VWVortex.com - symptoms of a bad throttle body
    Results 1 to 11 of 11
    Thread: symptoms of a bad throttle body
    1. 06-11-2003 12:42 PM #1
      any of you guys/gals that have had a throttle body go bad, can you give me some insight of the symptoms you had. here is a pic for views: (mah cah)
      Sep 12th, 2002
      Portland, OR
      98 Audi A4 and 2012 Tiguan SE 4Motion
      06-11-2003 12:45 PM #2
      you car won;t run above 3000rpm or it will idle really messed up, i've had 2 go bad, you car will do some weird things
    3. 06-11-2003 01:23 PM #3
      How the heck does a TB go bad?
    4. 06-11-2003 04:37 PM #4
      when mine went it would idle like crap to the point where it would stall. i didnt have any prob. at 3000 rpm though. my mech got me one from a junk yard w/24000 miles on it for like $30. good luck
    5. 06-11-2003 04:40 PM #5
      im having a similar problem, if i stay on the throttle for more than 4 sec it will bogg out but if i pump the throttle 3 sec. down let off for 2 and then back on for 3, over and over i dont have any problems, but it take forever to get up to speed. Does it sound like a TB problem? or maf?
    6. 06-11-2003 05:11 PM #6
      Quote, originally posted by 97wetjet »
      But how do you know it was the TB? The TB on MKIII 2.0's is a mechanical beast, not electrical. The only way the TB would need replacing is if the actual housing or butterfly mechanism or the linkage to it breaks which is very rare.
      There is an Idle Stabilizer Valve built into the TB on OBDII cars which you can take out and clean. Probably what was wrong with your car since it wouldn't idle but be fine off idle.
    7. 06-11-2003 05:12 PM #7
      Quote, originally posted by Fast Bumpers »
      Are you getting any CEL's?
    8. 06-11-2003 05:12 PM #8
      Quote, originally posted by MikeBlaze »
      yup its just glowing in my face, and i just got rid of it 2 months ago
    9. 06-11-2003 05:14 PM #9
      Get it scanned and start a new post in the 2.0 forum with the codes that are poppin up. We'll help you out. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    10. 06-11-2003 05:18 PM #10
      lol, just saw your post there. Definitely get it scanned and post the codes, not much anyone can do over the net wiothout them.
    11. 06-11-2003 05:38 PM #11
      this is what mine was doing
      http://www.imagestation.com/vi...79705
