The Official VgRt6 MKIV/VR6 DIY Thread Master List | « » 7:54 PM 12-4-2003 | |
I'm posting a master list of links to the DIYs that I create so those that find them useful can subscribe to the list and be updated whenever I post a new one.These DIYs are the result of work that I have performed on my 1999.5 MKIV Jetta GLS VR6. They are all specific to either the MKIV Jetta and/or the VR6 engine, but should still be useful to owners of other MKs and/or engines. I will be updating this list as soon as I perform another job/repair on my car and make a DIY for the procedure. I will also be listing DIYs that are in the works and others that are on the horizon. Feel free to post DIYs that you would like to see put together for your own or other's benefit. If I happen to do the job, or can write the procedure up quickly, I'll put a DIY together. UPDATE: I've also decided to post the links for Bentley and VAG-COM procedures that I've posted on the Vortex. This way all of the links are in one convenient place. Gary VgRt6 DIY PROCEDURES ...
* Removing interior parts (e-brake & center console, armrest, glovebox, ashtrays) - http://forums.vwvortex.com/zerothread?id=958556 * Removing interior parts II (dash trim, brake-light switch, radio, cupholder, radio/ HVAC cage) - http://forums.vwvortex.com/zerothread?id=967146 * Removing front door parts (door panel, door unlock handle and sideview mirror) - http://forums.vwvortex.com/zerothread?id=961163 * Removing rear door parts (door panel, door unlock handle and rusty triangle window insert) - http://forums.vwvortex.com/zerothread?id=960833 * Replacing the trunk microswitch - http://forums.vwvortex.com/zerothread?id=945378 * Replacing the dust pollen filter (also know as the cabin filter) - http://forums.vwvortex.com/zerothread?id=968305 * Replacing and/or lubricating front sway bar bushings - http://forums.vwvortex.com/zerothread?id=988261 * Replacing oxygen sensors - http://forums.vwvortex.com/zerothread?id=990129 * Replacing the front door window regulator clips and/or door lock module - http://forums.vwvortex.com/zerothread?id=1015107 * Removing and cleaning the throttle body (throttle valve control module) - http://forums.vwvortex.com/zerothread?id=1116399 * Removing a VR6 serpentine belt tensioner and lubricating the tensioner pulley bearing - http://forums.vwvortex.com/zerothread?id=1138497 * Replacing the main water pump on a MKIV 12v VR6 - http://forums.vwvortex.com/zerothread?id=1154344 * Installing a new brake light switch (without breaking it!) - http://forums.vwvortex.com/zerothread?id=1158315 * Replacing timing chains, tensioners and guides on a 12v VR6 - http://forums.vwvortex.com/zerothread?id=1264409 * Performing a compression test on a MKIV 12v VR6 - http://forums.vwvortex.com/zerothread?id=1510186 * Replacing the shifter rod on a MKIV 12v VR6 - http://forums.vwvortex.com/zerothread?id=1976181 * Replacing fuel injectors on a MKIV 12v VR6 - http://forums.vwvortex.com/zerothread?id=2975414 * Fixing a leaking MKIV windshield washer fluid reservoir pump - http://forums.vwvortex.com/zerothread?id=3018135 * Replacing and adjusting e-brake cables on a MKIV car - http://forums.vwvortex.com/zerothread?id=3055220 * Removing the windshield cowl and fixing noisy / squeaky wipers on a MKIV car - http://forums.vwvortex.com/zerothread?id=4497880 BENTLEY PROCEDURES ...
* Testing a 12v VR6 coilpack - http://forums.vwvortex.com/zerothread?id=793322 VAG-COM PROCEDURES ...
* Testing the MAF, O2 sensors and catalytic converter on a MKIV - http://forums.vwvortex.com/zerothread?id=1265064 * Generating Readiness Codes on a MKIV 12v VR6 - http://www.agthompsonfamily.com/vw/MKIV-VR6-readiness-codes.doc * Adjusting Displayed Fuel Gauge Level - http://forums.vwvortex.com/zerothread?id=3208286 MISCELLANEOUS
* Source for good quality triple square (serrated) bits - http://forums.vwvortex.com/zerothread?id=1208194 * Proof that MKIV VR6 and 2.0 MAF sensors are identical - http://forums.vwvortex.com/zerothread?id=773176 * List of fuses for MKIV vehicles - http://forums.vwvortex.com/zerothread?id=951306 * Sound clip of 12v VR6 timing chain noise - http://forums.vwvortex.com/zerothread?id=1127339 * Pics of my worn/broken timing chain parts (at 147k miles) - http://forums.vwvortex.com/zerothread?id=1264688 * MKIV door locks explained - why you're having problems!!! - http://forums.vwvortex.com/zerothread?id=1542461 * Have a water leak? - MKIV sunroof drain locations - http://forums.vwvortex.com/zerothread?id=1909676 * Have less than 80k miles (100k miles for some cars) and need a new catalytic converter or O2 sensor (plus other emissions components? - http://forums.vwvortex.com/zerothread?id=2011376 * Secondary / Auxillary / After-run water pump - why it stops working and what you can do to fix it - http://forums.vwvortex.com/zerothread?id=3038022 * Free and easy fix for ABS code 01276 - http://forums.vwvortex.com/zerothread?id=3986490 DIYs COMING EVENTUALLY (when I finally do it) ...
* Removing the transmission and replacing the clutch - FaelinGL beat me to it - http://forums.vwvortex.com/zerothread?id=2703042 * Swapping the ICM on a VR6 coilpack - completed and have pics, just need to do the write-up - IM me if you need info * Replacing the ignition lock cylinder and ignition switch - completed and have pics, just need to do the write-up - IM me if you need info * B5 Passat air filter replacement - completed and have pics, just need to do the write-up - IM me if you need info * Replacing control arms, ball joints, tie rods and axles - not gonna happen * Checking hydraulic lifters on a 12v VR6 * Replacing hydraulic lifters and cams on a 12v VR6
Modified by VgRt6 at 12:41 PM 9-9-2009
GaryNow: '99.5 Jetta GLS VR6 (281,000 miles and counting! ) - Stupid CEL Then: '90 Passat GL 16v - (RIP - i.e., Rest in Pain!!! in a junkyard somewhere you LEMON POS - still loved her though ) * The Official VgRt6 MKIV/VR6 DIY Thread Master List *
John Edward
11-30-2001
Richmond Virginia
2002 Jetta vr6 5 speed GLX wagon H & R Cup kit HP EVO's
Re: The Official VgRt6 MKIV/VR6 DIY Thread Master List (VgRt6) | « » 8:11 PM 12-4-2003 | |
Sweet!
2002 Jetta GLX vr6 5 speed wagon Buttlick Green H&R Cup Kit (bent) Now with Koni adjustable HP EVO's 18x8 235-40's front. 18x9 265-35's rear. OEMhids!! ECS tuning 13.1 front 12.1 rear rotors w/factory calipers http://www.johngerber.com
DORKEE_BORA_VR6
8-17-2003
bay area CA
00 jetta gls vr6
Re: The Official VgRt6 MKIV/VR6 DIY Thread Master List (VgRt6) | « » 9:29 PM 12-4-2003 | |
are you getting paid for this? because i think you deserve it!
i love ube cake!| Quote, originally posted by Stephen@VWvortex » | | Post Deletion Notification Your post in thread Best 4x4 look.. has been deleted. |
| Quote, originally posted by DORKEE_BORA_VR6 » | that's probably the best thing to do. |
Re: The Official VgRt6 MKIV/VR6 DIY Thread Master List (DORKEE_BORA_VR6) | « » 9:42 PM 12-4-2003 | |
My wife thinks I should. As long as it helps fellow Vortexers out, then it's worth all the work.
ultimate steve
4-17-2003
long island NY
GIT
Re: The Official VgRt6 MKIV/VR6 DIY Thread Master List (VgRt6) | « » 9:45 PM 12-4-2003 | |
| Quote, originally posted by VgRt6 » | My wife thinks I should. As long as it helps fellow Vortexers out, then it's worth all the work. |
awwwww
| Quote, originally posted by my sister » | if the tires are rotating when your driving, then why do they have to rotate the tires?
DORKEE_BORA_VR6
8-17-2003
bay area CA
00 jetta gls vr6
Re: The Official VgRt6 MKIV/VR6 DIY Thread Master List (VgRt6) | « » 9:52 PM 12-4-2003 | |
merry christmas! to: vortexers from: gary
Sully NJ 1.8
6-29-2003
Over the Hills and Far Away
03 GTi 1.8t
Re: The Official VgRt6 MKIV/VR6 DIY Thread Master List (DORKEE_BORA_VR6) | « » 9:53 PM 12-4-2003 | |
bump for a good guy
Brian R32 Steering wheels for $320 shipped  Official Vendor Feedback Thread 195whp, 254wtq....on the k03
Re: The Official VgRt6 MKIV/VR6 DIY Thread Master List (DORKEE_BORA_VR6) | « » 9:55 PM 12-4-2003 | |
| Quote, originally posted by DORKEE_BORA_VR6 » | merry christmas! to: vortexers from: gary |
'Tis the season!
Re: The Official VgRt6 MKIV/VR6 DIY Thread Master List (VgRt6) | « » 10:01 AM 12-5-2003 | |
Bump for the day crowd.
vdubinn
9-17-2002
MoNtErEy PaRk/AlHaMbRa, Ca
Re: The Official VgRt6 MKIV/VR6 DIY Thread Master List (VgRt6) | « » 10:08 AM 12-5-2003 | |
man this guy deserves an applause....great info
*****UNDER CONSTRUCTION*****http://community.webshots.com/user/vdubinn
vivagarcia
2-19-2001
AZ
Re: The Official VgRt6 MKIV/VR6 DIY Thread Master List (vdubinn) | « » 10:53 AM 12-5-2003 | |
I'll say it again. You're the man VgRt6!
Re: The Official VgRt6 MKIV/VR6 DIY Thread Master List (vivagarcia) | « » 4:03 PM 12-5-2003 | |
Thanks. Bump.
consyce
1-29-2001
Lowell MA
2008 TR R32 #805
Re: The Official VgRt6 MKIV/VR6 DIY Thread Master List (VgRt6) | « » 4:54 PM 12-5-2003 | |
thanks VGRT6, i think the vortex should give u your own DIY thread stickied.
2008 TR .:R32VWVortex Feedback My EBay Feedback My Paypal Verification
NeoJetta
8-3-2001
NY/NJ
2007 Audi A3 2.0T DSG
Re: The Official VgRt6 MKIV/VR6 DIY Thread Master List (consyce) | « » 5:03 PM 12-5-2003 | |
You, my friend, deserve lots and lots of . Thanks!
"Outside in the cold distance, the wild cat did growl..." -BD
MacDalund
6-30-2003
Saint Paul MN
2000 Jetta VR6
Re: The Official VgRt6 MKIV/VR6 DIY Thread Master List (NeoJetta) | « » 7:30 PM 12-5-2003 | |
bumpitty-bump! You're one of my favorite vortexers!
Rich2000 Jetta VR6 http://www.volksport.org
Re: The Official VgRt6 MKIV/VR6 DIY Thread Master List (MacDalund) | « » 10:34 AM 12-6-2003 | |
Thanks. Snowy weekend bump.
Vee Dub Nut
10-21-2002
San Antonio TX
Re: The Official VgRt6 MKIV/VR6 DIY Thread Master List (VgRt6) | « » 12:05 PM 12-6-2003 | |
Just read the tensioner diy.. Awsome work.. going to tackle that when I go home for christmas!Thanks
00 Cosmic Green VW GTi VR6 67 Porsche Guards Red VW Beetle 1915cc 67 Champagne Metalflake Fiberglass Buggy" I dont know who invented speed bumps, but im pretty sure they wernt german."
ElectroMike
6-26-2002
Exit 160 NJ
2006 A4 2.0TQ
Re: The Official VgRt6 MKIV/VR6 DIY Thread Master List (VgRt6) | « » 12:44 PM 12-6-2003 | |
Gary, thanks for sharing all the hard work you documented with us and throwing all the DYI's into one Master List! If there was a Vortex Man of the Year Award you my friend, would be clearly the winner of it!
Re: The Official VgRt6 MKIV/VR6 DIY Thread Master List (ElectroMike) | « » 1:07 PM 12-6-2003 | |
Thanks Mike. It's no big deal. You know about all the free time I have.
cdn20VALVE
1-23-2002
Brampton ON
cars and sleds
Re: The Official VgRt6 MKIV/VR6 DIY Thread Master List (VgRt6) | « » 1:39 PM 12-6-2003 | |
good info!
1993 MKI Cabby 16V 1998 Audi A4 Tdi http://forums.vwvortex.com/zerothread?id=4495286 2003 Audi A4 Avant Frankenturbo'd http://forums.vwvortex.com/zerothread?id=4655447 2000 Polaris XC SP 500
BCDS2003T
9-17-2001
Baltimore MD
2000 Jetta 1.8T, 1988 Jetta 16V
Re: The Official VgRt6 MKIV/VR6 DIY Thread Master List (cdn20VALVE) | « » 7:40 PM 12-6-2003 | |
I told you I would crash your thread!!Here's to the replacing the waterpump while I sit back and comment DIY
Re: The Official VgRt6 MKIV/VR6 DIY Thread Master List (VgRt6) | « » 12:16 PM 12-16-2003 | |
12/16/03 - I just added the procedure for replacing the main water pump on a MKIV 12v VR6Enjoy.
Re: The Official VgRt6 MKIV/VR6 DIY Thread Master List (VgRt6) | « » 12:10 AM 12-19-2003 | |
12/18/03 - I just added the procedure for properly installing a new brake light switch on a MKIV carEnjoy.
Re: The Official VgRt6 MKIV/VR6 DIY Thread Master List (VgRt6) | « » 10:16 AM 12-19-2003 | |
Morning bump.
CapeGLS
8-2-2002
Here CT
01 Golf GLS 1.8T, 02 Jetta GLS WGN
Re: The Official VgRt6 MKIV/VR6 DIY Thread Master List (VgRt6) | « » 10:50 AM 12-19-2003 | |
You know what, I dont even own a VR, but I would love to find one just to do these. Your DIY's, are great to follow. I wish you owned a 1.8t that way I would have a bunch of info to go on. Bump for a great DIY writer.
FlickR WRD WM FL Dunlop
Re: The Official VgRt6 MKIV/VR6 DIY Thread Master List (CapeGLS) | « » 10:57 AM 12-19-2003 | |
| Quote, originally posted by CapeGLS » | | You know what, I dont even own a VR, but I would love to find one just to do these. Your DIY's, are great to follow. I wish you owned a 1.8t that way I would have a bunch of info to go on. Bump for a great DIY writer. |
Thanks. Glad I could help out. Not all of them are VR6 related. Some are general MKIV and should be of use to you. My sister and a friend have 1.8Ts. If I ever fix something on one of their cars, then I'll put together a DIY for it.
momoVR6
7-10-2002
Rainstoomuch WA
Couple of VRs
Re: The Official VgRt6 MKIV/VR6 DIY Thread Master List (VgRt6) | « » 6:18 AM 1-8-2004 | |
Bump for a great DIY thread!
STÄTUS / MEISTER Gauge Faces™ / ACHTUN!NG
Re: The Official VgRt6 MKIV/VR6 DIY Thread Master List (momoVR6) | « » 12:01 PM 1-17-2004 | |
I've added Bentley procedures that I've posted on Vortex to the list.Enjoy.
Re: The Official VgRt6 MKIV/VR6 DIY Thread Master List (VgRt6) » | « » 11:08 PM 1-24-2004 | |
I've also started a miscellaneous section for other random useful stuff that I've posted, like a source for triple square bits.Gary
Waagenz
5-28-2003
No mans land
goin' rogue like sarah palin.
Re: The Official VgRt6 MKIV/VR6 DIY Thread Master List (VgRt6) » | « » 11:40 PM 1-24-2004 | |
Its a really great thing that you took the time out to put this list and information all together. Should help a lot of vortexer's out. Good work!!
Cars owned: Yugo on tsws, AMC Pacer and Hovercraft.
5.0 eater
12-4-2002
Fort McMurray Alberta
2001 Golf 1.8T 4Door 2006 BMW 330i
Re: The Official VgRt6 MKIV/VR6 DIY Thread Master List (VgRt6) » | « » 12:47 AM 1-25-2004 | |
Well Guys I think the reason Gary does such a great job on the DIY's is his 12 year University background (lots and lots and lots of reading and writing). He was just successfull in getting a job in his field (Materials engineering) on friday. Now Gary, I hope you don't let this job thing get in the way of the DIY's. HA HA. Congrats on the job and awesome work on all of the DIY's (I just went through them all) Jamie
Modified by 5.0 eater at 3:06 PM 1-25-2004
Jamie
Re: The Official VgRt6 MKIV/VR6 DIY Thread Master List (5.0 eater) » | « » 10:10 AM 1-25-2004 | |
technofly7
4-7-2002
Re: The Official VgRt6 MKIV/VR6 DIY Thread Master List (VgRt6) » | « » 10:14 AM 1-25-2004 | |
if you do a master post please! PLEASE!! make all the pics reside on one server so they dont get deleated or the pictures get deleated. thats a mjor pain to go to a DIY site and the pics were deleated 6 months ago.
vortex kids need to be stabbed.
samc
1-15-2002
Brooklyn NY
Re: The Official VgRt6 MKIV/VR6 DIY Thread Master List (technofly7) » | « » 11:02 AM 1-25-2004 | |
vgRt6 you should buy an old awp 1.8t and do the same(<~~~~ owns a 1.8t )
VW COOLWATER CLUB 'ing it  Rocking a 2006 Honda Pilot EX-L.
Re: The Official VgRt6 MKIV/VR6 DIY Thread Master List (technofly7) » | « » 1:29 PM 1-25-2004 | |
| Quote, originally posted by technofly7 » | | if you do a master post please! PLEASE!! make all the pics reside on one server so they dont get deleated or the pictures get deleated. thats a mjor pain to go to a DIY site and the pics were deleated 6 months ago. |
Don't worry. All of the pics are on one site. If the site stops working for some reason, they'll all be moved to a new site. Gary
