I replaced the CO2 sensor and relay in my MK1 1.7...car ran great for a few days after. No vibration, no loss of power, no weak launches into 1st gear. Car has new plugs, injectors, o-rings, etc.
Yesterday, I started the car, and the engine ran sluggishly, producing a foul-smelling exhaust. I re-started the engine, and it again chugged at a low idle.
I turned up the idle screw, and the engine came back to normal....now with more vibration.
Is this more than just a matter of the idle screw needed adjustment? I have a feeling I have a bigger problem, but I doubt it since I have so many new vacuum lines and fuel line components.
I immediately thought spark plugs, too. I had replaced them recently with new Bosch ones...maybe switch to NGK?
I noticed the day before one plug was not screwed in all the way. I torqued it down when the engine was cool to Bentley specifications. I doubt that would cause any issues several drives later, though.
don't understand your logic here. saying it's clogged up? wrecking the valves?
how is the flow out the tailpipe? if it's fine, cat is completely irrelevant.
misfire or vacuum leak (improper fuel metering). figure out which it is. shoot starter fluid in the intake and see if it smooths your idle out. or perhaps you're running far too rich? unplug the o2 sensor and see what happens. cat is completely irrelevant.
have you checked o2 sensor with voltmeter or duty cycle with dwell meter? if you've checked that you don't have ignition issues, move on to fueling. improper mixture misfire
how does it run before it's warmed up? what if you unplug the o2 sensor?
Fiddled with the idle screw to finally see if that could be the issue. It wasn't (now the idle is a little too high, and I'm worried the air/fuel mixture will be off).
I think I might have isolated the problem. The EGR canister wasn't fully seated in that rubber boot in front of the throttle body. Pushed it back in; the car will run steady now.
This may have been a misfire due to a vaccum leak....but could the aforementioned problem occur, disappear, and then re-occur like it just did? Could this misfire/stalling be caused by the timing being off?
First off, your car doesnt have an EGR valve.. thats the aux air valve.. basically the high idle valve.
im surprised your car even ran with that un hooked..
and it came out because you never put it back in the intake boot, or else the clamp is REALLY LOOSE..
i dont see the timing being an issue, unless its GROSSLY RETARDED..
as long as you tighten the clamp that holds the tube in, it should not ever come back out..
and i would say that your back fire was from the vacuum leak.
and dont worry about your idle air fuel mix, you CANT adjust it, so dont worry about it being off.. that screw you played with, thats an IDLE SPEED setting, not IDLE MIXTURE setting.. this is a throttle body, not a carburator..
the idle speed mixture is set with the main mixture screw on the fuel dizzy, and unless you messed with it, then you should not need to mess with it ever..
Timing does not just go "off" out of no where, unless the distributor hold-down bolt wasn't tightened, in which case, you'd have noticed the timing off a long, long time ago.
Adjusting the idle screw only alters the amount of air that bypasses the closed throttle body. It is metered air, and would not affect your mixture. If anything, it'd just do a lousy job of masking whatever underlying issue.
You car does not have an EGR. It's not clear what you're talking about, but I'm assuming you're referring to the hose that connects from the charcoal canister to the intake boot on top of the fuel distributor? If that was unplugged, then yes, you would be having an issue with unmetered air. Again, check for vacuum leaks all around.
I'd suggest hooking up a voltmeter to the o2 sensor and a ground to see what your mixture is, both in closed loop (o2 connected), and open loop (o2 disconnected). Watching the voltage with the sensor disconnected would allow you to play with all your vacuum parts / spray starting fluid and see changes in mixture. Fix accordingly. When all is said and done, you should be seeing roughly around 0.7v with the o2 sensor disconnected. Better get, use a dwell meter to diagnose cis+l.
Well, that idle air valve either has a leaky seal or it needs replacement altogether. The car will run fine now once warmed up. However, for the first 30 seconds after I start it, it'll get a rough, shaky idle
That's what I was hoping. I turned up the idle slightly to get it to the shop 3 blocks away from my house without stalling (they do Alfa Romeos and ancient Mercedes' so I figured they'd know CIS).
Update: I had the WUR taken out. Clenaed it, and found some black gunk in the screen. Car seems to idle find for now....
Related Threads
Ask a question
Ask a question
VW Vortex - Volkswagen Forum
84.4M posts
1.5M members
Since 2001
