Nice work![]()
#1
I found this list in a thread and thought it would be easier to locate in a search with a better title. Thanks to Jackal for posting this in the following thread (http://forums.vwvortex.com/zerothread?id=227321).
MKIV FUSE LIST1. Washer nozzle heaters, glove compartment light, memory seat control module (10A).
2. Turn signal lights (10A).
3. Fog light relay, instrument panel light dimmer switch (5A).
4. License plate light (5A).
5. Comfort system, cruise control, Climatronic, A/C, heated seat control modules, automatic day/night interior mirror, control module for multi-function steering wheel, control unit in steering wheel (7.5A).
6. Central locking system (5A).
7. Back-up lights, speedometer vehicle speed sensor (VSS) (10A).
8. Open
9. Anti-lock brake system (ABS) (5A).
10. Engine control module (ECM): gasoline engine (10A); diesel engine, Model Year 2000 > (5A).
11. Instrument cluster, shift lock solenoid (5A).
12. Data Link Connector (DLC) power supply (7.5A).
13. Brake tail lights (10A).
14. Interior lights, central locking system (10A).
15. Instrument cluster, transmission control module (TCM) (5A).
16. A/C clutch, after-run coolant pump (10A).
17. Open.
18. Headlight high beam, right (10A).
19. Headlight high beam, left (10A).
20. Headlight low beam, right (15A).
21. Headlight low beam, left (15A).
22. Parking lights right, side marker right (5A).
23. Parking lights left, side marker left (5A).
24. Windshield and rear window washer pump, windshield wiper motor (20A).
25. Fresh air blower, Climatronic, A/C (25A).
26. Rear window defogger (25A).
27. Motor for rear windshield wiper (15A).
28. Fuel pump (FP) (15A).
29. Engine control module (ECM) gasoline engine (15A); diesel engine (10A).
30. Power sunroof control module (20A).
31. Transmission control module (TCM) (20A).
32. Injectors: gasoline engine (10A); diesel engine (15A).
33. Headlight washer system (20A).
34. Engine control elements (10A).
35. 12 V power outlet (in luggage compartment) (30A).
36. Fog lights (15A).
37. Terminal (86S) on radio, Instrument cluster (10A).
38. Central locking system (with power windows), luggage compartment light, remote/fuel tank door, motor to unlock rear lid (15A).
39. Emergency flashers (15A).
40. Dual tone horn (20A).
41. Cigarette lighter (15A).
42. Radio (25A).
43. Engine control elements (10A).
44. Heated seats (15A).Fuse arangements in fuse bracket/battery:
S162. Glow plugs (coolant) (50A).
S163. Fuel pump (FP) relay/glow plug relay (50A).
S164. Coolant fan control (FC) control module/coolant fan (40A).
S176. Relays panel interior (110A).
S177. Generator (GEN) (90 Amp.) (110A).
Generator (GEN) (120 Amp.) (150A).
S178. ABS (hydraulic pump) (30A).
S179. ABS (30A).
S180. Coolant fan (30A).
Modified by VgRt6 at 1:27 AM 8-16-2008
#2
Nice work![]()
Forsale: Full screen MFA Euro Cluster :337 BBS RC's mint : Euro Gamma Radio with indash 6 Disc CD Changer : Lots of other misc parts : Parts Located In Canada
Please search my user name for parts for sale.
#3
I didn't type it in - someone else should get the credit.
#4
I call and raise![]()
#5
And I fold!![]()
#6
Thanks alot, I really did need this. I am waiting for Bentley to come out with the 2003 Manual for my Wolfie and I needed the fuse listing.Get this, my cigarrete lighter wasn't working with my cell phone charger, so I thought i blew the fuse, well i open the fuse box and guess what.....it wasn't there!!! in fact a few fuses weren't there!!! Nothing major, but a few discriptions weren't in the box cover so your thread will help me figure out what these numb nuts didn't put in. I called my Dealership VW Palisades and the sales guy was LIVID. He spoke to the group that does the inspection of the car before delivery DRI or something like that and tore them a new one. So just FYI for anyone who thinks that something isn't working on their new car...check the fuses.
#7
I say add this puppy(or the one it started from) to the FAQ!Great info.
#8
very nice.
saved it on the com![]()
#9
This fuse listing is already in the 1.8T FAQ, as well as a lot of other useful info.Check it out: http://forums.vwvortex.com/zerothread?id=450388
#10
Quote, originally posted by keycom » This fuse listing is already in the 1.8T FAQ, as well as a lot of other useful info. Check it out: http://forums.vwvortex.com/zerothread?id=450388
Not all of us drive 1.8T's
But that is a lot of info
#11
Quote, originally posted by Dub Nerd » Not all of us drive 1.8T's
thank god
Awsome info , Thx![]()
#12
So if my a'c/climate controls don't light up anymore, it may be a fuse? #5? At first , the lights would only come on sometimes, then one day that just decided to take a vacation and not light up at all. I don't think it's the bulbs either. If not the fuse, then what?![]()
#13
Quote, originally posted by michael whittaker » So if my a'c/climate controls don't light up anymore, it may be a fuse? #5? At first , the lights would only come on sometimes, then one day that just decided to take a vacation and not light up at all. I don't think it's the bulbs either. If not the fuse, then what? ![]()
Its the bulb
#14
It's almost definitely the bulb. It's a very common problem. There is a single bulb for all three HVAC dials. It's behind the center, fan speed dial. Use a pair of pliers and a rag (for protection) to pull the know out. It should come out with a good tug. The bulb is behind the dial and should cost around $1 for a new one.There is a DIY here - http://www.vwmkiv.com.
#15
is there a fuse for air pump?
#16
Fuse S162 (see above picture) according to the MKIV Bentley page 26-13.Also check the scondary air injection pump relay (J299). According to the MKIV Bentley page 97-9, it's located in the "engine compartment, left side, behind air cleaner housing, under protective cover."
#17
I just wanted to thank everyone who put effort into doing the fuse list. It really helped me out in finding a blown radio fuse.
#18
Quote, originally posted by KDmospd » I just wanted to thank everyone who put effort into doing the fuse list. It really helped me out in finding a blown radio fuse. Same here.
I pushed my OEM nav back into the dash and it died. My first thought was a blown fuse, but I was really dreading having to go through every fuse.
If you hadn't recently replied to this thread, it might have taken me a bit longer to find it.
#19
No problem, I was in the same boat as you were in and started a search. These forums are really informative, saved me a lot of time and stress.
#20
Bump, nice list.
#21
Nice list!!while trying to figure out if a fuse had blown due to the cig. lighter not working....my airbag light came on. Any ideas if I tripped a fuse or electrical misfire?
Never happened before until I started pulling fuses to check the outlet.
#22
Anyone know what the heated rearview mirror fuse is?
Just put it on my tab at Harry's
#23
now i can rule out my ac not working b/c of fuses.THANK YOU
#24
A few weeks ago something changed in my car. At night when i open the door and the lights are still on, it doesnt beeeeeeeeep at me anymore. Does anyone know which fuse this is? I was thinking 14.....![]()
#25
anyone know which fuse is for the power windows? I cant find it in the list.....
#26
6. Central Locking System38. Central locking system (with power windows), luggage compartment light, remote/fuel tank door, motor to unlock rear lid (15A).
I think power windows use the central locking system fuse number 38, but I could be wrong.
Modified by Robman at 8:44 PM 12-19-2005
#29
thanks for the list![]()
mujjuman
#30
Quote, originally posted by Hugo_Bling » anyone know which fuse is for the power windows? I cant find it in the list.....
Power for the motors comes from a circut breaker (S37) on the auxiliary relay panel under the dash.
#31
Are the tail lights on one fues? Both my tails went out the other night.
#32
Quote, originally posted by pkagel » Are the tail lights on one fues? Both my tails went out the other night. could be fuse 13, could be the brake light switch.
#33
Brake lights work fine as do the flashers and my rear fog that I installed. Luckily I installed it or I would have probably been hit before I got to a safe place the other night.
#34
I have a super high res one if anyone wants it...
Modified by MXTHOR3 at 8:10 PM 5-4-2006
