Stock Info
2011 VW GTI 2.0T
Candy White
Sunroof Package
6MT
RCD-510
18" Detroits
Engine Mods
APR Stage 3+ (GT30)
APR Injectors
APR Modular Boost Tap
AWE Turbo Outlet Pipe
BFI Stage 1 Full Motor Mount
BFI Stage 1 Full Trans Mount
BSH Throttle Body Pipe
Deka ETX16L/M6 to SAE Adapter/ Custom Mount
Eurodyne Tune
Godspeed Intercooler and Hoses
Golf R 3 bar map sensor
HPA Core Interlock mount
K&N Filter
Magnaflow 3" Catback
N2MB WOT Box
NGK BKR7EIX Plugs @.028
Powerflex Small Dogbone Bushing (PFF85-505)
R8 Coilpacks
Spectre 3" Velocity Stack
Synapse DV
6.6 Bar Fuel Filter
Transmission Mods
Diesel Geek Six Sigma Short Shifter
FFE Positive Engagement bushings
OEM Dual Mass Flywheel
OEM Metal Shifter Cable Bracket
OEM Steel Shift Forks (1-2, 5-6)
Peloquin LSD
Southbend upgraded pressure plate and stage 3 disk
USP Stainless Clutch Line
Suspension/Tires/Wheels
BF Goodrich G-Force SportComp2 225/40R18 Tires (summer)
Bilstein PSS (B14) Coilovers
Custom Under Body Brace
Custom 3" Frame Notch
H&R 24mm Rear Sway Bar
H&R 26mm Front Sway Bar
Motorsport Hardware Wheel Stud Kit
OEM Denvers w/ Nexan Snows (winter)
OEM TT Strut mounts and bearings
Tyrolsport Deadset Kit
Unibrace XB
VMR V710 18x8.5 et45 Powdercoated "Wet Black"
Whiteline WALK KCA-316
Whiteline W0503 Front Position FLCA Bushings
Whiteline trailing Arm Bushings W0504
Brakes
ECS GEOMET Drilled/Slotted Rotors
Porsche 4 Pot Brembo's (NQSBBK)
StopTech Street 309.11070 front pads
StopTech Street 309.14560 rear pads
USP Motorsports stainless steel braided brake lines
Interior
Aesthetic Creation Dummy Stickers
LED Door Puddle Lights
NewSouth RedLine Boost Gauge
NewSouth Vent Pod
OEM Euro Switch
OEM Dash Cubby
OEM CarGo Rear Liner
OEM CarGo Rear Liner Velcro Blocks
OEM GTI Monster Mats Kit
OEM Euro Cupholder
OEM Aluminum bottle opener
OEM Aluminum glove box handle
OEM USB Button Charger
Racesang Slammer Engraved Shift Knob
Removed Visor Airbag stickers
USP Interior LEDs 6000k
Valentine V1
Audio
Alpine S-Type 6.5" Components up front
Custom Side Mount Fiberglass Sub Box
JL CleanSweep
Memphis 12" Subwoofer (Dual 4 ohm in parallel)
OEM RNS-315
Rockford Fosgate R400-4D
Rockford Fosgate R250-1D Sub Amp
SOT-976 Wire Harness
A Ton of 16 Gauge Wire
Line out Converter w/ Remote Turn on used only to turn amps on/off
Exterior/Cosmetic
Color Matched Emblem Inserts
DeAutoKey LED Reverse Light
DeAutoKey LED Rear Turn Signals
DeAutoKey License Plate LED's
Ed's Dark Red LED Tailights w/ fog
Ed's Black housing Xenon Headlights
Gloss black front and back emblems
Gloss Black bumper center section
Gloss black grill stripes
LED Mirror Puddle Lights
Morimoto Elite 5000K HID's
Nokya 2500K yellow Fog Lights
OEM Euro-Lip CW
OEM Euro Bumper
OEM Backup Cam
Plasti-dipped rear reflectors
Yellow Lamin-x Front Fogs
35% Llumar Tint all around
VAG-COM
Confirmation honk off
DRL disabled
Gauge sweep
Seatbelt chime off
Teardrop wiper
Window up/down with FOB
Other stuff I can't remember...
Want List-Will buy soon
To Do
Build a master cylinder bracket
Build a hitch
Maintenance
Oil every 5000 miles with Castrol Syntec 5W40 and OEM Filter
NGK PRF7Q @ 55177
Coils @ 44000
Fuel Filter @ 40000
Air Filter cleaned @46500
Updated timing tensioner @ 47400
Cleaned valves @ 47400
Brake fluid flush @ 74000
Trans Fluid @61890
G12 Flush @ 67000
Pictarz:
Current
Last Summer
Track
Left lane, 93 octane, full weight minus spare
Previous Car..2002 1.8t K04 GTI
2011 VW GTI 2.0T
Candy White
Sunroof Package
6MT
RCD-510
18" Detroits
Engine Mods
APR Stage 3+ (GT30)
APR Injectors
Eurodyne Tune
K&N Filter
N2MB WOT Box
R8 Coilpacks
Synapse DV
6.6 Bar Fuel Filter
Transmission Mods
Peloquin LSD
Unibrace XB
Brakes
Interior
NewSouth Vent Pod
OEM Euro Switch
OEM Dash Cubby
OEM Euro Cupholder
Valentine V1
Audio
JL CleanSweep
OEM RNS-315
Exterior/Cosmetic
OEM Euro-Lip CW
OEM Euro Bumper
OEM Backup Cam
VAG-COM
DRL disabled
Gauge sweep
Seatbelt chime off
Teardrop wiper
To Do
Build a hitch
Maintenance
NGK PRF7Q @ 55177
Coils @ 44000
Fuel Filter @ 40000
Trans Fluid @61890
G12 Flush @ 67000
Pictarz:
Current
Last Summer
Track
