London Dub
2-1-2005
Toronto Ontario
81 Deisel Rabbit (formerly BMP 20th, '00GLX)
Golf / Gti Jetta Vent install - helpful for jetta/golf vent removal **Pics** | « » 2:46 PM 4-27-2005 | |
First off, I have to give props to jkrew for originally posting his DIY on this install. Also thanks to lag for helping me procure these vents. STEP 1 – Remove original vents If you are removing golf vents - keep reading, if you are removing Jetta vents, skip to the individual vents section (STEP 2). Most people know how to remove the vents, but there are a few tricks to help you. Golf vents First off, all 4 vents ( the parts that move and control air flow) all come out by pushing the side with the vertical wheel. You might need help of a screwdriver. Take out all of these first. Arrows show which side to push from.
 STEP 2 Individual Vents Drivers side (golf/jetta): 1. While in the off position, push the switch in while turning ‘on’ the switch will move to a position in between ‘on’ and ‘off’ you may hear a click sound. 2. Pull switch out, unhook harness by squeezing the little tabs on each side. 3. You should now see two torque screws. Remove these ( you can chuck ‘em, you won’t need em anymore IF you are installing Jetta vents) Here is a shot of their locations (I've taken them out by now)
 4. Pull the vent out, and pop off the harness to the dimmer switch, yank out dimmer switch (through the front) and set aside with light switch. Passenger side (golf/jetta): 1 There are no screws, you just need to yank it out. You might need to really reef on it – but if you’re like me – I didn’t really want to keep my old vents to I just gave ‘er. A putty knife can help here. ***If you are installing lighted vents*** 2. There is a little rectangle of thin plastic that you will see once the vent is out. – left hand side.
Take a flat screwdriver and press it against the rectangle, give the screwdriver a quick forceful shove and the plastic will break leaving you with a nice rectangular hole. This is where you need to run your wires for the vent. 3. While you’re here, remove the panel on the right hand side of the dash, it sits flush against the door when closed. Pull it evenly away from the dash towards the opened door a lot ( you should hear clicking as the metal clips disengage, then back towards the rear of the car. This piece is hard to move and you’ll most likely rip some of the clips off of their pins once it is loose, but I didn’t break anything on mine Center Vent 1. Remove two torque screws in upper corners of vents (you jetta guys don't need to do this part, follow steps 2-4). ***Jetta guys I have noticed in my travels, one or two instances where the center vent in a jetta had these two torx screws in place. They are a PITA to remove since you can't easily remove them. I suggest taking a good look through the 'louvres' of your vents to see if you see anything that looks like a screw back there, prior to yanking the vents out. IF, and its a big IF, you see screws in there - you'll need to carefully pull the front fascia of the jetta vents off the housing, then remove the louvres and then undo the screws. PM me for help if you need it*** 2. Carefully remove all of the buttons by prying behind them with a little screwdriver. The hazard switch and rear defrost will be mighty hard to get off. Undo the wiring harnesses for the witches, and store the switches in a safe place. 3. If you can’t get a switch out, you should be able to get the whole vent out and remove them from the rear. The top of the center vent should come out towards you a little bit, then the bottom should release itself from their clips. Again - a putty knife can help get under the edge and help the vent out - be careful not to damage the soft touch coating, patience is key. 4. Once out, you should be able to pull the vents out just enough to undo the harness for any stubborn switch, and then get the switch out. The problem with the above mentioned switches is they are held in with metal springs that are very tough to get out. STEP 3 Wiring (If lighted) Skip to step 4 if not installing lighted vents. The wiring can be done many ways, all you need to know is that the blue/grey wire is the power and the brown is the ground. Each switch in has these two wires leading into it. All you need to do is connect the blue/grey and brown wires from the wires coming off the vents, to matching wires in the existing wiring. I used 20 gauge speaker wire since it is easy to control and would stay together while I fed the wires behind the dash. I crimped and soldered my connections, but you could use tap ins if you wanted to. Wiring the passenger side: 1. Crimp about 4’ of wire to the power and ground of the wires on the vents. I used the copper wire as my ground and silver as power – just to make sure I didn’t mess it up (that way, copper always went to brown and silver went to blue/grey). 2. Feed this wire through the rectangular hole and behind the airbag to the center vent hole. 3. Slide the vent into the hole, and pull all of the wire through. Don’t push the vent all the way in though – just in case you need to yank it back out. 4. Leave wire there while you work on the drivers side. Wiring the drivers side: You can do this multiple ways. One way is to tap into the power and ground wires (Blue/grey and brown) of the dimmer switch, and then just run the wires behind the light switch to the wires coming off the drivers vent. Use tap in connectors or soldering. You might not even need to extend the wires from the vent if done this way. I did a slightly more complicated install 1. Run a wire from the drivers vent hole behind the steering wheel to the center vent hole. This is tricky, since I didn’t want to remove the paneling on the drivers side as I did with the passenger side. However, the speaker wire I had was a little stiff, and I was able to (with the help of my mechanic father) to feed the wires behind the wheel between the two vents. 2. Connect the power and ground wire from the vent wires to the speaker wire, cram everything back in lightly (again not too tight incase I had to remove it) Wiring the center Vents (and everything else together) The main reason I didn’t want to simply tap into the wires on the drivers side was because I wanted only ONE connection to the stock illumination system. What I did was locate the power wire and the ground wire that went into the rear defrost button. I removed the wires out of the harness by pushing the entire connection piece back through the harness. I was left with this:
Then I wrapped a little piece of my speaker wire to each of the wires as shown here, again with copper to brown, silver to blue/grey, and soldered them there, wrapped them in electrical tape, and reinserted the prongs of the wires to the harness
Next I gathered all of the power wires from the drivers, passenger and center vents and crimped them to the power wire I had just made off the switch. I did the same with all of the ground wires from the vents and the ground wire off the switch. I was left with this:
Then I just had to cram everything back in. STEP 4 Cramming everything in. This is rather self explanatory, however, please test the vents if you’re got the lighted ones to make sure they are all on, and they respond to the dimmer switch too. It s a little hard to get the center switches back in but with them strategic placement you’ll be fine. Here are some pics of mine:
And at night:
 If my pics ever stop working, just IM me and I can help out, and if you’ve got questions I’ll try to help as well. One day I'll get better pics....... Modified by London Dub at 9:23 AM 10-21-2008
Modified by London Dub at 12:02 PM 10-22-2008
mujjuman
7-29-2004
Albany NY
01 Jetta VR6, 06 Jetta 2.5, 03 heated seats
Re: Golf / Gti Jetta Vent install Pics and comments (London Dub) » | « » 12:00 AM 9-29-2005 | |
hottness
mujjuman 2001 Volkswagen Jetta VR6 + 2006 Volkswagen Jetta 2.5
| Quote, originally posted by kraut_pauer79 » | | wow, junkyards look like enchanted forests where you live. |
http://vwvortexsearch.webs.com/ < vwvortex search
digifant_gli
5-13-2004
Guelph Ontario
1990 Jetta GLI/1991 Corrado G60/2006 Jetta TDI Wagon/2007 New Beetle Convertible
Re: Golf / Gti Jetta Vent install Pics and comments (London Dub) » | « » 7:32 PM 1-25-2006 | |
Just wondering...is this a feature that VW has deleted on later production A4s? The reason that I ask is that my 2006 Jetta Wagon doesn't have the light up vents.....
VDUBRACER187
6-16-2004
Ridin Dirty
Re: Golf / Gti Jetta Vent install Pics and comments (digifant_gli) » | « » 7:35 PM 1-25-2006 | |
very nice... iv been looking for a set of jetta vents for awhile now. where did you pick those up and for how much $?
German$quad. Driver$port Inc.
digifant_gli
5-13-2004
Guelph Ontario
Re: Golf / Gti Jetta Vent install Pics and comments (VDUBRACER187) » | « » 7:41 PM 1-25-2006 | |
Assuming that the part numbers in my older version of ETKA are correct, these are what you would need to order from your dealer:(Listed from Left to Right) Left Vent - 1J1-819-703-E-2AQ - $103.22 Middle Vent - 1J0-819-728-D-2AQ - $223.53 Right Vent - 1J1-819-704-D-2AQ - $87.18 Definitley not an inexpensive mod to perform....
smokedoutVR6
1-29-2004
dallas tx
00 JTI VR6 82 caddy build
Re: Golf / Gti Jetta Vent install Pics and comments (digifant_gli) » | « » 7:46 PM 1-25-2006 | |
i paid 20 bucks for my set of vents just be patient they will come
| Quote, originally posted by mak » | you have had that **** in the shop for so long.. they dont even make mk4 anymore |
http://www.eurtoast.com
00BlueSi
10-3-2004
East Northport Long Island
Re: Golf / Gti Jetta Vent install Pics and comments (smokedoutVR6) » | « » 7:53 PM 1-25-2006 | |
go to the junkyard and buy them. everyone that i know with them baught them from there and they are in mint condition + only cost 30$ at most for all 3
FükenDübin
the7thcircle
6-10-2005
Boise ID
Re: Golf / Gti Jetta Vent install Pics and comments (00BlueSi) » | « » 8:28 PM 1-25-2006 | |
Hmmm -- theres a 00 Jetta in the local j/y -- might have to do this myself.
1999 Gti 2.0 - Its a piece of crap but its paid off. WTB: OEM springs for said piece of crap.
Ryanzard10
1-3-2006
Re: Golf / Gti Jetta Vent install Pics and comments (London Dub) » | « » 8:31 PM 1-25-2006 | |
nice DIY bro.
mujjuman
7-29-2004
Albany NY
Re: Golf / Gti Jetta Vent install Pics and comments (mujjuman) » | « » 8:56 PM 1-25-2006 | |
| Quote, originally posted by mujjuman » | | hottness |
ThaWeezord
2-16-2004
London Ontario
2000 Jetta TDI
» | « » 12:49 PM 1-26-2006 | |
solid post kyle.
hai guise, i has a deezul
| Quote, originally posted by dasvrsix » | | Tucking is for people that can't afford poking. |
Flickr
ollysnews
4-30-2004
SoCal CA
Re: Golf / Gti Jetta Vent install Pics and comments (London Dub) » | « » 11:44 PM 1-26-2006 | |
Great DIY. I did the same mod and I'm loving it especially at night. This is the way every GTI should have come stock
FS: OEM Euro stubby mirrors contact me Stubbies http://forums.vwvortex.com/zerothread?id=3920543
London Dub
2-1-2005
Toronto Ontario
» | « » 12:04 AM 1-29-2006 | |
Thanks guys - I didn't even know it had made it into the DIY section! I love them - and it is so much cleaner than the stock ones (ugh).
| Quote, originally posted by jus_dubin » | | ps your not a real dubber, a real dubber would have came out to the meet even with a cut up hand... just throw some painters tape on it that says show me your boobs |
Euro-Trash South Western Ontario Euros, forums, galleries, events
abydielsgli
5-7-2003
chattanooga TN
99 wolfsburg sold, 2003 GLI now, 69 bug project yet to begin.
Re: (London Dub) » | « » 12:26 AM 1-29-2006 | |
sweet write up
club.broke.status. My Hooptie dicestylzz Bentley Wheels FS/FT
felmans
6-16-2005
Atlanta GA
1996 Volkswagen Golf 2.0 GL /// Silver Golf 2001 1.8T GLS 4 doors...sweeT
» | « » 11:57 PM 1-30-2006 | |
awesome thread....good work
------ 1 VW is not enough-------
felmans
6-16-2005
Atlanta GA
Re: (felmans) » | « » 11:58 PM 1-30-2006 | |
neat pics too
astonishedboy
3-11-2004
Ahrn City PA
y2k Golf TDI
Re: (felmans) » | « » 4:15 PM 5-22-2006 | |
Excellent Write up!!
tboger0414
2-5-2006
MV MD
Reflex Rabbit
Re: (astonishedboy) » | « » 9:23 PM 6-7-2006 | |
Just did this today with some vents from a wrecked jetta. Great DIY! This will take a little time to run the wiring properly but it is well worth it in the end . Why didn't these come stock on golf/gti
bigmak
1-5-2004
FL/WA/VA
ay/bay/bay
Re: (tboger0414) » | « » 9:24 PM 6-7-2006 | |
| Quote, originally posted by tboger0414 » | Just did this today with some vents from a wrecked jetta. Great DIY! This will take a little time to run the wiring properly but it is well worth it in the end . Why didn't these come stock on golf/gti |
cost saving measure. plus, due to the markets involved with the cars, they came on jettas for a reason.
Mikey, aim: bigmak040 | 42 draft designs | Virginia Tech Hokies ~ 04-16-07| Quote, originally posted by firefighterjunkie » | Get off my bigmak! | █ eurogruppe ~ When mhmm and awkward are together, all hell breaks loose.
tboger0414
2-5-2006
MV MD
Reflex Rabbit
Re: Golf / Gti Jetta Vent install Pics and comments (00BlueSi) » | « » 9:25 PM 6-7-2006 | |
| Quote, originally posted by 00BlueSi » | go to the junkyard and buy them. everyone that i know with them baught them from there and they are in mint condition + only cost 30$ at most for all 3 |
Yeah good call. $25 for the set at the junkyard, my set cleaned up real nice. Def. don't buy full price.
thenick
6-19-2004
Myrtle Beach SC
1998 Jetta VR6 & 2000 Jetta VR6 or I can make a W12
Re: Golf / Gti Jetta Vent install - helpful for jetta/golf vent removal **Pics** (London Dub) » | « » 4:05 PM 6-18-2006 | |
Good write up! Quick Question though Do the Jetta vents just pull out, and just stay in place in the GTi?
| Quote, originally posted by SickWrathTerror » | Trendsters all over the world are proudly holding up their Starbuck's mocha-frocha-half-caf-decaf-vanilla chai-drizzled with sperm whale semen-on-top-iattos for a cheers. |
| Quote, originally posted by thesteve » | The Car Lounge is like the Roman Coliseum. It's spectators don't really care who "wins", as long as there's a ton of bloodshed. |
Disarray
5-15-2006
Baltimore Maryland
2007,2.5 Rabbit
Re: Golf / Gti Jetta Vent install - helpful for jetta/golf vent removal **Pics** (thenick) » | « » 5:07 PM 6-18-2006 | |
 VW OEM MK4 clean look vents, set of 3 US $ 169.00
vrsexyjetta
12-5-2005
Atlanta GA
2000 Jetta GLX
Re: Golf / Gti Jetta Vent install - helpful for jetta/golf vent removal **Pics** (thenick) » | « » 5:09 PM 6-18-2006 | |
The Jetta vents are a PITA, 1st remove a button, I had all options but if you have a blank button remove it carefully with a small flat head. Then if you look up inside the vent you'll see two tabs you need to press in with a screw driver, then the rest just pulls out, I thought I was about to break mine but it did pull out you just have to be super careful. If you have illuminated vents be careful not to rip out the wires that connect to the LED.
Modified by vrsexyjetta at 5:11 PM 6-18-2006
SAVwKO
3-8-2003
Austintown Ohio
HS Tuning
Re: Golf / Gti Jetta Vent install - helpful for jetta/golf vent removal **Pics** (vrsexyjetta) » | « » 9:02 AM 11-1-2006 | |
So if I understand this right, are there Jetta vents that don't have the lights in em and some that do? Would a 2004.5 GLI have em and just not be wired up?Also, anyone have a pictured DIY on removing them. Don't wanna break these guys.
London Dub
2-1-2005
Toronto Ontario
Re: Golf / Gti Jetta Vent install - helpful for jetta/golf vent removal **Pics** (SAVwKO) » | « » 9:35 AM 11-1-2006 | |
Removing the new style vents it a real PITA. As said above, you need to take out the buttoms/switch and reach up inside to find the little tabs. You pull them, while pulling the face of the vents out. The face falls off and the shutters come out oo. Then you can unscrew them. Alternativly you can reef on the front and hope they come out okay. The older style like '02 and lower, do not have these extra screws and simply pop off. Similarly, if you have the new style vents with the screws, you can use them to resinstall into your golf/gti. This involves installing the vents peicemeal, basically the back half with the screws, then the vents themselves, the louvres, and the face. It is hard to explain - but once you take the vents apart it is very easy to see.
SAVwKO
3-8-2003
Austintown Ohio
HS Tuning
Re: Golf / Gti Jetta Vent install - helpful for jetta/golf vent removal **Pics** (London Dub) » | « » 10:24 AM 11-1-2006 | |
Ok...well if anyone has pics I'd like to see em.Also, what about the lights? Are there 2 different sets of Jetta vents?
MeiK
3-18-2005
Cheshire Ct
2003 GTI 24V Turbo
Re: Golf / Gti Jetta Vent install - helpful for jetta/golf vent removal **Pics** (SAVwKO) » | « » 10:44 AM 11-1-2006 | |
Just bought a set for $120.00 Eh. No MKIV cars evAr make it to the junkyards around here...
24V2.9LVR6BTAWICVWGTI  5'th Gear Burnouts @ 130MPH FTMFW lawlz http://www.neherpetoculture.com http://www.meiksite.com
oj1480
6-6-2006
Brklyn Queens ny
new beetle 98, audi a4 98, jeeta 05
» | « » 10:47 AM 11-1-2006 | |
gti's vent really suck monkey balls.
----/========\ ' ---------''/==========\ (]/_ _____ _\[)-----(]/_ ________ _\[) ''/(OO)--[H]--(OO)\'--------(O8o)==\X/==(o8O) '|------||||||||------|------|\=============/| [__|--------------|__]--.-'[__|===========|__]
SAVwKO
3-8-2003
Austintown Ohio
HS Tuning
Re: Golf / Gti Jetta Vent install - helpful for jetta/golf vent removal **Pics** (MeiK) » | « » 11:18 AM 11-1-2006 | |
| Quote, originally posted by MeiK » | Just bought a set for $120.00 Eh. No MKIV cars evAr make it to the junkyards around here... |
So did you buy a set that has lights inside? Geeze can someone please tell me if there are two different vent styles for Jettas? One with and one without lights? If so, would a newer GLI have the lights in them? Don't feel like risking breaking these to take em out if they don't have lights.
VacantSkies88
11-15-2004
PA
2000 Jetta GLS VR6
Re: Golf / Gti Jetta Vent install - helpful for jetta/golf vent removal **Pics** (SAVwKO) » | « » 11:34 AM 11-1-2006 | |
| Quote, originally posted by SAVwKO » | | So did you buy a set that has lights inside? Geeze can someone please tell me if there are two different vent styles for Jettas? One with and one without lights? If so, would a newer GLI have the lights in them? Don't feel like risking breaking these to take em out if they don't have lights. |
There is infact one set with lights and also a set without lights. The GLI's vents are not illuminated.
TRACK PREPPED HONDA CIVIC HB FOR SALE - 233HP / 192 FT LBS
London Dub
2-1-2005
Toronto Ontario
» | « » 12:22 PM 11-1-2006 | |
You can't tell which ones are lighted versus which ones aren't unless you either take them out, or check behind them for the wires. But '04.5 GLI did NOT have lighted vents. You need soemthing a little earlier. Just buy one of my sets.....lol...
SAVwKO
3-8-2003
Austintown Ohio
HS Tuning
Re: Golf / Gti Jetta Vent install - helpful for jetta/golf vent removal **Pics** (VacantSkies88) » | « » 12:22 PM 11-1-2006 | |
| Quote, originally posted by VacantSkies88 » | There is infact one set with lights and also a set without lights. The GLI's vents are not illuminated. |
Thank you sir! You saved me lots of hassle to .
MeiK
3-18-2005
Cheshire Ct
2003 GTI 24V Turbo
Re: Golf / Gti Jetta Vent install - helpful for jetta/golf vent removal **Pics** (SAVwKO) » | « » 12:49 PM 11-1-2006 | |
I bought unlighted. I guess pre-2003 are lighted... According to undergroundVWpartts
PGH F4I
5-12-2005
Brooklyn Center MN
2001 VW GTI GLX VR6
Re: Golf / Gti Jetta Vent install - helpful for jetta/golf vent removal **Pics** (MeiK) » | « » 6:45 PM 12-28-2006 | |
I just got my whole lighted set for $10.00 at the local junk yard.
Modified by PGH F4I at 5:48 PM 12-28-2006
| Quote, originally posted by acbaldwin » | whoa - I forgot about the censorship! I meant s * * t a chicken... not f* as chicken... I don't f* chickens. at least, not when I'm happy. |
I survived Aristo's 06 http://forums.vwvortex.com/zerothread?id=2920735
PhrequenC
2-4-2005
Bridgeport CT
96 GTI2.0(sold) /// 00 GTI GLX (sold) /// 00 Civic Coupe
Re: Golf / Gti Jetta Vent install - helpful for jetta/golf vent removal **Pics** (PGH F4I) » | « » 11:33 PM 12-31-2006 | |
are the ones tmtuning sells plug n play to gti? or no? u have to do all thisi wiring bull?
