VWVortex.com - Audi TT 3.2 6 speed manual transmission in a mkv R32
    Results 1 to 13 of 13
    Thread: Audi TT 3.2 6 speed manual transmission in a mkv R32
      Mar 9th, 2011
      Kingston ny 12401
      03-24-2017 08:40 PM #1
      I was wonder if anyone has every seen a 6 speed manual trans from. 3.2 Audi TT swap in to the mkv 3.2 R32 any info is greatly appreciated as I would like to do this myself thanks in advanced
    2. Member dckeener's Avatar
      Jan 10th, 2005
      02.5 Gti 24v. 85 Golf 1.8t.
      03-26-2017 02:46 AM #2
      I dont own either of those cars but I am under the impression that they are the same transmissions as long as the TT is all wheel drive.
      Oct 31st, 2013
      Ottawa, Ontario, Canada
      2016 Golf R DSG / 2008 Audi TT 3.2 034 Motorsports Stage 3 / 2017 SQ5 Dynamic
      03-26-2017 09:32 AM #3
      I have a 6spd TT. As long as you have the correct flywheel (6spd TT dual mass). This is what I have been told.
      Mar 9th, 2011
      Kingston ny 12401
      03-26-2017 06:32 PM #4
      That is wat I was thinking just have to a matching flywheel thank for the input guys
      Mar 9th, 2011
      Kingston ny 12401
      04-01-2017 01:53 PM #5
      Does anyone kno if the computer will read check engine if I do this swap
      Oct 31st, 2013
      04-04-2017 11:09 PM #6
      Quote Originally Posted by keylo845 View Post
      You'd have to recode your ecu to take out the dsg.
      Mar 9th, 2011
      Kingston ny 12401
      04-05-2017 05:11 PM #7
      Ok thank you again
    8. Semi-n00b
      Oct 22nd, 2014
      Northland, New Zealand
      '06 VW Touran being R32'd, '72 VW 1200 Beetle
      04-06-2017 01:52 AM #8
      The R32 ECU's cannot be recoded from auto to manual. You need to get a manual ecu, or get some serious tuner to sort it out.
      I could NOT load manual software onto a DSG ECU in the mk5 R32 ecu I used in a conversion, either. I could write it, but it didn't allow starting or running and screw up the fans and all sorts. I ended up buying one brand new, and then found a second hand one as well.
      You can use either of the MK4 R32 or MK5 R32 manual transmissions. I don't know what they sold in the US, but the TT with the BUB or BDB 3.2 will be MK5 based. If you fit that trans (02Q), it's all bolt up.
      IF you find a MK4 R32 or 2.8 4motion type trans (02M), you can also use it - you need the flywheel matching the transmission, and you need the driveshafts for the front too, but you'll have to install MK5 outer CV joints - they fit right on. This is what I've done in my Touran R32, which is based on a MK5 chassis.
      You also have to wire in a clutch switch, code all other relevant modules for manual, and change one wire that used to go to the DSG, earth it to allow the starter to run (From Onboard Power Supply module - Central electronincs).
      the automatic type engine ECU will have a fault code for a missing TCU, and because of that code, the ABS module will have a "sympathy" code... so you'll have both lights on...
    9. Member V-dubbulyuh's Avatar
      Nov 13th, 2005
      Mk3 VRT, Mk4 VRT, Mk4 VRT, Mk4 VR, A3 VR, B6 3.6 4Motion, B5 1.8T
      04-08-2017 01:30 PM #9
      Great info in here, would like to see pics of your Touran swap.
      "OP sounds like a MKIV guy"
    10. Semi-n00b
      Oct 22nd, 2014
      04-09-2017 04:27 AM #10
      Quote Originally Posted by V-dubbulyuh View Post
      There's an 02M in here, fed by the R32
      This isn't full throttle - Trying to make sure I didn't destroy another driveshaft, after not assembling the first one correctly:
      https://youtu.be/r_Fj7KQqUZs
    11. 04-20-2017 08:27 PM #11
      Quote Originally Posted by DuBnurD View Post
      great information! thanks for sharing!
      24v VR club
    12. Member V-dubbulyuh's Avatar
      Nov 13th, 2005
      04-20-2017 11:20 PM #12
      Thanks for the pics, so to clarify you used a MkV trans for your swap?
    13. Semi-n00b
      Oct 22nd, 2014
      04-26-2017 01:14 AM #13
      Nope. Car is basically a longer MKV - trans is MKIV 2.8 VR6 (Bora/Jetta 2.8 4motion).
