VWVortex.com - VW center caps - do they fit all aftermarket wheels?
    Results 1 to 8 of 8
    Thread: VW center caps - do they fit all aftermarket wheels?
    1. Member sidewinder's Avatar
      Aug 18th, 2000
      Seattle, WA
      2014 Subaru Crosstek Limited
      06-18-2003 03:59 PM #1
      I just got a set of ATS Type 10 wheels and I want to put VW center caps in them. How do I know if they fit, and where can I order them? Thanks.
      Present: 2014 Subaru Crosstek Limited (Desert Khaki)
      Past: 2006 Mazda3 hatchback | 1998 GTI VR6 | 2000 Jetta GLS 2.0 | 1993 Nissan Stanza | 1992 Honda Prelude Si | 1990 Honda Accord LX Coupe
    2. Member Feyd's Avatar
      Apr 1st, 2002
      Chicago
      2011 Golf TDI, 2012 Touareg TDI
      06-19-2003 01:29 PM #2
      you'll be pretty hard pressed to find a vw centercap that will fit any aftermarket wheel.... sure there are a few wheels out there that will work, but by in large, they don't really exist.
      if you measure the hole in the center of the wheel in mm's you can find out the size cap you need. then you can check out ebay, the classifieds here, or definatly your dealer. problem is, that i don't think that the dealer knows what size the caps are, just what factory wheels they fit... so that can be a problem. i know that there have been postings on this before, search and maybe IM the creator. there was one guy who modified a set of new caps to fit some rota wheels a year or so ago...
      good luck, post pics if you getem workin.. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    3. Member sidewinder's Avatar
      Aug 18th, 2000
      Seattle, WA
      06-19-2003 03:46 PM #3
      I'm going to take one of my aftermarket caps to my friend at the dealer, and see if any of the VW ones match up. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    4. 06-19-2003 10:54 PM #4
      im running something similar to these. http://cgi.ebay.com/ebaymotors...67687
    5. Member sidewinder's Avatar
      Aug 18th, 2000
      Seattle, WA
      06-20-2003 11:38 AM #5
      yeah I ran across some of these in the classifieds...might work if the diameter matches, I'll have to measure.
    6. 06-20-2003 01:06 PM #6
      sidewinder: I pulled off a vw 17" Long Beach wheel cap and measured it...it is 56mm or 1/16" shy of 2.25", if this helps. The ebay link said those stickers were only 1.5" which is only 39mm...pretty small. I know the Borbet wheels I'm looking at have a 2.25" center cap but a set of Fondmetals I'm also looking at only have a 50mm cap...hope this helps... [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      what size are you center caps on your ATS's?
    7. Member sidewinder's Avatar
      Aug 18th, 2000
      Seattle, WA
      06-20-2003 01:36 PM #7
      I haven't measured them yet, thanks for the measurements. I'm sure that will help once I figure out what size mine are.
    8. 06-20-2003 10:19 PM #8
      the guy on ebay carries/makes all different sizes and colors
