VWVortex.com - I lost my wheel lock key! What do I do?
    Results 1 to 24 of 24
    Thread: I lost my wheel lock key! What do I do?
    1. 08-19-2003 04:16 PM #1
      THese are the locks that VW put on the car, can the Dealer look up my VIN and produce a new key for me?
    2. 08-19-2003 04:19 PM #2
      maybe.... but if you want a quick fix get a socket thats just a lil to small and beat the bastard on to nut then slowly crank off
    3. 08-19-2003 04:41 PM #3
      Take it to the dealer.....they have the keys to the locks....
      once you get them off, get some new ones......OEM lock are very expensive, even replacement keys....yo can get a new set of locks for cheaper than a new key
    4. 08-19-2003 04:48 PM #4
      if it comes down to it...spot weld a nut on the outside of the wheel lock the same size as your the oem lug bolt or lug nut. This what i had to do because the dealer lug keys wouldnt work.
    5. 08-19-2003 05:15 PM #5
      Quote, originally posted by Luckyzeee »
      yEP...they have master keys. They shouldn't charge ya anything to take it off.
    6. Banned Pfeil's Avatar
      Apr 14th, 2003
      08-19-2003 05:33 PM #6
      ahh i've had MANY troubles with lugs. taper the points on a 12-point 19mm socket. (i think it's 19, check it on the lug. it should be JUST too small) slam it on with a BFH and then use a breaker bar. throw out the lugs and replace them with regular ones.
    7. 08-19-2003 05:35 PM #7
      Cost me almost 30 bucks for a key. Just buy a new set after the dealer takes them off.
    8. 08-19-2003 05:47 PM #8
      I had the same problem. I took it to the dealer - long story but I was able to get them to take off the stock locking lug nuts without charging me .
      Dealership should be able to do it for you [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    9. Member GTI_2.0T's Avatar
      May 14th, 2001
      2014 GLI 30th, 1977 TA 455
      08-19-2003 06:05 PM #9
      The dealer does not have copies of all the keys. Neither dealer in Rochester had the correct key to fit my locks when I lost mine. I was also missing the key code card for the locks, so I was unable to order one.
      On a whim, a friend of mine at work and I tried the key from his '99 Wolfsburg and it matched. I borrowed his card and called McGard (They made the MkIII lock sets.)
      A new key shipped to me was about $12. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Jason • Now 2.0T / 455 • Then 2.0T / 1.8T / 2.0
    10. 08-19-2003 06:15 PM #10
      I kept everything the dealer gave me when I bought it, I'll go find that card!
    11. Banned Pfeil's Avatar
      Apr 14th, 2003
      08-19-2003 06:33 PM #11
      and then get regular lugs! don't deal with the key junk, they'll strip on you when you need them to work!
    12. 08-20-2003 10:12 AM #12
      Yeah I plan to...nobody wants to steal my stock wheels (That's why I still have them).
    13. 02-26-2010 10:25 AM #13
      This is true - after I lost mine this week the dealer told me that they don't have the right tools for most of the locks. Gave me the same advice someone else posted here - bang a socket until it fits and then crank it off with that.
      Alternatively if you can find a cold chisel that bangs in and has a hexagonal handle that can work as well. It's also something you can ratchet (hex handle) without ruining a socket.
    14. Member dubbinway's Avatar
      Apr 24th, 2007
      Brea, CA
      1995 Jetta 2.0
      02-26-2010 12:50 PM #14
      BANG A SOCKET ON IT!!! IMPACT!!!!! BWWAAAAA!
      Cinnamon Toast Crunch!
    15. Member ruck's Avatar
      Jun 19th, 2005
      Eastern CT
      the bus
      02-26-2010 01:05 PM #15
      Quote, originally posted by EvilScottBaio »
      its been six and a half years, i think hes got it taken care of by now
    16. Member SlowVRT's Avatar
      Jan 3rd, 2009
      Jacksonville, Florida
      92 Corrado SLC, 2001 Audi S4, 2013 CC
      02-26-2010 01:59 PM #16
      Quote, originally posted by ruck »
      Sure hope so!
    17. Member redskinsboy326's Avatar
      Oct 24th, 2007
      Indianapolis, IN
      02-26-2010 02:01 PM #17
    18. 02-26-2010 02:03 PM #18
      WTF? There's a rash of 5 or more year old threads getting bumped lately. Can no new people read?
    19. Member _supahtim_'s Avatar
      Aug 27th, 2009
      Toronto, Canada
      2007 Rabbit LA6Q
      02-26-2010 03:25 PM #19
      i think the new people are finally learning how to search. now if we can just teach them how to not bump old threads...
    20. Member bharry07's Avatar
      Jul 6th, 2006
      CT
      mk3s
      02-26-2010 03:28 PM #20
      Quote, originally posted by _supahtim_ »
      Have to take the good with the bad
      Dan's Auto Sales & Repair CT Auto Repair and Used Car
      Creep....
      IM me for Air Ride Installs, Frame notches, ect.
    21. Member NDubber's Avatar
      Sep 11th, 2006
      M-Town
      MKIII PB Whore
      02-26-2010 03:33 PM #21
    22. Member subatomic's Avatar
      Jul 23rd, 2009
      Southcoast Ma
      mk3 jetta vr6
      02-26-2010 03:46 PM #22
      wow... read a bit of that thread
      thats the absolute last thing i would try to get the bolt out
    23. 02-26-2010 03:54 PM #23
      Stands to reason some other "new" people (I've been a member here for over seven years, BTW) might find themselves in the same situation and, like me, use the search engine to find a solution. So I posted the info I got recently for that audience. I'm so terribly sorry for wasting all the cool kids' time with my post.
    24. Member ruck's Avatar
      Jun 19th, 2005
      Eastern CT
      the bus
      02-26-2010 04:07 PM #24
      its alright, hopefully it doesnt happen again
