VWVortex.com - New member with questions
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 28
    Thread: New member with questions
    1. 03-17-2017 12:04 AM #1
      Good evening; my first post.
      I am "armyRN", and I just bought (with my 17yr old daughter chipping in) a black 2008 VW bug convertible (with the 2.5 and the problematic tiptronic tranny) for her first car as she's getting ready to start college. She's loving it - she's always had a fascination with VW bugs. And my first car (back in 1976) was a 63 bug ($300 back then). so it runs in the family I guess. It looks and runs nice, but of course we have a few issues (and it is missing a few interior knobs/trip pieces and such). Car has 114,000 miles; paid $3700 in case you're wondering.
      I bought a Chilton's book at the parts store ($21), and we ordered from Amazon a 2008 owner's manual (with supplements, to include the convertible top booklet) for $90, but I hope she'll be keeping this car for a while. I figure they're an investment. And thank goodness I'm mechanically inclined.
      1. The temp light/convertible top light (above the rearview mirror) is blinking with the convertible top picture, and when we take off from a stop, something is alarming for exactly ten seconds (I'm assuming these two are related???). I've read that when the vehicle senses the top is secure, it will show the temp. I know the top is securely up, so what's going on? It seems to go up-and-down ok. What to try first?
      2. OBD II code 0411 (secondary air injector flow issue). What's the common cause and cure? I cleared the code; we'll see if it comes back.
      3. [P] [R] [N] [D] [S] all lit up - you all know what it is (tiptronic failure). I took the shifter apart - it is missing the large magnet at the end of the rubber strip. Looked all over with a flashlight - couldn't find the magnet. Haven't been able to find one today going to junkyards (or playgrounds as I call them). I did the put it in neutral, shut off engine, restart engine in neutral, start driving - and it only lit up the gear I was in. I don't care right now if we have [P] [R] [N] [D] [S] all lit up - I just want to know - is going to hurt anything driving like this? My daughter is totally not into the paddle shifting feature.
      My daughter is loving the car so far. I've still got to replace a headlight bulb and license plate bulb. Hopefully will have the bugs worked out (sorry if that pun gets overused here) soon so she can just enjoy driving it.
      Any words of wisdom for a new 2008 Bug convertible owner?
    2. Member billymade's Avatar
      Jan 29th, 2008
      Las Cruces, NM
      02' New Beetle Turbo S
      03-17-2017 10:44 PM #2
      Well, it sounds, like your got a pretty good deal for a 2008 model; although, from what you are saying, you have a number of typical "bugs" these cars tend to have.
      1. top lights going off and blinking. You might want to check in your user manual; for the locking procedure and possibly, the "reset" feature. Aside, from that; you could scan the car with a VW specific scan tool and see if there are any trouble codes, related to the top. Common problems, are some of the sensors in the top will fail and cause problems, as the controller cannot tell what the top's correct positions are.
      2. P0441, is evap system related; check out this link, for description of the typical problems and possible solutions:
      http://wiki.ross-tech.com/wiki/index...5/P0441/001089
      Common issues are damaged lines, charcoal canister or N80 purge valve failure. I would do a visual inspection; for any damaged lines or evap canister (under the right rear fender).
      how the n80 fails:
      https://www.youtube.com/watch?v=4IWzZzZb6B8
      purge valve locations; evap system diagram and testing procedures: (N80 purge valve)
      http://workshop-manuals.com/volkswag...ion/locations/
      canister:
      http://workshop-manuals.com/volkswag...ce_and_repair/
      leak detection pump:
      http://workshop-manuals.com/volkswag...nd_inspection/
      3. For the tiptronic, the magnet has been a problem and others have fixed, troubleshot this is issue before. I don't know about long term problems but I would get it repaired asap, as it could potentially cause problems and a rebuilt tiptronic trans, are not cheap to repair. You might post on newbeetle.org; as others, have repaired this issue. VW specific trouble codes from the transmission controller; could shed some light, on the specific issue, although it sounds like the magnet is a known problem. Here are some links and note the VW tech bulletin about the problem:
      http://newbeetle.org/forums/gtsearch...352j2772160j46
      Check out this link and the magnet issue, alignment procedure: (VW Technical Service Bulletin # 37-07-07):
      http://wiki.ross-tech.com/wiki/index.php/01045
      I would recommend that you invest in a VW specific scan tool; to troubleshoot and scan for VW trouble codes. For $60 the OBDelven, is a wireless dongle, that runs on Android devices and it is a affordable solution.
      https://www.google.com/search?q=obde...#q=obdeleven&*
      There are others, like handheld chinese vw/"vag" scanners (limited support) and then there is VCDS by Ross Tech, it runs on a windows pc, in the $200 plus range.
      http://www.ross-tech.com/index.html
      Trouble codes, can really help you diagnose problems and a good vw scanner, can do many other tests, coding, throttle body alignments, etc. Anyone, that is going to do his/her own repairs; will need to have a vw scanner, to correctly diagnose and complete repairs.
    3. 03-17-2017 10:53 PM #3
      Having fun with the little convertible. I just want it up-and-running for my daughter.
      A previous owner had put some H7 HID headlight bulbs in the factory housings (and they weren't working). They kinda butchered the installation job, so I undid it and put regular H7 headlight bulbs in the housing.
      Do these bugs have their headlights on all the time when the engine is running? Don't have the owner's manual yet, so don't know what right looks like.
      Top alarming: I tried resetting the windows (somehow they're connected to the convertible top electronics of so I've read), and sprayed some WD-40 in the passenger side windshield where the top latches to no avail. I also put the top up-and-down a couple times to see if I could make it happy knowing it was securely fastened closed to no avail - still alarms for 10 seconds every time we take off from a standstill. It is happy when down, but not happy when up. So I ordered an F202 switch. If anyone has a "how-to" link for getting in there and replacing it that would be great. I figured I'd try that before taking it to a place that specializes in convertible tops.
      The driver's seat doesn't want to pump up; any suggestions? Any common culprits? I messed with it some this afternoon to no avail.
      Cool looking bug; and my daughter's loving it. I'll like it more when I can get that alarm to stop!
    4. Member billymade's Avatar
      Jan 29th, 2008
      Las Cruces, NM
      03-17-2017 11:17 PM #4
      For the headlights: they have daytime running lights, they stay on but turn off, if you pull up on the parking brake.
      For the top, like I said different sensors can fail but to know for sure, a VW scan tool, will show you trouble codes for the top and the code will tell you what sensor is bad. At $60 OBDeleven can save you allot of money and that way, you don't throw parts at a problem but have more info, to correctly troubleshoot the problem with VW codes to refer to.
      To search for VW trouble code definitions and troubleshooting info; search on the ross tech site: (use the "search" feature or look at the "trouble codes" section of the wiki):
      http://wiki.ross-tech.com/wiki/index.php/Main_Page
      Here is the sensor you are referring to; check out the rest of the service manual for top related info and troubleshooting/repairs.
      http://workshop-manuals.com/volkswag...71/page_14817/
      Here is a good manual for the convertible top; download the self study program for VW techs: "ssp281 The New Beetle Cabriolet", to get a overview of how the system works, how to activate all the features and where the sensors are located.
      https://www.google.com/search?q=new+...le+Cabriolet&*
      For the seat adjustment not working; is it a powered or manual adjustment seat? For up and down height; there is typically, a manual "jack" style adjustment (up or down).
    5. 03-18-2017 01:16 AM #5
      Billymade - thanks for the info and references! I'll start checking the Secondary Air Injection system tomorrow (hopefully just a cracked hose somewhere).
      Thanks for letting me know about the headlights. I took it out this evening and adjusted them - they were way off. I need to go buy a ball-head 6mm hex wrench for future adjustments.
      The seat is a manual "pump up and down" seat. My daughter will just have to drive sitting low for a while. She told me it has butt warmers - nice.
      Right now I just want to get the check engine light to stay off (came back on tonight; I'm figuring the same 0411 code), and for that top alarm to shut up (F202 switch ordered)! I'd be happy to just find the buzzer and turn it off till I can get it properly fixed. The top is secured.
      If the weather's nice tomorrow I might hit some more junkyard and see if I can find a bug like ours with the tiptronic tranny that hasn't already been stripped.
      I didn't know this bug was going to become such the project! Good thing I'm a gearhead.
    6. 03-18-2017 03:56 PM #6
      So to get to the air pump, you have to remove the driver's side wheel and tire, and the inner fender lining. Done.
      Started it up cold, and felt the pump. Didn't really feel or hear anything.
      I'm not sure the pump is getting power. I unplugged the wiring to the pump, and an hour later started it and put a simple circuit tester to check to see if either of the two ports was getting power. Nope. I'll check again in another hour when I know the engine is cool (it was before, but just to double-check).
      So I googled where the relays and fuses were, and got this:
      http://workshop-manuals.com/volkswag..._j17/page_740/
      http://workshop-manuals.com/volkswag...fp)_relay_j17/
      I'm figuring the 2008 is the same as the 2007. So now I need to pull the lower panel off and check the fuse and relay. So now I'm trying to figure out how to remove this panel without breaking anything. Fun fun.
    7. 03-18-2017 09:29 PM #7
      Fun fun.
      Got the lower panel off so I could have access to the relays and such. Definitely not designed for easy access. The fuse looked good; couldn't tell by looking at the circuit breaker if it was good or not, so I went and got a replacement while I was there. Cleared the 0411 code, so we'll see if it comes back. Never could tell if I was getting power to the air pump itself; I had it unplugged and had a test light trying to see if I got power to either of the two female plugs-ins on the wiring. If the 0411 code comes back, I guess I didn't fix it. I didn't see any breaks in the hoses and tubes for the air pump system. How loud is that air pump anyways when running? I know it only runs for a minute or so first thing on cold starts.
      http://www.rockauto.com/en/moreinfo....sn=393&jsn=393
      And I should have replaced the fuel pump relay while I was there in case that was the cause. If the code comes back, that'll be my next attempt.
      While I had my torx bit set out, I went ahead and pulled off the top of the dash to see if I could find the buzzer for the convertible top alarm. There was a ton of little pine needles and leaves and such in there (and from watching VW videos that isn't anything strange). I vacuumed them all out, and no buzzer. It sounds like it is around the speedometer housing.
      So I called it a day and put it all back together. Got the F202 part on order to see if that'll fix the top alarm; should be here next week.
      Lots of good info and links on this forum. Thanks all!
    8. 03-19-2017 02:31 PM #8
      A vw scan tool: would really help, you diagnose things more intelligently (like the convertible top).
    9. 03-20-2017 06:53 PM #9
      Quote Originally Posted by billymade01 View Post
      You are correct. That would be better in the long run vs. me just buying random parts hoping that'll fix the issue.
      The check engine light came on again on the Beetle (0411), so I'm going to try swapping out the Fuel Pump Relay next (that's on the Ross-Tech Wiki solution guide). If that doesn't fix it, I'll seriously consider getting one. And I've got the F202 part ordered (has been shipped) for the top.
    10. 03-20-2017 07:46 PM #10
      Ok, let us know; how things turn out. Thanks.
    11. 03-22-2017 11:27 PM #11
      The F202 switch came in, I replaced it, and now the top is working like it should (no more alarming telling me the top isn't up and securely fastened). It wasn't easy getting to the switch, but doable in the end. Thank-you billymade for the links and such to get me going.
      I swapped out the fuel pump relay and cleared the 0411 code; we'll see if the check engine light comes back on with the same code.
      Next project: the seat lifter thingy. It is a manual pump mechanism thing to raise and lower the seat. Does anyone know if it is a module type thing that can be pulled from one seat and installed in another? I might hit a junkyard tomorrow to see if I can pull one if it is.
      I'm glad my daughter is loving this little beetle. I'm just working through the little issues you get when you buy a used vehicle.
    12. 03-23-2017 12:15 AM #12
      Good, glad you got the top fixed; luckily you chose the right sensor!
      Here is the service manual section for the seats; mostly wiring diagrams:!
    13. 03-25-2017 01:00 AM #13
      More fun stuff (or leaning as I go).
      The front driver's side inner fender well had a chunk taken out of it recently. Looked like it was rubbing against the tire. The part that the fender well attaches to along that area had broken off the fender. So today I went to the junkyard to get another fender well.
      The first junkyard I went to (that I had gone to on Sunday) crushed the Bug they had a few days ago, but they (Pick and Pull) had another yard about a half-hour away with three Bugs. So I went there and pulled an inner fender well. I learned that my 08 fender well is slightly different from the earlier new beetles. I super glued the part that came off the inside of the fender, and installed the junkyard fender well using part of the old one to close the gap. If I didn't point it out to you, you'd never know.
      The reason I was doing all this was because I went to replace the secondary air pump (it is under the driver's side front fender well). Changing out relays didn't work, and Advanced Auto was having a 20% 0ff special, plus I had a $5 coupon so I sprung for a new pump. Once I pulled the old pump, it was nasty - looked like it hadn't been working in a while. Water poured out, and the insides were all rusty and corroded. So hopefully this'll do the trick for the 0411 code (I cleared it - we'll see). The Dorman replacement air pump was supposed to come with the correct plug, but it didn't work. I ended up cutting the plug off the old air pump and splicing it into the wiring for the new pump.
      Yesterday I went to a junkyard and pulled a driver's seat out of a wrecked Bug with the manual seat pump thingy (that raises and lowers the seat height). So another of my Bug projects today was to figure out if I could swap out the pump mechanism. Short answer: Yes (it was a PIA though). We now have a functioning seat height adjuster. So now my daughter doesn't have to be driving all ghetto style sitting way low.
    14. 03-25-2017 01:55 AM #14
      Good progress! On the sai system and water in the pump; i would check all the hoses are not broken, plus the kombi valve works as it should. Basically, confirm all of the components of the sai system are working. This video talks about how the system works: https://youtu.be/Zj-_bAiPq9Y
      Service manual for the sai system:
    15. 03-25-2017 03:38 PM #15
      Thanks. I'm hoping with the air pump looking as bad as it did (it looked decrepit), and having also replaced both the Fuel Pump and Secondary Air Pump Relays, that this problem is fixed (we'll see if the check engine light comes back on with code 0411 - I am so glad I own a code reader). I pulled the hose off the Kombi Valve prior and checked to see if it was clean inside - it was. And all the hoses seemed solid from what I could tell. I made sure the hoses attaching to the air pump were securely seated when I put it back together.
      I didn't see a vacuum line going to the Kombi valve, so I'm thinking it is electronically triggered, and the Ross-Teck Wiki download didn't mention a vacuum valve thingy or vacuum lines in their trouble shooting or repair section.
      So other than needing door speaker covers, I think all the mechanical and related "stuff" are done with this car for now. My daughter will be going back to college next week (local), so I want her car to be good-to-go.
      Oh; I've got the 2.5L engine. How do you get that plastic black and silver cover thingy off the top of the engine? I don't want to just pull on it and break it.
    16. Member billymade's Avatar
      Jan 29th, 2008
      Las Cruces, NM
      03-25-2017 04:28 PM #16
      quote: "the engine cover is really easy to remove. just give it an upward tug on one of the front corners...not too hard though....you'll see it'll release without much effort. the front comes off first and then there's two clips on the back....
      just reverse the process to replace...."
      http://newbeetle.org/forums/2-5-lite...ngine-bay.html
    17. 03-26-2017 05:30 PM #18
      The door opening for the speakers are 7.5" across. One speaker is missing the cover; the other door has a cover, but it has come loose and is slid down slightly inside the door (but I should be able to just pull it out the speaker opening hole). I really don't want to take the door panels off, so I am going to go to a car stereo shop Monday and see if they have any 8" diameter speaker covers (with screw holes around the perimeter) that I can just screw into the door panels to cover the openings. I just want to protect the speakers and cover the holes. If I can find one with a thin rimmed chrome ring (with black mesh) that would work, that would look nice.
      I guess there are two different door panel styles. This is hers:
      https://parts.vw.com/a/Volkswagen_20...M/9211415.html
      This is the other door panel (the ones I usually find on junked Bugs):
      https://parts.vw.com/a/Volkswagen_20...r/9210410.html
      Why two different style door panels? This Bug has the Monsoon stereo system; is that the reason? I've yet to see another inside door panel like the one we have during my junkyard searching (when the door panels are still on the vehicle I should say).
    18. 03-27-2017 10:30 PM #19
      Arrggh! This is turning into a blog. Maybe someone can learn from it.
      Recap: I've been getting the 0411 check engine code (secondary air injection system: incorrect flow detected) on my daughter's 2008 Bug with the 2.5 engine. It was doing this when we bought it, so we knew there was an issue. So I'd been working down the Ross-Tech Wiki algorithm from simplest and least expensive to most complex/expensive.
      I checked all the hoses - didn't find anything.
      Replaced the Secondary Air Injection Pump Relay under the dash - didn't do anything. (~ $12.00)
      Replaced the Fuel Pump Relay under the dash - didn't do anything. (~ $50.00)
      So now I've got spare relays.
      Replaced the Secondary Air Injection Pump itself. It had a lot of water in it and was all corroded inside. Definitely needed replacing - thought I had finally found the problem and fixed it. (~ $95.00).
      Check engine light came back on the next time she drove it (0411).
      So what's left? The Secondary Air Injection Solenoid Valve N112 (aka "Kombi Valve"). I had done the "finger test" on the Kombi Valve and it had come back clean. But in my reading (googling this stuff), if this N112 solenoid goes bad, it can allow exhaust to go back to the pump. This exhaust is humid, and can cause condensation in the pump and fill it with water (and ruining the pump). VW dealer wants about $265 for the part; I can get it on-line for about $125 (plus the cost of a gasket and shipping). So I told my daughter to park her Bug till I can get this part replaced. It makes sense, and hopefully this'll do it. I'll let you know. I'm running out of options.
      https://shopdap.com/store/vw-2-5-com...7k131351c.html
    19. 03-28-2017 03:38 AM #20
      That was my concern about the ruined sai pump filled with water; addressing the symptom,!rather than the primary problem. Let us know, if the kombi valve fixes it.
      Output testing:
      https://www.youtube.com/watch?v=woyB...&feature=share
    20. 03-28-2017 01:52 PM #21
      Output testing:
      Yup; I'm learning as I go. And thanks - I appreciate any and all links related to the Kombi valve. I'm a gearhead, but this SAI (and troubleshooting) stuff is new territory for me (hence the learning curve). My previous studying up on this VW 0411 stuff mentioned the Kombi valve as part of the SAI system, but didn't mention the condensation and water in the pump if the Kombi valve was bad. The only thing I saw was the "finger test" where if you removed the hose and there was soot in there, the valve was bad; otherwise it was considered good (or working properly). Doing further reading after I replaced the pump (which definitely needed to be replaced - it was filled with water and corroded) did I find out about the connection with the bad Kombi valve and condensation/water in the pump - makes sense - I hope that's it. Here in WA we've been getting A LOT of rain, so I figured the water in the pump was somehow related to all the rain.
      And I'm in the medical profession (armyRN - get it?), so I definitely get the symptom vs. primary problem thing.
      So (sigh) this morning I ordered the Kombi valve and two gaskets (~ $188.00 total with shipping) from VW Parts Vortex, and will get it all installed as soon as parts arrives. I'll let you all know if the check engine light comes back on afterwards with the 0411 code.
    21. 03-28-2017 08:21 PM #22
      For vw dealer parts, i have been using these guys lately; some of the best prices i have found and their shipping price for small items is reasonable using usps.
      https://www.volkswagenpartsplus.com
    22. 04-15-2017 07:16 PM #23
      So it took a while for the Kombi valve and gaskets to get in, but they finally arrived. Got it installed (another PIA job), and then told my daughter to let me know if the check engine light came back on. It came back on - same 0411 code.
      So I've replaced the fuel pump relay and secondary air pump relay, the secondary air pump fuse, the secondary air pump itself, and now this Kombi valve with no luck. Still getting the 0411 code.
      In messing with it, it seems the Kombi valve is working, but the new air pump isn't getting power (or isn't working if it does get power). Monday I'm bringing it to a shop to have a diagnostic run to see if they can find the broken link in the system.
      It totally doesn't affect drivability (this 0411 code issue), it just keeps the check engine light on. So if something else went wrong, I wouldn't know it because the check engine light is already lit.
      I will let you know what they find out.
    23. Member billymade's Avatar
      Jan 29th, 2008
      Las Cruces, NM
      04-15-2017 07:29 PM #24
      http://wiki.ross-tech.com/wiki/index...5/P0411/001041
      Hmm, so you have replaced most of the parts of the sai system; the only thing left is the n112? Does the air pump; ever come on?
      Possible Causes
      Fuel Pump Relay (J17) faulty
      Hoses/Pipes to/between Components faulty/clogged
      Secondary Air Injection Pump (V101) faulty
      Secondary Air Injection Pump Relay (J299) faulty
      Secondary Air Injection Solenoid Valve (N112) faulty
    24. 04-22-2017 01:20 AM #25
      To recap: I am getting the 0411 CE code. Replaced the fuse, air pump relay, fuel pump relay, air pump itself, and Kombi valve. Nothing seemed to work (still getting 0411 code after I've cleared it). I gave up - tried or replaced everything I could think of (or was told to check/replace according to the repair algorithm).
      The Kombi valve works, but the air pump didn't want to run. Didn't know if it was just not working, or if it wasn't getting power.
      I brought it to a very reputable shop here in town with all the diagnostic equipment. They did a full diagnostic work-up, and their finding was... the secondary air pump I bought (and installed) was bad. And I talked to the owner of the shop who actually did the diagnostic work - he said they get bad new replacement parts all the time.
      So I will be getting a replacement air pump soon (exchanging it), and will make sure it works (bench check it) when getting power before swapping it out. Here's hoping it works. Should know by next week.
