VWVortex.com - Learn me xj cherokee
    The Car Lounge
    Page 2 of 2 FirstFirst 12
    Results 26 to 37 of 37
    Thread: Learn me xj cherokee
      Sep 24th, 2011
      Chino Hills
      2015 Focus ST
      03-16-2017 01:09 PM #26
      The 2.8 can easily be swapped for a Camaro 3.4 which all around was more durable. Edelbrock makes a smog legal manifold last I checked for the Chevy S10.
      I even think you can stroke the 3.4 to almost 3.9 with pistons from another engine, and a later crankshaft. That assumes you want to stay with the stock set up for some reason.
      Other then that a EROD swaps in easy enough, and I would go that route before a 4.0 swap.
      Focus ST which stands for Suspension Technologies.
      That means it does things magically. In such ways I can not describe, but it is better in every way.
    2. Member urbancynic's Avatar
      Apr 19th, 2007
      Flagstaff, AZ
      15 Jetta SE
      03-16-2017 03:06 PM #27
      Quote Originally Posted by Spatzle View Post
      Forgive my ignorance but what is an EROD?
    3. Member Pnuu's Avatar
      Jul 27th, 2005
      WA
      Driver, wheeler, braaap, some pedals, and a wifemobile
      03-16-2017 04:01 PM #28
      I understand that everyone wants to poo-poo on this XJ because it's one of the most unloved specs (still better than a Renault diesel ), but a mechanically saavy person could have this going for under $1k total. It would consist of bargain barrel Rockauto parts, junkyard parts, and Craigslist parts, but it's doable.
      The key phrase is "mechanically saavy"...
    4. Member
      Sep 24th, 2011
      Chino Hills
      2015 Focus ST
      03-16-2017 04:11 PM #29
      Quote Originally Posted by urbancynic View Post
      It is a series of 3 engines from GM that are smog legal swaps for up to 1995 or OBD1 cars. You can not use them on OBD2 cars. It is really important here in the people's republic of California with CARB. If you use the kit correctly ​they have to approve it.
      So if you have a cool 80's vehicle you want to daily. You can use the basic 5.3, standard 6.2, or the supercharged 6.2.
      I just checked they supposedly have a new LT1 version
    5. Member urbancynic's Avatar
      Apr 19th, 2007
      Flagstaff, AZ
      15 Jetta SE
      03-16-2017 04:12 PM #30
      Quote Originally Posted by Pnuu View Post
      That was what i was thinking. I know it runs and does move forward and back like it should. Not sure how it changes gears since i Wasnt able to go fast enough.
      I priced out everything I've found it needed as well as many things to help make sure it was on the reliable end of the spectrum such as belts hoses suspension and tune up stuff. Total at rockauto came out to about 250 bucks.
    6. Member IJM's Avatar
      Jul 30th, 2001
      District of Columbia
      '01 GTI VR6, '98 XJ Cherokee 4.0, '04 Mazda 3
      03-16-2017 05:03 PM #31
      Quote Originally Posted by Stevo12 View Post
      FTFY. No way in hell you'd want to put an AX-5 behind a 4.0L. It would be destroyed in short order (AX-5 was the light duty tranny they put behind the 4-bangers)
      The AW4 in my '97 was flawless. And it should have been, since it was an Aisin transmission that also found it's way into a lot of contemporary Toyotas, including the 4Runner
      Dammit. Good catch. Mine is an AW-4, so I never pay much attention to the manuals. Like you say, it's been flawless, though I did have to replace one of the solenoids shortly after I bought it. I have a B&W trans cooler I need to mount up if this ****ty weather ever leaves town.
    7. Junior Member 1x1's Avatar
      Jul 30th, 2016
      Portland, ME
      '67 M715, '76 Wagoneer, '06 Silverado
      03-16-2017 05:52 PM #32
      What is wrong with the Silverado?
      I bought my gf an '01 XJ, and it has been great so far. I agree with the others here in that you should find a better example unless this one is free. Small things will pop up that will cost you... things like new brakes, drivetrain seals, leaky windshield, hatch seal, u joints, etc. I dumped a grand into the '01 XJ with just new tires, alignment, and all new brake parts.
    8. Member urbancynic's Avatar
      Apr 19th, 2007
      Flagstaff, AZ
      15 Jetta SE
      03-16-2017 06:14 PM #33
      Quote Originally Posted by 1x1 View Post
      Front brakes and rotors
      Rear brakes and drums
      Steering rack is leaking
      Tie rods
      Control arm bushings
      Ball joints
      Trans needs a filter and fluid change
      Timing cover and oil pan leak
      Hoses and waterpump are original and should be changed
      Blower motor switch works sometimes
      Has a bearing noise but havent been able to locate source
      Cat needs to be replaced
      And besides that, its a regular cab and is too small for family use when its needed.
    9. Senior Member Sporin's Avatar
      Feb 17th, 1999
      Vermont, USA
      '10 Prius & '05 4Runner
      03-16-2017 07:12 PM #34
      You can buy a really good XJ for pretty cheap and it will probably still need some money thrown at it. I'm not sure I'd bother with an oddball basket case unless you enjoy that sort of rebuiding and problem solving process.
    10. Member Stevo12's Avatar
      Jul 27th, 2015
      Hartford, CT
      '14 WRB Frontier, '97 M3, '92 GTI project
      03-17-2017 08:47 AM #35
      Quote Originally Posted by Sporin View Post
      This, I believe, is the crux of the issue (at least it is for me). If you stick to a '91+ XJ it will make life a lot easier for same total $ outlay.
    11. Member Pnuu's Avatar
      Jul 27th, 2005
      WA
      03-18-2017 05:14 PM #36
      In my neck of the woods, a running 4.0l XJ, especially a 91+, is $1500 bare minimum. The 2.8l bastard child XJ in question could be as low as $200.
    12. Member chrisj428's Avatar
      Feb 26th, 2005
      Vernon Hills, IL
      '15 Ford C-Max Energi
      03-20-2017 07:02 PM #37
      My dad bought an '84 in October of '83, right off the truck.
      He went with the 2.5 4 cylinder because it was actually faster than the V6. And, if I remember correctly, that 2.8 liter made the leaks in a similar-era Range Rover look positively normal. Basically, when it stops leaking, it's out of whatever fluid is now on your driveway.
      Also, dad's had the CommandTrac. It was shift-on-the-fly, but a part-time 4WD system. I don't know much about the SelecTrac, except that it could be left in 4WD, even on dry pavement (There were two 4WD High settings, IIRC).
      --Chris
