turbo_wagon
10-26-2001
Anytown USA
 help me heel/toe« »
I keep hearing about heel/toe shifting. I have a vague concept that it has something to do with rev matching when downshifting, but more than that, I don't know.
I have a 5-speed in my Jetta and if I want to drive faster I just shift faster, but I always have my left foot on the clutch and right foot on the gas.
What am I missing? How can I learn how to do this?
nourdmrolnmt1
2-26-2004
Chagrin Falls OH
05 Malibu Maxx LS
what you described is double clutching
clutch
shift to neutral
de clutch
rev to match rpm when in gear
clutch
shift into gear
declutch
heel toe i dont know about, nor do i really care other than i believe it has to do with being on the brakes and clutching with the same foot.
Quote, originally posted by 2003GLI-NJR »
The BMW hands down would win...Have you seen the wheel gap on stock Mustangs???
Jettavr666
12-5-2000
2001 Passat GLX 4motion
 Re: (nourdmrolnmt1) »« »
basically you press the gas and brake at the same time. I will let someone more eliquant explain it better.
Just so you know, heel/toe-ing is very difficult in the MKIV cars due to the pedal placement.. The MKV's have drastically improved on this with the floor mounted gas pedal.
Josh| = |
Live, Laugh, Learn
juice
10-19-2004
Potomac MD
I'll suggest a good book on the subject, called Performance Driving by Alain Prost (though he didn't write most of it).
Good pictures and instructions. Plus extensive discussions about the racing line, which is even more useful IMO.
Quote, originally posted by AKADriver »
RWD G6? That's almost more appealing than the G8. Like a BMW 3-series for the rest of us. Pontiac, I'm officially sorry for all the nasty things I said about your ribbed panelling or the lousy steering and handling of my mom's old Grand Am.
BlitzAction
8-11-2003
Charlotte/Raleigh NC
93' MR2 Turbo sunroof
Quote, originally posted by nourdmrolnmt1 »
clutch
shift to neutral
de clutch
clutch
shift into gear
declutch
I never got the point of this, why cant I
be in 5th
clutch in
rev match for 4th
shift to 4th and clutch out
93 MR2 Turbo; 1967 Beetle
JonBabyUK
5-9-2005
Portland F_cking OR
 Re: help me heel/toe (kecart) »« »
Quote, originally posted by kecart »
how can I learn how to do this?
What you need to learn is how to NOT EVAR drive around with your foot on the clutch. Bad, bad, bad habit. Your left foot stays on the floorboard until it's time to shift. You don't sit at stoplights with the clutch depressed, do you? Number one way to burn out a clutch.
Sorry I can't provide much insight on the heel-toe stuff.
Peace, J
I'm part of the resistance.
Don't whine at me. I didn't vote for him.
Lankyleo
1-15-2002
Deer Park NY
'84 Rabbit convertible wolfsburg
 Re: (Jettavr666) »« »
u just position ur right foot across the gas and brakes in one of two ways (slanted to the right / with ur small toes, side of ur foot hitting the gas and rev matching, or slanted to the left \ with ur big toe on the brakes and side of foot,heel clipping the gas. so that u can brake, downshift and rev match all at the same time. i tend to find that the big toe/ball of ur foot on break foot slanted to the left \ usually works best
depending on pedal position, shoe size, and dexterity with ur feet ull figure out which one works best for u. once u get in the habit of doing it, and doin it well itll add to spirited driving fun
Modified by Lankyleo at 12:39 PM 8-11-2005
Modified by Lankyleo at 12:41 PM 8-11-2005
dürty 8v
The Old Schoolers Groupe
MK1 Clothing
Obin Robinson
10-20-2000
on a military base
2004 Hyundai Elantra, 2001 Porsche Boxster
what might just help you is getting a new gas pedal with an extension on it. something like these:
http://store.yahoo.com/ltbmoto....html
i found it nearly impossible to smoothly heel-toe my Scirocco until i installed pedals like those. some vehicles just have the pedals a bit too far apart for some people to smoothly heel-toe.
obin
Jettavr666
12-5-2000
 Re: help me heel/toe (Obin Robinson) »« »
Quote, originally posted by Obin Robinson »
obin
The DBW throttle also makes it next to impossible to do it smoothly.
Josh| = |
Live, Laugh, Learn
.:Ryan
8-8-2005
860 CT
01 Solara SEV6 MT
 Re: help me heel/toe (JonBabyUK) »« »
Rev-matching + downshifting. AKA "heel - toe" -ing:
This only happens while braking/downshifting/slowing down.
When you down shift with out rev-matching the engine, your RPMs will shoot up about 1k, right?
Example:
You're cruising along in 4th at 2k rpms. You disengage the clutch,downshift (with out revmatching), and then reengage the clutch. Now the tachometer will zoom up to 3k because of the Syncros in the transmission.
Well the idea of rev-matching is while your clutch is disengaged, give the engine some gas to make the engine speed match the RPM's that the engine will be at in the lower gear.
Example:
You're cruising along in 4th at 2k rpms. You disengage the clutch, press the gas so it reaches 3k, then reengage the clutch and you will have a much smoother, and less harful to your transmission shift.
The reason why it's called "heel-toe" is because on some cars, when you downshift and brake, your toes will be on the brake pedal and your heel will be on the gas. Also for people with small feet
For me, I have size 12 shoes, so I just roll my ankle over to touch the gas pedal
I hope this helps
Der Golf Kart
FS: Brand New Miro M02
FS/FT: Kuhmo V710 on snowflakes
turbo_wagon
10-26-2001
Anytown USA
Quote, originally posted by JonBabyUK »
I don't. And I'm neutral if i'm at a light.
Twosont
2-8-2005
Middletown CT
04 black Pathfinder SE
i find heeltoe to be too difficult in the mkiv jettas. the pedals are too distant. but im only a size 10 sooo
edit: i've got oettinger pedals too
Modified by Twosont at 1:19 PM 8-11-2005
work to live, not live to work.
veedub11
3-9-2002
Shaw District NW DC
2k Golf TDI, 07 Langster
Peace, J
ooops!
-Adán
(Sometimes my Pops posts on my username)
Let's Go Mountaineers!!!
Washington Redskins
GT17V
8-6-2001
Wharton NJ
2002 Golf GLS TDI
 Re: help me heel/toe (Jettavr666) »« »
Quote, originally posted by Jettavr666 »
It's not DBW that makes it hard-- it's the granny controls VW & Audi uses-- hit the brake and the ECU cuts all the engine power.
It's possible to heel-toe... it's really toe-toe for me--- on MKIV's. It's just trial and error (foot position) and practice
Returning to near stock.....
spdfrek
2-28-2002
Northlake IL
91 Montana Green GTI 1.8T, 07 T-red Rabbit 2.5low
I don't. And I'm neutral if I'm at a light.
I was told when stopped at a light you should always be in gear because if you are hit or something you won't roll into traffic.
Quote, originally posted by Dr. Hank McCoy »
For the RARE appearance of the mammalian species Petshackius Pervious - common name "Polipino Pedobear"
...the cause...
JonBabyUK
5-9-2005
Portland F_cking OR
Good deal. Just checkin' cuz in your original post you stated that you drive around with your left foot on the clutch.
JonBabyUK
5-9-2005
Portland F_cking OR
 Re: help me heel/toe (spdfrek) »« »
Quote, originally posted by spdfrek »
That's why you keep your foot on the brake.
passatvr6er
7-6-2002
St Louis MO
1995 Passat GLX, 1957 Oval Window Bug, Kia Sorrento
 Re: help me heel/toe (GT17V) »« »
Quote, originally posted by GT17V »
I have a mk3 well b4, but same basic pedal design, and its just toe to side foot, i wear a 14 also. The entire heal toe downshift should be done fairly quickly, the gas should only be a blip, but a blip large enough to have matched the revs for the gear you want to go in, and the clutch should move the swiftest of all. brake - blip gas, almost instantly hit clutch then downshift - continue braking - accelerate through the turn. it really is pretty quick, but it can be done rather smooth with practice.
e1_griego
11-28-2003
Salem OR
89 240sx, 92 SE-R
Someone might want to rehost this since photobucket might cut me off after a while.
I find heel-toe in VW to be difficult in general. I think my 240 has perfect pedal placement, though many times I end up sort of rolling my foot then using my heel since the pedals aren't long enough. But, it works well anyway.
Alex
Modified by e1_griego at 11:36 AM 8-11-2005
whatsacorrado2
8-26-2001
gr mi
The only positive with having the car in gear at a stop light is if you look in the rearview and see a car not stopping you can move faster to get out of its way.... you wont wear your clutch... you wear the throwout bearing.
2001 BMW Z3 coupe 3.0 -SOLD
2000 Mazda Miata SE-sold
2002 Audi A4 1.8tQ
2004 BMW Z4 3.0i
veedub11
3-9-2002
Shaw District NW DC
 Re: (e1_griego) »« »
Quote, originally posted by e1_griego »
Alex
Yea, can't do that in any car with 13s.
-Adán
Washington Redskins
e1_griego
11-28-2003
Salem OR
89 240sx, 92 SE-R
 Re: (veedub11) »« »
Quote, originally posted by veedub11 »
Nope, you can't
Alex
AKADriver
11-20-2001
Unreal VA
Some cars.
 Re: (veedub11) »« »
That's why you do the ankle-roll technique. Trust me, if you have moderately big feet (i.e. not giant Shaq feet) then you're actually at an advantage, because the ankle roll is a bit easier for most people to learn.
It's medium-sized feet that often have the most trouble. We're limited in maneuvering space but not wide enough to just roll to the side.
Modified by AKADriver at 2:28 PM 8-11-2005
My decantering is delicate and courageous.
Goldice
5-3-2004
Greater Seattle Metro
1999 Miata
Heel toeing in my rocco was kind of akward at first because of the footwell, it's hard to get the heel in. I just got used to big toe side foot shifting, works just fine for me.
Learning just takes a lot of practice to do properly, it can be frustrating when you mess it up, but once it learn its wonderful.
Seven to Six
Obin Robinson
10-20-2000
on a military base
IM sent
obin
Scott
3-6-2004
Frederick Maryland
RS2'd 95 Audi S-6 and 06 VW Jetta TDI
I happen to have that EXACT set of pedals for sale for $35 shipped... anyone interested?
Dubs Along the Rockies - 22 AUG 2010 at Pikes Peak International Raceway, be there or be lame! http://www.dubsalongtherockies.com
jaredpgh
1-18-2005
Pittsburgh PA
08.5 MS3 GT MGM
 Re: help me heel/toe (Colorado 16v) »« »
"BEHOLD the INFAMOUS stick shifting (heel-toe) writeup LONG"
http://forums.audiworld.com/s4b6/msgs/40040.phtml
tpr950h
10-14-2004
Santa Ana CA
1997 GT GTB, 2004 Volkswagen R32 BMP
Alex
thats pretty cool except no double clutch to neutral. that'll wear your syncros
JonBabyUK
5-9-2005
Portland F_cking OR
 Re: (tpr950h) »« »
Nevermind...I stand corrected.
Modified by JonBabyUK at 12:58 PM 8-11-2005
GT17V
8-6-2001
Wharton NJ
2002 Golf GLS TDI
the purpose of double clutch not to grind the tranny. Before synchros, people had to double clutch
Obin Robinson
10-20-2000
on a military base
Quote, originally posted by Colorado 16v »
that's a really good price for them too. i wish i had a car i could use them in still or i'd take you up on that offer.
obin
DaBrosch
9-14-2000
Oregon
2000 A8L, 84 E150, 06 599, 86 4kq
 Re: (JonBabyUK) »« »
If his car is stock it surely has synchros. Double clutching would help extend the life of the synchros by spinning up the layshaft during deceleration, otherwise if the clutch was in the whole time the layshaft would slowdown and the synchros would have to do more work. Double clutching would do nothing during acceleration, unless he took forever before shifting into gear.
-Dan
Gone: 79 Eldorado, 91 Jetta, 87 Supra Turbo, 88 Thunderbird LX, 83 944, 01 A4 2.8q, 90 Probe GT, 89 Saab 9000 Turbo, 82 GPz-550
veedub11
3-9-2002
Shaw District NW DC
Peace, J
Man, now you got me all paranoid that my clutch is slipping!
-Adán
Washington Redskins
GTIfreak
3-25-2001
NS
 Re: (jeremy80l) »« »
Quote, originally posted by jeremy80l »
be in 5th
clutch in
rev match for 4th
Because without braking you'll end up in a ditch or a marshall stand.
Searching for ///M
Please read and contribute to The Unofficial Vortex English Language Reference Guide
a529612
5-10-2006
 Re: (GTIfreak) »« »
MT tutorial videos collection:
http://www.standardshift.com/videos.html
Heel toe demo in M5:
http://video.google.com/videop...56591
Modified by a529612 at 4:26 PM 6-1-2006
» Return to The Car Lounge
