AutoXMan
8-7-2002
Cherry Valley IL
'03 GTI 20AE BMP
MK4 pedals: Heel and toe | « » 2:02 PM 4-27-2005 | |
Does anyone know of a good pedal set for heel / toe? I have the AE with rubber studded aluminum pedals, which suck. Your foot slips off the side of the brake pedal, the gap between brake / gas is too wide, and too deep unless you're really HARD on the brakes (read: into the ABS). I was thinking of a cover for the gas that would bring it up and in about 1/2" to the brake. If there isn't anything available, I will just make one. Thanks!
- Brandon
NOVAdub
7-28-2003
Burke VA
Re: MK4 pedals: Heel and toe (AutoXMan) » | « » 2:45 PM 4-27-2005 | |
They are probably a pain to install but I saw a set of sparco pedals that have a little piece of the gas pedal that sticks out to make it easier to blip the throttle. I have also heard that neuspeed has something similar so Id start there.
http://www.trackdaze.com
sanch0
10-27-2003
Reston VA
2006 GTI DSG, 2008 GTI DSG
Re: MK4 pedals: Heel and toe (NOVAdub) » | « » 3:50 PM 4-27-2005 | |
hehe what timing; we were just talking about this at VIR yesterday. Sparco makes a couple nice sets. i've had my eye on the Curva set for almost a year now.
OG Racing sells them locally here.
TrackDaze High-Performance DrivingBrakeSwap.com Friction FTW
RonJeremy
1-7-2004
Mongolia NA
2007 GLI
Re: MK4 pedals: Heel and toe (AutoXMan) » | « » 9:58 PM 4-27-2005 | |
I have TT pedal cover & am finally getting use to it. You foot position is different in this car than most. I put the ball of my foot in the middle right side of the brake & roll my foot sideways while sliding my heel towards the center console to hit the throttle. This is the only way I found to do it without fully pushing down on the brake.
chewy'sjetta
1-31-2004
slc ut
07 Passat and 95 m3
» | « » 11:31 PM 4-27-2005 | |
thats the way i do it. lately though i've been practicing left foot braking for autox. instead of riding the clutch.
AutoXMan
8-7-2002
Cherry Valley IL
'03 GTI 20AE BMP
Re: MK4 pedals: Heel and toe (RonJeremy) » | « » 8:23 AM 4-28-2005 | |
I don't know if the TT covers are the same, but my foot slips off the side of the brake. The gap between brake and gas is so large that I end up moving my foot so far to the right on the brake that it won't catch any of the rubber studs. Anyway, I'll check out the Sparco pedal set. It's only like $15.
- Brandon
enginerd
12-14-2001
MANCHESTER CT
2002 GTI 1.8T, 83 Turbo Rabbit, 95 SC Miata, 01 A4Q
Re: MK4 pedals: Heel and toe (AutoXMan) » | « » 2:27 PM 4-28-2005 | |
Just so you know, you can only left foot brake while on the accelerator for about a second before the drive by wire fun police come and close your throttle. You need to unplug the brake switch (no brake lights) to defeat this for proper left foot braking and boost building. You can hard wire in the lights if you need lights.
Coil Pack Retaining Brackets Here 1.8T TROUBLESHOOTING GUIDE TRACK DAY VIDS - WGI, LRP, NJMP http://www.youtube.com/user/baltruckij
Strider
9-20-2001
St Louis Park MN
2001 A4 1.8TQ, 1996 Golf GTI 2.0 Enduro Car
Re: MK4 pedals: Heel and toe (enginerd) » | « » 1:51 AM 4-29-2005 | |
| Quote, originally posted by enginerd » | | Just so you know, you can only left foot brake while on the accelerator for about a second before the drive by wire fun police come and close your throttle. You need to unplug the brake switch (no brake lights) to defeat this for proper left foot braking and boost building. You can hard wire in the lights if you need lights. |
this is why I jumped ship on my MkIV, nice to know that it is fixable, but I will keep my MkII now that i have thrown everything at it. Heel Toe on a MkIV SUCKS, the pedal placement is horrid, the gas is way to far back.. It would be sick to make a gas pedal that was rased and in a J shape, That way you could just have your toes on the brake and heel on the gas extention that would be under it.....dig? I saw this on a old skool Porschem it looked killer!!!!
Strider Cerberus Motorsports Nasa Midwest
AutoXMan
8-7-2002
Cherry Valley IL
'03 GTI 20AE BMP
Re: MK4 pedals: Heel and toe (Strider) » | « » 8:56 AM 4-29-2005 | |
I ordered the Sparco Curva (pictured above) which has the heel extension on the gas. I would rather have a toe extension on the gas. Interesting that no one seems to make this. The Sparco Curva is the widest gas pedal I could find at (only) 2"! If I need to I will make something to raise it and / or mount it as far left as possible.There are two ways to blip the throttle - (1) Using the outside flat portion of your foot - think pinky toe (2) Use the heel of your foot. I do (1) since I have never has a gas pedal be high enough for my heal to reach it while the toes are on the brake. Since the ball of my foot has to be on 2 pedals at once, they need to be close in width and in heigh off the floor when you're hard on the brakes. This works GREAT in the last Ford Probe/MX6. Terrible in the Mk4. And yes, try warming your brake pads coming to grid at an autocross. The throttle cut is pretty funny. But on a road course, I need to rev-match downshifts so I don't fry my clutch. Or at least get the revs UP so they're close when I go down a gear.
- Brandon
jamesb
3-14-2001
laurel md
The list keeps growing
Re: MK4 pedals: Heel and toe (AutoXMan) » | « » 8:57 AM 4-29-2005 | |
I have the sparco set, forget the name but it works well though the little nubs that came with it are starting to fall out. Maybe time for a new pedal set.
JamesB - [2001 Jetta WE] - The weekender [PMF Motorsports ITB Golf] - Thanks to Bildon Motorsport and Radial Tire 2005 Nissan Titan
wuzilla
10-14-2001
Leesburg VA
2001 BMW 325it, 1990 Volvo 245
Re: MK4 pedals: Heel and toe (sanch0) » | « » 11:51 AM 4-29-2005 | |
The Curva's work nicely. No bling for $29, but the most functional set of pedals that Sparco makes. The only real PIA is drilling into the pedal arms to install.Personally, I use the ball of my foot for blipping the throttle. On Mk4's the gas pedal sits a good inch in as opposed to the brake pedal, but when hard on the brakes, the two even out nicely. One note - Sparco has discontinued the Curva pedals. Might want to grab a set while you still can - see sig. | Quote, originally posted by sanch0 » | | hehe what timing; we were just talking about this at VIR yesterday. Sparco makes a couple nice sets. i've had my eye on the Curva set for almost a year now.
OG Racing sells them locally here. |
OG Racing - Motorsports Safety Equipment Ask for Steve (that's me )
IJM
7-30-2001
Washington, DC
2001 GTI VR6
Re: MK4 pedals: Heel and toe (steve@vwdriversclub) » | « » 9:20 PM 5-3-2005 | |
I've been using the Sparco Curva pedals on my MkIV for a few years now and have been happy. I seem to have the opposite problem. When I'm hard of the brakes when downshifting the throttle is too HIGH for me. I think that new pads and fluid will help this immensely, though.
You can accuse a person of just about anything and get away with it, as long as you don't call them a lousy lover or bad driver. -Sir Jackie StewartGTI VR6
krakkaNW
10-29-2002
4 walls and roof
04 wheels
Re: MK4 pedals: Heel and toe (IJM) » | « » 6:42 PM 5-8-2005 | |
the sparco carbon pedals are very good for HT. they also come with grip tape so your feet dont slip off.
Nick it's not the destination, its the journey
genxguy
5-26-2002
NoVA
93 E36 325i
» | « » 1:39 PM 5-17-2005 | |
It's just a matter of twisting your foot the right way for our cars. You won't be able to do it like you see in race videos. Once I started blipping the gas with the SIDE of my foot instead of trying to do it with the heel, I haven't had a problem since.
Parts for sale!!
AutoXMan
8-7-2002
Cherry Valley IL
'03 GTI 20AE BMP
Re: (genxguy) » | « » 2:31 PM 5-17-2005 | |
Yep, can't do it! Did it that way in my Probe, but not in my GTI. Soon, though. Sparco pedals are on my workbench.
- Brandon
pythiasjt
11-12-2003
Winnipeg mb
» | « » 10:11 PM 5-18-2005 | |
I've got the R32 covers for my pedals, which does bring the gas pedal out about a half to 3/4. i find the roll over like mentioned before works good for street driving but serious autocross ussually ends up with the RPM's kicking up in the last bit of the break pedal. i've adjusted my driving habits and seat position such as i can now pile my heal all the way down on the break and then tap the throttle for that sometimes needed 1st gear. however i ussually left foot break so when you forget you need to shift i'm Sh*t outa luck.--JT
2007 Nationals Runs Pictures of my car
thei3yron
11-26-2004
Glendale LA County CA
05 reflex silver GTI 1.8T
» | « » 6:24 AM 6-26-2005 | |
do you still have the 20th pedals?
2005 relex silver GTI 5 speed manual So broke I consider a carwash modding
5dr fanatic
6-16-2005
Las Vegas nv
95 del sol si
Re: (thei3yron) » | « » 6:06 PM 7-9-2005 | |
Razo makes a pedal that you can adjust to be closer to the brake. I have it in my golf and works awesome. I was having the same problem orginally with heel toe. Got the pedal and no problems. If you dont mind having parts from japan on your euro buy it. It is like $40.
1.6L of single cam 16 valve VeeeeTEC fury .
