RogueTDI
12-12-2002
Victorville CA
1998 Jetta TDI, Black, powered by Biodiesel
What defines fuel tank size? or, why can't we increase tank size to get more range? | « » 4:14 AM 12-20-2004 | |
Small cars have small tanks, bigger cars have bigger tanks. I can't understand why range has to be limited to 3-400 miles on most cars, when bigger cars can have much bigger tanks. Sure, there's more metal to protect, but I don't see how vehicle size should necessarily define safe tank size.
Diesel is the engine of the future. Make way for the revolution.The New World Order is REAL and tyranny is upon us. Time is short. Visit infowars.com. END THE FEDERAL RESERVE Our Republic is Falling
Mossman
9-6-2003
Brookline MA
85 635csi 5 speed swapped, 89 325ic 5 speed swapped, saving bimmers 1 autotragic at a time
» | « » 4:25 AM 12-20-2004 | |
There's usually not all that much room for the fuel tank to begin with, and an extra 7 gallons isn't a huge difference but it's more gas to protect and more weight to drag around when full.I dunno, it's 4:30 and i've been up since 9, let's see if someone who knows that they're talking about can field this one.
VR6-DasLightTheWay
8-27-2002
Limited BLING only where
it's required of course
Re: (Mossman) » | « » 4:28 AM 12-20-2004 | |
| Quote, originally posted by Mossman » | | There's usually not all that much room for the fuel tank to begin with, and an extra 7 gallons isn't a huge difference but it's more gas to protect and more weight to drag around when full. I dunno, it's 4:30 and i've been up since 9, let's see if someone who knows that they're talking about can field this one. | What are gallons?!? I mean it's almost 2005 for crying out loud!!!
▒████Pacific West Coast ████▒ "BADGES?!?... We Don't Need No Stinkin' Badges!!!"
munkey
4-29-2004
Richmond BC
04 Mini Cooper S
Re: (VR6-DasLightTheWay) » | « » 4:35 AM 12-20-2004 | |
| Quote, originally posted by VR6-DasLightTheWay » | | What are gallons?!? I mean it's almost 2005 for crying out loud!!! |
that's right! SI for lyfe dawg! anyway, i might be taking a total wild jab at this but the engineers might have calculated how large a tank will be optimal for a given car. like the first reply said, you may have a large tank, but that would just weigh you down and cause you to eat more gas while lugging it around, therefore not optimized. or if the tank is too small, you'll save on weight, thus easier on gas, but you sacrafice on how long you can drive before each fillup. so i think the tank sizes now are just what they calculated to be the longest distance you can travel with the largest tank of gas you can carry..or or sorts. lol... dont' take my word for it though, i'm jsut thinking of the stuff i learned in first year calc bout optimization and all lol.
"I wish girls had a Lagrangian..."
RogueTDI
12-12-2002
Victorville CA
Re: (munkey) » | « » 4:40 AM 12-20-2004 | |
The added weight is very little - maybe 50lbs at most. That's nothing in a 2-3000lb car, and won't affect economy meaningfully I imagine (I'm a mech E btw).I would think the added convenience of less frequent fillups would be a great selling point. I think I've heard that it's some sort of federal regulation perhaps, but what's that based on? I just don't see this being a simple matter of calculation - it seems like it could be an arbitrary thing.
SpeedRicer
2-6-2002
La Jolla CA and London UK
Re: What defines fuel tank size? or, why can't we increase tank size to get more range? (RogueTDI) » | « » 4:58 AM 12-20-2004 | |
Wouldn't it just be dependent on available space?Small cars have less physical space in the rear, and even though adding capacity to hold a few more gallons may not add extra weight, it would definitely cut into other areas such as trunk space. And conversely, larger cars simply have more room to accommodate a large trunk and a large fuel tank. As an example though, look at how much trunk space was affected in the GTO by fuel tank changes...
Fugitoid - Team Post-Killing Ninja |t|t|k|a|.net
VR6-DasLightTheWay
8-27-2002
Re: (RogueTDI) » | « » 5:03 AM 12-20-2004 | |
| Quote, originally posted by RogueTDI » | | The added weight is very little - maybe 50lbs at most. That's nothing in a 2-3000lb car, and won't affect economy meaningfully I imagine (I'm a mech E btw). I would think the added convenience of less frequent fillups would be a great selling point. I think I've heard that it's some sort of federal regulation perhaps, but what's that based on? I just don't see this being a simple matter of calculation - it seems like it could be an arbitrary thing. | Hmmm, I'm not sure if you have done your calculations lately on a small to mid sized car but if you did you would be quite surprised at how much of a difference there is in driving a full tank around for no reason. Hey, there must be a reason as to why airlines only place the required fuel on board for their flight and why they don't just fill'er up.
For sake of not hurting brain cells lets just say that one litre of gas weighs 1 kilogram (it's close enough). A full 55 litre tank in a Golf/Jetta is going to weigh 55 kilos. Now if you are just farting around town and never drive more than 50 Kms in day, there is no need to binge fill your tank. 20 litres is more than enough for four days unless you are driving a VR6. If you don't think that 35 kilos makes a difference then take it along for the ride. I think the real reason behind the tank size is to match to the driver's projected bladder size. The TDI's are excluded of course.
Modified by VR6-DasLightTheWay at 2:36 AM 12-20-2004
munkey
4-29-2004
Richmond BC
04 Mini Cooper S
Re: (VR6-DasLightTheWay) » | « » 5:29 AM 12-20-2004 | |
| Quote, originally posted by VR6-DasLightTheWay » | you would be quited surprised |
i loveded it! hahahaha:D and i don't know bout the weight difference then, i'm working towards an astrophysics degree....we work with things on a larger scale where something's weight to the magnitude of 28 is considered average!
Modified by munkey at 11:13 AM 12-20-2004
nuke941
4-10-2001
Portland OR
Re: What defines fuel tank size? or, why can't we increase tank size to get more range? (RogueTDI) » | « » 6:01 AM 12-20-2004 | |
Other than weight and size on a smaller car, it probably is based on an assumption that a smaller car owner assumes he or she will pump a full tank worth a lesser value at a time(this is probalby true for econo cars as well). Also I guess the manufacturers assume that the smaller cars are not used for long range trips as much. Its definitely a good point, I find that my almost 500mile range on a full tank(17-18galons) is quite nice, but then most of the time my blader needs to empty before that .
1990 BMW 525(m20) stick. 1989 BMW 535 Auto It is easier to find a score of men wise enough to discover the truth than to find one intrepid enough, in the face of opposition, to stand up for it.
VR6-DasLightTheWay
8-27-2002
Re: What defines fuel tank size? or, why can't we increase tank size to get more range? (nuke941) » | « » 6:05 AM 12-20-2004 | |
| Quote, originally posted by nuke941 » | | Its definitely a good point, I find that my almost 500mile range on a full tank(17-18galons) is quite nice, but then most of the time my blader needs to empty before that . | And there is another good reason why people should not drink and drive.
CChaos
5-30-2003
Norwalk CT
Windsor Blue '97 GTI VR6
» | « » 7:15 AM 12-20-2004 | |
My wife drives an Escape and I've heard one of the gripes people have with the car is with it's "range." It doesn't get great mileage, and it has a small tank. I don't know about you folks, but I've got 3-4 gas stations within 5 miles of my house, and I don't see a safari or artic expedition in the near future.
Parklife
2-19-2001
Wheaton IL
2007 VW Rabbit, 1999 Toyota Camry
Re: What defines fuel tank size? or, why can't we increase tank size to get more range? (RogueTDI) » | « » 9:15 AM 12-20-2004 | |
It's very much dictated by packaging concerns. On your average compact, one needs to design a spare tire well, exhaust system, crash structure, and rear suspension into the area behind the rear seats. That doesn't leave much room for a fuel tank. Larger cars have more floor space to work with than, say, a Golf TDI, thus the ability to have a larger tank. My truck has no such concerns because of the large bed, so it has a nearly 40-gallon tank strapped inside its frame rails.On some vehicles - such as the Saturn VUE - space is at such a premium that it uses a "saddle" tank - large reservoirs on either side of the rear drive shaft with a "booster" pump in one side to feed the other. Weight, aerodynamics, and crash-worthiness are also other factors. An extra fifty pounds of fuel will have a mileage penalty, and in an era where front and rear fascias are redesigned to increase mileage by as little as .2 MPG this makes a difference. A larger tank will also disrupt airflow under the car, which has recently become a concern for manufacturers. Lastly, a larger tank is more likely to be ruptured by intrusion from an exhaust pipe or lower control arm during a rear-side or back-end collision, and in the event of a breach of the tank there is more fuel to be spilled and possibly ignite.
CheddaJetta
1-14-2004
Enjoying retirement....again
Re: What defines fuel tank size? or, why can't we increase tank size to get more range? (Parklife) » | « » 9:20 AM 12-20-2004 | |
| Quote, originally posted by munkey » | | that's right! SI for lyfe dawg! |
ATL_Av8r
10-17-2002
Gapiana
Re: What defines fuel tank size? or, why can't we increase tank s ... (CheddaJetta) » | « » 9:23 AM 12-20-2004 | |
gasoline is 6.6 pounds per gallon
1/20/2009 & 1/21/2013 - The end of the errors
| Quote, originally posted by 92_525i » | | i find myself searching for a post by ATL_AV8r that i dont agree with... so far his words are gospel | | Quote, originally posted by vw_jason79 » | What does mike type that isnt funny. Hes like the top resident smart ass of the vortex. |
22 sigs and counting
tjl
3-24-2001
California, USA
Re: What defines fuel tank size? or, why can't we increase tank size to get more range? (RogueTDI) » | « » 9:59 AM 12-20-2004 | |
To get a long cruising range, one often has to find a car that is sold in both thirsty and fuel efficient versions, then choose the fuel efficient version. For example, the b4 Passat TDI had a long cruising range because of the 18 gallon fuel tank sized for the thirsty VR6 engine.But the Honda Civic VX had a smaller fuel tank than other Honda Civics for some reason.
LuckyDogg
2-3-2003
'96 Cavalier LS Sedan
Re: What defines fuel tank size? or, why can't we increase tank size to get more range? (SpeedRicer) » | « » 10:07 AM 12-20-2004 | |
| Quote, originally posted by SpeedRicer » | | Wouldn't it just be dependent on available space? Small cars have less physical space in the rear, and even though adding capacity to hold a few more gallons may not add extra weight, it would definitely cut into other areas such as trunk space. And conversely, larger cars simply have more room to accommodate a large trunk and a large fuel tank. As an example though, look at how much trunk space was affected in the GTO by fuel tank changes... |
Thank you for having common sense.
I figured that answer was pretty much a given...
- Dan
VR6-DasLightTheWay
8-27-2002
Re: What defines fuel tank size? or, why can't we increase tank size to get more range? (tjl) » | « » 5:23 PM 12-20-2004 | |
| Quote, originally posted by tjl » | To get a long cruising range, one often has to find a car that is sold in both thirsty and fuel efficient versions, then choose the fuel efficient version. For example, the b4 Passat TDI had a long cruising range because of the 18 gallon fuel tank sized for the thirsty VR6 engine.
^^^ So true!
GreenandChrome
5-24-2002
Snohomish WA
06 xTRA Boxy
Re: What defines fuel tank size? or, why can't we increase tank s ... (ATL_Av8r) » | « » 5:43 PM 12-20-2004 | |
i remember reading one of those environment pamplets (not a greenpeace propaganda flyer) that said for every 100lbs, you lose 1-5mpg while driving.i think the largest determining factor for tank size is physical limitations, not range. given that gas is 6lbs/gallon, we have 84lbs in a 14 gal. tank, 258 lbs in a 43 gal. tank. a lot of weight to drive around, even if it's being used up.
Trouble with Hollywood: | Quote, originally posted by IKEACAR » | | I put more thought into spending $40 on a pair of shoes than Bay did putting $300 million into this script. |
| Quote, originally posted by By Internet Trolls Everywhere » | | Your an idiot! |
Twitter: mbull GT: minglepringle
RogueTDI
12-12-2002
Victorville CA
Re: What defines fuel tank size? or, why can't we increase tank s ... (ATL_Av8r) » | « » 5:47 PM 12-20-2004 | |
| Quote, originally posted by ATL_Av8r » | | gasoline is 6.6 pounds per gallon |
And at that density, an extra 5 gal or so would significantly increase the range of most vehicles. I'm sorry, but 30lbs really makes virtually no difference to fuel economy.
RogueTDI
12-12-2002
Victorville CA
Re: What defines fuel tank size? or, why can't we increase tank s ... (GreenandChrome) » | « » 5:51 PM 12-20-2004 | |
| Quote, originally posted by GreenandChrome » | i remember reading one of those environment pamplets (not a greenpeace propaganda flyer) that said for every 100lbs, you lose 1-5mpg while driving. ... |
I doubt it's that much, but that's conceivable. For steady speed driving (highway), an extra 100lbs in a typical 2800-3500lb car these days might drop mileage perhaps .3mpg at most I imagine - just the increase of rolling resistance. For greater city driving, it will of course be more because of the extra energy spent on acceleration. Still not enough to amount to 5mpg though, I'm sure.
gobluevw
5-22-2003
Shelby MI
Car Shopping
Re: What defines fuel tank size? or, why can't we increase tank s ... (RogueTDI) » | « » 5:55 PM 12-20-2004 | |
its funny how much people just make stuff up and have no idea what theyre talking about
| Quote, originally posted by fsuhorizon » | I use Wikipedia frequently and have yet to find any factual errors. I don't see any reason not to trust it. |
VR6-DasLightTheWay
8-27-2002
Re: What defines fuel tank size? or, why can't we increase tank s ... (RogueTDI) » | « » 6:00 PM 12-20-2004 | |
| Quote, originally posted by RogueTDI » | And at that density, an extra 5 gal or so would significantly increase the range of most vehicles. I'm sorry, but 30lbs really makes virtually no difference to fuel economy.
| I'd chime in more but all this talk of gal and lbs is all Chinese or Greek to me and oddly enough they also would not understand since they use litres and kilograms.
6 billion people on this planet and only one country with only 285 million still uses an out dated measuring system.
matt007
5-15-2001
Portland Oregon
03 BMW M3,03 Ducati 620ie,02 Yamaha FZ1,87 Honda CH150D,96 Mazda Miata,72 Volvo P1800,81 MB 500SLC
Re: What defines fuel tank size? or, why can't we increase tank s ... (VR6-DasLightTheWay) » | « » 6:30 PM 12-20-2004 | |
| Quote, originally posted by VR6-DasLightTheWay » | 6 billion people on this planet and only one country with only 285 million still uses an out dated measuring system. | I have no idea how tall I am in centimeters or how much I weigh, although I could guestimate with some mental math, I still feel much more comfortable being 6'2" and 195lbs than 187.96cm and 88.45kg (wtf? )
I am the stig
RogueTDI
12-12-2002
Victorville CA
Re: What defines fuel tank size? or, why can't we increase tank s ... (matt007) » | « » 6:34 PM 12-20-2004 | |
| Quote, originally posted by matt007 » | I have no idea how tall I am in centimeters or how much I weigh, although I could guestimate with some mental math, I still feel much more comfortable being 6'2" and 195lbs than 187.96cm and 88.45kg (wtf? ) |
It's so funny, because it's just a matter of familiarity. Once you use either system for just a little while, it gives a context for all those numbers, and then those funny metric numbers start to have relevance. Saying I way 88kg seems meaningless to most Americans. Then consider the typical weights for context, like (just inventing info here) say women are typically 40-50kg, and men are typically 70-90kg. Suddenly, it doesnt become so weird anymore. It's just different numbers - that familiarity we feel comes from experience with the system that gives us a "feel" for what the numbers mean. There is nothing remarkably different about the metric system - it really is actually a lot smarter/better over all. Too bad that initial reaction by Americans is practically no better than if they were to be the first to read an extraterrestrial language.
JPawn1
4-4-2001
StrongLeft, Miami FL
Re: What defines fuel tank size? or, why can't we increase tank s ... (gobluevw) » | « » 6:49 PM 12-20-2004 | |
| Quote, originally posted by gobluevw » | | its funny how much people just make stuff up and have no idea what theyre talking about | well, ya know, 47% of all statistics are made up on the spot
VR6-DasLightTheWay
8-27-2002
Re: What defines fuel tank size? or, why can't we increase tank s ... (matt007) » | « » 6:53 PM 12-20-2004 | |
Actually you would be 188cm tall and weigh 88.4kgs. Either way it is far easier to work with decimal points than fractions. Hell, most of you guys already use SI when you check out the ladies and rate them... after all you say she's an 8 or she's 9 and what the hell are you rating her out of... 10 (TEN) and that's the whole basis of SI. So like daylight savings time, change over, get use to it and move on.
Besides you guys with the teenie weenies will be at least able claim yours is 11... cms that is Bwhaaaaa haaa haa And the fat chicks will feel so much better saying they only weigh 95... kilos that is haaaaahaaa haaaahaaa ha ha ha Think about bragging to your possie when you tell them you got pulled over doing 215... well yeah that was km/h but still it sounded cool didn't it? Oh and how easy is this to remember, water freezes at 0c and boils at 100c? That was tough wasn't it? Ever tried measuring the volume of a subwoofer cabinet that you made out of fibreglass (you know the weird shaped ones)? You would need some fancy assed math to figure that out but with SI all you need is a 1 litre measuring cup and you can figure it out by filling up your sub container one litre at a time until you reach the top. Then you will know what your volume is in litres. Of course you could use a larger 10 litre bucket, etc. if you already have some idea of the volume to speed things up but you get the point, I hope.
VR6-DasLightTheWay
8-27-2002
Re: What defines fuel tank size? or, why can't we increase tank s ... (JPawn1) » | « » 6:54 PM 12-20-2004 | |
| Quote, originally posted by JPawn1 » | well, ya know, 47% of all statistics are made up on the spot | No I believe it's closer to 49%
JPawn1
4-4-2001
Re: What defines fuel tank size? or, why can't we increase tank s ... (VR6-DasLightTheWay) » | « » 7:12 PM 12-20-2004 | |
| Quote, originally posted by VR6-DasLightTheWay » | | No I believe it's closer to 49% | statistics show that is is in fact 49% as of yesterday
sirhc
9-23-1999
Kuna ID
Re: What defines fuel tank size? or, why can't we increase tank s ... (JPawn1) » | « » 7:58 PM 12-20-2004 | |
... and 87% of people believe them, whether they're accurate statistics or not!
Chris 02' F350 / 01' Viggen / 88' Samurai / 56' Caddy / 43' Chevy / 28' Model A
lightsandsirens
6-1-2002
Burlington Ontario
2005 BMW 325i
Re: What defines fuel tank size? or, why can't we increase tank s ... (sirhc) » | « » 8:20 PM 12-20-2004 | |
I think it's mostly economics... they want you to frequent gas stations as often as possible. First off, with the gas price fluctuation everyone would fill up when the gas is cheap and would be able to drive 1000kms before requing a fillup, this way one could always wait until the gas cost is cheap again. Also think about how many people buy other items from gas stations... pop, chips, gum, cigarettes etc... say one person buys a chocolate bar every time he/she fills up. Now if this person would only require to get gas once a month instead of twice a month that gas station would be out of $12 each year!!!! I think I'll go get my tin foil hat now..
Gabe"Did you drive much in the 20th century? Nah, nobody really drove... there was too much traffic"
VR6-DasLightTheWay
8-27-2002
Re: What defines fuel tank size? or, why can't we increase tank s ... (lightsandsirens) » | « » 8:33 PM 12-20-2004 | |
| Quote, originally posted by lightsandsirens » | | I think it's mostly economics... they want you to frequent gas stations as often as possible. First off, with the gas price fluctuation everyone would fill up when the gas is cheap and would be able to drive 1000kms before requing a fillup, this way one could always wait until the gas cost is cheap again. Also think about how many people buy other items from gas stations... pop, chips, gum, cigarettes etc... say one person buys a chocolate bar every time he/she fills up. Now if this person would only require to get gas once a month instead of twice a month that gas station would be out of $12 each year!!!! I think I'll go get my tin foil hat now.. | Think of the possibilities that "Jenny Craig" and other fat farms could market if they came up with special weight loss cars that had HUGE gas tanks.
AZGolf
6-6-2000
PHX area, Arizona
Re: What defines fuel tank size? or, why can't we increase tank size to get more range? ) (.je) » | « » 8:54 PM 12-20-2004 | |
| Quote, originally posted by .je » | A long time ago I worked for a company that made gas tanks and other hollow car parts. The requirement and location comes from your customer, and it a balance of available space for tank, seats, axle, trunk, and anything else in the area, crashworthiness, etc. The customer chooses a volume target based partially on expected range and customer requirement/expectations, which is some of what you were getting at, and partially on space available. The product's intended consumer is part of the decision, ex. a small city car might have less range, but it also infulences how much space you have. |
Well there you have it!
The only thing necessary for the triumph of evil is for good men to do nothing.
RogueTDI
12-12-2002
Victorville CA
Re: What defines fuel tank size? or, why can't we increase tank s ... (ATL_Av8r) » | « » 2:52 AM 2-7-2007 | |
Meaning for an extra 30 lbs and 5 gallons, a typical compact/midsize car can go an extra 120-175miles. With a typical range of what, 300-400miles to start? That's a huge gain. And really, 5 gallons isnt that much volume increase over a starting 12-20gallon tank volume, when spread evenly over the tank's space envelope. Considering that increased range is a big selling/marketing point of diesels and hybrids, one has to wonder... Anyhow, was thinking of this again today and don't think we ever really got a solid answer.
Modified by RogueTDI at 11:58 PM 2-6-2007
Shomegrown
2-26-2002
» | « » 3:49 AM 2-7-2007 | |
You're thinking too hard.The average person is an idiot. He/She will think their car is a gas hog if it costs them $50 to fill the tank (when their last car cost them $35) even though they get more range out of it. A 300-400 mile range has been deemed acceptable by consumers. Adding more fuel creates packaging issues. Adding more fuel would not matter to most consumers.
onebadbug
12-21-2002
ohio
82 Rabbit Pickup, 94 Toyota SR-5, always looking for the next one
Re: (Shomegrown) » | « » 7:55 AM 2-7-2007 | |
| Quote, originally posted by Shomegrown » | | You're thinking too hard. Adding more fuel would not matter to most consumers. |
Exactly, what about the people that NEVER fill their tank? There's more than you think. My statistics (gathered from a poll of co-workers) shows that 86% of drivers just drop $20 at a time in their tanks. I was suprised to see such a high % considering these people range in age from about 25 to 55 years old and I haven't NOT filled completely since I started working 18 years ago. I will admit that I didn't count the two or three times I've pumped just enough obscenely priced gas to get to a more resonably priced station.
Modified by onebadbug at 7:59 AM 2-7-2007
| Quote, originally posted by Blonde Guy » | | That's a minivan with a 1.3 L motor? Why can't we buy one of those here? Why are we so far behind China technologically? |
ban OneBadBug!
