VWVortex.com - Why hasn't any electric car manufacturer ever put a RAT (Ram Air Turbine) on their cars?
    The Car Lounge
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 28
    Thread: Why hasn't any electric car manufacturer ever put a RAT (Ram Air Turbine) on their cars?
    1. Global Moderator EPilot's Avatar
      Jul 27th, 1999
      NJ
      Present: 16 GTI SE Past: 12 GTI, 99.5 GTI GLX, 95 Golf Sport, 78 Bus…
      05-18-2017 11:48 PM #1
      Why hasn't any electric car manufacturer ever put a RAT (Ram Air Turbine) in or on their cars? Supposedly they can produce anywhere from 5-70 kW of energy so why hasn't a car company tried such a device to offset the loss in stored energy from driving?
      Seems like you add a smaller RAT somewhere on the car and use aerodynamics to speed up the air going to the RAT to generate even more power.
      From Wikipedia
      A typical large RAT on a commercial aircraft can be capable of producing, depending on the generator, from 5 to 70 kW. Smaller, low airspeed models may generate as little as 400 watts.
      A RAT for those who might know what it is.
    2. Member Robstr's Avatar
      Jun 8th, 2006
      South Bend, IN
      '07 Mini Cooper S, '91 318is Frankenstien With a built eta swap.
      05-18-2017 11:50 PM #2
      Quote Originally Posted by EPilot View Post
      Doesn't work that way. Adding one of these would only decrease efficiency, except it it only popped out when decelerating.
      All opinions are not equal. Some are a very great deal more robust, sophisticated and well supported in logic and argument than others.
    3. Global Moderator EPilot's Avatar
      Jul 27th, 1999
      NJ
      05-18-2017 11:51 PM #3
      Want to explain why it wouldn't work since you seem to have some understanding of the way RATs work that I don't?
    4. Member mx5er's Avatar
      Apr 28th, 2001
      NY
      05-18-2017 11:59 PM #4
      I first heard about RAT during a TV show about the Gimli glider. The Gimli glider was a Air Canada flight originating from Montreal to Edmonton where the aircraft ran out of fuel.
      No fuel means no electrical power. So the pilot deployed the RAT so the aircraft had electrical power.
    5. Member GTI_2.0T's Avatar
      May 14th, 2001
      2014 GLI, 1977 T/A
      05-19-2017 12:44 AM #5
      I'm guessing conservation of energy.
      I'd think the energy required to overcome the drag of a turbine will offset any energy gained.
      Jason • Now 2.0T / 455 • Then 2.0T / 1.8T / 2.0
    6. Global Moderator EPilot's Avatar
      Jul 27th, 1999
      NJ
      05-19-2017 12:52 AM #6
      Quote Originally Posted by GTI_2.0T View Post
      I think that point is probably why.
      There is a patent for it.
      https://www.google.com/patents/US8098040
      Ram air driven turbine generator battery charging system using control of turbine generator torque to extend the range of an electric vehicle
      US 8098040 B1
      ABSTRACT
      A system and method to convert the ram air energy resulting from the movement of an electric vehicle through the air mass into electric energy to recharge the energy storage devices of the vehicle while minimizing the apparatus caused drag effect on the vehicle, thereby extending the driving range of the vehicle between external charging. At least one ram air driven turbine is positioned within the vehicle, the turbine driving a mechanically coupled generator to charge the battery. Ram air is ducted in the front of the vehicle to cause the turbine generator to rotate and output electrical energy to charge the battery. The effect of variation in vehicle speed on both turbine generator output and turbine caused drag is optimized by adjusting the pitch angle of the turbine blades. At least one included ultra capacitor will implement a pre-programmed charge/discharge profile to reduce charge resistance electrical loading on the turbine generator and enable continued battery charging with minimal increase of turbine caused drag.
    7. 05-19-2017 06:38 AM #7
      Same reason why they don't have giant fans in front of wind turbines.
      Electric vehicles already have electricity. Aircrafts need a way to generate electricity and therefor they sacrifice some efficiency for this.
    8. Member MrRoboto's Avatar
      Jul 26th, 2000
      VHHH
      E82M / V40 T4 R-Design / MSX125
      05-19-2017 08:22 AM #8
      I imagine that because electric cars generally spend most of their time at low speeds where a RAT won't work, carrying that extra weight (and cost) to implement such a solution probably won't be worth it. The additional aero drag at high speeds would probably negate the advantages, even if you put it behind a NACA duct I imagine.
      The usage is different for aircraft though. Efficiencies don't matter much when you need hydraulic pressure to work flight controls if all your hydraulic pumps have stopped, either due to pump or engine failure.
    9. Member Nealric's Avatar
      Feb 16th, 2013
      '16 WRX STI, Turbo S3 Alfa Spider, Family Truckster
      05-19-2017 08:40 AM #9
    10. Member Egz's Avatar
      May 30th, 2002
      Virginia
      2006 Ford Fusion 2.3 Turbo, 2016 Ford Fusion Hybrid
      05-19-2017 08:46 AM #10
      I suppose if you could get past the aerodynamic drag, sizing would be an issue. To have a generator to create sufficient power, the size might be larger than the real estate available on the car. Sort of like solar panels; just not enough room to make enough power.
    11. Member Unilateral Phase Detractor's Avatar
      Aug 23rd, 2005
      Columbus, Ohio
      2016 Mazda CX-5  2013 Ford Focus Electric
      05-19-2017 09:16 AM #11
      It's about as feasible as direct exhaust injection.
    12. Member Nealric's Avatar
      Feb 16th, 2013
      05-19-2017 09:25 AM #12
      Quote Originally Posted by Unilateral Phase Detractor View Post
    13. Member Crispyfritter's Avatar
      Nov 21st, 2001
      SW KS
      05-19-2017 09:28 AM #13
      Maybe we could invite Feliks in to build it and have VigorousZX design it into the car.
      This thread is going places.
      Chris
      | 2017 Korean Appliance SE | 2008 Suburban LTZ | 2003 Dodge Ram | 2002 BMW 530i con mañuel | 1974 SuperBeetle x 2 | 1979 Camaro | 1975 Scout |
      The poster formerly known as 200HP4dr
    14. Geriatric Member spockcat's Avatar
      Jun 4th, 2003
      West Coast, not that west coast. Bay area, not that bay area.
      11 328i Touring, 16 Colorado Crew, Versys, 2017 Barracuda
      05-19-2017 09:41 AM #14
      From Wikipedia
      Low airspeeds in planes like that are very, very high speeds in cars. So even less power than the 400 watt figure. And additional drag of such a device means the car needs to use more power to move it. EVs already have electric regeneration in braking. Doing that regeneration via the air isn't really necessary and the added weight of the equipment would be counterproductive.
    15. Member Robstr's Avatar
      Jun 8th, 2006
      South Bend, IN
      05-19-2017 10:03 AM #15
      Exactly. If you're cruising down the highway any power you gained from the RAT is LESS than the power lost from the RAT's extra drag regardless of the configuration. This is an absolute thermodynamic certainty. It has nothing to do with the car going too slow for it to work (it's a bad idea at any speed). That's because the power a RAT generates comes directly from its drag: the force of airflow on the blades is how it generates power (actual power generated is somewhat less than its drag).
      You could use one like you use regenerative braking. But regenerative braking systems are probably better in every measurable way.
    16. Member johnny_p's Avatar
      Dec 7th, 2007
      Philly
      2017 STI
      05-19-2017 10:15 AM #16
      You'd need it to only deploy while braking or decelerating, meaning it would need a hatch and motor to pop the door open and flip this thing out, then close it when deceleration is complete. That's a lot of added weight and complexity not to mention the space it would take up. Regen braking can all be done in the electric motor, it's all contained, and any extra weight is minimal.
      '12 Trek X-caliber // '11 Cervélo R3 // '90 Havnoonian custom
      Gone: 2010 VW GTI
    17. Senior Member AZGolf's Avatar
      Jun 6th, 2000
      Phoenix area
      05-19-2017 10:23 AM #17
      This is correct. As for the notion of only popping the RAT out when slowing down, that's unnecessary because all electric cars even back to the 1st gen Prius and Insight have done regen at the wheels when slowing down, which is far more efficient than collecting it through wind.
      So ultimately it can be summed up as such: The OP wants to know why EVs don't do regen, which is starting from a false standpoint because they all already do regen in the most efficient way possible.
    18. Whine Connoisseur WhineMCABasket2.0t's Avatar
      Oct 2nd, 2005
      Sunnyvale CA
      Lighten up Francis
      05-19-2017 10:31 AM #18
      If something could create more energy than it takes to move it then we'd have a perpetual energy source which bends physics.
      I'm just a regular Joe, with a regular job. I'm your average white, suburbanite slob.
      Quote Originally Posted by Rabbit5GTI
      You have cornered the entire 'I hate Ford Fusions' market around here
      Quote Originally Posted by Turbio!
      Pure electric vehicles will never fully replace fueled (pure ICE or PHEV) vehicles.
    19. Member uberR32's Avatar
      May 3rd, 2004
      The Woodlands, TX
      '14 JKU Sahara, '93 Porsche 911 RSA, '92 LS2 Miata
      05-19-2017 11:44 AM #19
      This is why.
      Quote Originally Posted by jackboots View Post
      Wow. Its like a bicep with six-pack abs made entirely of fists.
    20. Senior Member bzcat's Avatar
      Nov 26th, 2001
      Los Angeles
      05-19-2017 01:23 PM #20
      Quote Originally Posted by AZGolf View Post
      Came to post this.
      Also, RAT is a device that converts kinetic energy from motion (change in velocity) back into battery storage. Exactly the same physical conversion of energy from a change in velocity as brake regen. Except brake regen is much more efficient at lower speeds.
      RAT trades a slight decrease in very high air speed to generate electricity (e.g going from Mach 0.85 to Mach 0.849). Brake regen trades a large decrease (e.g. in % terms going from 60mph to 0) in relatively slow ground speed to generate electricity. RAT won't be effective in cars because the change in velocity in absolute terms (i.e. going from 60mph to 0) is not a meaningful change in air speed.
    21. Member Gvr4-330's Avatar
      Aug 25th, 2002
      Washington, DC
      91 Galant VR-4, 01 S2000, 12 CTS-V Wagon
      05-19-2017 01:54 PM #21
      Past: 08.5 Mazdaspeed3 | 96 Buick Roadmaster Estate | 84 Mercedes 300D | 04 Mazda3 5-dr | 91 Mitsubishi GVR4 | 88 Sterling 825SL | 87 Sterling 825S | 86 Oldsmobile Custom Cruiser
    22. Geriatric Member ValveCoverGasket's Avatar
      Mar 20th, 2002
      trendy homeless camp, OR
      german and british
      05-19-2017 02:01 PM #22
      this thread
    23. Member
      Apr 27th, 2005
      2013 Passat TDI SEL Prem.
      05-19-2017 02:32 PM #23
      You would be better off lining the underside of an electric car with piezoelectric power generators. They would generate electricity from the movement/vibration of the car. Would not work when not moving though.
    24. Global Moderator EPilot's Avatar
      Jul 27th, 1999
      NJ
      05-19-2017 02:39 PM #24
      Came to post this.
      Thank you for the post and information. Now off to my newest fascination.
      Gassy seats lol
    25. A beautiful Summer's Eve Sold Over Sticker's Avatar
      Nov 28th, 2009
      Corner of salt water and vinegar
      8 Nozzles and 16 Valves
      05-19-2017 02:53 PM #25
      Vehicle engineers don't exist in a vacuum, and they constantly borrow from one another. Want to know how automobiles ended up with disc brakes and anti lock braking systems?
      If the RAT was a feasible idea and had good performance to the expense of R&D and manufacturing costs, it would be on the car. This idea is similar to those pot metal turbines that drop into your intake a swirl the air for more efficiency. In a world where engineers fight for fractions of a MPG across the drivetrain, if there was a $14.99 plus shipping and handling fix to get 10+ mpg, it would already be on the car.
      Also, the amount of kinetic and potential energy an aircraft has to swap to generate electricity far exceeds what my old LEAF would have, unless you took my LEAF up to FL350, accelerated it to .76 mach and dropped it back to earth.
      Driving While Awesome Podcast. Give it a listen.
      Quote Originally Posted by bothhandsplease View Post
      Brendan told me to get the best discount, I had to send dick pics. I thought this was standard car buying practice.
      Quote Originally Posted by H.E. Pennypacker View Post
      Brendan and his all knowing heavy breathing baboon are correct.
