jtc126
8-16-2004
2001 VW Golf 1.8T 4-dr
TB Throttle Body Cleaning Procedure (fix rough warmup, rough idle, engine choking) | « » 5:16 PM 5-12-2005 | |
TB Throttle Body Cleaning Procedure (fix rough warmup, rough idle, engine choking)Hi All, This is a extension / continuation of a thread posted by Tone-Dogg. http://forums.vwvortex.com/zerothread?id=1678991 The reason why I decided to write this up is because after cleaning the throttle body, a lot of my problems were solved. No more rough startup, rough idle, cleared my Check Engine light CEL... etc.
So here we go: 1) Know WHERE thy Throttle body is It is located on the left bottom of this picture. It is the weird-looking thing that connects the intake manifold and the black plastic air tubing:
 A Closer Look:
2) Disconnect the plastic tube above it. The clamp holding the tube is one-time clamp but you can still remove the tube from it without destroying it.
Tube connected:
Tube disconnected:
3) Now, we remove the plastic clamp that holds the air tube to the TB and disconnect it from the TB. Then, remove the 4 bolts holding the TB to the Intake Manifold
4) Remove the electrical wire conector underneath the TB, to allow remove the whole TB out for cleaning Where the connector is located:
5) Now, Clean the TB with whatever (or not) but make sure you dry it up if you use any liquid.
TB removed from the Engine:
 6) Clean the intake manifold if you'd like. (I didn't) The intake manifold:
7) If desired, you can remove / replace the Air Temperature Sensor mounted on the intake manifold for cleaning (They use 1 bolt to hold it - same as the ones used on the TB but shorter)
The location of the Temperature sensor:
 8) If desired, replace the gasket with a new one.
The old gasket stuck on the TB:
 The new gasket to put on:
 9) Put everything back on and DO NOT OVER-TIGHTEN the bolts. I'm sure we don't want to get a new Intake Manifold because of it.
Please correct me if you see fit. P.S. - How tight should the bolts be on the intake manifold? 13lb/ft? 15? - You can buy the Throttle Body gasket and the Air Temperature Sensor at ECSTuning for a couple of bucks. - Use the right tool everyone, I think I have stripped one of the bolts a little... anyone know where I can buy the bolt set? I'm not very car-literate myself, so please give up your ideas or corrections! No hard feelings!
Modified by jtc126 at 2:31 PM 5-12-2005
jtc126Trying to learn....
flanders
4-5-2001
Ottawa, Ontario, Canada
Re: TB Throttle Body Cleaning Procedure (jtc126) » | « » 7:22 PM 5-12-2005 | |
Mr. Bentley says tighten bolts to 6Nm (52 in-lbs). This is the torque for the 4 bolts that mount the TB to the intake mani, and the torque for the intake air temp sensor.
▊♣▊ 1.8T OVD - Ottawa Vdubbing club!
V84LNCH
8-29-2003
Canton Ohio
double horse powered 1.8t...
Re: TB Throttle Body Cleaning Procedure (flanders) » | « » 7:26 PM 5-12-2005 | |
nice write-up what about pulling the tb control sensor off?
lVolkswagenllIntercooledllTurbol European Performance Labs <--------click for custom tuning 344whp@ ~22psi
4thvw
1-3-2004
somerset nj
2004 gti 1.8T KO3S & 4 straight rods!
Re: TB Throttle Body Cleaning Procedure (V84LNCH) » | « » 8:11 PM 5-12-2005 | |
No pic's of the dirty TB? How many miles on your car before these problems appeared?
"You buy the ticket, you take the ride"-Hunter S. Thompson 2004 GTI 1.8T 1987 Buick GN, 1966 vette 427/390hp 2002 jetta GLI, 1996 jetta GLX, 1989 jetta GL
jtc126
8-16-2004
Re: TB Throttle Body Cleaning Procedure (4thvw) » | « » 8:42 PM 5-12-2005 | |
Sorry. I didn't have a dirty TB because I cleaned it. I just took these pictures when I got my new gasket to put onI'd say to check it every 30K miles. according to this post. My car has 75K and it came to point where my engine would stop when idle. So definitely check it at 30K. http://forums.vwvortex.com/zerothread?id=1678991
Buttero J-Lo
3-5-2003
Depths of Hell
Re: TB Throttle Body Cleaning Procedure (jtc126) » | « » 8:43 PM 5-12-2005 | |
DUBAHOLIC DESIGNS MEMORYFAB SERIOUS EURO TUNING GRAFIXPRESSIONS APR
16vracer
7-12-1999
Re: TB Throttle Body Cleaning Procedure (Buttero J-Lo) » | « » 9:39 PM 5-12-2005 | |
I'll take mine off and clean it tomorrow night or Saturday, maybe it will help my car
'08 A4 3.2Q '05 XC70 DCI-S.Sound
DJKeebler
12-5-2001
Kaneohe HI
No car right now. In transition.
» | « » 11:27 PM 5-12-2005 | |
don't forget to do a TB alignment with VAG-COM if you've got it. I didn't have a VAG when I cleaned my TB but if you're going to remove it to clean it, doing the alignment is HIGHLY recommended.
Matchstick red 2002 GTi 1.8T-Just a few select goodies
Tone-Dogg
2-19-2002
Newington CT
05 A4 1.8T 6MT Quattro, 10 A4 2.0 6MT Quattro Premium Plus
Re: (DJKeebler) » | « » 11:51 PM 5-12-2005 | |
Nice Write up, see I told you, You could pull off the job, not very hard. Ya, crank those bolts down a bit more your don't want any leaks for reasons to throw a cell.Great job man.
2005 A4 1.8T Quattro 6MT SE2010 A4 2.0T Quattro 6MT Premium Plus 2001 Jetta 1.8T WE gone
Italian GTI 1.8T
6-19-2003
Cupertino, S.J. CA
'02 Silver GTI Turbo (Sold), 2006 Evo IX
Re: (Tone-Dogg) » | « » 3:05 AM 5-13-2005 | |
sticky it!!!!
blueGOLFturbo
3-9-2004
Colorado Springs CO
2000 Golf GLS 1.8T--- Twin Intercooler
Re: (DJKeebler) » | « » 5:22 AM 5-13-2005 | |
| Quote, originally posted by DJKeebler » | | don't forget to do a TB alignment with VAG-COM if you've got it. I didn't have a VAG when I cleaned my TB but if you're going to remove it to clean it, doing the alignment is HIGHLY recommended. |
I cleaned my TB and did an adaptation last weekend and the car would die at iddle all of the sudden, the adaptation was sucessfull, so Im not sure what could be going on?? anyone have thoughts on this? Greg
No time for love, Dr. Jones.
roi
8-5-2003
Golf 4 GTI 1.8T 2001 model
Re: TB Throttle Body Cleaning Procedure (jtc126) » | « » 7:16 AM 5-13-2005 | |
nice wright up
GT3071/ 750RC injectors/ 034EFI stage IIc /greddy s-type /greddy boost controler / Atp big cooler /clutch master st 3 /autoteck fw / 2.75" exhaust system / ap Racing 330 brakes / 18" OZ
jtc126
8-16-2004
Re: (blueGOLFturbo) » | « » 3:27 PM 5-19-2005 | |
Is it still doing it? Did you figure out what happened?Did you reconnect the electric cable under the TB too?
pressed
7-16-2005
Kansas City KS
'01 Jetta 1.8t AWW
Re: TB Throttle Body Cleaning Procedure (jtc126) » | « » 2:54 PM 8-30-2005 | |
I agree, nice writeup and thanks for the pics!
$2.98/g
O2VW1.8T
boosted NC
All wheel drive 1.8T GTi
Re: TB Throttle Body Cleaning Procedure (pressed) » | « » 3:04 PM 8-30-2005 | |
i clean mine once to twice a month. It gets dirty fast
GT35R with AWD - (1/4 mile 11.76@126mph pump gas)best 1/8th 7.36@102mph http://www.pagparts.com http://www.Eurodyne.ca http://www.forcefedengineering.com http://www.INAengineering.com http://semmotorsports.com B6 A4 1.8T fronttrak Converted to AWD but RWD for now 1988 audi 90q - slow project
jetta_grl
7-1-2005
Colorado Springs CO
2001 VW Jetta 1.8T Wolfsburg
Re: TB Throttle Body Cleaning Procedure (jtc126) » | « » 3:24 PM 8-30-2005 | |
Awesome post! Thanks for the tips! BTW, what's good to clean the TB?
It's not about the 0-60MPH, it's about the 100-160MPH THIS CAR IS FOR SALE: http://cosprings.craigslist.org/car/544933621.html http://www.cardomain.com/ride/2051204 http://www.myspace.com/jetta_girl001
O2VW1.8T
boosted NC
Re: TB Throttle Body Cleaning Procedure (jetta_grl) » | « » 3:51 PM 8-30-2005 | |
brake kleen
SHUMopper
1-1-2002
Long Island
2007 A4 2.0T 2008 Touareg2 V6
Re: TB Throttle Body Cleaning Procedure (O2VW1.8T) » | « » 4:09 PM 8-30-2005 | |
i should clean mine...ive had it off a few times now and forgot each time. duh!
|:|SHUMOPPER|:|TYROLSPORT|:|
ruso
7-28-2004
Wheeling WV
07 United Gray GTI, 08 Candy White Rabbit (Wife's)
Re: TB Throttle Body Cleaning Procedure (SHUMopper) » | « » 7:13 PM 8-30-2005 | |
Any of you guys get a studdering or helicopter sound along with misfire codes upon cold start when the secondary air is running?
07 United Gray GTI| Quote, originally posted by veedubtek » | | ...I am very meticulous in my inspections (vw master certified, finalist in the world service qualification championships last year). |
| Quote, originally posted by mk2vdubber » | | walt - what are the torque specs on a vr6 head? |
| Quote, originally posted by veedubtek » | | 1/2" impact gun on the 3rd setting. |
groftja
7-19-2004
Frdbg VA
20thAE GTI
Re: TB Throttle Body Cleaning Procedure » | « » 10:20 AM 8-31-2005 | |
CAUTION: Last night I took out the IAT sensor in the manifold to clean it. It has a rubber o-ring that sits in a groove on the part to seal the hole from the manifold pressure. After 45k miles of use, my o-ring had expanded enough that it took brain surgery to get the part back in with the o-ring attached. Basically, I had to stick the IAT in the freezer to shrink and strenthen the o-ring, oil the o-ring and the hole in the manifold, and then use a tiny screwdriver to keep the o-ring from wanting to squeeze out when I pushed the IAT into the hole. It was a beotch to do (took about 30 minutes of messing with it) and recommend others try to buy a new o-ring before they do this procedure. If the o-ring is not sold separetely, be ready for a likely pain in the asz. BTW, my IAT was clean and didn't even need to do this.
Wolfsburg1.8
9-22-2003
Pittsburgh PA
A very loud, very gutted E36 M3 / 2001 Wolfsburg Jetta - sold!
Re: TB Throttle Body Cleaning Procedure (groftja) » | « » 4:22 PM 10-4-2005 | |
| Quote, originally posted by groftja » | CAUTION: Last night I took out the IAT sensor in the manifold to clean it. It has a rubber o-ring that sits in a groove on the part to seal the hole from the manifold pressure. After 45k miles of use, my o-ring had expanded enough that it took brain surgery to get the part back in with the o-ring attached. Basically, I had to stick the IAT in the freezer to shrink and strenthen the o-ring, oil the o-ring and the hole in the manifold, and then use a tiny screwdriver to keep the o-ring from wanting to squeeze out when I pushed the IAT into the hole. It was a beotch to do (took about 30 minutes of messing with it) and recommend others try to buy a new o-ring before they do this procedure. If the o-ring is not sold separetely, be ready for a likely pain in the asz. BTW, my IAT was clean and didn't even need to do this. |
is it really necessary to clean the IAT sensor? could a dirty IAT sensor cause a feeling like the throttle is closing at steady throttle? can you clean it with brake clean?
95 BMW M3: CF Intake, Amsoil Filter BPK, UUC Catback, AA Track Pipe, AA Headers, AA ECU, Samco Hoses, UUC UDP's, KW V3 Coilovers, AA Upper Strut Brace, JT-Designs RSM's, BMW X-Brace, UUC Sway Bars, UUC Adjustable C.C. Arms, JT-Designs Tranny Mounts, B&M SSK, Fully Gutted, Sparco Seats, Apexi AFC, Autometer Gauges, Autopower Race Roll Bar, Aluminum Underpanel, ZKW HID Projectors w/ Xtec Demon Eyes
groftja
7-19-2004
Frdbg VA
20thAE GTI
Re: TB Throttle Body Cleaning Procedure (Wolfsburg1.8) » | « » 4:35 PM 10-4-2005 | |
My guess is that when it's dirty, it tells the ECU that the intake air is hotter than it actually is (it's insulated by the crud so less voltage to keep it at a given temp which is same that happens when the air actually is hot). Can't say for sure, but maybe the ECU tries to shut the throttle body since it is freaking out about how hot it thinks the intake air temp is.Mine did not need to be cleaned but I am super careful about air filter and motor oil quality and bet that some others who aren't and have older cars, have cruddy IAT sensors. Whatever you use to clean it, make sure it is safe on plastics...that's all I can say. You did see my CAUTION sign above right? Be careful.
modifieda4
10-27-2003
fairfield cnty ct
2000 A4 1.8tqmsx
Re: TB Throttle Body Cleaning Procedure (jtc126) » | « » 4:51 PM 10-4-2005 | |
| Quote, originally posted by jtc126 » | 9) Put everything back on and DO NOT OVER-TIGHTEN the bolts. I'm sure we don't want to get a new Intake Manifold because of it. |
nice writeup if you do happen to strip out the threads in the aluminum manifold, rest easy, you will not have to replace the whole manifold. you can repair the threads with heli-coils...here's a how to: http://www.modifieda4.com/web/....html
ModifiedA4 1.8tqmsx, K04'dmy A4:http://www.modifieda4.com/web/mya4.html How does the performance of your A4 stack up? Check out the CAPS Database:http://www.modifieda4.com/web/caps/b518-new.html
Bastard
7-3-2003
Ottawa On
» | « » 7:23 PM 10-4-2005 | |
You know its going to go rapidly downhill when you have to refer to the throttlebody as " the weird-looking thing "
If you believe your K04 car makes 450whp. I got a bridge to sell you. Guess what dyno is not actually located at the top of mount everest, despite what he has his elevation set to.
Az!
8-3-2001
Tampa FL
2001 Black-Beige Wolfsburg
Re: TB Throttle Body Cleaning Procedure (jtc126) » | « » 12:56 PM 11-20-2005 | |
Okay, I'm having the same issue. Last time this started happening, I just had a TB alignment done via Vag-com. My problem seemed to go away for several months.Now it's back again and it's worse than ever. I just finished cleaning out the TB, disconnected the battery for a few mins, reconnected without starting for a few minutes, and gave it a crank. The bouncing tach at idle is still there and no better. I've also noticed if I'm giving just enough gas to maintain my current speed, I get the choking, stuttering (very very slightly), as I do when it's just at idle. If I give it full on gas acceleration, there's no issue (at least that I could feel). One thing I did notice, is that when my AC is off, the problem is much less pronounced, as soon as I hit the AC, the stutter. flutter is noticebly worse. Any other suggestion as to what else I should look at?
2001 Black Wolfsburg | GIAC X-chip | Velocity CAI |
screwball
12-10-2001
46lbs/min
Re: TB Throttle Body Cleaning Procedure (Az!) » | « » 1:20 PM 11-20-2005 | |
a boost leak maybe? you can check your fuel trims w/ a vagcom to see if you're running rich.
Junk T.I. - Central NJ VW & AUDI Mechanic /// SMS Performance
Az!
8-3-2001
Tampa FL
Re: TB Throttle Body Cleaning Procedure (screwball) » | « » 2:31 PM 11-20-2005 | |
When we checked with Vagcom last, I did have a fuel rich alert. How do I go about finding a boost leak?Should I go ahead and replace the Temperature sensor or would this not be causing my current symptoms.?
W_Jetta
3-4-2004
GA
R32
Re: (DJKeebler) » | « » 2:10 PM 2-28-2006 | |
Can you give me some information on that? What if I dont have vag-com to alignment?
W_Jetta
3-4-2004
GA
R32
Re: (W_Jetta) » | « » 3:12 PM 2-28-2006 | |
ttt need information on this please
W_Jetta
3-4-2004
GA
R32
Re: (W_Jetta) » | « » 5:27 PM 2-28-2006 | |
Big Bad Wolf
1-28-2003
east south fallowville Pa.
2001 Jetta slightly modded. Trailblazer SS
Re: (W_Jetta) » | « » 5:55 PM 2-28-2006 | |
| Quote, originally posted by W_Jetta » | bump |
post in your regional,,,and i'm sure somwone local will be able to help you with a TBA
My car suffers from WWD aka..wrong wheel drive 20squared tuning Flickr
W_Jetta
3-4-2004
GA
R32
Re: (Big Bad Wolf) » | « » 7:42 PM 2-28-2006 | |
I just wanna know why is highly recommended?
westendtruck
3-12-2006
Port Jefferson N.Y.
2001, VW, Jetta 2.0
Re: (W_Jetta) » | « » 9:00 PM 3-15-2006 | |
where is the IAT located on 01 jetta 2.0
dansgti
4-13-2005
glendora ca
2002 gti 1.8t
Re: (DJKeebler) » | « » 9:27 PM 3-15-2006 | |
so what if you dont got a vag?
dansgti
4-13-2005
glendora ca
2002 gti 1.8t
Re: (dansgti) » | « » 9:49 PM 3-15-2006 | |
can i buy a IAT SENOR at the dealer? and for how much?
