mustang GT, 2008 Mazda3 GT, 1986 Mazda RX-7 GX
      03-19-2017 02:14 PM #55
      Quote Originally Posted by Aonarch View Post
      It sounds like the shop is a tad bit incompetent.
      RF would have said the tires were flat spotted and they would have been able to see if a wheel was bent.
      The shop needs to shake down the control arms and bushings too. This is really simple stuff, that a lot of shops fail at.
      Most Common Vibration Issues In Numerical Order:
      1. Bent Wheel (Modern day with large diameter wheels, usually it is the wheel not the tire)
      2. Out of round tire
      3. Bad control arm, ball joint, or other bushing
      4. Axles or related part
      What about steering rack as a very very last resort?
      Also, 70 mph is not very fast, I agree.
      Quote Originally Posted by Elite_Deforce View Post
      Panache, bruh.
      Quote Originally Posted by Ernie McCracken View Post
      I don't trust the judgment of anyone who likes black wheels.
      I find it ironic that long time Euro brand fans would assume long term reliability issues would destroy any love of a unique product.
    6. Member 7GIRLS3CUPS's Avatar
      Aug 11th, 2016
      [253]
      38 cylinders, 17.5 litres
      03-20-2017 12:19 PM #56
      Our highest speed limit is 70, so it seemed like the claimed speed was in excess. Seems you guys out 'yonder play by different rules
      2016 security breach victim #129,248. Formerly karlorado
      IG @_chip_douglas_
    7. Member Frank@AntwerpenPerformance's Avatar
      Dec 7th, 2000
      Glen Burnie
      13 mb c300, 07 tundra, 03 24v gli, 89 e30
      03-20-2017 01:15 PM #57
      sounds like cupped/chopped tires to me.
      Frank, Service Advisor @ Antwerpen VW in Pasadena MD
      The local tuner friendly VW dealership
      APR, 1552, Radi8, 42dd, and the list goes on and on.
      Contact me for flash tuning and more!
    8. 03-20-2017 04:59 PM #58
      Quote Originally Posted by BUJonathan View Post
      TomTom or Garmin did some research years ago and found the average speed traveled on the highway was 70mph. Heck the only reason some speed limits are at 55mph is because of the 70's oil embargo.
    9. Senior Member
      Nov 7th, 2001
      The Village
      KAR 120C
      03-20-2017 06:03 PM #59
      I'm betting you have one or more bent wheels.
      The 18" wheel on my Boxster had a small bend on the inside lip. It exhibited a vibration at around 76mph up through 85mph with two different tires mounted. Had the wheel straightened and it's smooth as glass now.
    10. Member atoson's Avatar
      Dec 28th, 2002
      San Jose, Ca. South Bay Area
      12 Golf TDI, 00 GTI, 00 NB, 84 Scirocco, 80 Dasher
      03-23-2017 06:50 AM #60
      If you can check for repair history, look for any work done to the CV Joint flanges like seal replacement. In most cases a C-clip is used to secure the drive flange to the differential gear. There are instances where it breaks off from it's perches and gets chewed by the diff and flange, causing the front end to vibrate only during acceleration. No clunk, no worn ball joints and every thing torqued to spec except for this weird vibration during acceleration, beware, this problem can cause baldness trying to figure out.
      I've experienced it myself after I replaced my diff seals, who would think this could happen when no tell tail sign a problem happened in there unless you check that the clip or whatever is holding the flange to the diff is actually there holding it securely. I found everything holding it down was chewed up into a single ball bearing about an inch in diameter, that's what causing all that vibration. Now another scenario with an opposite effect, this time during deceleration a vibration occurs. It could be a loose engine mount, specifically a tranny mount not meeting it's torque spec's. Hope you don't pull your hair trying to solve this, hope this helps.
    11. Member g-man_ae's Avatar
      Jun 20th, 2001
      Twickenham AL · USA
      2015 VW Passat V6 (mine), 2012 VW Beetle 2.5 (wife's)
      03-27-2017 04:14 PM #61
      New update: Local VW-Mazda shop has a Hunter Road Force balancer. (Our local wheel repair place does not, despite what "people on the Internet" say.) 3 of the 4 tires are now balanced; one tire, passenger-front, needs to be replaced because it refused to be balanced - and this is a brand new tire, too (factory Conti)
      Technically I "bought" the tires through VW, so they're warrantied (even road hazard'ed) by VW. My local dealership can therefore take care of this, sparing me yet another 200 mile roundtrip to where I bought the car
      Minivans are the sweatpants of automobiles. SUVs and CUVs are just wagons and hatchbacks suffering from obesity
      Quote Originally Posted by Cigar Aficionado
      You can measure the power of a car, but you cannot measure the smile it puts on your face.
