VWVortex.com - Launched my Stage 2 R for the First time.
    Results 1 to 6 of 6
    Thread: Launched my Stage 2 R for the First time.
    1. Member joszer's Avatar
      Apr 30th, 2016
      Riverbank California
      2016 6MT MK7 Golf R-- 2012 Corvette Z06/Z07
      03-19-2017 12:24 AM #1
      I did the VCDS tweak to limit the ECU torque interruption when dumping the clutch and it worked!
      This is with the RSR Clutch. So far I have 5000 miles on the clutch and it's holding up fine. Launched it for the first time this morning. Definitely won't make a habit of doing this but wanted to experience it at least once.
      https://youtu.be/-DMzSDyrWLo
      Jul 12th, 2002
      Texas
      17 2.0t, 16 2.0t R
      03-19-2017 07:51 AM #2
      Sounded like wheel hop. Wouldn't mind seeing a 6000 rpm launch.
    3. Member MiamiBourne's Avatar
      Jan 9th, 2010
      Brooklyn, NY
      2016 Golf .:R
      03-19-2017 11:41 AM #3
      Quote Originally Posted by joszer View Post
      Nice...now if one of these tuners will just create a tune for launch control and no lift shifting like some did for the MK6...
      I'm still not sure what clutch I would go with yet but it's between the RSR and Southbend Stage 3.
      Oryx White Pearl | 6MT | S3 Res Delete | ECS Spacers 15mm/20mm | ED Springs
      Boomba Short Shifter | BMS Clutch Stop | Torque Solutions Shifter Cable Bushings
      Helix Soundbox | V1 w/VW-009 Blendmount | VCDS | Helix Dongle
      Instagram: @miamibournes_golfr
    4. Member
      Oct 20th, 2011
      Vancouver BC
      2016 Golf R Pure White 6MT & Tech Unitronic Stage II, 2014 Tiguan RLine
      03-19-2017 01:26 PM #4
      Hey Jozer,
      Which VCDS tweak is it you are talking about? Link?
      Cheers,
      Dan
      Jul 12th, 2002
      Texas
      17 2.0t, 16 2.0t R
      03-19-2017 02:41 PM #5
      Quote Originally Posted by Hoop71 View Post
      Hey Jozer,
      Cheers,
      Dan
      http://forums.vwvortex.com/showthrea...it-via-Vag-Com
    6. Member
      Oct 20th, 2011
      Vancouver BC
      03-19-2017 04:47 PM #6
      Thanks TaxMan
