sony224422
2-12-2005
Deep River CT
2002 golf 2slow
alternator help | « » 8:14 PM 3-25-2005 | |
Does anyone know if you can get a HO alternator for a 1996 jetta GLS. I need atleast a 120 amp out put. I have found them, but my car has a/c. I have a large sound system and my head lights are dimming and i don't like it. So any help. Thanks.
Quote, originally posted by Mr.Bungle » bro... you don't even know. i see the jager machine and throw down the visa card then yell at the reciept in the morning Quote, originally posted by Mr.Bungle » my car is my girlfriend haha
tiohero
9-28-2004
Ithaca NY... study at Plattsburgh
1996 VW Jetta 2.0
Re: alternator help (sony224422) » | « » 8:28 PM 3-25-2005 | |
| Quote, originally posted by sony224422 » | | Does anyone know if you can get a HO alternator for a 1996 jetta GLS. I need atleast a 120 amp out put. I have found them, but my car has a/c. I have a large sound system and my head lights are dimming and i don't like it. So any help. Thanks. |
Do you have a capacitor for your sound system???
sony224422
2-12-2005
Deep River CT
2002 golf 2slow
Re: alternator help (tiohero) » | « » 8:46 PM 3-25-2005 | |
Caps don't really help, i mean they do a little but its like a tiny fix. I need a bigger alternator, i know, because i have 3 amps delivering over 3500 watts. I am going to get a cap, and it will help, but a bigger alternator will cure the problem. I just can't find one bigger than the stock one that will work with the a/c
sony224422
2-12-2005
Deep River CT
2002 golf 2slow
Re: alternator help (sony224422) » | « » 2:01 AM 3-26-2005 | |
tiohero
9-28-2004
1996 VW Jetta 2.0
Re: alternator help (sony224422) » | « » 3:57 AM 3-26-2005 | |
| Quote, originally posted by sony224422 » | | Caps don't really help, i mean they do a little but its like a tiny fix. I need a bigger alternator, i know, because i have 3 amps delivering over 3500 watts. I am going to get a cap, and it will help, but a bigger alternator will cure the problem. I just can't find one bigger than the stock one that will work with the a/c |
Using a capacitor is not a "tiny" fix. Get a capacitor big enough and it will handle just about any power you want. Also, most people running that kind of power use a boat battery in their car instead. Do some research.
VR6PwrdGTI
2-21-2005
Melrose Park IL
1999 VW GTI VR6
Re: alternator help (tiohero) » | « » 8:03 AM 3-26-2005 | |
[QUOTE=tiohero]Using a capacitor is not a "tiny" fix. Get a capacitor big enough and it will handle just about any power you want. Also, most people running that kind of power use a boat battery in their car instead. Do some research.[/QUOTE What you need is an isolator, basically it allows you to hook-up 2 batteries to it and both get charged, except the main battery is for the car the second for your system. And the "boat" battery or a deep cycle battery as it's really called is what you should run. Also adding caps is ok, it just stores enough energy in them to prevent your amps from "sucking" all the current from the electrical system, sort of act like regulators to maintain max output amperage
I'm all ooey gooey icky and sticky
tiohero
9-28-2004
1996 VW Jetta 2.0
Re: alternator help (VR6PwrdGTI) » | « » 1:55 PM 3-26-2005 | |
| Quote, originally posted by VR6PwrdGTI » | What you need is an isolator, basically it allows you to hook-up 2 batteries to it and both get charged, except the main battery is for the car the second for your system. And the "boat" battery or a deep cycle battery as it's really called is what you should run. Also adding caps is ok, it just stores enough energy in them to prevent your amps from "sucking" all the current from the electrical system, sort of act like regulators to maintain max output amperage |
no need for a bigger alternator
sony224422
2-12-2005
Deep River CT
2002 golf 2slow
Re: alternator help (tiohero) » | « » 8:00 PM 3-26-2005 | |
Okay, your not understanding. I know what i need, and i need a larger alternator. A deep cycle battery just puts even MORE strain on the alternator, causing it to work harder. I know how these things work, i do it for a living. Caps don't do ****, unless they have the power to supply them. All i asked was a simple question, not for you jacka$$es to tell me what you think i need and don't need.
nfx
7-18-2004
bel air md
mk3 jetta 2.0t project, 01 hyundai elantra daily
Re: alternator help (sony224422) » | « » 8:04 PM 3-26-2005 | |
Calm down... I think that's what you really need to do.
LG6S (and primer) 2.0T
.2.Slow4U.
9-6-2004
Charles County MD
98 Windsor 2.0-SOLD, 07 BMP GTI
Re: alternator help (nfx) » | « » 8:08 PM 3-26-2005 | |
I'm with the noob, you guys suck.
If you need 2.0 ABA parts, I have pretty much whatever you need. PM me, I need to empty my garage.
sony224422
2-12-2005
Deep River CT
2002 golf 2slow
» | « » 8:09 PM 3-26-2005 | |
thanks
.2.Slow4U.
9-6-2004
Charles County MD
Re: (sony224422) » | « » 8:11 PM 3-26-2005 | |
The OEM VR6 alt. is 120a. Maybe if nothing else you could custom fit one of those?
nlap5000
3-25-2005
windham Nh
98 GTI 2.slow
Re: alternator help (sony224422) » | « » 8:16 PM 3-26-2005 | |
you could pull apart your alternator, and change the stator to delta configuration... but then yould be ****ed in the low RPMs. im with the other guys .. cap or battery should do it, or look around for a bigger "wye" stator that will fit in your stock alternator
sony224422
2-12-2005
Deep River CT
2002 golf 2slow
Re: (.2.Slow4U.) » | « » 8:17 PM 3-26-2005 | |
well i have found 120 amp alternators.. but they say without a/c. I have a/c.. so thats my problem. i have seen 120 amp alternatos on ebay.. i dunno, i just thought someone on here would know something
.2.Slow4U.
9-6-2004
Charles County MD
Re: (sony224422) » | « » 8:21 PM 3-26-2005 | |
I don't see how the alternator would be affected if you have or don't have A/C?
sony224422
2-12-2005
Deep River CT
2002 golf 2slow
yeah i see what your saying if its too big.. except that the engine should be able to keep up with a pretty big alternator.. like a 200 amp one. I know you guys don't really specialize in this sort of stuff.. i do, and i know that having an extra battery and a cap is awesome to have, i have one in my other car, deep cycle battery, not boat.. but anyways, the ONLY way those things can work right is if they get enough juice.. which starts with the alternator.
sony224422
2-12-2005
Deep River CT
2002 golf 2slow
Re: (.2.Slow4U.) » | « » 8:22 PM 3-26-2005 | |
i think its the a/c compressor is on the same belt or something.. i dunno thats why i asked
.2.Slow4U.
9-6-2004
Charles County MD
Re: (sony224422) » | « » 8:23 PM 3-26-2005 | |
Just thought about this, the guys in the car audio forum might be able to be of more help. http://forums.vwvortex.com/zeroforum?id=12| Quote, originally posted by sony224422 » | | i think its the a/c compressor is on the same belt or something.. i dunno thats why i asked |
Yeah but I mean as long as you have the belt made for a/c cars you should be fine right?
Modified by .2.Slow4U. at 8:24 PM 3-26-2005
sony224422
2-12-2005
Deep River CT
2002 golf 2slow
Re: (.2.Slow4U.) » | « » 9:08 PM 3-26-2005 | |
No, i looked at them, and the little gear thingy that the belt goes on thats on the alternator is different than the stock one. I think you might be able to switch them over, im not sure though..
tiohero
9-28-2004
1996 VW Jetta 2.0
Re: alternator help (sony224422) » | « » 9:34 PM 3-26-2005 | |
| Quote, originally posted by sony224422 » | Okay, your not understanding. I know what i need, and i need a larger alternator. A deep cycle battery just puts even MORE strain on the alternator, causing it to work harder. I know how these things work, i do it for a living. Caps don't do ****, unless they have the power to supply them. All i asked was a simple question, not for you jacka$$es to tell me what you think i need and don't need. |
There is no need for a bigger alternator, I don't understand where you got that idea from but if you want to f**k with your car then go right ahead. A bigger alternator isn't something that I "think" that you don't need, it is something that I KNOW that you don't need. Frankly 3500 watts is absolutely nothing spectacular. If you were drawing upwards of 10,000 watts power output then you may need to start searching for a new alternator, but otherwise it makes no sense
Modified by tiohero at 6:47 PM 3-26-2005
Vento_VR6
2-14-2004
Dundee Scotland
1993 Vento VR6
Re: alternator help (tiohero) » | « » 10:34 PM 3-26-2005 | |
would anything bad happen if you say put a 150amp alternator on a car that has a 70 amp one as standard, i can't see how it would damage anything but i could be wrong
Andrew (aka Vento_VR6 or DundeeDub)VR6 Vento + Mk1 Jetta 2.1L 16v Turbo in progress (well give me a few years) http://www.VR6OC.com http://www.eastsidevw.co.uk
VR6PwrdGTI
2-21-2005
Melrose Park IL
1999 VW GTI VR6
Re: alternator help (sony224422) » | « » 10:43 PM 3-26-2005 | |
if you do this for a living and know "what you need" then why the hell ask for help mister know it all? geez im a electronic tech with 12 years under my belt, installed my first car radio into a 79 ford granada, and I was 8 when I did this, so if you know what you need then by all means do it
tiohero
9-28-2004
1996 VW Jetta 2.0
Re: alternator help (VR6PwrdGTI) » | « » 11:00 PM 3-26-2005 | |
| Quote, originally posted by VR6PwrdGTI » | if you do this for a living and know "what you need" then why the hell ask for help mister know it all? geez im a electronic tech with 12 years under my belt, installed my first car radio into a 79 ford granada, and I was 8 when I did this, so if you know what you need then by all means do it |
He is probably just looking for an excuse to put in a chrome or a polished alternator. nOOb: "You see, the chrome helps to dissapate heat needed by the 3500 watt amps of POWER!!!"
Modified by tiohero at 8:21 PM 3-26-2005
sony224422
2-12-2005
Deep River CT
2002 golf 2slow
Re: alternator help (tiohero) » | « » 1:00 PM 3-27-2005 | |
OH YEAH I LOVE THE CHROME. F@G. YOU DON'T KNOW **** ABOUT ANYTHING CAR AUDIO RELATED. YOU ALL THINK YOU KNOW EVERYTHING ON HERE, IM NOT GOING TO **** WITH MY CAR, I KNOW I NEED IT.
Modified by sony224422 at 9:13 PM 3-27-2005
VR6PwrdGTI
2-21-2005
Melrose Park IL
1999 VW GTI VR6
Re: alternator help (sony224422) » | « » 3:05 PM 3-27-2005 | |
| Quote, originally posted by sony224422 » | | OH YEAH I LOVE THE CHROME. F@G. YOU DON'T KNOW **** ABOUT ANYTHING CAR AUDIO RELATED. YOU ALL THINK YOU KNOW EVERYTHING ON HERE, IM NOT GOING TO **** WITH MY CAR, I KNOW I NEED IT. Modified by sony224422 at 1:23 PM 3-27-2005
waaaaaaaaaaaaaaaaaaaaaaaaaaa, call the waaambulance quick
sony224422
2-12-2005
Deep River CT
2002 golf 2slow
Re: alternator help (VR6PwrdGTI) » | « » 7:58 PM 3-27-2005 | |
your pretty f-ing cool to make fun of people who are asking for help.. let me say even more that your even cooler for making fun of people online. I bet you wouldn't say it to my face dicklick
FlyinFishy
3-27-2005
Tamarac FL
» | « » 11:39 PM 3-27-2005 | |
Anyone who thinks "3500 watts is absolutely nothing spectacular" is the one thats misinformed. 3500 watts is equal to 4.7 Hp! and would require 243 amps @ 14.4 volts with an amplifier that was 100% efficient.Where is this power coming from? While a car is running an alternator is responsible for providing ALL of a car's electrical needs including charging batteries and caps and powering important accessories such as headlights, windshield wipers, a/c fans as well as any added audio equipment. Adding extra batteries and stiffening capacitors only adds more load to a sorely taxed alternator and would only serve to exaserbate the situation. If Sony says he needs a bigger alternator then he needs one. Why don't y'all try and help him out instead of showing your ignorance. Frankly I'm baffled as to how an electronic tech with 12 years experience wouldn't understand the situation and offer more assistance than "if you know what you need then by all means do it". Sony isn't asking whether he needs a bigger alternator. He's asking where he can find one. -Fishy
Modified by FlyinFishy at 8:57 PM 3-27-2005
sony224422
2-12-2005
Deep River CT
2002 golf 2slow
Re: (FlyinFishy) » | « » 11:54 PM 3-27-2005 | |
Thanks. I owe you one
Thursday759
3-25-2005
Deep River CT
2002 Vdub Golf 2.Sl0w
Re: (sony224422) » | « » 3:07 PM 3-28-2005 | |
Wow you people on here are really stupid. hahahahaha way to not know anything, and are you going to answer him where he can get a new alternator if your all so smart?
|V|o|L|k|s|w|A|g|E|n| my anti-drug.
.2.Slow4U.
9-6-2004
Charles County MD
Re: (Thursday759) » | « » 11:06 AM 3-29-2005 | |
| Quote, originally posted by Thursday759 » | | Wow you people on here are really stupid. |
Hahahaha How do you like your 1998 Volswagon 1.8T Gulf? hahaha We're stupid
Jacob_c14
3-31-2005
winona MO
» | « » 10:55 PM 3-31-2005 | |
All of you who say that a bigger alternator won't help and a new battery will are just fn stupid. A batter will only help him if he only listens too his system with the car off. When the car is running the batter doesn't do much of anything. A cap would help a little bit but a cap supplys enough power for a short loud bass note then it has to recharge and if the alternator doesn't have the power to recharge it, which in this case it doesn't it will do nothing but strain your electrical system more because your alternator will be trying to power the system and charge the cap at the same time. You guys are dumb. You would rather try and sound smart than actually help someone out. I would buy a high output alt. and then a cap if you need it. Oh and i dunno what kind of system you have but 3500 watts is alot of power. The bad thing is that all of u guys prolly don't even know anything and are out bumbin your sony's every weekend so just do everyone a favor and don't ever try and help anyone again.
XLR8FloSSiN
4-28-2003
Watching you WA
2001 VR6 Jetta
Re: (Jacob_c14) » | « » 9:56 PM 4-9-2005 | |
OK, I agree most of you don't know what you are talking about. A bigger alternator will give you more Amperage PERIOD. So now back to the question. WHERE CAN YOU FIND A LARGER ALTERNATOR? WHO SELLS THEM? IS THERE A LINK? I too am looking for one, so I and i'm sure SONY would like to know.
