 DIY Lower Core Support.« »
This is the bar that holds up the radiator from the underside of the subframe. I had no idea this thing would rot out this bad. However, its easy to change, and requires about 1 hour. Mine is a 2.0 I think the VR6s are the same. Check this part NOW if you live in the NE. Note: no need to remove wheels, coolant, or anything else... its easy.
The part costs $161 from the dealer (Central east coast USA, 8/05).
Needed, good jack (not widowmaker), 2 jack stands, 8 and 10mm deep socket, 16mm 1/2 drive deep socket (6pt), two long zipties.
Time < 1 hour.
Here's how.
Jack up car at front sub frame. The front motor mount is a good place to do this. Position some jack stands under the front sub frame on either side of the jack.
Remove the upper fan shroud (3-8mm bolts), and use the plastic Zipties to hold the upper radiator hose to the upper support, and then do the same for the A/C condenser (metal) hose. This will hold up the radiator when we remove its support from the bottom.
Next, reach down and remove the two 10mm bolts holding the radiator to the lower support. These bolts are on either side of the side tanks, and have large washers that will come out with the bolts.
Next, Remove the 4 large 16mm bolts from the front of the sub frame. Take care not to lower or shift the vehicle at this point as there is a small chance you may knock off the alignment of the frame (and change toe adjustment and thrust angle).
At this point, the old lower core support comes out. Kick that rusty Mexican crap into the trash and either make sure that your junkyard one has ZERO rust, or grind/sand blast it/prime it/paint it with a good quality spray paint (I used black Rustolium "hammer tone"). Even if this part were new, I'd still spray it. Water sits on this part every time it rains... plus its down in the "salt zone" for us winter driving morons..
You may wish to think about a euro-rad support if you are going to do this, its not a big deal..
Modified by Dan J Reed at 1:25 AM 8-10-2005
BB 62.. bitch!
BBQmotorsports - BUBENGROPEN - LOWERED CARS SAVE GAS! my DIY page -
dr. locktopus
6-23-2001
Kitchener Ontario
2003 BMW 325i
 Re: DIY Lower Core Support. (Dan J Reed) »« »
that's some holey crap!
nice write up. i'll have to check my 93
das jetta kartell: get up on the table
Franco...
6-18-2004
out of the gay
and in da Valley...CT
i hear ya
autocratica
1 thirty pack at a time
jhayesvw
10-2-2001
Tucson AZ
1996 Golf 4 door VRT
 Re: DIY Lower Core Support. (Franco...) »« »
MY CAR
vwvortex is like the Hotel California, you can check out any time you like, but you can never leave.
Tucson Forced Induction
"The welfare of humanity is always the alibi of tyrants." - Albert Camus
bikerbill2021
10-7-2004
Upstate NY
Turbo Mark 3, e30, CB500T
finally ill get a chance to replace this bastard
mine is totally gone, radiator hangs down sideways, good thing my MK3 is off the road for the winter
:.Tyler.:
DoWn
2
EaRtH!
So Sophisticated, I'm such a zero...
vdubfiend
10-16-2001
unngggghhhhh lake balboa
damn i miss the east coast
heart
atc
MASON-TECH
WTT:my polished 16" x 1.5" 34 hole lips for your 16" x 2" 34 hole lips
Underpants
1-13-2006
NY
TOPHEAVY
 Re: DIY Lower Core Support. (vdubfiend) »« »
Quote, originally posted by vdubfiend »
who're you?
2008-7410/8520-*936+
.+-+MK3 PRINTS.
*/7410*+*/ ``aA1222233454Q2A23QAS23SD34E5DFCVBVG T76GYUBHJN 78MJK,890I,L.,.;/78YUHJNM76Y767776=[P]\]]
NJMK.L?``111 q
1-25 characters
5-25-2006
Hell
 Re: DIY Lower Core Support. (Underpants) »« »
Did you just call bob a whore?
http://www.dubfestmagazine.com
Christopher Columbus discovered America and was the Indians' best friend. He helped the Indians win their war against Frederick Douglass, freed the Hebrews from Napoleon and discovered France.
CamelSkull
9-11-2006
Gravestones A.D.
 Re: DIY Lower Core Support. (1-25 characters) »« »
I have a spare for sale pm me.
ATC
Trailer Option N/A
1-25 characters
5-25-2006
Hell
 Re: DIY Lower Core Support. (CamelSkull) »« »
A spare whore? sweet.
a3clusters
1-6-2007
look behind you
GAP's got it for $62...
toybitzVR6
10-23-2006
Glendale CA
95' VW GTI VR6
hehe that sucks... i wish mine still better...
--> 95' VW GTI VR6
--> '07 SCION TC 2.4
MRosier
9-17-2006
Finksburg MD
1997
i think mine is bent, is that bad?
repete offender
8-22-2007
Central NY
MK3 LOVE (TDI&VRT)
Quote, originally posted by a3clusters »
http://www.germanautoparts.com...9E112
Pete
number 5 on deck.
envi
7-31-2005
east side
GTi x2
 Re: (repete offender) »« »
Project Partout
Badass Motor
 Re: DIY Lower Core Support. (a3clusters) »« »
Wow blast from the past. I am glad GAP now carries this part... back when I did mine... they didn't.
BB 62.. bitch!
mk2vrooom
10-15-2003
Nashville TN
08 GTI 2.0T
 Re: (envi) »« »
Quote, originally posted by envi »
damn!...if you need another one i have one fs
http://www.dubbedbyrma.com
Pennsylvania College Of Technology
...blowme
someone should take over my mk5 lease so i can get an mk3 again...
Sandlock
8-9-2001
Fresh Prince MD
ouch
all day, every day - junglists unite
do work on my fire sale
8100+280=
rat-stylz for the cure
dunkin-motorsport
2-18-2005
Nyack NEW YORK
98 BMW 328i
 Re: DIY Lower Core Support. (Sandlock) »« »
i got one at show and go last year but never got a chance to put it in.mine hangs bad.
are they a universal part for vr and 2.0s? i got a vr
Rockland g2g 8:30pm Wednesday nights @ Palisades Mall Commuter Lot (across from Home Depot)
TEAM PERM-A-SHOCK
a good punch in the mouth can go along way
vwjettalikewhoa
9-3-2003
01002 MA
16v/ABA MK3 and a scene MK2
holy old post batman.
Quote, originally posted by vwjettalikewhoa »
i thought we were doing pretty good for the MKIII forum
Quote, originally posted by King »
yeah.....no.
MasterAres
8-26-2006
Central 73two NJ
mine rotted off my car without me touching it.. vr6 for reference.
1995 Sequoia Green automatic jetta 3
1996 Black 5-speed VR6 Jetta
Check out my FS/FT thread:
http://forums.vwvortex.com/zerothread?id=4368750
Complete 1994 GTI Partout, T-Red, Central NJ!!
http://forums.vwvortex.com/zerothread?id=4585411
Netdewt
2-19-2008
Minneapolis MN
Slow 4-door MK3 Golf
 Re: (MasterAres) »« »
Mine is 3/4 as bad as Dan J Reed's... but I didn't know what it was until now. Thanks!
Quote, originally posted by Alan Partridge »
faded red crackwagen.
» Return to Golf III & Jetta III
