Silver VR6 Corrado
5-25-2003
Las Vegas NV
Steering Wheel shake??? Driving me nuts and poor | « » 8:43 PM 1-23-2004 | |
[EDIT] !!!!!FIXED via Hub Centric Rings!!!!! [/EDIT] Ive tried reading all the archives for steering wheel shakes and keep finding the problem but noone ever posts what made it stop.
Steering wheels shakes around 55-60 mph then goes away above or below. A slight vibe around the 35mph range also. First I went to get a nail removed and saw inside of tire was going so I bought 4 brand new tires 205/40/17s. Once fully balanced/installed still got the same thing. Next weekend I got an alignment. Still no help. Bought a new set of FKs and another new set of tires 215/40/17s Yoko ES100s and still exactly the same thing. Had axels serviced and new inner cvs installed and same thing. Just replaced Control Arm bushings and the problem is still there. Im at a loss and getting very irritated at this problem. I have seen people in the search mention strut bushings/bearings but my car doesnt make any noise while moving even at low speeds. My axels are straight as an arrow also. How can you tell if your strut bushings are bad? This dam shake is hurting my pocket more than anything. Doesnt affect anything else but the steering wheel around 60mph and my pocket and now I have to fix it Any help would be greatly appreciated.
Modified by Silver VR6 Corrado at 10:08 AM 3-6-2004
92 Corrado 02 337 04 Touareg V8 DIY: Steering Stalks repair Diecast Cars For Sale
1967ghia
1-27-2003
So Cal
1990 Corrado Lysholm "Lacy", 90 Corrado G60 "Sold", 67 Karmann Ghia "Tracy"
Re: Steering Wheel shake??? Driving me nuts and poor (Silver VR6 Corrado) » | « » 9:04 PM 1-23-2004 | |
after my buddy had his tires balanced 2 of the weights came off and his steering wheel would shimmy at about 60-65. Did you check to see if the weights are still on??? An idea......and also could warped rotors do this, I don't see them as being a cause but I don't have a degree in mechanical engineering either.
Modified by 1967ghia at 2:05 AM 1-24-2004
SERGEANT OF MARINES F/A-18 Hornet Weapons Technician IYAOYAS Droppin Warheads on Forheads AKA-- Population Control My car... SCCG RCOC: Red Corrado Owners Club
Silver VR6 Corrado
5-25-2003
Las Vegas NV
Re: Steering Wheel shake??? Driving me nuts and poor (1967ghia) » | « » 9:06 PM 1-23-2004 | |
Ive been to the tire balancer too many times. All the weights are still on and they balance out at 0.
capthowdy_1968
1-9-2001
St Augustine FL
93 Corrado VR6
Re: Steering Wheel shake??? Driving me nuts and poor (Silver VR6 Corrado) » | « » 9:22 PM 1-23-2004 | |
Warped rotors would cause they shake when braking. I have had several warped rotors and only had it then. My thought would have been a control arm bushing but since you have already replaced it I guess not. How is your steering rack? Is their a lot of play in it?
Bari Quippe Boni
KidCorrado
8-10-2001
Reading PA
S50 E36
Re: Steering Wheel shake??? Driving me nuts and poor (Silver VR6 Corrado) » | « » 9:23 PM 1-23-2004 | |
Check your ball joints?
-Nick Current: 1995 Dakar M3 Past: 2 M3s, 3 Corrados, a tim's gay, and a R32
Silver VR6 Corrado
5-25-2003
Las Vegas NV
Re: Steering Wheel shake??? Driving me nuts and poor (KidCorrado) » | « » 9:25 PM 1-23-2004 | |
Brakes are only about 5 or 6 months old and I dont ride them hard. My car is stock height also.How do I know if Ball Joints are bad? Can I locate that with only a floor jack or needs a mechanic shop to look at it? Also how do I check Steering Rack? I cant wait to get this dam shake taken care of.
Modified by Silver VR6 Corrado at 6:27 PM 1-23-2004
KidCorrado
8-10-2001
Reading PA
S50 E36
Re: Steering Wheel shake??? Driving me nuts and poor (Silver VR6 Corrado) » | « » 9:31 PM 1-23-2004 | |
Just take the wheel off and turn it all the way and you can see them...i cant really explain it without a pic but they have little boots on them and after time they wear out and create more play in the suspension area..mine were bad on my old C and after I replaced them the little shake i had went away
Silver VR6 Corrado
5-25-2003
Las Vegas NV
Re: Steering Wheel shake??? Driving me nuts and poor (KidCorrado) » | « » 9:34 PM 1-23-2004 | |
Ill try that next. Probably could have bought a new car for the cost of this dam shake. And didnt even get any fries to go with it.
Golf8VTurbo25
8-1-2001
Salem MA
92 Corrado SLC, 06 Focus POS
Re: Steering Wheel shake??? Driving me nuts and poor (Silver VR6 Corrado) » | « » 9:39 PM 1-23-2004 | |
kfc has apple pies now i aint tried em cuz i cant eat em but thats new for me $2......k my off topic quote of the day is now finished
Richie "Always pull them seatbelt relays" - ME (do it trust me ) CCA# 9639 AIM: Richie102582  http://www.myspace.com/richie1025 Snowcool since '01
Josh@Jaztuning.com
1-30-2002
Mount Bethel PA
2000 Nogaro S4
Re: Steering Wheel shake??? Driving me nuts and poor (Silver VR6 Corrado) » | « » 9:42 PM 1-23-2004 | |
How about CV joints?
Silver VR6 Corrado
5-25-2003
Las Vegas NV
Re: Steering Wheel shake??? Driving me nuts and poor (Syonara_G60Style) » | « » 9:48 PM 1-23-2004 | |
Replaced Inner CV Joints and Outers were like new.
1967ghia
1-27-2003
So Cal
Re: Steering Wheel shake??? Driving me nuts and poor (Syonara_G60Style) » | « » 9:49 PM 1-23-2004 | |
| Quote, originally posted by Syonara_G60Style » | | How about CV joints? |
He had the inners done, but what about the outers???
Gazoo
11-22-2003
Calgary Alberta
VW
Re: Steering Wheel shake??? Driving me nuts and poor (Silver VR6 Corrado) » | « » 9:53 PM 1-23-2004 | |
Aftermarket wheels? Wrong offset? Have you tried a dynamic balancer where they balance the wheels on the car?
___________________________________________"Great spirits have always found violent opposition from mediocre minds. The latter cannot understand it when a man does not thoughtlessly submit to hereditary prejudices but honestly and courageously uses his intelligence." A. Einstein ___________________________________________
Silver VR6 Corrado
5-25-2003
Las Vegas NV
Re: Steering Wheel shake??? Driving me nuts and poor (Gazoo) » | « » 9:56 PM 1-23-2004 | |
The shake was not there when I had the MAK Planets on the car. Then one day it just starts bouncing @ 60mph. So I put new tires on those rims with no luck and then the FKs are 17x8 +35 and new tires once again and still the same thing.
Josh@Jaztuning.com
1-30-2002
Mount Bethel PA
2000 Nogaro S4
Re: Steering Wheel shake??? Driving me nuts and poor (Gazoo) » | « » 9:57 PM 1-23-2004 | |
How about wheel bearings?
Silver VR6 Corrado
5-25-2003
Las Vegas NV
Re: Steering Wheel shake??? Driving me nuts and poor (Syonara_G60Style) » | « » 10:00 PM 1-23-2004 | |
All this good help is great.Would wheel bearings make noise? My mechanic is baffled by this problem also. He says the wheel bearings are fine.
white lightning
6-9-2002
hamburg pa
94 corrado slc (ice violet grey baby)
Re: Steering Wheel shake??? Driving me nuts and poor (Silver VR6 Corrado) » | « » 11:16 PM 1-23-2004 | |
u would be able to tell wheel bearings...either u'll hear squeaking...alot of low noise when taking turns...or u can just push/pull ur wheel while its off the ground and if it moves alot ur bearings are shot...but i doubt thats it...i have this same problem didn't really try diagnosing it yet...but i've basically assumed its ball bearings/tie rods
joe c forum status: blows 94 Ice Violet Grey| Quote, originally posted by bulldog2.G » | WhiteLightning......King of the MASS QUOTE!! Love it! |
Silver VR6 Corrado
5-25-2003
Las Vegas NV
Re: Steering Wheel shake??? Driving me nuts and poor (white lightning) » | « » 11:43 PM 1-23-2004 | |
OK. Its not wheel bearings then. Must be Tie Rods or Ball Joints. He-ll maybe I will have a whole new front end by the time I figure it out. At least I will be able to pass along some info to the next guy.
1967ghia
1-27-2003
So Cal
Re: Steering Wheel shake??? Driving me nuts and poor (Silver VR6 Corrado) » | « » 1:47 AM 1-24-2004 | |
I am betting myself that it will be tie rod ends, if I am right I will buy myself front/rear sway bars and if wrong I'll still buy them.
Silver VR6 Corrado
5-25-2003
Las Vegas NV
Re: Steering Wheel shake??? Driving me nuts and poor (1967ghia) » | « » 2:07 AM 1-24-2004 | |
I will replace those next. If your wrong split the cost with me . If your right Ill buy you a x6 next time Im down there or you come up here.
Golf8VTurbo25
8-1-2001
Salem MA
Re: Steering Wheel shake??? Driving me nuts and poor (Silver VR6 Corrado) » | « » 2:10 AM 1-24-2004 | |
yeah its what kyle said now give me a free 6er too! sam adams preferably
Modified by Golf8VTurbo25 at 11:13 PM 1-23-2004
Silver VR6 Corrado
5-25-2003
Las Vegas NV
Re: Steering Wheel shake??? Driving me nuts and poor (Golf8VTurbo25) » | « » 2:11 AM 1-24-2004 | |
x6 for all who helped if thats what it is.
vdubCorrado
11-8-2001
Baltimore MD, Wilkes Barre PA
91 Corrado R32 (in slow progress) / 09 FG2 Si / 99 F350 / many others
Re: Steering Wheel shake??? Driving me nuts and poor (Silver VR6 Corrado) » | « » 9:29 AM 1-24-2004 | |
could be alignment. if no one said that... my 2000 celica when i had it used ot shake and shimmy around 55 - 65 so i used to like driving faster than that so it went away haha cause they won't do 2 wheel alignments around here. which sucks cause you can but a car new and a decade later may still not need a rear end alignment. and it sucks cause that's how they make money cause places will never even touch the rear end. i know pep boys has not even checked the rear end of some cars that come in
"G60 - n. A small, mean little monster that eats money. Lives under the hood of many Corrados and some other VW automobiles. When you feed it lots of money, it stays happy; if you don't, it gets angry and breaks things."CCA Officer Audi Valvelift System (AVS) - now all VW owners who made fun of VTEC can put their foot in their mouth
Silver VR6 Corrado
5-25-2003
Las Vegas NV
Re: Steering Wheel shake??? Driving me nuts and poor (vdubCorrado) » | « » 2:37 PM 1-24-2004 | |
Got 2 alignments already. 1 when first set of new tires went on and no help and once just yesterday when the new control arm bushings went on. Maybe I will take it back to discount and have them remove and rebalance all 4 wheels again and then alignment again.
SLCorrado
3-5-2002
Troy, MI
Down the street from VWOA
Re: Steering Wheel shake??? Driving me nuts and poor (Silver VR6 Corrado) » | « » 3:03 PM 1-24-2004 | |
I had the EXACT same thing. I got a drives side ball joint and new front disks and front tires and it went away.
www.hostdub.com Image & Video Hosting: For VWVortex Members by VWVortex Members
OdorCide
8-4-2000
Dallas TX
1990 Lysholm Corrado - 1975 Beetle - 1994 Jetta GL
Re: Steering Wheel shake??? Driving me nuts and poor (SLCorrado) » | « » 3:52 PM 1-24-2004 | |
Another thing man, if you have aftermarket rims, are they hub centric with a 57.1mm center bore? If not make sure you have the proper hubcentric adapters. Your wheels might not be on the lugs straight.
-Justin -Dubbest drunks in town, DrunkDubs.com Buy my Corrado Rush poster!
NVmyVW
8-29-2001
n o
Re: Steering Wheel shake??? Driving me nuts and poor (OdorCide) » | « » 5:39 PM 1-24-2004 | |
i had the same thing on my old C, when i put coilovers it almost all went away. then got worse when i put the OZ's on. it got worse before it got better. i never really did find all of the problems. but i think it is a combination of ball joints and I a had a bent tie rod.
Do your best to ignore trolls. WTB B5 RS4 parts, body panels, interior, let me know what you have. Used or new.
Silver VR6 Corrado
5-25-2003
Las Vegas NV
Re: Steering Wheel shake??? Driving me nuts and poor (NVmyVW) » | « » 7:46 PM 1-24-2004 | |
Looks like Ball Joints are next on the list. Then if that no workie I will do Tie Rods but they look good (but WTF do I know). But for now: My steering wheel shake is better than yours. Id teach you but Id have to charge.
G60Scuzz
11-13-2003
D Town CO
Black 90 No-Sunroof G60 (VR swapped w/G60 Gearset) 84' Vanagon SVX (Boost coming soon)
Re: Steering Wheel shake??? Driving me nuts and poor (Silver VR6 Corrado) » | « » 7:54 PM 1-24-2004 | |
| Quote, originally posted by Silver VR6 Corrado » | | Looks like Ball Joints are next on the list. Then if that no workie I will do Tie Rods but they look good (but WTF do I know). But for now: My steering wheel shake is better than yours. Id teach you but Id have to charge. |
Does it bring all the Cs to the yard?
Good Luck
- Doogie http://www.doogielabs.com
IMNOBUG
12-1-2001
one horse town Indiana
'90 Corrado G60
Re: Steering Wheel shake??? Driving me nuts and poor (G60Scuzz) » | « » 7:56 PM 1-24-2004 | |
Steering wheel on tight?
MJM Autohaus! US Rally Team!
Silver VR6 Corrado
5-25-2003
Las Vegas NV
Re: Steering Wheel shake??? Driving me nuts and poor (IMNOBUG) » | « » 8:01 PM 1-24-2004 | |
SW is on tight. I will find the cause of the hippy hippy shake if it kills me.Definately going for broke on this venture.
TorontoCorrado
1-27-2000
Toronto Ontario
1991 Corrado G60, 2001 Jetta TDI
Re: Steering Wheel shake??? Driving me nuts and poor (Silver VR6 Corrado) » | « » 10:07 PM 1-24-2004 | |
WHOASTOP your all over the place! you shouldn't be "guessing" whats wrong and replacing parts randomly in hopes of repairing this vibration problem. What you need to do first is establish what kind of vibration problem your having. We know what speeds you are complaining about but is the vibration a shimmmy? (ie: wheel rotates at a high frequency) or is it a vertical vibration/roughness? (ie: wheel shakes up and down & feels like a "buzzieness") From that you can start to focus on key areas... First and foremost, you need to check suspension play. Although not all that common, a bad BJ or Tie rod (especially inner) can accentuate a vibration. So jack up the front end and place jackstands as close as possible to the ball joint. Then check the suspension/steering play and make sure there isn't any. If there is, replace the necessary components to fix the play then check to see if the vibration is there. Now I will list common root-causes of "shimmy" and "roughness" steering vibration problems Shimmy: - poor wheel imbalance. How good is the machine your using? Has it been calibrated lately? (most machines in the market, even at dealerships arent properly maintained or calibrated) are the wheel weights falling off? Is the tire slipping on the rim? (usually happens when new tires are installed and tech uses too much tire lube... this causes imbalance to change.) - what kind of balance did you conduct? Static or Dynamic? You would want to get your static as close as possible to zero as static balance affects "shimmy" more than dynamic since it is a 1st order vibration - what kinda shape are your brake rotors in? brake rotors too are balanced and can have an affect. Ive seen old rotors that rust and end up missing chunks of material at the edges cause this. - have you had a brake job performed recently? could be that your rotor isnt sitting flush to you hub ie: rust or some other foreign debris - are you using plastic centering hubs for your wheels? If so, try without them. SOmetimes these plastic hubs are so poorly manufactured they can make things worse - what shape are your wheels in? are they dented/dinged? have you tried match mounting them to your tires? - what shape are your tires in? when you spin them on the balancer, do they have a high spot? Does the balancer you use have a road force measuring wheel? Find a place that has a Hunter GSP9000 machine. Although this machine is not very accurate, it would be able to pick up defeciencies in the tire if your vibration is this bad. - If all of this I mentioned above is OK then you might have a problem in your drivetrain like warper driveshafs or bad CV joints. This is pretty difficult to check unless you have expensive vibration measuring equipment or are willing to then start swapping parts in hopes of correcting the problem. At this point I would recommend you find a place with an "on car balancer" or "finishing balancer" that can balance your wheels on the car and take into consideration the imbalance of the drivetrain as well. It usually works really well. Roughness: - key thing to check here are your tires. This type of vibration is usually caused by a bad tire. Run your hand around the tire and see if the surface is smooth or rough/lumpy. Or again, find a shop that has a Hunter GSP9000 and get them to measure the Radial Harmonic Forces (1st, 2nd & 3rd) that could tell you if you have a bad tire. Or you can swap front to rear and see if there is a noticeable difference. The rear should be less sensitive to transferring the vibration to the wheel. - This type of vibration will usually also transfer to the floor or cause a cabin resonance like a "booming". Are you getting any of this as well or just steering vibration? - What condition are your bushings in? ie. front lower arm bushings. Are they dry and cracking? - Have you done any suspension repairs lately where you loosened the bushings? If so, you need to make sure that the bushing are retorqued with the vehicle at the "1G position" ie: with the vehicle on the ground so that you don't preload the bushings. Usually when you preload thebushings, they are not able to function correctly and transfer alot more vibration. Well, there's alot more that you can do to try and "bandaid" this problem if you cant fix it 100% but like i said, you need to figure out exactly what kind of vibration you are having. Hope this helps, Mikey
got boost? 91' Corrado G60 - 01' Jetta TDI - 01' Audi Allroad Corrado Club Of Canada http://www.corrado-club.ca Need a G60 Rebuild? call Kompressor Canada http://www.kompressorkanada.ca
Silver VR6 Corrado
5-25-2003
Las Vegas NV
Re: Steering Wheel shake??? Driving me nuts and poor (TorontoCorrado) » | « » 10:29 PM 1-24-2004 | |
Im not guessing. I have NO IDEA whats wrong so Im trying to find out via this thread. My steering wheel rocks back and forth from about 50-65 MPH and then again around 80-85 MPH (going this fast only for diagnosis purposes ). Car rides straight as an arrow and not bouncy only the steering wheel. No bad rattles like when you have a bubbled tire. My Wheels/Tires are Brand New as of 12-23 and been on the car since 12-28-03. This problem was here before the NEW Wheels. My Front Sway bar was installed wrong and it broke the mounting piece when they were pulling it off the lift for an oil change. This is when the problem started. Not sure if something was bent/smashed during this or what not. I know one of the weights was off of the Right Front Wheel also (rebalanced but no help). Since then I have done/replaced: Tires (on old wheels), Alignment, Wheels/Tires again, Inner CV Joints (Axels were straight and Outers were in LIKE NEW state), Control Arm Bushings. All of this and still exactly the same thing. Maybe I should go get another Balance/Alignment before I try anything else. Other possibilities are Ball Joints and Tie Rods . Never messed with suspension and its stock height.
Gazoo
11-22-2003
Calgary Alberta
VW
Re: Steering Wheel shake??? Driving me nuts and poor (Silver VR6 Corrado) » | « » 10:30 PM 1-24-2004 | |
I hope the shop that broke the part is picking up the tab?
Silver VR6 Corrado
5-25-2003
Las Vegas NV
Re: Steering Wheel shake??? Driving me nuts and poor (Gazoo) » | « » 10:38 PM 1-24-2004 | |
If I could find the problem and prove thats what caused the shake Im sure they would pay for it.
