VWVortex.com - Brake Forum "Official" DIY/FAQ...
    Results 1 to 4 of 4
    Thread: Brake Forum "Official" DIY/FAQ...
    1. Geriatric Member
      Mar 10th, 1999
      SoCal
      2003 Jetta GLI (Project car), 1957 Porsche Speedster (replica)
      07-28-2003 03:24 PM #1
      Brake Forum DIY/FAQ. This thread will work very similar to the DIY\FAQ threads in some of the other forums. To have a topic added to the FAQ please contact a moderator using the 'Alert Moderator" function. This will automatically supply a link to the thread. You just need to let them know you would like it added to the "Brake FAQ" thread.
      Alert Moderator - How To Report A Post To A Moderator
      When you are searching for an answer to a question, use the search function. if you cannot find the answer to you question in the Recent Topics try changing the Data Set to Archived Topics and you might find an answer
    2. Geriatric Member
      Mar 10th, 1999
      SoCal
      07-28-2003 03:31 PM #2
    3. Geriatric Member
      Mar 10th, 1999
      SoCal
      04-26-2004 02:32 AM #3
      Golf & Jetta I:
      DIY Front Caliper Rebuild (using MKII 9.4" as a model) - evilpat
      Golf & Jetta II:
      MKII brake info & donor cars - vwtoys
      MKII brake info - Hemlock
      Rear disc brakes on 8V GTI - Batan
      The Big Brake Upgrade Picture Thread - Jezztor
      Golf & Jetta III:
      Brake Upgrades - Mk3 VR6 - vwventovr6
      Front Brakes Walk Through - Mk3 2.0L - Dan J Reed
      Golf & Jetta IV:
      The brakes of the MK4 platform - OEM and Upgrades - eggroller
      What tools are needed to change brake system? - phatvw
      Rear Brakes - MRP2001GTi
      337/TT rear brake upgrade - Helicon Twist
      R32 13" brake conversion instructions - GT17V
      Golf & Jetta V:
      The brakes of the MK5 platform - OEM and Upgrades - eggroller
      Passat - All other models:
      Passat B5:
      Touareg:
      Phaeton:
      Corrado:
      Fitting Audi two piston calipers -cramer
      Scirocco:
      Lupo:
      Polo:
      Fox:
      Big Front Brakes
      Vans & Transporters:
      Modified by eggroller at 5:00 PM 8-2-2007
    4. Geriatric Member
      Mar 10th, 1999
      SoCal
      04-26-2004 02:32 AM #4
      TT
      A2
      A3 & S3 (A4)
      A3 (A5)
      A4 & S4 (B5)
      A4 & S4 (B6)
      RS4
      Allroad
      A6 (C6)
      A6 & S6 (C5)
      Replacing FT & RR brake pads on the A6 (2.8q and 2.7t) - Mark Quinn
      Replacing Front brake pads/rotor on Audi A6 (C5) - kevin1533
      RS6
      A6 & 100 (C4)
      A8 & S8 (D2)
      A8 (D3)
      5000, 100, 200 (C3) & V8 (D1)
      4000, Coupe GT & 80
      80, 90, Coupe quattro & Cabriolet
      Porsche 996 brakes on a 90 coupe - 90quattrocoupe
      Possible rear vented rotor combinations for the Coupe - 90quattrocoupe
      Ur S4, Ur S6, S2 & RS2
      UrQuattro & Sport Quattro
      Modified by eggroller at 7:55 PM 3-1-2009
