I've been troubleshooting this code for a while now with no luck. So far I've replaced the gas cap, N80 valve, the new updated hose for the N80 valve and even the carbon canister. No matter what the code has always come back.
I've ran Basic settings 70 with vagcom and ran the evap test and it fails when it gets to 66.8%. Don't know what these numbers are telling me though. Anybody know?
In another forum somebody mention checking the double check valve (in red below) with a vacuum. I was not able to pull a vacuum on it. I don't know what its suppose to do. This double check valve is to the left of the N80 valve
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Control Module Part Number: 1K0 907 115 B HW: 1K0 907 115 B
Component and/or Version: 2.0l R4/4V TFSI 0040
Software Coding: 0403010A18070160
Work Shop Code: WSC 65728 1018 854933
VCID: 254B9B83ECFA27B
1 Fault Found:
001089 - EVAP Emission Control Sys
P0441 - 002 - Incorrect Flow - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 0
Fault Frequency: 2
Mileage: 205092 km
Time Indication: 0
Date: 2000.00.00
Time: 19:41:35
Freeze Frame:
RPM: 742 /min
Load: 20.8 %
Speed: 0.0 km/h
Temperature: 81.0°C
Temperature: 18.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.970 V
Readiness: 0000 0000
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Mileage: 205092 km
Time Indication: 0
Date: 2000.00.00
Time: 19:41:35
Freeze Frame:
RPM: 742 /min
Load: 20.8 %
Speed: 0.0 km/h
Temperature: 81.0°C
Temperature: 18.0°C
Voltage: 13.970 V
