| Quote, originally posted by rs4-380 » |
| its actually kind of common. upping the fuse won't help at all, and in fact it is somewhat dangerous. They usually short out within the housing themselves. In other words the back of the projector, where the wires are attached to the light bulb, sometimes short against the housing. To fix if simply wrap all the exposed contacts (spade terminals, etc/) inside that housing with electrical tape. |
hit the nail on the head! the white wire in the housing on my right fog was having major issues. it had two breaks and a hole near the pin connection. i basically taped the whole wire as well as the pin after it was reconnected. went thru a few fuses but at least i did it myself. major thanks! rs4 & sawdust. cheers
BOWLING FOR COLUMBINE
