I'm pleased to say that my car came alive today! Running SDS EM4-4F and I can't believe how well it runs!Installation was easy. I bought the system a few months ago, so I had time to read the manuals over and over and after a while I just installed-it in my head over and over, picturing where everything was going to go. Even in my sleep, I would figure out how I would mount certain components.
I took a kazillion pictures, so if anyone is interested I can post-up a nice, long, detailed post on everything I did. If it can help out future SDS users.
I got the system from L-Sport 5 minutes from my house. When I showed-up there to order a system, Karim told me he had a system already coming for a customer who had backed-out. It had every option I wanted except for the back-lit LCD and fuel-pump relay. Karim called SDS to see if it was too late to change the options and they were only able to send it with the backlit LCD or I could wait longer to get the fuel pump relay. I said okay for the back-lit LCD but forget the fuel-pump relay.
The original customer was going to use 240cc injectors (or something like that) and as you know, the system comes pre-programmed. I'm using 580cc injectors. So I set all my RPM FUEL values accordingly when I first plugged it in.
So today, when I finished installing the system, I plugged everything back together and felt pretty confident that it would start. I crank it and nothing happens. It just cranks and cranks. Doesn't even try to catch. I twisted the knob endlessly and nothing at all. Damn. +50%/-50% doesn't do it?! I can't be THAT off can I? So I check for spark, yup, nice strong spark. Listen to injectors. Yup, they're clicking. I check my ECU grounds. Yep, good to go.
Finally, I check the SDS manual real quick and I see a section "Changing Fuel Injector Size" ... basically, it tells you which parameters need to be adjusted and I changed my start values. I crank it once more time and she fires right up! What a good feeling!
I let it warm-up a little and started giving little quick "kicks" in the throttle. It chokes for a few seconds then bounces back. A little ACC LOW and ACC SENS tweaks and now the engine responds real good.
I took it out for a little drive, and it feels pretty good. Lack of power though. I'm not sure if it's 'cause I have been riding in my pop's 328I a lot lately, and since the Jet has been parked in my garage with no tranny for like 2 months now ... but it felt pretty slow. Probably just regular 2.0L wimpiness ...
A few things I noticed. The engine sounds different. It has a more "rhythmic" sound ... it has a more pronounced growl. I'm not sure if it's the lack of an airbox (I know what that usually sounds like too) or if the ignition timing is far off from what it's supposed to be at? I don't know. I don't have a timing light so I have no idea if my magnet position is good or not. I have to do that tomorrow for sure. Also, when cruising in vacuum, like right between accel and decel, right in the middle, it jerks back and forth a lot. Nothing that can't be fixed with some fine-tuning, I'm sure.
So far I have been tuning by nose.
I have no idea at all how for off I am in the AFR department. I can guess the idle by feel, with the knob, and I go sniff it out back. By the way it smells, I think it's okay for idle.
Tomorrow I throw on my wideband and get serious!
A few details I have to work on include cleaning-up the wiring, even though it's already surprisingly clean. (Using wiring looms does WONDERS!) I need to put my interior back together. (Looks like a race car now).
So I'll post some pics soon, probably tomorrow when I get a hold of my ****ty webcam.
I took some real photos too so I can scan the negatives and have super-high-res shots.
That's about it for now! I'm psyched! Once this thing is running good, the turbo is getting thrown-in!
Modified by Agtronic at 9:56 PM 8-19-2003
