Finally ... a sound clip of timing chain noise | « » 3:23 PM 11-26-2003 | |
The topic of timing chain noise and the fear of chain breakage comes up frequently enough that I thought it would be valuable to post a sound clip of my timing chain noise. The clip starts out with a hold at 1200 RPMs (with a short blip to 1500RPM), then a slow rev up to 2500RPMs and back down to idle, then a quick rev to 1500RPMs and back down to idle and finally, another hold at 1200RPMs. The timing chain noise (i.e., chain slap) is audible in the 1200RPM holds (it's almost rhythmic at times), but disappears as the revs go above that.FYI, the engine is in a '99.5 Jetta (MKIV) and has 145k miles on it. Everything on the engine is original except for the MAF (replaced 15k miles ago) and intake manifold shifter rod (replaced 10k miles ago). The noise has been present for at least the last 40k miles and doesn't seem to have gotten any worse. The clip was recorded using a Mini DV digital camcorder sitting directly below the tranny bell housing. Click here to hear timing chain noise! (1.4Mb) UPDATE (1/5/04) ...................
A bunch of us replaced my timing chains this weekend (1/3/04 and 1/4/04 - 147.5k miles on the original parts) since I couldn't stand the rattling noise anymore and didn't want to risk destroying the engine any more than I already had. Well, we found out what was rattling. The upper guide rail was snapped in half and a 1"x2" piece from the middle of it had slid down and wedged itself between the upper chain, the inner intermediate sprocket and the block. The piece rattled whenever the engine was running at it's harmonic frequency, which appears to be somewhere between 1000 and 1200 RPMs. I'll post pics as soon as the whole job is complete - we still need to put the tranny back in and reassemble the engine bay. Based on my noise and what we found, I'm confident when I say that if you hear a rattle then some part of the timing chain setup is either loose or broken. That being said, I wouldn't ignore timing chain noise too long as it means that there is the POTENTIAL for something bad to happen. Not that it definitely will, just that it might. I'm sure I could have driven for quite a while longer with the guide rail chunk rattling behind the intermediate sprocket, but I'm glad that the broken piece is out of there and I know that it can't cause a problem in the future. UPDATE (1/8/04) ...................
The new timing chains are finally in and the car is completely back together. It started up without a hitch the first time and is COMPLETELY SILENT. Not one hint of timing chain noise!!! I'll be posting a sound clip of the new chains for comparison with the clip of the chain (actually upper guide) rattle as soon as I can get my hands on my dad's mini DV cam. UPDATE (2/28/04) ...................
I finally posted the DIY for replacing timing chain parts. Here is the link ... Replacing timing chains, tensioners and guides on a 12v VR6 I also posted pics of the old and new timing chain parts to illustrate how much wear occurred in 150k miles. You can find the pics in the following thread ...
Comparison of new and old/worn/failed timing chain parts UPDATE (8/20/06) ...................
Here's an even better video clip of bad timing chain noise - http://www.agthompsonfamily.co...2.wmv. Thanks dankvwguy!
Modified by VgRt6 at 12:51 PM 8-20-2006
GaryNow: '99.5 Jetta GLS VR6 (281,000 miles and counting! ) - Stupid CEL Then: '90 Passat GL 16v - (RIP - i.e., Rest in Pain!!! in a junkyard somewhere you LEMON POS - still loved her though ) * The Official VgRt6 MKIV/VR6 DIY Thread Master List *
BlindingWhiteGLI
8-8-2002
Vancouver WA
'09 Si
Re: Finally ... a sound clip of timing chain noise (VgRt6) | « » 4:10 PM 11-26-2003 | |
Finally, I know what to listen for/dread.Thanks.
myvr6gti
9-4-2003
Anywhere you want me to be WA
1997 VR6 GTI
| « » 4:11 PM 11-26-2003 | |
hold on a sec...my 93 rado motor makes the same sound and i have never been able to figure out what it was. now that i have heard that is sounds like my problem...it makes the noise till i get to about 3000 RPM's.. then it goes away...how did you fix it?
1975 Chevy Vega GT (Sold) 1992 VR6 GTI (Sold) 1989 3.0L VR6 GTI (Sold) 1982 1.8T Jetta Coupe (Sold) 1997 GTI VR6 (Own)
vr6golf.com
4-1-2003
Over here in NY
Re: (myvr6gti) | « » 4:27 PM 11-26-2003 | |
you take your trans out and replace these parts: http://www.vr6golf.com/forum/topic.asp?TOPIC_ID=81
Matt We  Technik Motorsport
corpsedub
8-3-2001
san francisco
06 330i,04 COBRA,01 Eurovan GLS,00 GTi VR6,92 F-150 300 inliner
Re: Finally ... a sound clip of timing chain noise (VgRt6) | « » 4:44 PM 11-26-2003 | |
nice job on the sound byte. sucks that it's happnening though. sometimes i wigout and think my chains are rattleing like that..but then i disconnect the intake ****er rod and the sound dissapears(cause that thing clanks around). they sound pretty loose there. thought about taking the plunge and getting it taken care of?edit:with 111,000 on mine im fearing that one morning im gonna fire her up and..clanalangalang it will go.
Modified by corpsedub at 1:45 PM 11-26-2003
Re: Finally ... a sound clip of timing chain noise (corpsedub) | « » 4:48 PM 11-26-2003 | |
Yes and no. The car has 145k miles on it so I know it will have to be done fairly soon. It's been making the noise for at least the last 40k miles though and hasn't gotten any worse, so I don't think it's urgent. I plan on replacing everything when my clutch finally gives up. Unfortuntely, it seems like it will never die. I guess I'll just have to wait.
Ed52
5-21-2001
Toronto, ON
I've been around since the time Old School was New School
Re: Finally ... a sound clip of timing chain noise (VgRt6) | « » 4:56 PM 11-26-2003 | |
Thanks for the valuable info
ALMOST RACING <Phil> 176 Bullock #15, Markham, 905 294 9055 For your VW and Audi service needs Home of the 600+ hp 1.8T AWD Audi project
DasoGTI
11-21-2001
Montreal QC
Re: Finally ... a sound clip of timing chain noise (Ed52) | « » 5:27 PM 11-26-2003 | |
mk4? sounds more like your intake shifter rod than your chain, but I might be mistaken.
Car by L-Sport.Need to organise a trip to Montreal Canada? Fun In Montreal Party organisation for out of town people! Come experience the night life!
Re: Finally ... a sound clip of timing chain noise (DasoGTI) | « » 5:34 PM 11-26-2003 | |
It's definitely not the intake shifter rod. I replaced that recently. Anyway, it usually rattles at higher RPMs, like between 2500 and 4000. The chain noise in the clip is loudest just below the bell housing, right near where the lower chain is. I'm 99.9% that's it's at least one of the chains, probably the lower one.
DasoGTI
11-21-2001
Montreal QC
Re: Finally ... a sound clip of timing chain noise (VgRt6) | « » 5:38 PM 11-26-2003 | |
| Quote, originally posted by VgRt6 » | | It's definitely not the intake shifter rod. I replaced that recently. Anyway, it usually rattles at higher RPMs, like between 2500 and 4000. The chain noise in the clip is loudest just below the bell housing, right near where the lower chain is. I'm 99.9% that's it's at least one of the chains, probably the lower one. |
Cool! I have that exact same sound. I always thought it was my shifter rod again. I'll verify where my sound comes from in the engine bay.
Re: Finally ... a sound clip of timing chain noise (DasoGTI) | « » 5:44 PM 11-26-2003 | |
| Quote, originally posted by DasoGTI » | Cool! I have that exact same sound. I always thought it was my shifter rod again. I'll verify where my sound comes from in the engine bay. |
I don't know if I'd be happy that it's not the shifter rod. Replacing the shifter rod or even replacing the upper intake manifold and shifter rod is cheaper and/or less work than replacing chains. EDIT: Even though I'm virtually certain it's not the shifter rod, I'll double check tomorrow. I need to change my oil filter, so the hood will already be up.
Modified by VgRt6 at 5:47 PM 11-26-2003
skyliner77
12-8-2002
undadac la
Re: Finally ... a sound clip of timing chain noise (VgRt6) | « » 6:56 PM 11-26-2003 | |
too cool! thanks for posting that. bet we see alot of links to that in the future! Makes me glad mine were done at 102,XXX, and my motor sounds nothing like that. always wondered though cause as you know the vr is a noisy motor
Audi Master Guild Technician'74 Super Beetle RIP '89 GLI RIP '95 GTI Blown then Blown up '97 GTI Sold, and regreting it!
DasoGTI
11-21-2001
Montreal QC
Re: Finally ... a sound clip of timing chain noise (VgRt6) | « » 7:05 PM 11-26-2003 | |
| Quote, originally posted by VgRt6 » | I don't know if I'd be happy that it's not the shifter rod. Replacing the shifter rod or even replacing the upper intake manifold and shifter rod is cheaper and/or less work than replacing chains. |
well, I highly doubt my chains are up for change... my engine's only got 52 000 KM, meaning 32 000 miles about.... Regular oil changes with synthetic oil...
Re: Finally ... a sound clip of timing chain noise (DasoGTI) | « » 7:25 PM 11-26-2003 | |
I agree. Yours should be fine at that mileage.
T99inFL
8-4-1999
Sunrise Florida
Re: Finally ... a sound clip of timing chain noise (VgRt6) | « » 8:04 PM 11-26-2003 | |
VgRT6: Just curious, what type of engine oil have you used in this car since birth & what was the mileage interval between changes? I hope this is not what I must expect when I get to 140k.
T99inFL-> 2003 Gray Jetta 1.8T 1999.5 Silver Jetta VR6....rot in hell you money pit! "0-60 in 30 seconds can still earn a speeding ticket."
Re: Finally ... a sound clip of timing chain noise (T99inFL) | « » 8:34 PM 11-26-2003 | |
I used dino up to 100k, either 5w-30 or whatever the dealer put in it. Since then I've used synthetic, Mobil 1 0w-40. Oil and filter changes were done every 10k miles.While my timing chain noise may sound bad, I believe it's normal for a high mileage VR. It's inevitable even with regular, frequent synthetic oil changes. Also, it doesn't necessarily mean that there's DEFINITELY a problem, just that there is POTENTIALLY a problem. Honestly, while I've spent some time thinking about the chain noise, I'm not that concerned about an imminent failure. There are VR6s that have gone well past my mileage with noise for over 100k of it. It's not a bad idea to replace them if the chance arises (like when a clutch goes), but if it were something that had a high probability of failure, I'm sure VW would have recommended a mileage for replacing them. One more thing, even though the chain noise is audible in the clip, I don't hear it unless the windows are down and the car is up against a wall, like at a drive-thru. With the windows up, all I hear is the sweet sound of the VR.
Daemon42
2-9-2001
Lakewood CO
2004 R32 Blue
Re: Finally ... a sound clip of timing chain noise (VgRt6) | « » 11:37 PM 11-26-2003 | |
Thing is, if the tensioners ever fail (folks seem to like to let em wear all the way through ) and it takes out your chain, then you *will* have a major problem, in the form of piston to valve contact. My thought is that you shouldn't be hearing chain slap at all, because the VR6 does have a chain tensioner. Thanks for the recording. That is useful. ian
Re: Finally ... a sound clip of timing chain noise (Daemon42) | « » 11:55 PM 11-26-2003 | |
I know about the VR6 being an interference engine. I guess I'm willing to take the chance for a while longer.I find it interesting that the chain noise only occurs in the narrow RPM range that it does. The tensioners should be keeping the chain tight, but dont seem to be doing a good job in the 1000-1200 RPM range. I wonder if this is due to the design of the VR6 or the chain system. Maybe there's not enough oil pressure to keep the upper tensioner tight when the RPMS are low. It's hard to tell in the clip, but at higher RPMs the chain noise is not just covered up by the louder engine noise, it actually seems to be gone. I'd be more worried than I am if the noise was presnt over a wider RPM range, especially one that the engine spendsa lot of time in. It spends very little time in the 1000-1200 RPM range. With my bad luck, the chain will probably snap or jump while the engine is revving through this range. My guess is that I won't wait that mucch longer before doing the chains. When I finally do, I'm going to post pics of the setup to show how worn a setup this noisy really is. If I'm feeling ambitious, I may also put some sort or DIY post or video together for doing the chain job.
T99inFL
8-4-1999
Sunrise Florida
Re: Finally ... a sound clip of timing chain noise (VgRt6) | « » 12:09 AM 11-27-2003 | |
VgRt6: Thanks. I've been using dino since new, but I change every 5k. I know the recommended interval is 10k but I felt uncomfortable with the length and opted for 5k intervals. I recall that recently ROCKnRLR's timing chain took out his crankshaft ring gear and he had the motor replaced at 69k. http://forums.vwvortex.com/zerothread?id=1038270 It will be interesting to see how my motor holds up with 55k and counting.
Re: Finally ... a sound clip of timing chain noise (T99inFL) | « » 12:36 AM 11-27-2003 | |
I remember reading about Jose's mishap. I think his situation is not the norm - 69k miles seems awfully early for the chain to break if it's flaw-free. VW's belts last longer than that - their chains certainly should.I'm sure your motor will be fine. IM f1forkvr6 if you want some more positive feedback about timing chain noise. He's got over 200k miles on his Passat VR6 and has had chain noise for at least half of the miles. It's interesting that despite the large number of people who say they have chain noise, I'm only aware of TWO people who've had their chains snap. One is Jose and I think there were extenuating circumstances with his failure. The other is 88GTiVR6. His failed at around 80k miles and bent three valves (http://bellsouthpwp.net/a/r/ar...n.htm). His mileage also seems low for a failure.
Re: Finally ... a sound clip of timing chain noise (T99inFL) | « » 12:50 AM 11-27-2003 | |
Here's the link for a thread I started back in May asking how many miles people currently had on their chains or how many they had when they were replaced. There are some interesting responses (including someone with 250k on their original setup! )http://forums.vwvortex.com/zerothread?id=849574
James 93SLC
9-27-2000
Northeast OH
93 Corrado SLC & 02 Passat Variant V6 4Motion
Re: Finally ... a sound clip of timing chain noise (VgRt6) | « » 10:24 AM 11-27-2003 | |
Perfect Gary!! That is an awesome capture of the noise.
James 93 SLC ...Turn2, TT Exhaust, Koni, TT Chip The 12V VR6 headgasket/timing chain/cooling system parts list Replacing the Corrado hood release + part numbers
Re: Finally ... a sound clip of timing chain noise (James 93SLC) | « » 10:38 AM 11-27-2003 | |
Thanks. Now fix my car for me.
T99inFL
8-4-1999
Sunrise Florida
Re: Finally ... a sound clip of timing chain noise | « » 11:22 AM 11-27-2003 | |
I have been looking through whatever timing chain posts that I see. My conclusion is that the tensioner used in the mark IV is not prone to the wear which plagued prior models.
vr6golf.com
4-1-2003
Over here in NY
Re: Finally ... a sound clip of timing chain noise (T99inFL) | « » 11:41 AM 11-27-2003 | |
Its not the tentioner that fails in these engines, the guides get worn excessively and the tentioner ends up fully extended trying to make up for the tracks the chains are making in the guides.The A4's have the same issue, just doesn't seem to happen as often. you can use all the A4 parts in your A3-B4 as well if that eases your mind. You just need to make sure you swap out the cam & intermediate gears at the same time. All in all, a 5-600 dollar repair is to be expected after 100-150 KMI! Most cars are ready for the crusher by then from other manufacturers. Good informational post. I posted a link to all the PN's and illustration earlier... And if you hear chains slapping, you shouldn't ignore it. Once the chains wear through the composite plastic on the guide, they then start wearing away at the metal backer and fill your oil and with filings that get embedded in your bearing halves. If they are noisy, the repair bill for putting it off is much more than taking care of your car today. The valves & guides for parts alone in a VR6 nearly meet the cost of the entire timing chain job... If you happen to crack a piston, then you can basically junk the motor and buy a crate engine. My point is, just because its been running like that for 30k doesn't mean you aren't destroying it every time you run it.
Modified by vr6golf.com at 8:43 AM 11-27-2003
Re: Finally ... a sound clip of timing chain noise (vr6golf.com) | « » 1:05 PM 11-27-2003 | |
Every time I read or post something in this thread, I get a little more worried about my chains. Damn, why did I start this thing! Just kidding - it's good to discuss this topic. I'll probably end up doing it sooner than later, if only for peace of mind. Maybe we'll have another big storm here this winter and my car will be snowed in for days. That would give me plenty of time to do the repair.
Modified by VgRt6 at 1:26 PM 11-27-2003
DrTacoElf
7-14-2003
Beverly Hills CA
Re: Finally ... a sound clip of timing chain noise (VgRt6) | « » 1:18 PM 11-27-2003 | |
I think i might have this also. Although my car only has 30K I have that sound, or close to it around 1200rpms. Also at 1200 rpms i have a pretty hard shaking coming from the front of the car. Both of these happen in gear and in neutral . Now to comlicate things more i'm going to get a GIAC chip installed on tuesday -- would this totally void my warranty? or would they even be able to detect it and how do i go about talking to the dealer about noisy timing chains, and warraty repair without getting ripped off with diagnostic fees?
vr6golf.com
4-1-2003
Over here in NY
Re: Finally ... a sound clip of timing chain noise (DrTacoElf) | « » 1:24 PM 11-27-2003 | |
The dealer can physically inspect & detect the GIAC on A4 chassis, the ECU has to come apart for neuspeed at least, and I assume GIAC too. If you want my advice, never add a mod to a vehicle thats not running right, Its just an ill idea. Fix the car first, get it running properly and then add your modifications... Respect your ride.
Re: Finally ... a sound clip of timing chain noise (DrTacoElf) | « » 1:26 PM 11-27-2003 | |
I have the same engine shake/shudder around 1000-1200 RPMs. More than likely every VR6 has the same thing.I find it interesting that the shake occurs at virtually the same RPMs as the chain noise. Coincidence? Or does the shake contribute to the chain making noise? Very, very interesting.
DrTacoElf
7-14-2003
Beverly Hills CA
Re: Finally ... a sound clip of timing chain noise (vr6golf.com) | « » 1:33 PM 11-27-2003 | |
yeah i never thought that i had timing chain problems until i read this thread and it matched the strange noise/shaking i have For the chip what if get the following done? If you wish to have a stock chip module assemnled(allows stock software to be plugged back in for dealer service,warranty etc...)that is an additional $50. Would that be undetectable?
Modified by DrTacoElf at 6:34 PM 11-27-2003
vr6golf.com
4-1-2003
Over here in NY
Re: Finally ... a sound clip of timing chain noise (DrTacoElf) | « » 2:14 PM 11-27-2003 | |
On another note, try depressing the clutch... If your unknown noise goes away, its a TB and not to worry.. the ratlee bit sometimes.
DrTacoElf
7-14-2003
Beverly Hills CA
Re: Finally ... a sound clip of timing chain noise (vr6golf.com) | « » 2:18 PM 11-27-2003 | |
TB?
Re: Finally ... a sound clip of timing chain noise (DrTacoElf) | « » 2:25 PM 11-27-2003 | |
Throwout bearing. If the noise goes away when you push the clutch in, then it's the bearing and not your chains.I wish this were the case with my car. Mine make the noise with the clutch in and out.
fordhack
7-10-2002
Fuquay Varina NC
89 Helios GLI/88 Jetta coupe/03 jetta gl(wifes daily)
Re: Finally ... a sound clip of timing chain noise (VgRt6) | « » 3:32 PM 11-27-2003 | |
my chains were making that noise and then my lower timing chain broke. I found the guide rails in about 9000000 pieces in the oil pan. do not let the noise go unchecked. you will regret it if a chain goes.
-Gerich my shop sucks
Re: Finally ... a sound clip of timing chain noise (fordhack) | « » 3:51 PM 11-27-2003 | |
| Quote, originally posted by fordhack » | | my chains were making that noise and then my lower timing chain broke. I found the guide rails in about 9000000 pieces in the oil pan. do not let the noise go unchecked. you will regret it if a chain goes. |
Thanks for ruining my Thanksgiving holiday. J/K. I know it's serious. I'm going to see if I can scrape some $$$ together and reserve James' time (expect an email) and see if I can get this taken care of. Stupid timing chains.
