hamilton8415
10-30-2004
Santa Cruz CA
 VR6 Timing Chain Tensioner bolt - plugged!« »
Hi, I recently re-installed a re-built head on a VR6 in a '93 Passat. Engine started and ran smoothly, but valves seemed a bit noisy. After a few minutes of running the engine started running roughly and eventually quit with a rather unhealthy sound. Today I got around to taking it back apart and found the cams seriously mis-timed. I'm well aware of the implications of this and the potential that I'm taking this head off again for a second re-build. However, I was very careful with the cam timing when I put it together. I removed the timing chain tensioner bolt and found the small hole that allows oil-presure to charge the bolt plugged with a small bit of rubber, sorta o-ring material. Not sure at all where this bit came from but it sure has caused a problem. My main question is: Why is there no spring in this tensioiner bolt, relying on oil pressure is great when the engine runs, but why doesn't this tension relax when the engine is stopped. Perhaps there's a check valve somewhere, but that would still leave the initial start-up after rebuild a bit dodgy. Does anyone have experience with that bolt, is it supposed to have an inherent "springiness" independent of oil pressure? (it's the earlier design, with a nipple that fits into a grove in the metal tensioner itself, what a horrible design that piece is, but anyway...). Thanks in advance for any help, my current plan is to re-time, re-assemble and compression test to see if I can figure out the state of the valves before I remove the head. -- andy hamilton
kreuzer
5-20-2001
that are pure excrement
 Re: VR6 Timing Chain Tensioner bolt - plugged! (hamilton8415) »« »
Sounds like your chain skipped, causing the cams to be mis-timed. The newer style chain tensioner (from mid-97 and up ) do contain a spring, and hold the chain in place even when there is no oil pressure. I would change my upper tensioner bolt and rail to the newer style. the newer motors only have a single row upper chain, but don't worry about that. This setup will work fine with your double chain setup. the newer style upper rails also last a lot longer that the older ones. Many people have done it with no problems.
old rail :
new rail:
old tensioner bolt:
new tensioner bolt withspring):
Modified by kreuzer at 4:52 PM 10-30-2004
Per pound, my car is cheaper than a Big Mac.
90 Mercury Topaz
mhjett
10-16-2000
Arlington VA
1995 Jetta GLX VR6
 Re: VR6 Timing Chain Tensioner bolt - plugged! (kreuzer) »« »
I upgraded my 95 VR6 with both those parts. Don't know why the old bolt has no spring pressure. Good luck
1995 Jetta GLX VR6
.:www.michiganvw.org:.
A2T
11-9-2000
Atlanta, GA
92 SLC
 Re: VR6 Timing Chain Tensioner bolt - plugged! (mhjett) »« »
Bolt has a check valve built into it. Therefore, it can ONLY extend, never compress. Once oil pressure extends it, it will not retract (unless you put a very small wire into the body of it to release the check valve, then you can push it back in. When installing it, you must first bleed that bolt, by engaging the check valve with small wire, and submerging the bolt in tub of oil. Then, extend and retract bolt tensioner a few times. Set tensioner on bolt to provide "a little" tension on chains. Once engine fires, it will build pressure and tension itself. As long as there isnt peice of rubber in the oil port
pi2060@yahoo.com
$95 Metal VR6 Crack Pipes, Shipped -- TRACK TESTED !!!
http://www.vwfixx.com/forums/i...97415
Custom Made VR6 Intake Mani Shift Rod Bushings - http://www.vwfixx.com/forums/i...34870
BILLET VR6 Keychains http://www.vwfixx.com/forums/i...34080
9seven6
6-7-2004
Long Island
Quote, originally posted by mhjett »
I used them on my 95 as well. Works good.
http://www.fourseasontuning.com- VW/Audi Performance & OEM Parts Source
Blowing up VR6's since '02
one_vee_dub
12-4-2003
Acton, On.
Rides - '96 GTi VR6
 Re: VR6 Timing Chain Tensioner bolt - plugged! (P i m p y 9 7 6) »« »
do i need to change BOTH parts? or can i put in a new style bolt alone???
http://WWW.IDANCECANADA.CA
 Re: VR6 Timing Chain Tensioner bolt - plugged! (one_vee_dub) »« »
The rail and bolt are designed to work together. You need both.
Gary
Gary
Now: '99.5 Jetta GLS VR6 (276,000 miles and counting! )
* Free VAG-COM scans in the DC area - IM me *
fastslc
9-14-1999
Mauritius
 Re: VR6 Timing Chain Tensioner bolt - plugged! (VgRt6) »« »
Same here.. I used both for my 92 VR.. I've put 3K miles on it so far.. No problem
d
92 SLC - C2 , AWE Short Shifter
Visit my Island = http://www.mauritius.com
formulavr6
10-9-2004
Shediac NB
2004 Infiniti G35 Coupe 6MT Brembo Navigation
 Re: VR6 Timing Chain Tensioner bolt - plugged! (fastslc) »« »
I had similar problems with my other '93 passat aswell...I rebuilt the motor and re-used the tensionner thinking it was good(and keeping rebuild costs down )
and whenever I started the motor after sitting for more than an haour, the chains would make this gawd awful noise, but after it ran for like 5 seconds it would be perfect(didn't know what the problem was at first), Come to find out the tensionner was f'ed and was draining oil pressure when the car was shut off. it ended up missaligning one of the cams by one tooth and causing loss of power (but still running). In your case, if the motor ran ALL that time with no oil pressure going there, and no tension on the chain, your probly looking at bent valves.
2004 Infiniti G35 Premium 6MT Navigation.
1997 Jetta VRT (solded)
Some people are like slinkies...
Not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
» Return to 2.8l 12v VR6 Engine Forum
