kamzcab86
2-13-2002
Topless in AZ
1986 VW Cabriolet Best Seller, 2000 VW Jetta GLS VR6
 D@mn Center Vent Problem Thread« »
Okay, forget every other thread and post I ever made about this stupid center vent problem 'cuz after spending nearly all Saturday on the problem and sitting down with manuals and ETKA last night, I had a revelation that leads me to describe myself as a royal idiot. Herein lies a few explanations & clarifications of the system as well as another quest for suggestions as to what in the hell is going on...
First, I replaced the vacuum distributor. A) I was told this was the problem several years ago (dealer wanted $300 to replace it ), B) it didn't solve the problem (surprise, surprise). But, the old one made a racket and was difficult to move so the replacement wasn't a total waste. Being the curious girl I am, I took apart the old one; for anyone curious as well, here's a pic of the nifty thing:
Is that cool or what? See the holes in the bottom piece? See that one is larger than the rest? Okay, this is where Bentley is totally wrong,... EDIT: No, I was totally wrong ; a vac test revealed that the 2 hoses on the front of the distributor are correctly diagrammed in Bentley. AND, reverse the air re-circulation and vac reservoir arrows in the pic above.
During this whole escapade, I asked this question: where does the air get routed for the defrost vents? After studying all my sources I came to the revelation that Bentley, once again, needs better clarification! The "defrost servo" is really the defrost/center dash vent servo! When the flap is closed, air flows out the defrost vents; when flap is open, air flows out the center vent but never both at the same time. The servo in the rain tray is for air recirculation and is operated only when the top selector lever is on the far left setting (Max A/C). Herein lies another pic:
Okay, now here's the conclusion:
1. The footwell vent flap operates as normal (i.e. servo engages and retracts).
2. The air recirc. vent flap operates as normal ((i.e. servo engages and retracts).
3. The defrost/center vent servo retracts slightly to shut the flap but does not open the flap which leads to the presumption that a) there's not enough vacuum to open that heavily spring-loaded flap, or b) the servo is failing. My guess is "a" so now it's a matter of tracking down why there's not enough vacuum. The vac tubes (hard plastic stuff) will be replaced as well the vac connector hoses (some for the engine vac system look crappy). If it's "b" you'll be hearing a dictionary of swear words from AZ 'cuz that servo looks to be a really huge PITA to replace!
Now, my question is with this check valve. On the check valve is the word "motor" on the side and an arrow on top; which direction is the arrow to be facing? And, in checking the valve, I blew and sucked with all my might and nothing; my dad sucked on one end and said that it was functioning. Someone said this was a $3 part, but in fact, new, it's a $35 part so before replacing the stupid little thing, I want to check to make sure it doesn't work properly first. I do now have a vacuum gauge that I'll be hooking up tonight to see what it shows as well.
Oh, and before I hit submit, click here for a pic of an explanation on the HVAC controls and what/how they operate (it's too huge to post).
Modified by kamzcab86 at 11:35 AM 9-28-2004
Modified by kamzcab86 at 11:36 AM 9-28-2004
Cabby-Info.com - The Original VW Cabriolet FAQ Site!
Advice is seldom welcome, and those who want it the most always like it the least.
icky1.8T
12-8-2003
Reno/ Roanoke Va
85 Rocco 8v /87 Cabriolet Best Seller [retired]
 Re: D@mn Center Vent Problem Thread (kamzcab86) »« »
This is a very helpful post! I just gained a much better understanding of the damn Vacuum system I have and found that a intrepid investigator has found that even "The Bentley Bible" can suffer from misprints and wrong information. Thanks for the hard work and useful information
01 Golf GLS 1.8T.....4 Door "Franz" [Sold]
89 Fox GL Sport "Otto" [Sold] Founder/President, Reno Auto Werks
82 4 Door Rabbit L "Herman" [Sold]
85 Golf CL [sold before I could ever drive ]
Moljinar
9-20-2001
Indianapolis IN
85 Cabby, 90 Jetta, 83 GTI (RIP)
OK first you need to go to Autozone and get a generic check valve for $2. Forget that $35 thing. Blow/suck on it to establish direction if not marked.
Get a MityVac! Little dude can save you hours by letting you vacuumize the lines and solenoids to see what's working. Or pressurize where needed too!
Oran's greatest hits!
Starter relay Swap to manual tranny
Hammer of the Gods blog
Moljinar
9-20-2001
Indianapolis IN
Quote, originally posted by kamzcab86 »
Okay, The servo in the rain tray is for air recirculation and is operated only when the top selector lever is on the far left setting (Max A/C).
Mine is set to recirculate interior air ONLY when in Heat setting. Warms up the car faster.
kamzcab86
2-13-2002
Topless in AZ
 Re: D@mn Center Vent Problem Thread (Moljinar) »« »
Okee-dokee, will do Moljinar
Anyone with a fully functioning A/C system wanna take a quick look at their check valve to see which way the arrow is pointing? Pleeeeeeze...
Cab42
8-23-2004
Boston MA
87 VW Cabriolet, 92 VW Cabriolet
One needs masters degree to understand what HVAC system is supposed to do, PhD to understand WHY, and 7 year post-doctoral studies to understand how to fix damn thing...
6cylVWguy: If you purchase a car with the intention of modifying but you can't respect it in stock form, you will never respect it modified. You are doing yourself a great injustice.
Moljinar
9-20-2001
Indianapolis IN
Just checked my 83 GTI manual and found on page 7-29 two diagrams showing how to run the vacuum lines. ones a picture and ones a diagram. And the don't agree with each other And neither is the same as what you've come up with!
kamzcab86
2-13-2002
Topless in AZ
Quote, originally posted by Moljinar »
See, the HVAC controls have the wrong pics on them; 'cuz even when you have the top lever over to "Max A/C", you can move the bottom lever over to the right (heat) and it'll put out heated air from the center vent! So, the far right on the top selector is actually air recirculation not A/C but the A/C system is on when the lever is set to that position and puts out heated air from the center vents at the same time if you want it too .
Cab42
8-23-2004
Boston MA
The fastest way to get the info on this is to hang upside down the guy who designed this system in the middle of Wolsburg downtown in Germany and to keep him that way subsequently until he tells all, AND appologizes to all Cabriolet owner....
kamzcab86
2-13-2002
Topless in AZ
Quote, originally posted by Cab42 »
See? See why we're all so friggin' confused about this damn system?! Even the gurus at Bentley can't get it straight!
Black_cabbie
7-15-2003
Greek Proud Fellow
07 Audi Q7 4.2 S-Line, 07 Smart Passion Four Two, 07 Mercedes A-150
I just had a look and the motor logo in on the side of the motor. There is also an arrow which points towards the inlet manifold as well.
Hope this helps.
Digifant Chip for Sale!
Black_cabbie
7-15-2003
Greek Proud Fellow
 Re: D@mn Center Vent Problem Thread (Black_cabbie) »« »
Btw, mine is so hard I think I am going to break it sometimes.
And the air/circulation function doesn't work because the whole mechanism "bents" when I force the slider all the way to the left. it works if I forced the distributor by hand though.
Any solution to that?
kamzcab86
2-13-2002
Topless in AZ
Quote, originally posted by Black_cabbie »
Hope this helps.
Muchas gracias! Mine's installed correctly; now, to see if it's working correctly...
Black_cabbie
7-15-2003
Greek Proud Fellow
let me know if there is anything else you need. I am in the bank doing the grave yard shift so I have all the time in the world.
kamzcab86
2-13-2002
Topless in AZ
The control mechanism might need lubing or is binding on something. Might check to see if the vac dist. is the problem: push down on the vac dist. while pulling up on the control arm and move the arm out of the way. Move the vac dist by hand; if it's difficult to move, there's your problem. Might just need to spray some WD-40 type of lube into the control arm pivot point and grease up the selector plate(s).
Black_cabbie
7-15-2003
Greek Proud Fellow
Kammy,
I think I have both problems.
As soon as I finish with the works in my apartment, I will dedicate myself to make the car new again
Thanks for the info!
vdoubleyou
7-22-2004
Danville VA
87 Cabriolet
My car is missing that black plastic thing that holds the levers together. The green arrow in the picture above is pointing to it. Anybody have one of these laying around. Does it just snap in or what?
Bob Deitrich
87 Cabriolet
71 Beetle
89 GMC Suburban
Mine is a life of extreams
cnrmoose2003
10-7-2003
Abingdon VA
01 F-150 XLT SC 4X4,88 Cabriolet
 Re: D@mn Center Vent Problem Thread (vdoubleyou) »« »
It has probably broken off and is laying around somewhere there in your dash. I just had the same thing happen the other day. Find the piece if you can and put some epoxy on it and carefully push it down in the hole, you will have to twist it a little to get it to sit flush. Let it sit a couple of days and then your top lever will work perfect. Chris
ectonvw
3-15-2001
Norristown PA
84 Rabbit Convertible, 02 325 xi, 03 Passat Variant
 Re: D@mn Center Vent Problem Thread (cnrmoose2003) »« »
I went through this last year on my 84 Rabbit Convertible. The center vent flap did not work, air only came out of the defrost vent. The center vent vacuum servo failed. It was only a $35 part from VW, but you're right - it's a little tough to replace - the dash needs to come out.
Removing the dash is not hard, it's just time consuming. Disconnect the battery. The hardest part is getting the knee bar out. It's easier if you remove the front seats. First you need to remove the Jetronic box bolted to the kneebar on the pass side. 2 bolts and 2 nuts on each side of the kneebar and it's out. The dash comes out pretty easy after that - couple of bolts on each side, couple of screws on the bottom. You will also need to take the steering wheel off.
Once the dash is out, it's real easy to replace the servo.
As for binding controls, there also is some sort of AC thermostat connected to one of the levers. That could require some lubrication as well.
Hope this helps.
kamzcab86
2-13-2002
Topless in AZ
 Re: D@mn Center Vent Problem Thread (ectonvw) »« »
Good to know . Replacing the servo will be a last resort for me, but I'll bookmark this thread to keep your instructions handy .
I ran a vac test on the system this morning, per Bentley's instruction; as soon as I turned the engine off it lost vacuum so there's a leak or two somewhere. The check valve appears to be functioning properly as well. So, all vac lines will be replaced and a direct vac test on that servo will be performed sometime this week.
northernMike
12-22-2002
toronto on
87 cabriolet, 92 jetta ... well, parts of them
when i first got my cabbie i was thinking i'm gonna install a climatronic from an 80s audi ...
i didn't.
i'm gonna re-engineer my controls one day using NO original parts. i'm frustrated too.
Black_cabbie
7-15-2003
Greek Proud Fellow
 Re: D@mn Center Vent Problem Thread (northernMike) »« »
Quote, originally posted by northernMike »
i didn't.
Actually I though of that some months ago. Do you know of a panel which has the same size and fits the area under the radio?
ectonvw
3-15-2001
Norristown PA
I used to own a 78 Scirocco without AC. The entire Heater/defroster/vent system was cable operated - no vacuum controls. When my convertible's vacuum system went out, I was seriously considering replacing my vacuum controls with cable operated ones. I couldn't find all the parts, though!
It would have worked fine - remember how the old controls had 3 sliders (one for temp)? One slider would replace the center vent servo, the other would replace the other 3 position servo.
jordanvw
1-8-2001
southeast, Pa. USA
'90 cabby, '84 vanagon wolfsburg, '91 Westy, '90 Multivan, '85 vanagon transporter doublecab pickup
 Re: (ectonvw) »« »
bump so i can read all this later when i have more time thanks kammy for doing the investigative work and posting pics ..makes stuff easier to understand
dont send an IM.. SEND ME A EMAIL. thanks.
want a faster response? SEND A EMAIL PLEASE.
jordanvw@aol.com
A bunch of parts vanagons and parts westy campers.. need T3/ vanagon / westy parts?? email me.
if no response to a vortex IM or thread, please EMAIL me!
welcome to vw poortex, where punk kids talk trash, and have no cash
kamzcab86
2-13-2002
Topless in AZ
 Re: (jordanvw) »« »
Quote, originally posted by jordanvw »
I'm in the process of replacing all the vac lines (particularly the rubber connector hoses). This morning I discovered the tube going into the vac reservoir was loose (easy to pull out and put back in); the grommet is pretty worn on the inside (new tube will be siliconed to the grommet). Still need to test the servo which I'll do tonight.
By the end of all this, I'll know that stupid vacuum system inside and out!
PART 2 OF THIS SAGA: http://forums.vwvortex.com/zerothread?id=1603270
Modified by kamzcab86 at 12:02 PM 9-24-2004
Busbodger
7-28-2004
Little Town TN
'97 Cabrio, '78 VW Westy (Corvair powered), '65 Beetle (Type IV powered), '99 CR-V EX AWD
 Re: (kamzcab86) »« »
Yea! VW did a good thing - they started using cable controls sometime before they built my '97. My '84 had the same problems in 1993.
For the person that suggested WD-40 as a lube for the pivot, use silicone spray. Won't evaporate and is plastic friendly. WD-40 is basically turpentine and evaporates. Vaseline is pretty good too for lubing plastic parts. I think that may be - mor eor less - what VW used.
Chris
TEAM SLOWPOKE
kamzcab86
2-13-2002
Topless in AZ
 Re: (Busbodger) »« »
Quote, originally posted by Busbodger »
For the person that suggested WD-40 as a lube for the pivot, use silicone spray. Chris
I said "WD-40 type" of spray 'cuz I had a brain lapse (I never use WD-40!); couldn't think of the name of the spray I always use: Tri-Flow (much better than WD-40 and it's a silicone spray)
Busbodger
7-28-2004
Little Town TN
Yeah! Tri-flow is good stuff. It doesn't make the plastic brittle?
Chris
TEAM SLOWPOKE
» Return to Cabriolet
