VWVortex.com - GTI DSG Holds gears 1-4 until engine is warm?
    Results 1 to 2 of 2
    Thread: GTI DSG Holds gears 1-4 until engine is warm?
    1. 06-19-2017 11:25 AM #1
      As the title says, I noticed this this morning. I've only had the car for a few days, so it may just be me to used to it yet, but after getting up to speed (50 MPH) the DSG will hold in 4th or 5th at about 2800-3000 RPM. Ideally if I'm cruising at that point, I'd like it to just stay in 6th. I can manually upshift to sixth, but the car downshifts by itself after a few seconds. So far I've only noticed this after a cold start...
    2. 06-19-2017 01:26 PM #2
      You shouldn't go above 3k rpm's until the engine is at operating temp. (190-200 degrees).
      I don't even move the car until the idle is set at around 7-800 rpm's unless I have to go.
      2011 MK6 2 Door UG | ECS Stage 2 Intake | COBB Stage 2 | COBB Turboback w/Highflow Cat/42DD O2 Spacer | Full DeAuto LED Kit | HID/Fog Kit | RevD, DV+ | R8 RedTops | Welcome Door Light VW Logo Projectors | VagCom Mods | Hatch Pop Kit | CTS PCV Catch Can | Neuspeed Charge Pipe | CTS Discharge Pipe | Eonon GA5153F Headunit | Full Kicker Audio | Alzor 081 18's | Pirelli PZeros
