VWVortex.com - The Chronicles of SneakySnakes | Vol III
    The Car Lounge
    Page 12 of 12 FirstFirst ... 289101112
    Results 276 to 287 of 287
    Thread: The Chronicles of SneakySnakes | Vol III
    1. Member slowhatch's Avatar
      Jul 1st, 2010
      Houston
      '13 BMW 750i, '16 Mazda Miata, '13 Viper GTS
      06-13-2017 10:36 AM #276
      Some recent shots from a close friend;
      Mar 28th, 2004
      Austin TX
      06-13-2017 10:37 AM #277
      I came, I saw, I came again.
    3. I love The Backstreet Boys. Holla! leitloaf's Avatar
      Oct 9th, 2016
      $2000 for a 1 bedroom
      '15 Fiesta ST; '16 GTI
      06-13-2017 10:59 AM #278
      Quote Originally Posted by slowhatch View Post
      Snake in the grass. Nice
    4. Member slowhatch's Avatar
      Jul 1st, 2010
      Houston
      06-13-2017 11:00 AM #279
      Quote Originally Posted by 6cylVWguy View Post
      If you don't mind me asking, how powerful is the pressure washer you are using on the car? I'd like to buy one of these for around the house, but if I can also use it to help wash the car, it would be a bonus.
      I believe its a 3000psi, 2.8gpm unit.
      From what I was told by the pros, to get proper foam, you need at least 2500psi. It will foam with less, but it wont be as thick.
      Quote Originally Posted by MartyMcFly88MPH View Post
      I just bought this one. Cheapest Home Depot has. While i'm sure its not the best quality, it does the trick of washing my car just fine so far. You can safely go a little higher pressure too from what I've read.
      I was also told to stay well clear of cheap electrics. They are weak in output, and break more often than not. They are super convenient though in regards to not having to keep fuel.
      I have had my ~$300 home depot gas unit for almost 3 years using it 1-2 times per month and it has never skipped a beat. I have used friends electrics and they are absolutely night/day compared to mine (much much weaker).
      The car looks incredible.
      One thing that I always think about with these crazy details is rattles. Doesn't pulling so many little pieces apart for cleaning increase the chance of annoying rattles down the road?
      It all had to be assembled at one point, so it can be dis-assembled and assembled again. If done properly, I've never had an issue. I do shy away from taking things in the interior apart, unless I have all new fresh fasteners/clips.
      Quote Originally Posted by d.tek View Post
      Orrrr his detailer just got some awesome images to help promote his business?
      I am intrigued by the ceramic coating, and want to do it to my S2000; I feel like it might be too expensive, but the idea of basic washes might make it worth it.
      He could care less about promoting his business (in regards to my crappy cell photos and car) haha. He has million dollar exotics in there and he's quite a photographer himself.
      We were helping each other out. He was teaching me new stuff (which i love), and I was lending him a hand so he could focus on work that actually made him money.
    5. Senior Member 6cylVWguy's Avatar
      Jun 14th, 2000
      PA
      Blog Entries
      4
      '11 M3 ZCP; '94 SLC
      06-13-2017 11:16 AM #280
      Ok, cool thanks! I have a standard foam gun that I just hook up to the hose and while it works, the foam isn't all that thick. It looks like when you are ready to rinse the car off, you just use the water gun/wand that came with the pressure washer, without the foam cannon hooked up, correct? I was looking at some options around 3k psi, but I want to make sure I don't ruin the finished with too much pressure---either applying the soap or rinsing it off.
    6. Member slowhatch's Avatar
      Jul 1st, 2010
      Houston
      06-13-2017 11:30 AM #281
      Don't be afraid of it, it will not harm anything. 2 Rules;
      1. Always stay at least 12 inches away from the surface when using the pressure washer
      2. Always use the softest nozzle when spraying paint (usually the white 40deg unit)
    7. 06-13-2017 12:31 PM #282
      SlowHatch I love all your threads. Thanks for putting in the time to show us the great lengths you go to keep your rides clean and well maintained.
      My question is what size spacer are you running and how are the ET lug nuts "holding" up.
      Also do you recall the amount of complete turns you got with the spacers and ET lug nuts?
    8. Member tampaSi's Avatar
      Apr 10th, 2006
      17 GTI Sport
      06-14-2017 10:29 AM #284
      History | C7 Z51 | GT86 | 987.1 | S197 | W126 | EM1 | GVR4
    9. Member slowhatch's Avatar
      Jul 1st, 2010
      Houston
      06-14-2017 10:49 AM #285
      Quote Originally Posted by S197Jay View Post
      I am running .450" slip on hubcentric up front, and a slip on .375" hubcentric in the rear.
      ET nuts typically buy back a little over .300" worth of thread engagement. I do not recall the turns but I am well within a safe range. Typically, if you look at a contact force distribution on a thread form, the first 2 pitches carry 90% of the load. Hence why typical design manuals call for a standard 4 threads (pitches) worth of engagement at minimum from a threaded fastener. This is around .200" worth of thread engagement in my 1/2-20 case, and I am WELL above that.
    10. Member Power5's Avatar
      Jun 19th, 2001
      Cincinnati, Ohio
      '17 Scat Pack Manuel / '01 Camaro SS Manuel
      06-14-2017 11:47 AM #286
      Amazing photographer is amazing. I would love to see the raw images before any photoshopping had been done. That is if any has been done. I am just amazed at how well he photographed that color.
