dbrowne1
10-31-2000
Richmond VA
2004 Audi A4 1.8TQM6
Bypassing the N249 - An Easier Approach | « » 7:37 PM 4-27-2004 | |
I just finished road testing my car after bypassing the N249, in a much more direct and "clean" method than some of the ones I've seen suggested. It works great, partial throttle is MUCH smoother and predictable - no jerky boost.All I did was this: 1. Trace the path of the top (actuator) hose from the DV. It goes to a metal tube that runs along the block, then to another rubber hose, then underneath the intake manifold to the N249. 2. Remove the hose that connects the tube to the N249, at the side closer to the N249. There is a reusable clamp, just pinch it with pliers and pull the tube off. 3. Cap the tube to the N249 with a rubber hose cap (available at Auotzone, etc.) and clamp it on there with a hose clamp. 4. Tapinto the FPR vacuum/boost line, which is RIGHT NEXT to the hose you just disconnected. It's the thinner braided hose that goes to the FPR. 5. Using a 3/16" x 3/16" x 3/16" T fitting, connect the newly disconnected N249 hose to the T. Voila. Instant, clean bypass. Works like a charm, looks stock.
dbrowne1
10-31-2000
Richmond VA
Re: Bypassing the N249 - An Easier Approach (dbrowne1) » | « » 7:40 PM 4-27-2004 | |
All you need to do this is:1. 2 hose clamps 2. 3/16" T fitting (plastic works fine) 3. 5/16" rubber cap
Seanathan
4-30-2002
Chandler AZ
Re: Bypassing the N249 - An Easier Approach (dbrowne1) » | « » 7:44 PM 4-27-2004 | |
very nice man. for now I was just going to cap of the line from the dv valve, and run a new one.
nrml
1-21-2002
sd ca usa
Re: Bypassing the N249 - An Easier Approach (Seanathan) » | « » 7:53 PM 4-27-2004 | |
always good to see useful info on this forum
aol : darknrml | msn : lenity@hotmail.com | icq : 6040674** WTB: Black GTI Bumper 2002+ **** WTB: Frotnt RE-BAR **
enginerd
12-14-2001
MANCHESTER CT
2002 GTI 1.8T, 83 Turbo Rabbit, 95 SC Miata, 01 A4Q
I Just did it this way myself. Except I tee'd into the other Vac line right next to the FPR line on the underside of the manifold. I already tee'd the FPR line once for my boost gauge. Also, I used a ss bolt to plug the hose instead of capping it at the N249. Boost is much more predictable at part throttle.
Coil Pack Retaining Brackets Here 1.8T TROUBLESHOOTING GUIDE TRACK DAY VIDS - WGI, LRP, NJMP http://www.youtube.com/user/baltruckij
turbovw18
7-5-2002
getting posts deleted
Re: Bypassing the N249 - An Easier Approach (enginerd) » | « » 8:00 PM 4-27-2004 | |
| Quote, originally posted by enginerd » | I Just did it this way myself. Except I tee'd into the other Vac line right next to the FPR line on the underside of the manifold. I already tee'd the FPR line once for my boost gauge. Also, I used a ss bolt to plug the hose instead of capping it at the N249. Boost is much more predictable at part throttle. | i took this route as well... works just fine
My Car that Sucks Don't click here pittspeed 13.somethingbuy my stuff!!!
1.8tizzle
5-22-2003
Roanoke, VA
2005 Honda s2000
Re: Bypassing the N249 - An Easier Approach (turbovw18) » | « » 9:39 PM 4-27-2004 | |
I did it a more ghetto, easy way. The black vaccum box on the valve cover....... i unbolted it, and followed that line to where its plugged. Pulled that hose, and just put a cap over the tube where the line went to. Works fine for me.
Current: 2005 Honda s2000 Past: 2003 1.8t GTI Myspace AIM: turbo tizzle
DJKeebler
12-5-2001
Kaneohe HI
No car right now. In transition.
» | « » 10:49 PM 4-27-2004 | |
Is this another possible solution to upgrading the N75 when surging is a problem? I'm still learning about my motor and saving for a VAG-COM setup so I don't want to do anything that will throw codes or cause more problems.
Matchstick red 2002 GTi 1.8T-Just a few select goodies
Mk4Jettaboy
7-21-2003
Myrtle Beach SC
Re: (DJKeebler) » | « » 12:13 AM 4-28-2004 | |
My car surges also, im running garrett software. It only surges at WOT in a high gear. Is this a remidy for my problem, Sorry im not the smartest at engines
00 1.8t Jetta GIAC v.11 - 007p on the flip - VDO(blue lighted)
dbrowne1
10-31-2000
Richmond VA
Re: Bypassing the N249 - An Easier Approach (1.8tizzle) » | « » 10:11 AM 4-28-2004 | |
| Quote, originally posted by 1.8tizzle » | | I did it a more ghetto, easy way. The black vaccum box on the valve cover....... i unbolted it, and followed that line to where its plugged. Pulled that hose, and just put a cap over the tube where the line went to. Works fine for me. |
This doesn't actually bypass the N249 - the electronic valve still mediates what the DV sees. It helps because the valve can no longer introduce vacuum to the mix. What I did is plug the DV directly into the intake manifold. The DV now sees exactly what is in the manifold, there's nothing inbetween. There may not be any practical difference - but I like knowing that the DV actuation is directly from the manifold.
dbrowne1
10-31-2000
Richmond VA
Re: (Mk4Jettaboy) » | « » 10:12 AM 4-28-2004 | |
| Quote, originally posted by Mk4Jettaboy » | | My car surges also, im running garrett software. It only surges at WOT in a high gear. Is this a remidy for my problem, Sorry im not the smartest at engines |
Try bypassing the N249 as I suggested. It may help, it may not, but it's a very cheap mod that you should do regardless.
GTIMOLA
3-19-2004
Maumee OH
Re: Bypassing the N249 - An Easier Approach (dbrowne1) » | « » 10:19 AM 4-28-2004 | |
| Quote, originally posted by dbrowne1 » | This doesn't actually bypass the N249 - the electronic valve still mediates what the DV sees. It helps because the valve can no longer introduce vacuum to the mix. What I did is plug the DV directly into the intake manifold. The DV now sees exactly what is in the manifold, there's nothing inbetween. There may not be any practical difference - but I like knowing that the DV actuation is directly from the manifold. |
I did this and now have severe fluttering of my hyperboost DV. Cleaned and lubed it and that didn't help. I believe that the n249 also serves to assist in slamming the DV open as fast as possible via the extra vac in the black canister. I was not having any problems with the N249 opening the DV when I didn't want it to so I may be putting the canister back on and reconnecting everthing in a stock manner.
| Quote, originally posted by SAMMICHES » | Hi! My name is Sean, and I'm str8 Ghetto!!! |
http://www.cardomain.com/memberpage/690474
SlvrBllt
10-15-2001
Heat Soak Florida
2002 VW Jetta 1.8T
Re: Bypassing the N249 - An Easier Approach (GTIMOLA) » | « » 10:54 AM 4-28-2004 | |
| Quote, originally posted by GTIMOLA » | I did this and now have severe fluttering of my hyperboost DV. Cleaned and lubed it and that didn't help. I believe that the n249 also serves to assist in slamming the DV open as fast as possible via the extra vac in the black canister. I was not having any problems with the N249 opening the DV when I didn't want it to so I may be putting the canister back on and reconnecting everthing in a stock manner. |
The problem here is your hyperboost DV and too stiff of a spring. With a Forge valve, mine does the same thing. With the stock valve it works like a champ. Have you tried reversing your DV?
JettaRed
8-14-2000
Middletown Maryland
04 Audi TT 225QC * 00 Audi A4 1.8TQ * 99.5 Audi A4 1.8TQ
Re: Bypassing the N249 - An Easier Approach (dbrowne1) » | « » 11:03 AM 4-28-2004 | |
Is the sole purpose to eliminate surging or fluttering at high boost levels (>15 psi)?
2004 Audi TT 225Q GIAC, DevilsOwn Injection, Neuspeed 19mm RSB, BoostMachine, Haldex Blue, Borla CatBack 2008 Infiniti G35x 1999.5 Audi A4 1.8TQ GIAC K04 PC-16, DevilsOwn W/M, 5sp Tranny Swap, Short Shift 2000 Audi A4 1.8TQ GIAC 2003 GTI 1.8T Black SOLD 2001 Audi A4 1.8TQ DEAD 2000 Supercharged JettaRed DEAD
GTIMOLA
3-19-2004
Maumee OH
Re: Bypassing the N249 - An Easier Approach (SlvrBllt) » | « » 11:03 AM 4-28-2004 | |
I figured that this was the problem. Unfortunately, the stock dv failed and I would really like to use the Hyperboost. I wonder if there is a way that I could modify the current spring or get a softer spring.
dbrowne1
10-31-2000
Richmond VA
Re: Bypassing the N249 - An Easier Approach (GTIMOLA) » | « » 11:04 AM 4-28-2004 | |
I have an older Forge 006 valve (it's almost 4 years old) and it works fine with the bypassed setup. Zero flutter. I'm holding 25-27psi in the lower rpms, 20psi at 5K, using an MBC. If you had better performance with the N249/vac cannister then by all means go back to using it. Results are what matter. One thing that's nice about the setup I suggest is that it is easily reversible. The only "permanent" change is cutting the fpr line, and that's easily fixed with a plug on the T or a plastic hose connector.
dbrowne1
10-31-2000
Richmond VA
Re: Bypassing the N249 - An Easier Approach (JettaRed) » | « » 11:05 AM 4-28-2004 | |
| Quote, originally posted by JettaRed » | | Is the sole purpose to eliminate surging or fluttering at high boost levels (>15 psi)? |
Main purpose is to reduce flutter and resulting jerky boost at partial throttle, between 0 and 5psi of boost, where the N249 seems to get confused and can make your throttle very sensitive and jerky. It worked well for me.
JettaRed
8-14-2000
Middletown Maryland
Re: Bypassing the N249 - An Easier Approach (dbrowne1) » | « » 11:13 AM 4-28-2004 | |
It amazes me how every car is soooo different.
hugemikeyd
8-28-2001
Long Island NY
2003 Jetta Wolfsburg
Re: Bypassing the N249 - An Easier Approach (dbrowne1) » | « » 11:23 AM 4-28-2004 | |
that is a great way to do it, keeps it looking stock since you are changing an area normally hidden by engine covers...
.: Huge Mikey D :. :: 2003 Wolfsburg TyrolSport :: REVO ::
coolvdub
2-19-2000
California City CA
2002 Jetta GLS 1.8T/ Reigning High Mileage King 312,107 & counting
Re: Bypassing the N249 - An Easier Approach (hugemikeyd) » | « » 3:27 PM 5-1-2004 | |
I looked at my car an '02 Jetta and the small braided line goes to the Combi valve not the FPR. So my question is, did you actually tap into the FPR line which is braided also and very short or the line feeding the Combi valve, also braided, but longer and right next to the line that feeds the N249 valve.
Don Spread The O&A Virus Spreading the Tip Love CANCER SUCKS
hugemikeyd
8-28-2001
Long Island NY
Re: Bypassing the N249 - An Easier Approach (coolvdub) » | « » 11:29 AM 5-2-2004 | |
| Quote, originally posted by coolvdub » | | I looked at my car an '02 Jetta and the small braided line goes to the Combi valve not the FPR. So my question is, did you actually tap into the FPR line which is braided also and very short or the line feeding the Combi valve, also braided, but longer and right next to the line that feeds the N249 valve. |
if you are talking from the intake minifold, its the same vaccum/boost source, so it doesn't matter... but i would use the FPR line.
coolvdub
2-19-2000
California City CA
Re: Bypassing the N249 - An Easier Approach (hugemikeyd) » | « » 1:02 PM 5-2-2004 | |
Okay, thanks for the advice. I will do exactly that.
turbotazzy
7-15-2002
Miami Florida
2005.5 Audi S4 Avant, 2002 VW GTI 337
Re: Bypassing the N249 - An Easier Approach (coolvdub) » | « » 7:39 PM 5-8-2004 | |
Okay, I just did this mod. Partial throttle is improved bigtime over what it was before. A couple times, I punched it and backed off the throttle. I had the lurch a couple of times but it went away after more driving.However, I think I'm still getting a DV flutter. I have the 710N valve and it sounds like the DV is opening and closing rapidly at partial throttle while it hisses. Ssss-sss-ss-ss-sssss-sss-sss! Lol! Would a MBC help or maybe an adjustable DV (GReddy Type S) so that I can play with the settings and try to adjust it? By the way, I tee'd into the fpr line. It was a b*tch to get to! 5 minute job? Yeah... okay.
Modified by turbotazzy at 4:40 PM 5-8-2004
Frantz Tassy Miami, Florida Current car: '05.5 Audi S4 Avant Current car: '02 GTI 337 Former car: '93 Honda Civic Si Turbo
VWJETTAVW
11-17-2002
Miami FL
2006 Audi A4 2.0T
Re: Bypassing the N249 - An Easier Approach (turbotazzy) » | « » 8:02 PM 5-8-2004 | |
to get to? The fpr line is like right there, it should take 2 minutes to cut it and put a t on it
Old weak dyno - BLIM -
turbotazzy
7-15-2002
Miami Florida
Re: Bypassing the N249 - An Easier Approach (VWJETTAVW) » | « » 4:09 AM 5-9-2004 | |
Maybe I used the wrong T. I used3/16" x 3/16" x 3/16". It didn't go on very easily. That combined with what I found to be tight quarters (couldn't get a firm grip on it to push the hose on the t) didn't make it a 2-minute job... for me. That fpr line is short!!!
goualon69
12-27-2002
QUEBEC
JOLF 94 1.8T
» | « » 3:17 PM 5-12-2004 | |
some picture of what you are talking? because i plan to do it, i have to try everything to solve my problem! thanks
Jolf A3(94)with 2000 beetle 1.8T engine (APH), K03sport, 3"DP, 2.5" cat-back, Upsolute chip, Saab viggen FMIC, forge dv, diode, 320cc, adj FPR, in-line gas pump, N75J, Koni H&R, Neuspped tie bar, peloquin diff, 16lbs F.W., ACT vr6 clutch, vr6 brakes on 4 lugs. Peaking 20psi and holding 16psi, i am not english speaker, exuse my missunderstanding writing!!
dbrowne1
10-31-2000
Richmond VA
Re: Bypassing the N249 - An Easier Approach (turbotazzy) » | « » 3:44 PM 5-12-2004 | |
| Quote, originally posted by turbotazzy » | By the way, I tee'd into the fpr line. It was a b*tch to get to! 5 minute job? Yeah... okay.
I'm sorry, but a one-armed ape with downs syndrome and a butter knife could do this in 5 minutes. The line is practically staring you in the face if you are looking down at the point where you detach the hose between the DV and the N249. The 3/16" T fitting is tight, but tight is good. It means it won't come loose, even if you don't use clamps on it.
Modified by dbrowne1 at 12:45 PM 5-12-2004
keycom
9-26-2001
Nebraska City
2002 Jetta 1.8T 1984 Rabbit GTI 1983 Rabbit GTI 1990 Audi Coupe Quattro 1976 Bus RIP
Re: Bypassing the N249 - An Easier Approach (dbrowne1) » | « » 4:20 PM 5-12-2004 | |
Any reason for those of us unchipped (as yet) to do this mod? I don't have any noticeable surging or other problems.P.S. I typed this with one hand, using my butter knife.
fat Rabbits . . . Member #17 #52 SCCA ITB Bare Bones Racing
turbotazzy
7-15-2002
Miami Florida
Re: Bypassing the N249 - An Easier Approach (dbrowne1) » | « » 8:53 PM 5-12-2004 | |
| Quote, originally posted by dbrowne1 » | The line is practically staring you in the face if you are looking down at the point where you detach the hose between the DV and the N249. Modified by dbrowne1 at 12:45 PM 5-12-2004 |
Just because it's staring me right in the face doesn't mean it's easy to work with. It took 1 minute to cut the line and put the tee on one end of the hose but to put the other tee on was a pain to me. You can't tell me you can put two hands in there without a problem. The fpr line is very short! My setup doesn't look like this: http://www.aurealanrealms.org/~tjboyer/PIPING.jpg If it did, it would be much easier... but whatever. I'm 90% surge-free now. Thanks for the write-up. No thanks for the sarcasm.
Stroked1.8t
1-8-2004
92 GTI 20v
Re: Bypassing the N249 - An Easier Approach (turbotazzy) » | « » 9:32 PM 5-12-2004 | |
be smarter then what you are working on. if you can't get it with the hose on, remove it, you can also turn the FPR to the side to allow you better access to the Vac line. this is a very simple thing to do.
92 GTI 20/20, 3071r, E85 12.8@124 12.66@121
dbrowne1
10-31-2000
Richmond VA
Re: Bypassing the N249 - An Easier Approach (turbotazzy) » | « » 8:55 AM 5-13-2004 | |
| Quote, originally posted by turbotazzy » | If it did, it would be much easier... but whatever. I'm 90% surge-free now. Thanks for the write-up. No thanks for the sarcasm. |
Well, you're welcome for the writeup. That's why I put it here. Please note that NOWHERE in the writeup did I say that is was a "five minute job," a term that you injected and which you sarcastically commented upon in your entirely unnecessary and unsolicited response. Also note that I have not one, but TWO 3/16" T fittings in my "short" fpr line. That's probably because it isn't really that short at all.
bump909
6-30-2002
Lynn MA
2005 Saab 9-2x Aero, 2001 Aprilia SL1000 Falco
Re: Bypassing the N249 - An Easier Approach (dbrowne1) » | « » 11:12 AM 5-13-2004 | |
awesome, thanks for the write up dbrowne. my part throttle is horrible.. hopefully this will improve it.
Jon Electro Oontz Boston Derby Dames myspace
turbotazzy
7-15-2002
Miami Florida
Re: Bypassing the N249 - An Easier Approach (dbrowne1) » | « » 2:54 PM 5-13-2004 | |
My comment was never meant sarcastically and it wasn't directed towards you. Okay, I'll stop this unnecessary bickering and keep this thread on topic.Question: How do I stop the lurching I get when I let off the throttle slowly? Is this a DV issue? This doesn't happen when I let off quickly. I've read that the DV opens when you're on boost and closes when you let off. I have the 710N valve so it's non-adjustable. Would an adjustable DV help resolve this issue? I thought bypassing the N249 would help but it hasn't. Thanks in advance.
guywhoisjustin
3-17-2004
Greenville NC
2004 GLS Jetta 1.8T
Re: Bypassing the N249 - An Easier Approach (dbrowne1) » | « » 3:01 PM 5-13-2004 | |
Would this mod be any good with stock engine?
Who wants to do to D's Diner? Who wants to go down to D's?
dbrowne1
10-31-2000
Richmond VA
Re: Bypassing the N249 - An Easier Approach (guywhoisjustin) » | « » 3:37 PM 5-13-2004 | |
| Quote, originally posted by guywhoisjustin » | | Would this mod be any good with stock engine? |
It is meant to solve a specific issue (partial throttle sensitivity) which is not usually an issue in stock cars.
