30g60
12-25-2002
france FRANCE
 What turbo charger on a g60?« »
I would like to put a turbo charger on my g60 to have 200 to 220ps
I would like to know what turbo can i put? compressor wheel and turbine wheel ?
i have seen kkk04 t3/t4 an t3 super 60 what is the best for my 8v turbo?
Capt.Dreadz
6-3-2003
LongIsland NY
WWW.EEMILITIA.COM
 Re: What turbo charger on a g60? (30g60)« »
50 trim T3, #30 inj., SnS chip would get you around 220whp. this is providing you have a effiicent enough IC
dreadz
MK2 Forum Elder
West Indian Crew : Resident Virgin Islander
EE Militia...Long Island HQ
Evolution Euro Militia ...Gettin' bigger & better!!
AoA....Nuttin' but 5 Generals
a2-8v-pgh
8-16-2003
trafford pa
sweet i was wondering about the same...
92golf 4dr red - 86 gti white
reppin all 8v's right now
16v gettn built in the garage for a raddo...
GTibunny16v
8-12-2001
'84 Rabbit GTI
i ran a t3 .63 stage 1 super 60 on my g60T motor. It was spooling at 2400rpms and made full boost at 3200-3400rpms. Pulled hard to 6500rpm.
It should be plenty to get you to the 200hp mark.
Dustin
Autobahn Tuning Solutions- Norwalk, CT: Specializing in VW/Audi, Honda/Acura Contact me (Emergency house calls in the CT/NY/NJ area not a problem)
Pic of the BEAST
Agtronic
5-14-2001
Montreal Quebec
1996 Jetta GL
Quote, originally posted by 30g60 »
I would probably use a T3 60 trim as it's less expensive than the Super-60. But the Super-60 would give you a little more headroom.
Markku Kivinen
1996 Jetta GL
Agtronic Motorsport | Custom Fabrication | Professional TIG Welding | Complete Certification | Roll Cages | (514) 225-3793
LF : 02M 5-SPEED (4 CYL.) W/ ANGLE DRIVE and HALDEX REAR DIFFERENTIAL!
IMI
12-6-2002
lakewood oh
86 Jetta Coupe VR6
 Re: What turbo charger on a g60? (Agtronic)« »
t3/t4e pushing 15 psi kicks in late but hits like a freight train.
get an electronic boost controller and a decent 42# chip
and run more boost
its so much fun we have one in the shop,
"Rev it to 7200 rpm--it likes it there."
- Brian Mick
30g60
12-25-2002
france FRANCE
 Re: What turbo charger on a g60? (IMI)« »
so the t3 super 60 is one of the best? how much for something like that?
I have a frien who have put a kkk 26 ?
killa
11-26-2000
Boostville, Dirty Jursee NJ
Super 60's can be had cheaply, however they're not found in any OEM applications, IM me if u want a nice quote on one.
Paul
Capt.Dreadz
6-3-2003
LongIsland NY
WWW.EEMILITIA.COM
 Re: What turbo charger on a g60? (killa)« »
Quote, originally posted by killa »
Ford Turbo coupe came with a Super 60
MK2 Forum Elder
GTibunny16v
8-12-2001
'84 Rabbit GTI
 Re: What turbo charger on a g60? (I Wuz BottlFedG60)« »
Quote, originally posted by I Wuz BottlFedG60 »
Nope only 60 trims. Super 60 is a Turbonetic creation
Dustin
Pic of the BEAST
Holy Piston
10-23-2003
Riceville HI
1985 Fox
 Re: What turbo charger on a g60? (GTibunny16v)« »
Yep super 60 has wider (2.1")inducer(compressor wheel),and as far as I know,Turbonetics was first to create/market it.Get one with a .48 stage 1 for that hp yu want,or a .63 for more top end........
Corrado 16VT,dailydriver,2.0 60ft., 12.82@,113.29,:Hawaii RacewayPark,03/19/04 http://www.TAI-VW.com http://www.REVOTECHNIK.com http://www.PTRSDS.com http://www.laughatrice.com yes I am a idiot,I like to argue on the Vortex
killa
11-26-2000
No, it came with a 60 trim, just measure the inder and you'll see, it has a 1.8x" inducer, the super 60 has a 1.9" inducer and the regular 2.367" exducer, the super 60 compressor wheel is made by turbonetics.
Hope this helps.
Paul
Holy Piston
10-23-2003
Riceville HI
1985 Fox
Killa,you are correct,I was thinking of the "Super S trim",IIRC,it WAS 1.8-1.9 in the Turbonetics catalog.
killa
11-26-2000
 Re: What turbo charger on a g60? (Holy Piston)« »
The Super S is just an S-3 wheel with a 3" exducer IIRC, so it'd have a 1.9xx" inducer and the "super" 3 inch exducer oppposed to the normal 2.75" or so. You must be thinking of the Super V, or the H3 wheel.
hope this helps
Paul
Capt.Dreadz
6-3-2003
LongIsland NY
WWW.EEMILITIA.COM
Then where does this Turbo come from?. It say's ford on the inlet adapter.
Specs:
T3 Super 60:
High performance T3 .63 a/r (stage 2 wheel) Turbine and .60 T3 compressor with exducer
of 2.3 (super 60)
Modified by I Wuz BottlFedG60 at 4:27 PM 12-23-2003
MK2 Forum Elder
GTibunny16v
8-12-2001
'84 Rabbit GTI
Either its a 60 trim or it was machined to fit the super 60 wheel in it.
Dustin
Pic of the BEAST
killa
11-26-2000
That's a ford compressor housing machined to fit a super 60 compressor wheel, if u want i'll even tell u the name of the guy who built it on IM
Paul
corradokyd
6-4-1999
Hampden/Severna Park MD
turbo corrado
turbo g60, i think the super 60 is a little late boostin unless you can build your set up to spool it up a little faster then itd be great. but it depends on what you want. some like late boost and like it to come hard. i opted for the 60 trim standard t3 because i like my low compression motor boostin eariler. gives it more of that charger feeling. that ish is ass slow before the turbo spools, i couldnt stand it if that turbo spooled any later.
keith
TURBO CORRADO
CorradoAbaTurbo
8-29-2003
Columbia tn
1990 Corrado crossflow turbo
 Re: What turbo charger on a g60? (corradokyd)« »
I use a regular T3-60 trim, works pretty well. Good all around drivability.
1990 Corrado ABA TURBO 2035cc, twin throttle bodies, brakes, suspension, carbon fiber hood, reiger bumper/side skirts, and other stuff
Hardcore VW
10-9-2001
132 and Bush
Quote, originally posted by corradokyd »
You have to be kidding me to think you can tell or feel the difference between a 60 T3 and a Super 60 T3.You'd need lab equipment to find a difference.
30%'r
Team Balance
My Unique,nonpimped,cut chop rebuild,german hotrod
GTibunny16v
8-12-2001
'84 Rabbit GTI
 Re: What turbo charger on a g60? (Hardcore VW)« »
Quote, originally posted by Hardcore VW »
haha, I was thinking the same thing when I read his post. I dont know what you guys are complaining about I saw full boost (22psi) by 3200-3400rpm) on my .63 a/r super 60. If you want quicker spool up get a .48 stage 1.
I liked that turbo so much, I will be buying another one for my daily driver.
Dustin
Pic of the BEAST
corradokyd
6-4-1999
turbo corrado
i wont argue with you but yeah, i did notice a difference. both cars on stock injection though.
keith
TURBO CORRADO
IMI
12-6-2002
lakewood oh
86 Jetta Coupe VR6
The ford 60 trim housings are big enough to put a super 60 wheel inside with no machining this is per my turbo rebuilder. thats why he uses the ford turbo coupe turbos. less work and save him and me money.
- Brian Mick
killa
11-26-2000
that's because both the ford and nissan Z31's have .60's compressor housing a/rs
hasaposerviko
12-12-2002
cincinnati oh
1991 vw gti AWD turbo widebody
Killa,
Wouldn't a ball bearing center section really help the bigger turbos (super 60, T3/T4) spool up a lot faster?
CorradoCody
10-12-2001
Dover AFB DE
1990 SP VW Corrado 1.9T, 2007 Suzuki GSF1250S Bandit, 2008 Jeep Wrangler Unlimited X (JK)
 Re: What turbo charger on a g60? (hasaposerviko)« »
Ball bearings help my T3/T4 spool up quick.
CC
1990 VW SP Turbo Corrado 1.9T
1993 VW SP SLC VR6 (NA)
Let's just say it's been worked on a little. CCA # 1392
Schimmel Performance
GTibunny16v
8-12-2001
'84 Rabbit GTI
Yes a ball bearing center section will help with spool up. But a super60 really doesnt need it. Its not a larger turbo. If you want something that preforms and with quick spool up. Look into the GT series of turbos. Be prepared to spend $$$, though.
Dustin
Pic of the BEAST
killa
11-26-2000
Quote, originally posted by GTibunny16v »
Agreed
30g60
12-25-2002
france FRANCE
What do you think of the t3/t4 To big or not?
i've seen that many guy's use it on 8v turbo with more than 220 whp!
Agtronic
5-14-2001
Montreal Quebec
1996 Jetta GL
 Re: (30g60)« »
Every turbo has its purpose. If you're only looking for 200-220, you don't need the larger T04 compressor, all it will do is take more time to spool.
Markku Kivinen
1996 Jetta GL
GTibunny16v
8-12-2001
'84 Rabbit GTI
 Re: (30g60)« »
If my memory serves me correctly a t3 super 60 is a very effiencent turbo up to 22psi on a g60 motor. Its been over a year since I did a compressor map though. Either way the turbo is a great match for 15-17psi on a g60 motor.
If you want to go with a t3/t4. I would use a t3/t4E 40 or 46 trim. Id have to do a compressor map to see which one would be best suited.
Dustin
Pic of the BEAST
hasaposerviko
12-12-2002
cincinnati oh
 Re: What turbo charger on a g60? (killa) »« »
Killa,
I think I understand how to size the compressor side of the turbo, but what's the deal with the turbine side? I am building a 1.9 16V motor with a very efficient air-water IC. The bottom end is built for >300 HP, but I also want good low-end torque. I am debating whether to go with a T3-Super 60 or a T3/T4E - the super 46 has an awesome compressor map, no? What turbines would you recommend to drive these compressors with this engine?
» Return to Forced Induction
