VWVortex.com - Just how complicated is a 1967 Bentley T1's fuel system anyway?
    The Car Lounge
    Page 3 of 7 FirstFirst 1234567 LastLast
    Results 51 to 75 of 151
    Thread: Just how complicated is a 1967 Bentley T1's fuel system anyway?
      Nov 8th, 2002
      Whitefish, MT
      06 Explorer 04 Forester 97 M3/4/5 91 318iC
      03-16-2017 11:47 AM #51
      Quote Originally Posted by ValveCoverGasket View Post
      the point is the whole car was essentially designed around that brake system and the RR v8 under the hood - with two log exhaust manifold that go around the front of the motor, and no real place to mount any brake parts.
      replacing any of that with "conventional" hardware would be a huge undertaking.
      for example, there isnt a brake master cylinder (these early cars had one for "brake feel" but thats about it), or a place to put a booster.
      on the other hand, fixing whats already there - and what works well if its maintained! - is a lot easier as you can order up a few boxes of parts from albers or flying spares that youre sure will fit and go wild replacing them.
      im not a purist by any means, but its a stretch to think you could have it converted to some "conventional" state for less money/effort than itd take to just make it a working stock example. not to mention it wouldnt be worth much if you hacked it all up to fit a SBC in there.
      so, in closing, of course theyre complicated - they cost ~2x the price of an average home when new.
      but all of the parts are available and nearly all of the complex systems were designed to be rebuilt and all of those rebuild and service parts are available.
      ...but i feel like im talking to myself... in before someone else posts "yeah, but itd be perfect with an SBC"
      Reality sets in on a Roadkill dream. Something like this would be a lot more fun than another G body (no offense to the G body builders).
      Something like this with better cosmetics would be fun.
    2. Geriatric Member ValveCoverGasket's Avatar
      Mar 20th, 2002
      trendy homeless camp, OR
      german and british
      03-16-2017 11:52 AM #52
      Quote Originally Posted by PoorHouse View Post
      and guess which engine and transmission that has in it...
      ill give you a hint, its not a SBC...
      Quote Originally Posted by MylesPH1 View Post
      First it was like everyone in TCL was buying Chevy SS's... then we had a run on Golf R's... I think this era of Bentleys and RR's should be our next "group buy"
      I've been pestering ValveCoverGasket for info on these, they just seem like the perfect way to distract yourself from being stuck in LA traffic - assuming you've properly refreshed the cooling system, of course..
      another thing to note, speaking of traffic. these early RHD cars had the 4spd gearbox as i mentioned earlier, which in antique gm circles is known as the jerkomatic.
      its stout, if the fluid is kept up on, but not super smooth in the 2->3 shift as it has to shift the range and the gear at the same time. that synchronization isnt always perfect and you get a bit of a bump depending on how dialed in it is (too soft and youre burning up clutches, so its worth going a bit on the bumpier side).
      granted in slow enough traffic youd be in 2nd most of the time anyway, but something to keep in mind... then again T1s dont grow on trees, finding one with a 3spd could be tricky, and i go back to my earlier point about valuation and rarity.
      this one could actually have some ROI...
    3. Member Juniper Monkeys's Avatar
      Jul 18th, 2003
      Davis, CA
      1932 Prolecrusher Imperiale, 2076 Voss Nose Molestahedron 88
      03-16-2017 01:20 PM #53
      I just need someone's NorCal driveway on a temporary basis. No luck so far
      Ay yo.
      Look, Octopius, it is my website! | 遠慮せずに食べてください。| 🐒
    4. Senior Member bzcat's Avatar
      Nov 26th, 2001
      Los Angeles
      03-16-2017 01:39 PM #54
      Vad I really hope you get this one, or another like it.
      Come on, you know Vad better than that
      This one is not nearly Vad-worthy... the engine starts for one. It also doesn't have that much rust. And it doesn't have salvage title.
    5. Global Moderator MylesPH1's Avatar
      Aug 6th, 2000
      Los Angeles
      One E24, One W124, One P2
      03-16-2017 01:59 PM #55
      Yeah, that's why I posted the other one earlier but the one he found has potential without being perfect... so it's in the range of your normal VadApproved project, plus it's endorsed* by those who know a bit about them, so I hope he does it.
      *= endorsed along with all informed cautions.
      - A bunch of old, tough, unbreakable German iron
      - One temperamental, stubborn, fragile Italian thing
      - One Swedish memoriam
    6. Member VadGTI's Avatar
      Feb 24th, 2000
      Hollywooooooood, CA
      2013 GTI/S60R/E30 M3 (imported from Nigeria)/Saab 9-5 Aero (imported from Washington)
      03-16-2017 02:56 PM #56
      Quote Originally Posted by Juniper Monkeys View Post
      Ay yo.
      Volunteer?
      Fizzy - Team My Little Pony
      #FREEPATRIKMAN
    7. Member Juniper Monkeys's Avatar
      Jul 18th, 2003
      Davis, CA
      03-16-2017 03:58 PM #57
      Volunteer?
      Yesss. This seems like a thing that should happen. Bentley ownership is always a thing that should happen.
    8. Geriatric Member ValveCoverGasket's Avatar
      Mar 20th, 2002
      german and british
      03-16-2017 04:11 PM #58
    9. Member VadGTI's Avatar
      Feb 24th, 2000
      Hollywooooooood, CA
      03-16-2017 04:11 PM #59
      My god, it's actually close to you, too. I thought it was in the Bay Area but it's in Rancho Cordova. Let's see if I can get Nick or Vlad to go check it out .
      ValveCoverGasket, I'm going to need that inspection check-list, stat!
      #FREEPATRIKMAN
    10. Member VadGTI's Avatar
      Feb 24th, 2000
      Hollywooooooood, CA
      03-16-2017 04:15 PM #60
      To add to that, unless you feel like driving to Rancho Cordova . Of note, I am already sending Nick to look at an M Roadster in Rancho Cordova this weekend.
      The M Roadster is nearly the same price as the Bentley.
      Hmmm.
      Bentley or
      #FREEPATRIKMAN
    11. Geriatric Member ValveCoverGasket's Avatar
      Mar 20th, 2002
      german and british
      03-16-2017 04:31 PM #61
      youve got PM
      Nov 20th, 2003
      Pittsburgh
      2003 Wolfsburg, 2008 Fit Sport, 2010 Kizashi S, 2012 500 Sport, 2000 4Runner, 2015 CX5, 1975 MGB
      03-16-2017 04:58 PM #62
      You don't have the balls.
      (how's that for motivation?)
      Power is knowledge
    13. Geriatric Member ValveCoverGasket's Avatar
      Mar 20th, 2002
      german and british
      03-16-2017 05:46 PM #63
      he's gotta go all in!
    14. Senior Member bzcat's Avatar
      Nov 26th, 2001
      Los Angeles
      03-16-2017 06:46 PM #64
      How is it that we are now on page 3 of a Vad car shopping thread and we haven't digressed into a discussion about pastrami sandwich?
    15. Geriatric Member ValveCoverGasket's Avatar
      Mar 20th, 2002
      german and british
      03-16-2017 09:33 PM #65
      Vad check your inbox for my novel
    16. Member VadGTI's Avatar
      Feb 24th, 2000
      Hollywooooooood, CA
      03-16-2017 09:38 PM #66
      Wow, that's a read! Going through it now while simultaneously attempting to convince nm+ to visit the Bentley with said novel. Thanks again!
      #FREEPATRIKMAN
    17. Member EuroAtomic's Avatar
      Jun 17th, 2002
      CA/NJ
      Cult Cars.
      03-16-2017 10:12 PM #67
      I am not getting involved in this. I am not getting involved in this. I AM NOT GETTING INVOLVED IT THIS.
      Ok fine, I am off till the 28th so I can donate some of my time. But my driveway is off limits or Titleist will laugh in my face when my wife files for divorce.
    18. Senior Member nm+'s Avatar
      Jan 6th, 2006
      Land of Bro-Dozer Ya Yas
      2005 Legacy GT Wagon 5MT w/overnight diffs from Japan; 2013 Mazda 2 5MT
      03-16-2017 10:34 PM #68
      Wait, I'm doing what now?
      Someone with technical ability will need to supervise
    19. Member EuroAtomic's Avatar
      Jun 17th, 2002
      CA/NJ
      Cult Cars.
      03-16-2017 10:43 PM #69
      We are looking at a car for Vad. We should just roll up in Bent M, kick the tires and pay in rubles.
      I'll also bring my Russian babysitter. She knows everything, looks like Andre the Giant and is really good at negotiating the financial terms.
    20. Member titleist1976's Avatar
      Feb 25th, 2002
      Mini R55 S, Mazda Miata NA, Honda Pilot
      03-16-2017 11:41 PM #70
      Quote Originally Posted by EuroAtomic View Post
      I'd never laugh... In your face.
      That Bentley would get me kicked out of my hoa.
    21. Senior Member nm+'s Avatar
      Jan 6th, 2006
      03-17-2017 12:17 AM #71
      Per vad, are you going friday?
      If you go Saturday, I can join, but not friday. I think I lost your # at some point.
    22. Geriatric Member ValveCoverGasket's Avatar
      Mar 20th, 2002
      german and british
      03-17-2017 01:30 AM #72
      vads got my number, if youre there saturday and get stuck let me know
    23. Senior Member
      Nov 7th, 2001
      The Village
      KAR 120C
      03-17-2017 01:52 AM #73
      I love it when a TCL plan comes together...to spend LawBear's hard-won rubles.
    24. Member Sold Over Sticker's Avatar
      Nov 28th, 2009
      NorCal
      8 Nozzles and 16 Valves
      03-17-2017 02:41 AM #74
      Funny you mention pastrami. Law Bear and I were going to grab lunch at my favorite pastrami place a few months back. Guess where I happened to go for dinner tonight with a friend? Same pastrami place.
      You know what sucks? I'm on a diet. I had a salad and didn't have sweet pastrami meat.
      You know what else sucks? Vad hasn't purchased this yet.
      Driving While Awesome Podcast. Give it a listen.
      Quote Originally Posted by bothhandsplease View Post
      Brendan told me to get the best discount, I had to send dick pics. I thought this was standard car buying practice.
      Quote Originally Posted by H.E. Pennypacker View Post
      Brendan and his all knowing heavy breathing baboon are correct.
    25. Geriatric Member Aonarch's Avatar
      Dec 4th, 2006
      Atlanta, GA
      Burnt Camaro, ATS
      03-17-2017 07:23 AM #75
      Quote Originally Posted by The A1 and A2 German View Post
      So much car for $4,000 or, there's a reason this is $4,000.
      Considering this isn't an ultra rare "omg" ~barn find, what a find!......I would go another route.
      - 10 hours buffing the paint
      - 5 hours buffing the glass
      - 5 hours reconditioning and redying the seals
      - 2 weeks pulling apart (semi apart) the interior and shampooing and redying the carpet, treatment of all the leather, treatment of the wood, and just bringing her back to life on the inside where needed.
      Then, the controversy: ~Modern 4 disk swap with modern brakes, drivetrain and modern motor swap. 1.5-2" drop on coils and something that complements the car considering the wheels. I'd document the original pieces and sell to others for their restoration purposes.
      Mint mint inside, mint mint outside, however solid with an EFI V8 ~modern system.
      Let's face it, the #1 reason people avoid cars of this nature is the nightmare which lies beneath it's sheet metal. No one's scared of the body, the interior, the radio, the chrome, the paint.....it's the components under neath which make people cringe, so do away with them.
      Do it proper, no bright colors under the hood, no red or blue AN fittings, no stainless steal braided lines. Take the ~modern V8 valve covers and powdercoat them that old red plum matt champagne color, and components that old tan color, using brushed nickle hardware. Nothing glossy, nothing bling.
      Best of both words, like a house built in the 1900's with modern wiring, plumbing and roof.
      Yes please. LS Swap it.
