2003 Jetta TDI with 204k+ miles and recently the mileage has decreased (last 10 fill ups). 5 years ago, I was averaging a consistent 46.2 MPG all the time and now I rarely hit 40MPG anymore. What made me write in is that I just put 600 miles on the car, all highway which normally results in the best mileage I see. Tonight it averaged out to 38.4. Is this just age?
In case it's not age, here's what I've looked at hoping there's some maintenance I've missed
1) The intake is not all coked up with carbon
2) The air filter was just replaced
3) The MAF was out of spec last year and causing the car to go into limp mode. I replaced the MAF last year and recently found it's still within specs
4) Tires are properly inflated
5) I switched diesel stations in case there is a difference in fuel now from a few years ago. I've seen no change in mileage.
6) No engine codes or engine light
7) The timing is within specs
The car can breathe and the fuel was eliminated as a factor, what else could it be? aging injectors?
Everything is original, turbo, injectors, etc. The only things I've had to change in 204k are the glow plugs, a few MAFs and an alternator (obviously oil, tires, fuel filter, air filters, etc).
The car runs like a champ, just the MPG isn't what it used to be.
I bet your injectors are just worn. Do you run diesel additive like diesel kleen to keep things clean/boost cetane? My mileage was going down the ****ter but went up when I swapped in better nozzles (old ones had 160k something like that...), and got even better when I upgraded turbo.
A can of diesel purge may help or your injectors could be getting old and tired and the nozzles are worn so you are not getting as efficient of a spray pattern from them any more leading to incomplete burn and reduced fuel economy. If the springs are worn they may be popping at a lower pressure and letting more fuel through at a lower pressure which once again leads to an incomplete burn and reduced fuel economy.
Here is a link with more info on the nozzles and there is a link to a video showing how to do a purge.
I've looked at upgrading my injectors in the past, but decided to go with a chip a few summers ago. The injectors are still stock and I've never used any additives. I would be interested in replacing the injectors but I would probably go with just stock at this point to return mileage to the old girl.
Last I remember kermatdi.com had good injectors, do you guys have any suggestions on brands? I'm not super interested in spending a bunch of money on a 9+ year old car with 200k+ miles.
If changing the fuel filter this weekend doesn't make a difference, I'll strongly consider a new set of injectors
the smaller nozzle will atomize fuel better, leading to a more efficient burn, and more power/economy..
the smaller nozzle is just no good for performance, because of the limited fuel flow..
but if you are staying stock, then it doesnt matter anyways..
simply changing to bigger injectors will not give you more power or mileage.. you need to have the engine re-tuned before you can see the benefits of either..
new injectors; make sure you loosen and tighten towards head, so wrench will be in opposite directions, towards trans when loosening and toward pulleys when tightening.
(w/new injectors)run a can or 2 of lubro-moly straight, make sure you use additive when fueling up.
run the run off return line back into can when flushing with lubro moly.
Get dlc 1019 injector and nozzle setup. You won't need a new tune for them. I put them on my '03 and it gives a nice bump in power and fuel efficiency stays the same
got mine from dbw but my experience with them wasn't exactly pleasant after he got my money. Its not something to get into so me personally would say not to go there. Kermatdi also offers them. I believe the nozzle holes are bigger than stock.
I changed my fuel filter and I'm finally writing back in after I've run a full tank of diesel through the car. The mileage is still sitting in the high 30s. As you can guess, I'm disappointed.
If the next best option is to replace the nozzles, I'll try that to get the mileage back. I wandered around kermatdi to find stock ALH nozzles. I already have a chip in the car so I think I'll keep the nozzles stock so I don't have to get my ECU tuned. About the cheapest option I found is $335 going with their sprint 520 nozzles (older model) vs $425 with the new DLC nozzles. Everything I read, save a few articles, says just send the nozzles out for replacement and testing from a place like kermaTdi since I don't have the equipment to perform a "pop" test, etc.
My only concern is could something else be causing this mileage decrease? Perhaps the turbo?
Related Threads
Ask a question
Ask a question
VW Vortex - Volkswagen Forum
84.4M posts
1.5M members
Since 2001
