hoTTub
11-5-2000
Vortexer formally known as VR6 CABBY
 Real deal info on the Dahlback Intake Manifold.....Dynos inside.« »
Gotta start off by saying the guys at http://tjmmotorsport.com stand by their products....I told them that I was going to do this testing once and for all, and they told me that if for any reason I was not happy with the manifold I could return it and they would refund me the dyno time. They had no problem with me posting about what the products do.....they were not interested in anything more than me posting the facts... Fair enough...
Baseline Car is APR ST3 with Forge FMIC, BMC Intake and stock 225 intake Manifold.
I dynoed the car about 2 yrs ago and got what I thought were respectable #'s, many said they weren't *real* numbers because technically I did have 100 oct in the tank, while running the APR 93 program. For my first ever dyno, I wanted to have a 93 and a 100 oct run just to see what it pulls....however, it DID have 100 oct in the tank with the 93 program running but there is no other way of doing it short of draining the fuel tank
The first dyno is from 2 yrs ago and the car mechanically is the same, nothing had been added or changed....NOTHING. The only 2 differences between then and now is that this time, no 100 octane whatsover and this time of year, the weather is much better turbo weather so keep that in mind...
1st one done in 2002 83* and 29% humidty
2nd one done in 2004 66* and 9% humidty
I set myself up thinking that the dyno WAS going to be worse because of the 100 octane thing.....
However.....
Dyno 003 is 2002
Dyno 004 is 2004
Zero smoothing and SAE CF
These overlayed dynos were about 1 min 30 sec from each other today with no changes...just how I drove it in...stock 225 manifold.
Dyno 004 is the first baseline run
Dyno 005 is the second baseline run
On to the goodstuff.....
Dyno 04 is the 1st baseline today with stock 225 manifold
Dyno 06 is the 1st baseline with the new Dahlback manifold...no other changes.
The #'s are there in black and white.
Numbers speak for themselves...
Figure 284 vs 290 hp rounding it out.... Not bad at all
However, there was about the same loss of 7 ft / lbs on the torque in the same spot and rpm range...
Kind of cancels it out depending on how you look at it....
Here is one more dyno chart that I thought was interesting, not for any other reason than to debate that a smoothed dyno chart is MUCH different than your regular UNsmoothed dyno chart, notice that this chart is exactly the same as the one above, just with a dynojet smoothing factor of 5 (which happens to be the highest on a 0-5 scale)
Gain of about 8 hp and the loss of 8ft/lbs tq.... weird. I guess I thought smoothing it would make the variations *less* between variables, not more....oh well.
On the way home from NGP http://www.ngpracing.com (who graciously allowed me to hold up the dyno for the whole day while I switched manifolds and allowed me to bum a few clamps and stuff) I called Randy at TJM and told him the news...I gave him the decency of letting him know the results 1st before I posted em here for you guys...
I got home and sent him the dyno files (btw if anyone wants me to send them so you can view them with the dynojet file reader and get all the specs, temp, humidity, time rpm, A/f ratio etc.....IM and I will send them to you...) and we talked about the results...
We talked about whether we should have reset the ecu's each time before the 2 major runs, but I thought it to be bad to reset the fuel trim and any other adaptations right before you rev the crap out of your car on the dyno.
We talked about whether I did a recalibration of the throttle body ( I did not) since it was unplugged and then replugged in ???(Any insight on whether that matters???)
Randy at TJM thought that the #'s were not what they had hoped for because they had a bit different results but they never had #'s to compare like what I did today. They had always resest the T.B. and driven the car in between dynos...
Randy asked if I would be willing to get back to the dyno shortly at his expense and retest the setup after the car had been driven a bit and had time to adapt.
No problemo....
Here is the deal, its the holidays coming up very shortly and I work in retail...so it is a busy time for me but in a week or so after the new year I will be back on the dyno to see what happens....The shop stays a pretty consistent temp with the heaters this time of year, and as long as there is not alot of humidity...the #'s should be comparable....
After the ride home tonight, I have no intentions of taking this manifold off the car...I had my chance to send it back with refund of everything and only be out my time today...Nope, it is staying on the car.
I have owned the car 4 yrs, 2 years with the APR Stg 3 and I have NEVER broke the wheels loose in 3rd gear except when I had 100 oct in the car....only times.
Today, with 93 in the tank and the 93 program.......broke the wheels loose in 3rd.....in a heavy TT....I'll take that
Syay tuned for more info.....
Modified by hoTTub at 12:30 PM 12-16-2004
2001 TTR APR Stg 3 and a few more bits...
2001 Audi ProjekTT on Audiworld
2004 Jetta TDI *2002 Jeep Liberty * 1990 Cabriolet
gt2437
7-29-2000
2000 New Beetle GLX
damn! I'll read that when I get home.
edit:
just read. great write up!!
Modified by gt2437 at 5:50 PM 12-14-2004
2000 New Beetle GLX | APR STG3 | Stoptech | KW | RH | GHL | BAR Tuning | OEM Turbo S, TT, R32 bits...
2003 GTI 20AE | APR | Yarrowsport | Neuspeed | GHL
DubAdicted
1-20-2003
Rochester MI
01 Wolfsburg
 Re: (gt2437) »« »
very interesting
nice job on comparing the two
01 Wolfsburg
250whp/305wtq
dubnub
3-5-2004
Framingham MA
2001 Wolfsburg 1.8t
 Re: (gt2437) »« »
Very objective and nice writeup , interested to see the retest if you do it. So how long did TJM say they thought you would need to drive the car in between dynos for the ecu(or whatever) to adapt to the change in flow?
hoTTub
11-5-2000
 Re: (dubnub) »« »
Quote, originally posted by dubnub »
I dont think they had a time in mind really, it just needs to probably go through more than just an idle warm up period before another dyno run....ya know, throught the gears and into the boost a bit. All we did was get the coolant level up to normal before unleashing her. I know I stomped on it a few times on the way home and it wasn't until a little jockying for position to turn with another car that I stomped on it and she broke loose in 3rd......~honk~ sniff~ Daddy is sooo proud
Modified by hoTTub at 6:19 PM 12-14-2004
Hybrid VW
1-18-2001
NOT Washington State
 Re: (hoTTub) »« »
The peak numbers are one thing, but the DB manifold shows slightly quicker spoolup, and a significant gain in power from 5500-6300rpm. I would think it could get better after driving it some more
EFI101
1.BillyT
8-2-2000
Arlington TX
 Re: (Hybrid VW) »« »
Quote, originally posted by Hybrid VW »
That is the only place it made power, literally. To me, the difference in spool is negligable.
Interesting results.
www.dubsquared.net
Big Texas V-Dub Performance
experience > theory
DJKeebler
12-5-2001
Kaneohe HI
No car right now. In transition.
Are there any more complete pics of the car as it is now? I want a better view with the headlights since that isn't listed on your webpage. Sweet car!
Matchstick red 2002 GTi 1.8T-Just a few select goodies
chris86vw
2-23-2000
da souf
82,91,97,97,00,06 vw,vw,yamaha,dodge,vw,audi
 Re: (dubnub) »« »
A few questions/comments
First off having the TB disconnected to change the manifolds would not affet anything unless possily the key was switched on and it threw a code for a TB.
Clearing the codes before each run may have had some affects but if you are going to do that you must do it right before each run at aproximately the same time before you plan to do the next run to ensure that adaptation is as equal as it can be. I would say there is some possible adaptation needed to extract maximum power out of a mod like this but nothing you would say OMG over a few days later.
How many runs were done with the DBR manifold on the car? You show two before and only 1 after run. The gains are not spectacular were they worse on the second run (which theorecially should have been more adapated).
Also you mention you went home (I think thats what you said) to change the manifolds. How far of a drive was it.. back roads or highways?? Did you go WOT with the car? Or was it changed at the shop I forget what was said.
The dyno looks like what happens on any specially tuned intake, manifold it only works in one area of the power band because thats where it happens to make that "perfect" frequency.
OPINION OPINION OPINION (if you don't like it hit the back arrow)
I personally would say from the results where they stand that it is not worth the cost of this upgrade. The area under the curve where there are gains is extremely small only about 750rpm and are not that spectactular at that. If this were to retail in say the $400 range tops I'd say maybe people should consider it but what really needs to be looked at is the area under the curve and its far from impressive for that price.
does anyone else have an obsession with the yaris 3-door like I do? can't stop thinking about building a turbo one.
"You agree, through your use of this service, that you will not use this Discussion Forum to post any material which is knowingly false and/or defamatory, inaccurate, abusive, vulgar,......"
These rules apparently do not apply to all members.
hoTTub
11-5-2000
 Re: (chris86vw) »« »
Quote, originally posted by chris86vw »
Chris, I did 3 runs with the DBR manifold but did not post them because they were worse, but I attributed that more to heat soak just like what was shown the the 2nd chart above.....even with a FMIC, you still lose HP, especially with only waiting a minute or so in between runs... I can post them but I did not think they were really relevant...
As for the drive home...no, the car did not leave the dyno....2 baseline runs with the 225 manifold were done and then shut off and the manifold changed on the dyno, not even unstrapped. I did the swap myself.
Only time for adaptation would be the idle up to normal coolant temp to do a safe run while it was at operating temp.
Don R
10-3-2002
Manifesting Within
2000 Golf AWD 1.8T
Just a simple question...How is the spool-up response time in between shifts? Quicker than before?
Elitedubs |Unitronic - DonR@unitronic.ca | QED Power | Pagparts
UniSettings for USB OBD Cable
hoTTub
11-5-2000
 Re: (Don R) »« »
That is really hard to say...the #'s speak volumes, but the fact that my car has NEVER ripped 3rd gear at 5k-7k rpm's except the times I had 100 octane in the tank in the 100 octane programs speaks a bit more to me personally...
Like I said, I could return it for a full refund of parts and dyno time, and I have no intention on doing it
chris86vw
2-23-2000
da souf
 Re: (hoTTub) »« »
Quote, originally posted by hoTTub »
I"d post them they could be very relevant. If the manifold has a spike there it should do it on every run somewhat consistantly even if the over all power is lower.. Now that you mention the car was not driven and left on the dyno makes me question the over all power even more then orginally. The first dynos would have been straight off the road with much higher under hood temps then letting it sit to work on the car while it was changed (how long did the swap take), especially if you said it sat long enough for the coolant temps to drop enough to warrant warming it up again.
Certainly not 30hp no matter how youlook at it.
I'm gonna have to go back to my orginal thought that the thin opening that is supposed to make for even airflow is actually probably causing some sort of restriction that only allows an increase in airflow at the one frequency that occurs in that rpm range.
Don R
10-3-2002
Manifesting Within
2000 Golf AWD 1.8T
 Re: (hoTTub) »« »
Sorry, but you didn't answer my question; I'm not questioning the #'s when you went home and went ripping thru the gears how was the response in between shifts...did it improve or you really can't tell the difference...Thanks
hoTTub
11-5-2000
Just for clarification...
the car was not driven ON to the dyno and then.....BS'd for a while, strapped the car in etc.....all in all, about an hour passed from the time I pulled in to the time I dynoed...
It took me about 2 hrs or so to do the swap, I had to reroute some vac lines and trial fit some things before I hacked my other setup...
So, yes...about 2 hrs passed but the car was brought up to temp and I was not ROMPING on it when I was driving to NGP....
bobqzzi
9-24-2003
Coventry RI
2001 VW Jetta 1.8T
 Re: Real deal info on the Dahlback Intake Manifold.....Dynos inside. (hoTTub) »« »
Thanks very much for sharing your information.
QED Power.Com
Stock and high performance 1.8T parts.
QED Engine Forum
Turbo VW.Com
hoTTub
11-5-2000
 Re: (Don R) »« »
Quote, originally posted by Don R »
Can't say I noticed a diff in spool, only a bit in power
Don R
10-3-2002
Manifesting Within
2000 Golf AWD 1.8T
 Re: (hoTTub) »« »
Thanks, reason why I was asking is b/c of it's particular design. It seems that it would more effeciently pack more charge hence the response time. They more than likely used the same principles in design from their own track car.
chris86vw
2-23-2000
da souf
 Re: (Don R) »« »
So how long was it between the other two runs? and how much less did it make?
inovillo
11-12-2001
Miami Fl.
'92 GTI 1.8T3/t4 (almost ready), '06 A3 for daily driver.
Great info
Now, IMO, not worth the amount of $$$ this manifold retails for...
APR * REVO * PES-Tuning * Kranson Forged * PPI Design * Milltek * Custom Alignments * Fender Rolling * AWE-Tuning * GHL * ATP * Eibach * H&R * Turbo Upgrades *
Novitech Tuning
15420 SW 136th St. #8 Ph. (305)251-6661
http://www.novitechtuning.com
Home of the first APR Stg.3 TSI
MoBlueTT
8-17-2002
Chesterfield MO
'02 Audi TT
Sean - Great Work !!! It's better than you think....
Short Version: The Only Thing You Really Need to Know... Repeat after me. "It is better to make torque at high rpm than at low rpm, because you can take advantage of *gearing*."
LONG VERSION
http://vettenet.org/torquehp.html
MoBlueTT
2kjettaguy
12-24-2000
Millersville MD
 Re: (MoBlueTT) »« »
When going with a larger intake manifold you theoretically make more air available easier for each intake cycle of each piston. When the intake valve on a piston opens it is able to draw air into the cylinder with less restriction and is more likely to take in more air. I noticed when changing from my stock 2.0 manifold to my short runner that I was flowing alot more g/ps on the MAF sensor. I should have done some logs, but so much had to change to do it that back to back would have been impossible. Anyways, with the larger airflow I hit a point in my fuel map I hadn't tuned and therefore was dumping in way too much fuel.
It's too bad you didn't get air fuel readings on each run. Air fuel can tell alot when comparing dyno runs, especially when you can compare them on an overlayed dyno chart.
Now, I am not saying your fuel isn't right. Obviously I see no data. I am just saying that one possiblity could be that the increased airflow did not yield increased fueling, and you ran a little lean. Or, the increased airflow could have richened you out a bit. Or, the more likely factor is that this manifold didn't increase the available volume of air enough to make much of a difference in airflow.
airflow aside, engine management is everything. Especially when making a change in actual airflow (not just an air filter).
42 Draft Designs
07 GTI 4DR / 01 TT 225 / 96 Jetta VR6
** 42 News! **
Save $?
hoTTub
11-5-2000
 Re: (2kjettaguy) »« »
actually, there was air fuel...I just have to go and get the file and export it....
Jack Skelington
7-5-2004
Tortuga
Black Pearl
This was the comment I made in the original thread, on the Z06 we just did headers/x pipe/catback on it made 27 whp pre tuning and 39 after. I really am a believer that each mod requires proper tuning to truly get its potential to show. Granted I understand that we are a bit limited in terms of how precise are fuel/timing tuning is
Bulletproof Speed Hardware
BSH Speedshop
Quote, originally posted by shadowmilkman »
lol how do u have a VRT and only 58 posts, that is awsome btw
How do you have spongebob squarepants ants in the pants and I cant buy a chessboard. - Me in Walmart
Don R
10-3-2002
Manifesting Within
2000 Golf AWD 1.8T
 Re: (ZER0) »« »
I'll have to concurr..but to some extent wouldn't you think our Motronic system as intelligent as it is be able to adapt to it...
enginerd
12-14-2001
MANCHESTER CT
2002 GTI 1.8T, 83 Turbo Rabbit, 95 SC Miata, 01 A4Q
 Re: (Don R) »« »
great presentation of the data. Very professional, and unbiased.
I feel that driving the car would have made a big difference, not 30 hp, but maybe 10. I know what you mean about the burning the tires. it's like when you switch programs the car is not fast at first, but a half hour later, and it's way faster. You don't realize how much better the 100 oct file is untill you switch back to 93 and whack the throttle.
Tha said, i am patiently awaiting the second bacth of dyno runs. please make sure any and all smoothing and related correction factors remain the same. As you showed, simple data manipulation can make a big difference.
Also if you did a before and after g/s log, or block 26 knock sensor voltage that woudl be great.
Thanks for you efforts
Modified by enginerd at 9:49 PM 12-14-2004
Coil Pack Retaining Brackets Here
1.8T TROUBLESHOOTING GUIDE
TRACK DAY VIDS - WGI, LRP, NJMP http://www.youtube.com/user/baltruckij
2kjettaguy
12-24-2000
Millersville MD
 Re: (Don R) »« »
Yes, but not within the next pull! It takes change over time for any adaptation to occur.
Remember Motronic's primary goal in adaptation isn't our primary goal - power. It's more concerned with fuel economy and prevention of it's own destruction. It's concerned with making sure VW doesn't have to shell out the big bucks for boo-boos while still having some fun with boost.
I am really interested to hear how this feels in the next couple days and to see the dynos!
I would also be interested to see someone with a true speed density system to do back to back runs with tuning in between. Go to a dyno and advance timing until no extra power is made, then turn back a couple degrees. Get the fuel curve flat and consistent.
Then, throw this manifold on, get the fuel curve flat again (speed density doesn't know flow, just pressure. Increase fuel @ said psi until fuel goes flat again assuming airflow did increase. Then dyno.
42 Draft Designs
** 42 News! **
Save $?
FrankiEBoneZ
6-4-2002
Da hood NEW YORK
GTI 337
This is off the to do list.
707WHP/468trq 2.0/20v GTI.... GONE BUT NOT FORGOTTEN!! RIP September 2008
Current Car 2003 Mustang Cobra Terminator, Sonic Blue, Kenne Bell Blown, 615WHP 535TRQ, 10 second daily driven
L.I. Street Racing
fast_a2_20v
6-24-2004
Salt Lake City Utah
92 gti 16v
2kjettaguy the fuel will almost automaticaly calibrate, on the fly, the computer is equipped with both a wideband o2 sensor and most importantly it is MAF based.
those are some awesome peak power gains especially like the way it helps out up top.
intengineering.com
Havepitty
12-3-2002
chime cal
TT,
 Re: (FrankiEBoneZ) »« »
it would have been nicer to see some flow numbers on the stock manifold vs dalhback.
dahlback mani might come in handy if you are going for higher boost...
good wrightup
fast_a2_20v
6-24-2004
Salt Lake City Utah
92 gti 16v
i would think that the manifolds made by momentum , or many fabricators out there which are very likely higher flowing then this, would come in *more* handy
intengineering.com
puredrive1
6-9-2003
north austin tx
88 MKII GLI
 Re: (fast_a2_20v) »« »
anyone know if the Dahlback inatake is available for the transverse 1.8T motors
06 GTO LS2
88 GLI 16v
04 Buell Firebolt XB9R
http://www.europeanag.com
GONE: GTI GT30R 385whp on Revo BT
RIGHT CLick and save: here is my GTI video. 10min of slowness
gt2437
7-29-2000
2000 New Beetle GLX
 Re: (puredrive1) »« »
Quote, originally posted by puredrive1 »
that is a transverse 1.8t in the pic. just happens to be a 225 TT manifold w/ the reverse orientation on the throttle body. They also have the 150/180 transverse manifold too.
puredrive1
6-9-2003
north austin tx
88 MKII GLI
 Re: (gt2437) »« »
Quote, originally posted by gt2437 »
yeah for the VWs i ment...
06 GTO LS2
88 GLI 16v
gt2437
7-29-2000
2000 New Beetle GLX
yep, they do.
First  1 2 3 4 5 6 7 8 >  Last
» Return to 1.8T Engine Forum
