ROCKnRLR
10-30-2000
Miami FL
'10 CC Sport
 Do you have an aftermarket exhaust?« »
Chances are that it is heavier than the stock exhaust and that some time has passed since your car was new. Eventaully, the rubber bushings that hold the rear muffler have given away to weight, heat, salt, and such. They have become softer, mushier and they stretch more than they used to. Your exhaust hangs lower than it did before.
Parts needed:
Go to your dealer (or online VW parts store), order:
- 1J0 253 144 (bracket)
- 1J0 253 144 J (bracket)
Both include the metal bracket and the rubber bushing.
Tools needed:
- Jack
- Jackstand
- Piece of 2x4 if ur car is too low for your jack (mine is)
- 13mm socket
- Socket wrench
- Long extension (8in)
- Knife or straight blade
Procedure:
- Jack the car by the driver side rear tire, put a jack stand in your rear axle beam.
- Support the muffler with the jack. Put a rag (so you dont stracth the muffler) on the jack cup and raise the muffler a bit.
- Use a 13mm socket with a long extension to remove the bolts holding the bracket in place.
- Note the orientation of the bracket!
- Remove old bushing from hanger. You can try to pry it out or you can cut it. I cut the older bushing because of the design of the Milltek hangers, I wasnt planning on reusing them anyway.
- Push the new bushing into the hanger.
- Put bolts in the bracket, check the exhaust tips aligment.
- Repeat procedure for the other bracket.
- Drop car.
- Collect your tools
- Paypal me $5
I did the rear bracket first, don't know if this affects the fitment. My exhaust tips are better aligned now.
Trying to bring back the old Mk4 forum, one post at a time,
Modified by ROCKnRLR at 1:19 PM 10-23-2003
Autobahn Touring, Miami, FL
Est. 1997, "ten deep!"
VWvortex Folding@home team # 116349
Get schooled!
VR6 Kid
9-1-2001
Montreal QC
2000 GTI VR6, 1999 Jeep Grand Cherokee Ltd
 Re: Do you have an aftermarket exhaust? (ROCKnRLR)« »
god right up!
see if the mods can add this ti the stickies
VR6Kid
2000SatinSilver
mahmgb
2-3-2003
Swarthmore PA
'08 IY S4 DTM
What's your Paypal address again?
ROCKnRLR
10-30-2000
Miami FL
'10 CC Sport
 Re: Do you have an aftermarket exhaust? (mahmgb)« »
Check my user profile, I use the same one for paypal,
Get schooled!
2K1Jettaz
11-30-2000
Portland
Excellent write-up. I need to redo mine and now you just made my life easier. VR6kid is right, this belongs in the MKIV FAQ
2008 Nissan Xterra Off-Road
ElectroMike
6-26-2002
Exit 160 NJ
2006 A4 2.0TQ
Two steps ahead of you baby, or 2 hangers ahead!
Bought both last month myself, did not get a change to install them yet, too lazy.
Looks like the new rubber is a little more rigit, or stiffer.
There was discreptancy in the part #'s though, they got me the wrong part first, once I get home, I'll verify the part#'s with your, since the hangers are different.
Here is what I plan to do though. Take the inside hanger, drill out the pin which holds the rubber piece, remove the rubber and replace it with one of these:
From http://www.rapidparts.com/Pages/vwc006k.html
MTLVR6
4-18-2003
Montreal QC
Sticky!
ROCKnRLR
10-30-2000
Miami FL
'10 CC Sport
 Re: Do you have an aftermarket exhaust? (ElectroMike)« »
That thing looks nothing like the ruber hangers that i replaced. I will grab the old ones from the garbage can and snap a couple fo pics.
Get schooled!
ElectroMike
6-26-2002
Exit 160 NJ
2006 A4 2.0TQ
I know it looks different and I'll need to make up the left-to-right gap inside the OEM braket but the cool thing about that Rapid Parts hanger is the chain inside, this will be one of those custom hangers once I'm done.
I already have the RP hanger at home and the two new OEM hangers, so I'll cut and make a nice new one out of the two, I'll take a pic before the install.
Stephen@VWvortex
Administrator
3-10-1999
So Cal
2003 VW Jetta GLI
 Re: Do you have an aftermarket exhaust? (VR6 Kid)« »
Quote, originally posted by VR6 Kid »
god right up!
Added to the DIY.
Vortex Media Group | Forum Rules | Forum Help System
<--- - - - - - - - - Project Jetta GLI 24v - - - - - - - - --->
"This is Call of Duty 4" - Jeremy Clarkson
ElectroMike
6-26-2002
Exit 160 NJ
2006 A4 2.0TQ
Quote, originally posted by ElectroMike »
I checked my parts, your Part#'s are 100% accurate!
Part# 1J0 253 144 (Inside hanger bracket with oval sling)
Part# 1J0 253 144 J (Outside hanger bracket with Y sling)
When they first ordered mine, they left out the "J" so that's why I remembered getting the wrong part at first.
JamieK18T
1-14-2002
Louisville, KY
01 GTI, 94 Jetta, 87 Jetta Coupe
i think aftermarket exhausts are normally lighter than the stock system, nice write up none the less.
01 GTI
01 Jetta - R.I.P.
1991 Alfa Romeo 164S
1990 Civic B16A
GolfPro
5-9-2002
Millersville PA
2009 Chevrolet Traverse
Great post Jose. I was just thinking about changing mine, now I don't have to do all the research. Expect my $5 soon .
Quote, originally posted by ROCKnRLR »
If this could only happen.
spkn^GRMN
7-24-2002
Indian Trail NC
vehicle
Great write up! I'll put this in my own DIY folder!
-Wes-
•SPKNGRMN•
There are only two reasons to be in business: Fun and profit.
And if there's no profit, it's not much fun!!
roly
2-2-2002
Sophistiphunk FL
400-63
Jose did you actually do it your self? or did you have Darvin do it
Big Turbo 337 FS
v3.37 is here.
BLIM
screw. nut. bolt.
PAGPARTS for your car
ROCKnRLR
10-30-2000
Miami FL
'10 CC Sport
 Re: Do you have an aftermarket exhaust? (roly)« »
I did it!
Get schooled!
kroonspeed
8-17-2003
Bridgewater nj
MKIV Jetter Vr
i dunno about everyone else, but i'm damn sure my aftermarket exhaust weighs alot less then the stocker suitcase full of bricks.
Nineteen Ninety-Nine Jetta VR6
Will web/graphic design for a garage to work on my car.
aim:Kroonoverdrive
Jenkins
4-17-2001
Singapore
2000 Veedub Bora
 Re: Do you have an aftermarket exhaust? (ElectroMike) »« »
do you have the picture of the new rubber hanger, bolted on the car ? Do you need 2 parts, or just one of them?
a before and after pic will be great!
Zenyee.com © ::: VW Audi Singapore
ElectroMike
6-26-2002
Exit 160 NJ
2006 A4 2.0TQ
 Re: Do you have an aftermarket exhaust? (Jenkins) »« »
I never made the custom hanger I mentioned here, still have the parts, just never got to it, ended up doing two other things though.
For the rear slingshot hanger, once I centered the tips then took a small rubber washer, wrapped it around the metal pin (between the rubber hanger and the mushroom end of the pin) then put a tie wrap around it, that prevents it from moving side to side.
To bring the tips up, I took a SS clamp and tightened it around the inside rubber hanger, tightened the clamp until the tips were high enough, this prevents the rubber hanger from stretching when the exhaust heats up and expands at the bends.
There was a post a while back with pics on this (not my pics).
SoFlaJetta
11-21-2002
Tequesta/Gainesville FL
06 Touareg Individual
 Re: (ROCKnRLR) »« »
sadly no
Der Kommissar
1-9-2003
Beast Coast
2006 Golf VE, 2000 Sloop
 Re: Do you have an aftermarket exhaust? (mahmgb) »« »
Good stuff.
liliillililiillililil
kommissar
8 year olds Dude.
DAUQS PEED SLLAB
Habitual Linestepper
3-10-2003
Fletch F.Fletch
Children in heat
 Re: Do you have an aftermarket exhaust? (Der Kommissar) »« »
actually a cheaper way to support the rear hanger (not the one at the very back) but by the torsion beam is to take 2 decent sized zip ties, have someone hold the tips where you want them to be and then zip tie and hanger nice and tight.
The Lesion of Doom
If were all God's children, why is Jesus so special?.
Let's face it: there are few things in this world more stupid than dancing. Except break dancing, which pirates and lumber jacks would agree is awesome. Other than that, dancing makes me envy cripples. - maddox
wolfsburg023
10-19-2007
nj
03 jetta 1.8T
 Re: Do you have an aftermarket exhaust? (Habitual Linestepper) »« »
wouldn't the zip ties just melt
looking to buy-
fogs / 4mo front lip / reflex silver trunk lid
myTurboGTiMKiV
8-22-2008
Cypress Ca
2003 Volkswagen GTI MKiV
 Re: Do you have an aftermarket exhaust? (ROCKnRLR) »« »
Bumping an old post.
about how much do the brackets cost ??
For Sale
15mm Spacers: http://forums.vwvortex.com/zerothread?id=4496518
1.8T Engine Cover: http://forums.vwvortex.com/zerothread?id=4496626
Stock Headlights: http://forums.vwvortex.com/zerothread?id=4498235
samc
1-15-2002
Brooklyn NY
 Re: Do you have an aftermarket exhaust? (myTurboGTiMKiV) »« »
Exhaust Hanger
Rubber hanger for rear of rear muffler, comes with bracket
Brand: Genuine Volkswagen Audi - Corporate Logo
ES#:259167
Mfg#: 1J0253144J
Qty:
Ships in 1-3 days Ships in 1-3 days
$15.36
OE Aftermarket Exhaust Hanger Exhaust Hanger
Rubber hanger for front of rear muffler, comes with bracket
Brand:
OE Aftermarket
ES#:523247
Mfg#: 1J0253144
Qty:
In Stock In Stock
$5.79
VW COOLWATER CLUB 'ing it
Rocking a 2006 Honda Pilot EX-L.
Oly_Golf
5-20-2006
Olympia WA
2001 Volkswagen Golf 4 Door 1.8T AT
Not sure where he got the good deal from above, but mine cost $42 including shipping from http://www.1stvwparts.com and they usually have decent prices.
I have a stock 2001 Golf 1.8T with 110K miles on it. Stock exhaust of course.
Glad I found this thread!!!!! Man, I only took it for a test drive but it feels so much better. Rear end is stiffer. Less bounce return on annoying parking lot speed bumps. Slightly better hard cornering (exhaust end is not "swinging" left so much when I take a right)
If you are at a point and doing for instance LCA TT bushing or even a rear sway bar, include this while you are at it!!
Took only 30 mins, tops. As the OP stated, remember the orientation of the original hangers and cut out the old ones, makes it easier. The old hangers were probably an inch lower than the new ones. I had to jack it up quite a bit to get the new ones in. They felt MUCH tighter!!!
Also, if you still have stock exhaust, and it is heavier than those with aftermarkets above, then this would make even more sense for stock folks to replace it!
jimothy cricket
7-9-2008
tinley park IL
tiptronic uniblack hussy on Strahls
 Re: Do you have an aftermarket exhaust? (VR6 Kid) »« »
yyuuuuuppp!
2 KUHMO 205/45/17 AST tires for sale. Pristine condition rode for 3K miles $145 shipped ! :http://forums.vwvortex.com/zerothread?id=4719125
