VWVortex.com - Production 2017 Honda Civic Type R finally unveiled - 306 hp and 295 lb-ft, on-sale in the spring
    The Car Lounge
    Page 1 of 22 1234511 ... LastLast
    Results 1 to 25 of 530
    Thread: Production 2017 Honda Civic Type R finally unveiled - 306 hp and 295 lb-ft, on-sale in the spring
    1. Senior Member Ryukein's Avatar
      Dec 10th, 2006
      Detroit
      1984 Mercedes-Benz 300TDT, 1994 Miata R-Package
      03-07-2017 02:49 AM #1
      Quote Originally Posted by Press Release
      The Wait Is Nearly Over: New 2017 Honda Civic Type R Makes Global Debut at Geneva Motor Show
      First Type R-badged Honda available in the U.S. goes on sale late spring
      Most powerful, quickest, fastest and most agile Civic ever
      2.0-liter i-VTEC® DI TURBO: 306 horsepower and 295 lb-ft. of torque
      Major chassis and suspension upgrades for track-ready performance
      GENEVA, March 6, 2017 – Honda today took the wraps off one of the most anticipated models in its history with the unveiling of the production 2017 Civic Type R at the Geneva Motor Show. The long-awaited Civic Type R, slated to go on sale in the U.S. in late spring with an MSRP in the mid-$30k range, is the first ever Type R-badged Honda to be sold on American soil. The Type R will feature a high performance 2.0-liter turbocharged powertrain, substantially upgraded body and chassis, and other track-ready, Nürburgring-tuned and tested performance components. The 2017 Civic Type R will make its U.S. debut at the New York International Auto Show on April 12, 2017.
      “The fastest, most powerful Honda ever sold in America, the Type R caps off the incredible success story of our 10th generation Civic lineup,” said Jeff Conrad, senior vice president & general manager of the Honda Division, American Honda Motor Co., Inc. “We’re happy to inform our U.S. enthusiasts that the long wait for the forbidden fruit of Honda Type R performance is nearly over!”
      The new Civic Type R, sharing the body style of the 5-door hatchback variant of the tenth-generation global Honda Civic platform, will be powered by a U.S.-built 2.0-liter DOHC, direct-injected and turbocharged i-VTEC in-line 4-cylinder engine with peak ratings of 306 horsepower at 6,500 rpm and 295 lb.-ft. of torque from 2,500 to 4,500 rpm. The engine will be mated exclusively to a short-throw 6-speed manual transmission with rev matching capability – employing automatic throttle blips for smoother shifts and power delivery. A new single-mass flywheel reduces clutch inertia by 25 percent versus the previous (European) Type R and a lower final gear ratio is employed to improve acceleration response.
      The Civic Type R chassis builds on the major upgrades undertaken for the 10th- generation Civic makeover with model-exclusive spring, damper and bushing settings, a new Dual-Axis front suspension setup with aluminum lower arms and steering knuckles for improved at-the-limit cornering and reduced torque steer; a new four-wheel Adaptive Suspension System with three-chamber dampers; a retuned and adaptive dual-pinion electric power steering system with variable gear ratio; and a helical limited-slip front differential. Mounted to the suspension are 20-inch aluminum alloy wheels shod with 245/30R 20 Continental ContiSportContact 6 performance tires. Decisive stopping power comes from Brembo 4-pot aluminum calipers squeezing 350mm (13.8-inch) cross-drilled rotors at the front. The rear braking system features solid 305mm (12-inch) rotors.
      The Type R’s scalpel-sharp responses are further enhanced by a body more rigid than the substantially improved Civic Hatchback on which it’s based – with a 38 percent increase in torsional rigidity and 45 percent gain in bending rigidity versus the previous Civic Type R – enhancing steering response and cornering stability while mitigating body vibration and cabin noise. The improvements are made possible by the application of structural adhesive throughout the body. Ultra-high strength steel is used for 14 percent of the body structure, and the Type R has an aluminum hood, contributing to a 16 kg (35 lb) reduction in body weight versus the previous Type R, and a 7 kg (15 lb) reduction versus the base 2017 Civic Hatchback.
      The 2017 Civic Type R is designed to reward the driver in all driving conditions, on the track and on the street, and features three driving modes: Comfort, Sport (default) and +R. The driver selectable modes adjust steering and throttle response, transmission rev- matching, Vehicle Stability Assist (VSA) and the Adaptive Damper System. Utilizing new, three-chamber dampers, individual stroke sensors and three vehicle-G sensors, the new damper system offers a wider range of variability for ride comfort and dynamic handling response.
      The 2017 Civic Type R will launch this spring in a single, premium-contented Touring trim. A 7-inch Display Audio touchscreen interface with embedded Honda Navigation system has both Apple CarPlayTM and Android AutoTM compatibility; and should the driver ever tire of hearing the Type R growl, a 540-watt, 12-speaker audio system with SiriusXM 2.0, HD Radio and Pandora compatibility is also provided as standard.
      Additional interior Type R features include heavily bolstered sports seats, leather- wrapped steering wheel and shift boot, aluminum shift knob, aluminum sport pedals, red Type R driver’s meter and serialized Type R plate on the center console.
      The Civic Type R will be manufactured by Honda of the U.K. Manufacturing in Swindon, England, with its 2.0-liter turbocharged engine made by Honda of America Mfg. at its Anna, Ohio engine plant using domestic and globally sourced parts. Pricing specifics and additional details on the 2017 Civic Type R will be provided closer to launch.
      Twitter | Tumblr | Instagram | PSN: dsgolson | XBL: Ryukein
      Quote Originally Posted by ClothSeats View Post
      In after Ryukein seal of approval.
      Quote Originally Posted by IridiumB6 View Post
      Your photos don't qualify for the Ryukein seal of approval
      Jul 25th, 2004
      Denver/Frankfurt
      03-07-2017 03:11 AM #2
      Sounds like it's the same engine as the old FK2 Type R, the K20C1. I like it.
      17 Volvo XC90 T6 Inscription P*
      15 BMW 328d xDrive Sports Wagon M Sport
      15 Audi SQ5 Prestige
    3. 03-07-2017 03:30 AM #3
      turbo + Vtec!!!
      Even the Halo NSX doesnt get that!
    4. Member Ross1013's Avatar
      May 25th, 2012
      NoVA
      '17 Golf R DSG, '12 Crosstour V6 AWD nav, '09 Civic Si 4d nav
      03-07-2017 04:07 AM #4
      Awesome. Feels a little weird not to be buying it, especially since I just bought a car a week ago.
      Past: '06 Accord V6, '95 Taurus SHO, '01 ITR, '98 Civic HX CVT
      Quote Originally Posted by jamerican1
      Dude, you know you're like the opposite of a purist, right?
      Feb 1st, 2012
      MI
      2005 Acura TSX
      03-07-2017 06:52 AM #5
      Pity the exhaust pipes couldn't be bigger, to break up the monotony of the rear end.
    6. Member Code Red!'s Avatar
      Sep 22nd, 2011
      deep down, in places you don't talk about at parties
      Gee oh elle eff, Vee oh elle tea
      03-07-2017 07:14 AM #6
      It definitely makes a statement.
      A loving welcome from TCL
      Quote Originally Posted by Metallitubby View Post
      Did you **** him?
    7. Senior Member AZGolf's Avatar
      Jun 6th, 2000
      Phoenix area
      03-07-2017 07:19 AM #7
      Quote Originally Posted by Honda
      I think it's safe to say that you probably won't ever have to worry about brake fade!
      Mar 20th, 2001
      2007 Porsche Cayman 5MT; 2009 VW Passat Highline Wagon 6MT; 2017 VW Golf R 6MT Tech Pack
      03-07-2017 07:52 AM #8
      Quote Originally Posted by AZGolf View Post
      The ugly alone should be enough to stop it. The brakes are simply there as backup.
      Quote Originally Posted by 20aeman View Post
      No, the real enthusiast vehicle would be the RX8. It combines V12 Lamborghini gas mileage with Hyundai Genesis 4cyl. performance.
    9. Member Professor Gascan's Avatar
      Sep 11th, 2002
      Canada
      03-07-2017 07:55 AM #9
      I'd buy one if I could bring myself to buy a FWD car again.
    10. Member GTijoejoe's Avatar
      Oct 5th, 2001
      '06 Evo Mr, '15 CRV Touring, '16 Civic Touring
      03-07-2017 07:58 AM #10
      Yea, I think you'll be OK.
      Also, a nice set of active dynamic dampers
      Now, lets ignore the fact it stated mid $30's and convince everyone its $40-50k
      2.0T+034efi+meth = 300+whp = RIP
      Quote Originally Posted by Ryukein View Post
      Everyone always praises function over form until the form is something that they don't like
      FS: 2015 Honda CRV Touring
    11. 03-07-2017 07:59 AM #11
      Hate the huge rear wing. But I knew it probably would be inevitable they would put one of those things on the Type R edition.
      Other than that, I like about everything about it. Looks most bad ass.
      If I were in the market for a FWD pocket rocket, this would probably be at the top of my list now.
      Joe C.
      May 31st, 2014
      N
      03-07-2017 08:02 AM #12
      Designers went to eBay and purchased every rice addition they could find; yuge wing, hood scoop, center three tip exhaust, roof diffuser....
    13. Member jepva's Avatar
      Feb 10th, 2011
      Richmond, VA
      Q50 RS400, '05 Lexus GX470, '98 F150 redneck mobile
      03-07-2017 08:14 AM #13
      What will this thing weigh?
      Will we see this command the same MSRP+ markup from dealers?
      Sent from my Nexus 5X using Tapatalk
    14. Member madrussian's Avatar
      Mar 29th, 2003
      Akron, OH
      17 Golf R, 15 VW Tiguan, 93 LX Foxbody, 70 C10 5.3L LS
      03-07-2017 08:21 AM #14
      I see Honda finally decided to save us the pain of watching the aftermarket ruin a Civic and did it for us from the factory....
      How many branches did this thing hit on the ugly tree?
    15. Member Chilled Euphoria's Avatar
      Mar 22nd, 2005
      Kirkland,WA
      2003 VW Jetta GLi VR6 24v, 2007 Audi RS4
      03-07-2017 08:35 AM #15
      The only thing I like about the car is the interior but everything else about it I hate, especially those headlights and the wing.
      | VRalliance #320 | VRSociety Member #115
    16. Member
      Jan 26th, 2009
      Saint Paul, MN
      '03 Passat W8 6MT Variant
      03-07-2017 08:36 AM #16
      Fugly. Put that drivetrain in a "normal" looking Civic, and you've piqued my interest.
      Honda, I used to hold you in such high regard. No matter how nice your shifter bushings may be, I'd never be caught driving something looking that ridiculous.
      Peak Honda design:
    17. 03-07-2017 08:38 AM #17
      Quote Originally Posted by coderedcomputing View Post
      Sadly , the statement is "Honda thought the regular Civic wasn't ugly enough".
      There also may be a copyright infringement issue.
      Unofficial Feelings Manager for OT. http://www.npboards.com/index.php
      "I am JIMP."
    18. Senior Member FlashRedGLS1.8T's Avatar
      Apr 17th, 2001
      Ohio
      03-07-2017 08:39 AM #18
      Sounds great but I can't get over the looks and what most likely is an interior that wouldn't fit me well.
    19. Member TetsuoShima's Avatar
      Nov 30th, 2008
      Hamilton, Ontario, Canada
      1994 Honda Prelude V-TAK
      03-07-2017 08:44 AM #19
      Really glad they hired Brad from Autozone to design the new Type R
    20. Member Dravenport's Avatar
      Dec 20th, 2010
      Ottawa, Ontario
      2011 128i
      03-07-2017 08:55 AM #20
      the triple exhaust thing looks a bit weird, but I'd be interested to see it in person
      Quote Originally Posted by westopher View Post
      If you want to spend a bunch of money for something to look at, buy a painting. I'll happily drive my car til its worth nothing.
      Quote Originally Posted by JalopnikMatt View Post
      Since my presence has been requested, Beetlejuice-style, I'll address the current controversy:
      Yes, the Prius is the greatest car ever made.
    21. Member Cabin Pics's Avatar
      Mar 19th, 2008
      In The Woods
      Murica
      03-07-2017 09:27 AM #21
      Wow, that is busy. No thanks.
      Instagram - efrie004
    22. 03-07-2017 09:30 AM #22
      This would have been great......15 years ago at the peak of ricerdom.
    23. 03-07-2017 09:34 AM #23
      Quote Originally Posted by Professor Gascan View Post
      This. I'm kind of thinking the Type-R should move to AWD. A bit blasphemous, I know.
      I love the car though. Nice to see Honda working on recapturing the mind of the enthusiast.
    24. Member
      Nov 21st, 2009
      M235i 6MT fakerich edition
      03-07-2017 09:35 AM #24
      Major stylistic fail: gaudy and juvenile. Too bad because it probably drives well.
    25. Senior Member 6cylVWguy's Avatar
      Jun 14th, 2000
      PA
      Blog Entries
      4
      '11 M3 ZCP; '94 SLC
      03-07-2017 09:36 AM #25
      When this comes out, it will easily be the ugliest new car on the market. Having said that, if a stripped out version is available, I think I might like to own one exclusively for track days. It would a great replacement and a big jump forward from my corrado (). No way I could own this as my only car given the horrible styling however.
