eiprich
3-3-2003
Westminster MD
Various VW's and an R32 Turbo
Dyno Results - R32 Exhaust Mod...and more... | « » 12:03 AM 3-16-2004 | |
Two Sunday’s ago I decided to figure out if we could Dyno the R32 in FWD rather than AWD in order to allow us to Dyno Tune our new product line in-house. The answer is yes, it can be done very easily and by merely disabling the rear differential electronically. Since there has been a lot of discussion on the topic I decided to do several runs in various gears with and with the Exhaust Valve hooked up and functioning as it was intended and the same runs with it fully open (disconnected and capped the vacuum line). Just for curiosity sake I also tested a K&N panel filter, new out of the box. Here are the results:
The exhaust valve must not open all the way when hooked up and functioning as stock, if it did the power figures above 3500 rpm should be the same. So running it open seems to be the best choice for HP and Torque. We are in the process of decoding and tuning the ECU and we will be dyno testing this upgrade and I will post the results here. We will also be testing a full series of exhaust upgrades and different variants of our 2.5” & 3” SS Systems with duel outlets of course. We will dyno and post the results for this as well. -Rich
Modified by eiprich at 12:24 PM 3-16-2004
TRUE VW POWER Proudly made in the USA Email: info@eiptuning.com Phone: (410) 871-0406 If you have questions I'll do my best to have answers. Oh...and EAD
Greanhouse
6-24-2003
city state
» | « » 12:05 AM 3-16-2004 | |
broken pic
http://www.vwfixx.comAPR tuned, APR exhaust, Carbonio cai, Diesel Geek ss, Energy Suspension dogbone inserts
Greanhouse
6-24-2003
city state
» | « » 12:12 AM 3-16-2004 | |
Thanks!Oh, reply to my email 'bout the turbo kit pricing!!!! I'm dyin' over here!!!
Daemon42
2-9-2001
Lakewood CO
2004 R32 Blue
Re: Dyno Results - R32 Exhaust Mod...and more... (eiprich) » | « » 12:15 AM 3-16-2004 | |
Strange about the power increase that the top end. There seems to be no discernable "opening point" in the stock dyno curve. Could you *hear* it opening at the normal time? Above 45mph, above 3400 rpms? I wonder if the ECU was confused about the wheelspeed sensors running in 2wd mode, and simply never actually opened the valve. ian
eiprich
3-3-2003
Westminster MD
Re: (Greanhouse) » | « » 12:20 AM 3-16-2004 | |
| Quote, originally posted by Greanhouse » | | Thanks! Oh, reply to my email 'bout the turbo kit pricing!!!! I'm dyin' over here!!! |
Email just sent a few minutes ago... -Rich
eiprich
3-3-2003
Westminster MD
Re: Dyno Results - R32 Exhaust Mod...and more... (Daemon42) » | « » 12:24 AM 3-16-2004 | |
| Quote, originally posted by Daemon42 » | Strange about the power increase that the top end. There seems to be no discernable "opening point" in the stock dyno curve. Could you *hear* it opening at the normal time? Above 45mph, above 3400 rpms? I wonder if the ECU was confused about the wheelspeed sensors running in 2wd mode, and simply never actually opened the valve. ian |
Yes it was opening as normal right at 3500 RPM but I agree the transition is surprisingly smooth. We have the entire session on video, we closed the bay door specifically so you can hear the change-over and it is loud when it opens. We did multiple runs in each gear 3rd, 4th, and 5th just to be sure the results were consistent. -Rich
Daemon42
2-9-2001
Lakewood CO
2004 R32 Blue
Re: Dyno Results - R32 Exhaust Mod...and more... (eiprich) » | « » 12:33 AM 3-16-2004 | |
And switched it back to stock operation after the higher power runs? ian
eiprich
3-3-2003
Westminster MD
Re: Dyno Results - R32 Exhaust Mod...and more... (Daemon42) » | « » 12:38 AM 3-16-2004 | |
| Quote, originally posted by Daemon42 » | | And switched it back to stock operation after the higher power runs? ian |
Yes...no change from the original stock runs. Even though it makes power I run mine in stock form, like it quiet...I must be getting old -Rich
milo
2-18-2002
ATX
EVO 9 MR, Z31 Turbo
Re: Dyno Results - R32 Exhaust Mod...and more... (eiprich) » | « » 12:42 AM 3-16-2004 | |
Freaky R32 that is fwd!
Member of The Dark Side
mec_vw
2-22-2001
Olathe KS
2004 R32, 1980 Scirocco, 2006 Jetta TDI
Re: Dyno Results - R32 Exhaust Mod...and more... (eiprich) » | « » 8:01 AM 3-16-2004 | |
Great stuff--thanx for sharing, Rich! Mike
Present: '04 Golf R32 / '80 Scirocco / '06 Jetta TDI Past: '74 Scirocco / '85 Scirocco / '95 GTI VR6 / '84.5 Scirocco Wolfsburg Edition / '04 Golf GLS TDI My VWs - Mo-Kan VW Club - KCH2O
SaucemanVR6
1-20-2001
Mk1 Pizza Box, Mk2 (Mk3 Foster Child) Mk4 Mk5 Hatches
Re: Dyno Results - R32 Exhaust Mod...and more... (mec_vw) » | « » 9:07 AM 3-16-2004 | |
| Quote, originally posted by mec_vw » | Great stuff--thanx for sharing, Rich!
ditto
Thou shalt not partake of Decaf. PTAC! flickr
ValveFloat
8-12-1999
Montana
1993 911 - 03 Ducati M620
Re: Dyno Results - R32 Exhaust Mod...and more... (eiprich) » | « » 10:17 AM 3-16-2004 | |
| Quote » | | Two Sunday’s ago I decided to figure out if we could Dyno the R32 in FWD rather than AWD in order to allow us to Dyno Tune our new product line in-house. The answer is yes, it can be done very easily and by merely disabling the rear differential electronically. |
How did you disable the AWD? Did you pull the fuse, or disconnect something, or just pull the e-brake? Thanks for sharing your findings.
I like things that more are than profess -Roy Blount, Jr. -Big Sky VW-
1.8 nut
3-2-2002
Littleton MA
'87 Golf GL 4-dr
Re: Dyno Results - R32 Exhaust Mod...and more... (eiprich) » | « » 11:09 AM 3-16-2004 | |
| Quote, originally posted by eiprich » | | We have the entire session on video |
Any chance we could see these videos?
Daemon42
2-9-2001
Lakewood CO
2004 R32 Blue
Re: Dyno Results - R32 Exhaust Mod...and more... (eiprich) » | « » 12:18 PM 3-16-2004 | |
Here's a slightly condensed version of the dyno image.
ian
eiprich
3-3-2003
Westminster MD
Re: Dyno Results - R32 Exhaust Mod...and more... (Daemon42) » | « » 12:26 PM 3-16-2004 | |
| Quote, originally posted by Daemon42 » | Here's a slightly condensed version of the dyno image. ian |
MAN, you beat me to it! Well, I updated my original post with a pic rather than a link. -Rich
banzaimf
4-10-2002
Seattle wa
R32
Re: Dyno Results - R32 Exhaust Mod...and more... (eiprich) » | « » 1:21 AM 3-17-2004 | |
Which is the K&N run?
RCW 46.61.100.Subsection 4 "It is a traffic infraction to drive continuously in the left lane of a multilane roadway when it impedes the flow of other traffic." Wa. plate laws Keep it on the track!
Daemon42
2-9-2001
Lakewood CO
2004 R32 Blue
Re: Dyno Results - R32 Exhaust Mod...and more... (banzaimf) » | « » 1:23 AM 3-17-2004 | |
| Quote, originally posted by banzaimf » | | Which is the K&N run? |
The green one. But it sorta doesn't matter as it was worth about half a horsepower, which falls well within the error of margin. ian
verustung
2-5-2004
2004 R32
Re: Dyno Results - R32 Exhaust Mod...and more... (Daemon42) » | « » 8:20 PM 3-26-2004 | |
Wow! Impressive results from just the exhaust mod alone. I may have to try it out sometime. I am a little surprised that the addition of the K&N didnt yield better results. Were you at all suprised at that Rich? Do you forsee much headway in chip tuning? AMD is claiming 15WHP and has dyno results to back it up. I would love to see a chip with gains up to 20WHP but that just may be impossible. The results of the exhaust mod combined with an aftermarket chip seem promising. Most chips bump torque about 10lb ft, consider that with the addition of 10 extra lb ft from the exhaust mod and you have some serious torque brewing
08' Audi TT Ibis White"Bottles are for Babies, Real Men get Blown"
HOTSKILLET98
3-12-2002
BITBURG GERMANY
Re: Dyno Results - R32 Exhaust Mod...and more... (eiprich) » | « » 6:57 AM 3-27-2004 | |
Comon Rich stop playing' with the lil stuff and keep up with the big boy R32 research and developement.
verustung
2-5-2004
2004 R32
Re: Dyno Results - R32 Exhaust Mod...and more... (HOTSKILLET98) » | « » 11:53 PM 4-24-2004 | |
So why does the maximum output change over 3400RPM if the vacuum line should already be opened??? New Dimensions only recorded 10lb ft gains, but your results also show an increase of 8HP in addition to some minor torque gains... Interesting, ND makes 10lb ft and EIP's car made 4lb ft but with HP gains. What do you think Rich?
Twelvizm
4-12-2004
Not approved in the Couve
'06 GLI, '07 Wolfsburg
Re: Dyno Results - R32 Exhaust Mod...and more... (verustung) » | « » 2:23 PM 4-25-2004 | |
All that dough on a turbo and still running with he stock air box You're the expert
SE PDX GTG Meinmedia The Werkstatt <-- Ksport, Eurojet, Kinetic, 034 Motorsports. Free shipping on all Eurojet gear. Got questions about the joining the Army? I have answers, IM me.
HOTSKILLET98
3-12-2002
BITBURG GERMANY
Re: Dyno Results - R32 Exhaust Mod...and more... (Twelvizm) » | « » 3:36 PM 4-25-2004 | |
| Quote, originally posted by Twelvizm » | All that dough on a turbo and still running with he stock air box You're the expert |
Actually HGP/HPA are the experts. The must know what they are doing huh?
Greanhouse
6-24-2003
city state
Re: Dyno Results - R32 Exhaust Mod...and more... (Twelvizm) » | « » 10:10 PM 4-25-2004 | |
And you don't know ish about the stock airboxes or if that is even stock
Patrick
Global Moderator
4-28-2000
Rocket City, Alabama
'87 Jetta Coupe 16V
Re: Dyno Results - R32 Exhaust Mod...and more... (Twelvizm) » | « » 11:12 PM 4-25-2004 | |
Open mouth...insert foot
For Sale: 1987 Jetta Coupe 2.0 16V in Alabama - lot's of extras
Jason@Streetwerke
7-27-2001
Palo Alto CA
'01 Audi S4 / '04 R32
Re: Dyno Results - R32 Exhaust Mod...and more... (verustung) » | « » 11:37 AM 4-26-2004 | |
| Quote, originally posted by verustung » | So why does the maximum output change over 3400RPM if the vacuum line should already be opened??? New Dimensions only recorded 10lb ft gains, but your results also show an increase of 8HP in addition to some minor torque gains... Interesting, ND makes 10lb ft and EIP's car made 4lb ft but with HP gains. What do you think Rich?
Our car was dynoed in AWD mode on a Dyno Dynamics chassis dyno, so results will vary from EIP's dyno. My results and Rich's results both indicate that the free exhaust mod is really making power, not just more noise.
Jason Leone Founder Streetwerke www.streetwerke.com
