El Romano Loco
9-8-2000
not
Mother Earth
Finally did it - .71 5th Gear swap... | « » 2:40 AM 10-18-2005 | |
So last Sunday, I finally swapped out the 5th gear I purchased about a month ago that was being used as a paper weight at work:) I'll try to make a step by step (i am not good at this crap): 1. Took the wheel off  2. Removed the fender liner. 3. Drained the tranny. 4. Removed the six 11mm( ) bolts that hold the end cap. 5. Removed the bolt holding the shift fork bracket. 6. Removed the two bolts holding the shift fork and took it off. 7. Wiped of as much oil as i could of the gears. 8. Took off the big Torx bolt and washer holding the "big" gear on the left. 9. I took off the ring and the three clips that hold/push the syncro, slid that out of the way (but i don't think it's necessary). 10. Wiped as much oil as i could off the gear. 11. I used a propane/butane torch to heat up the gear(not the shaft!) for about a good minute. 12. I modified/grinded the hell out of the "fingers" of a gear puller, to fit it behind the gear(big one). 13. It came off real easy with an impact(weakest setting). 14. Took torx bolt off the smaller gear on the right. 15. Heated it up for a minute too. 16. As i went to install the puller, the gear fell off! That's pretty much it. When i put the new gears on, I also heated them up for a minute and they went on real easy Don't forget to fill up the tranny. I used the OEM stuff, 1.9 liters. Driving impressions: For those of us with the 3.94 final drive, it should have been like this stock. Just to give you an idea: My revs use to be 4500 at 100mph. Now, at 4500rpm I am right at 135mph I couldn't believe I was cruising along at about 120mph(normal for the autobahn) and the motor wasn't screaming for help. Not to mention the powerband is much wider in 5th. It's real nice to shift from 4th to 5th now. Actually pulls harder at higher speeds, because i am in the meat of the torque. I am not for sure about MPG savings, but i am very curious(especially with gas prices) This is totally worth it in the sense of noise and engine friction while at higher speeds. It sounds like a completely different car in 5th. I will post MPG changes in the next week or so. BTW I purchased the gears locally for about $230. and I can get any combo you need, just let me know. Adrian
Sid-Rage
6-15-2004
WPB FL
90 G60 Corrado
» | « » 2:49 AM 10-18-2005 | |
that sounds great.. thanks for the input
90' G60 C.
O2VW1.8T
boosted NC
All wheel drive 1.8T GTi
Re: (Sid-Rage) » | « » 2:54 AM 10-18-2005 | |
how does the car feel at 170. I know mine at 160 feels real light. Maybe its the stock suspension and H rated tire's. Who knows, its pretty scary
GT35R with AWD - (1/4 mile 11.76@126mph pump gas)best 1/8th 7.36@102mph http://www.pagparts.com http://www.Eurodyne.ca http://www.forcefedengineering.com http://www.INAengineering.com http://semmotorsports.com B6 A4 1.8T fronttrak Converted to AWD but RWD for now 1988 audi 90q - slow project
El Romano Loco
9-8-2000
not
Mother Earth
Re: (O2VW1.8T) » | « » 3:01 AM 10-18-2005 | |
Honestly, it feels the same after about 150mph. Everything goes by real fast I have race springs with Stiffest Bilsteins available, so its very controllable. However, at those speeds, one little movement and you are three lanes over... FYI, I don't normally drive a 170mph. This was just a test to see the difference. I use the same flat strip of autobahn I always do for my tests My hands were sweating big time, but I wasn't nervous or anything, just natural reaction i guess...
QuickK03Crap
10-4-2004
102 degrees AL USA
03 1.8t GT3076R
Re: Finally did it - .71 5th Gear swap... (El Romano Loco) » | « » 3:06 AM 10-18-2005 | |
Good info.
Today's bandwagon IS tomorrow's disappointment.FS: Reflex Hagus mirrors http://www.unitronic.ca http://www.pagparts.com
spoolin turbo s
Gate City Virginia
2002 new beetle turbo s
Re: Finally did it - .71 5th Gear swap... (QuickK03Crap) » | « » 3:09 AM 10-18-2005 | |
so at 60-70 mph where are you at rpm wise
"Son if you got lag you ain't driving right" -Carroll Shelby
El Romano Loco
9-8-2000
not
Mother Earth
Re: Finally did it - .71 5th Gear swap... (spoolin turbo s) » | « » 3:14 AM 10-18-2005 | |
The rpms are at 2100@ 60mph, at 70mph not sure, but I can check and post later. Keep in micd that I have the old 3.94 final drive, yours is a 3.6XX I believe...Ad
spoolin turbo s
Gate City Virginia
Re: Finally did it - .71 5th Gear swap... (El Romano Loco) » | « » 3:20 AM 10-18-2005 | |
no mine is more like 4:10 i have a six speed in the ole turbo s beetle i was just curious i love my gear ratios the way they are right now............i wish first and secons were a little longer but other than that i think its perfect.......... just not for drag racing
El Romano Loco
9-8-2000
not
Mother Earth
Re: Finally did it - .71 5th Gear swap... (spoolin turbo s) » | « » 3:27 AM 10-18-2005 | |
Gotcha... Didn't notice the "S" sorry. Yeah, i actually considered the 02M 6speed, but with my budget, the 5th swap was ~$1500 less;)Adrian
flanders
4-5-2001
Ottawa, Ontario, Canada
Re: Finally did it - .71 5th Gear swap... (El Romano Loco) » | « » 8:54 AM 10-18-2005 | |
| Quote, originally posted by El Romano Loco » | | The rpms are at 2100@ 60mph, at 70mph not sure, but I can check and post later. Keep in micd that I have the old 3.94 final drive, yours is a 3.6XX I believe... Ad |
ahhh...that's perfect! I still gotta get around to doing this
▊♣▊ 1.8T OVD - Ottawa Vdubbing club!
El Romano Loco
9-8-2000
not
Mother Earth
Re: Finally did it - .71 5th Gear swap... (flanders) » | « » 10:10 AM 10-18-2005 | |
Just got back from a beautiful drive on the autobahn. 70mph is right at 2500rpms. Lovin' it!! I can get this setup for $250 shipped. Nobody else offers it in the states... Adrian
Ricky_Rockstah
8-3-2003
Fayetteville AR
Black '03 WE Jetta
» | « » 10:19 AM 10-18-2005 | |
good to see someone doing this. I' m *VERY tempted*
'03 Uni-Black Jetta WE APR Stage III+, Eurojet Race, Peloquin, SBC, .717 5th, Oettinger, Emphase, Votex front and Rear, BBS CH, Koni, H&R, Eibach, etc. the local thread: http://forums.vwvortex.com/zerothread?id=293473 The myspace thing: http://www.myspace.com/Ricky_Rockstah
El Romano Loco
9-8-2000
not
Mother Earth
Re: (Ricky_Rockstah) » | « » 10:26 AM 10-18-2005 | |
IMHO, It's totally worth it Ad
16vracer
7-12-1999
Re: Finally did it - .71 5th Gear swap... (El Romano Loco) » | « » 2:28 PM 10-18-2005 | |
| Quote, originally posted by El Romano Loco » | | Just got back from a beautiful drive on the autobahn. 70mph is right at 2500rpms. Lovin' it!! I can get this setup for $250 shipped. Nobody else offers it in the states... Adrian |
Sweet. Sounds like a great winter time swap
'08 A4 3.2Q '05 XC70 DCI-S.Sound
enginerd
12-14-2001
MANCHESTER CT
2002 GTI 1.8T, 83 Turbo Rabbit, 95 SC Miata, 01 A4Q
Re: Finally did it - .71 5th Gear swap... (16vracer) » | « » 2:56 PM 10-18-2005 | |
This is more of an afternoon swap. Piece of cake.
Coil Pack Retaining Brackets Here 1.8T TROUBLESHOOTING GUIDE TRACK DAY VIDS - WGI, LRP, NJMP http://www.youtube.com/user/baltruckij
16vracer
7-12-1999
Re: Finally did it - .71 5th Gear swap... (enginerd) » | « » 3:25 PM 10-18-2005 | |
| Quote, originally posted by enginerd » | | This is more of an afternoon swap. Piece of cake. |
True, but it'll be winter before I have the extra cash to do it
El Romano Loco
9-8-2000
not
Mother Earth
Re: Finally did it - .71 5th Gear swap... (enginerd) » | « » 6:13 PM 10-18-2005 | |
lol, no poop. I was counting on 3 hours min... I was done in less than two, cleaned up and everything  If you guys want to start a group buy we can do that too  Adrian
E7TDI
11-27-2004
Ridgefield CT
1999 1/2 Jetta TDI
Re: Finally did it - .71 5th Gear swap... (El Romano Loco) » | « » 10:44 PM 10-18-2005 | |
You have part numbers? John
Boostin20v
3-22-2000
Central NY
1991 Audi V8
Re: Finally did it - .71 5th Gear swap... (E7TDI) » | « » 10:53 PM 10-18-2005 | |
i did this in '01, got the parts from http://www.thescirocco.com/ - cost was ~200ish
FS: Mk2 Votex Console1.8t Swap FAQ
d0wnShifT
6-28-2004
Oklahoma City OK
04 GTI
Re: Finally did it - .71 5th Gear swap... (Boostin20v) » | « » 11:16 PM 10-18-2005 | |
oh and how i wish i was back in the motherland again. The autobahn is something everyone should experience at least once in their life.. I need to come visit
Modified by d0wnShifT at 11:20 PM 10-18-2005
2004 MK IV GTI Reflex Silver -- GHL 2.5" TB--Revo Stg 2--Forge 007--Velocity CAI--Smoked Pizzys--25AE Ecodes--AWE Boostgauge--Koni Coilovers
RoyalOakMichiganJim
4-5-2003
Royal Oak Michigan
2002 VW GTI 337 Edition
Re: Finally did it - .71 5th Gear swap... (El Romano Loco) » | « » 11:53 PM 10-18-2005 | |
........I wish it was that easy for the six speed trans that I have.... That O2M with 2 final drive ratios is a different breed of cat........
337... APR v2 93/100, VTune, APR FMIC, GHL 3" TB Street, Quaife LSD, Spec 7 lb FW/STG3 clutch, SSR Comps/Avon slicks, K&N, Airbox a la Jorge W/ CAI, ECS Pullies,Autotech rear sway, Disabled ASR/EDL, Dieselgeek race, Audi TT IC vent, Prothane bushings/dogbone, descreened MAF, Powergasket 234whp 287wtq http://volkswagengtijim@comcast.net
El Romano Loco
9-8-2000
not
Mother Earth
Re: Finally did it - .71 5th Gear swap... (E7TDI) » | « » 4:59 AM 10-19-2005 | |
John, the part number are:02a 311 361m & 02a 311 158r these are for the .718XXX ratio. Also available for any 02A or 02J tranny are the .75XXX and .68XXX gear sets. For about the same price. Actually the .68 is about $10 cheaper... other guy, Yes the 02M is a diff story all together. other guy#2, I checked that link and didn't find anything. Adrian
Boostin20v
3-22-2000
Central NY
1991 Audi V8
» | « » 8:46 AM 10-19-2005 | |
as other guy #2....the site doesnt list half the stuff you can get from them....but if you contact them you can get the gear sets needed for the conversion.
El Romano Loco
9-8-2000
not
Mother Earth
Re: (Boostin20v) » | « » 9:31 AM 10-19-2005 | |
lol, other guy #2, couldn't remeber your SN and didn't wan't to go back... So, you did this same swap? .71XX gear set? What was total price shipped? Thanks! Ad
an204421
9-8-2004
Arlington Tx
2000 1.8T Jetta
Re: Finally did it - .71 5th Gear swap... (El Romano Loco) » | « » 10:26 AM 10-19-2005 | |
Is there anything like this for an automatic (the 4 speed), maybe adding a fifth gear
JDriver1.8t
5-19-2005
Charlotte/ Raleigh/ Greensboro NC
2003 VW GTI 1.8t
Re: Finally did it - .71 5th Gear swap... (an204421) » | « » 10:47 AM 10-19-2005 | |
Unfortunately, there isn't anything that can be done for an auto.
I spend too much.Photobucket: JDriver18t
Boostin20v
3-22-2000
Central NY
1991 Audi V8
Re: Finally did it - .71 5th Gear swap... (JDriver1.8t) » | « » 12:14 PM 10-19-2005 | |
I paid ~200 bucks shipped for the parts back in '01
QuickK03Crap
10-4-2004
102 degrees AL USA
03 1.8t GT3076R
Re: Finally did it - .71 5th Gear swap... (El Romano Loco) » | « » 1:07 PM 10-19-2005 | |
Any chance you could see what the rpm drop is between 4th at redline into the new 5th? Where it puts you after the shift basically.
Schoolbus
2-24-2000
Raleigh NC
2002 Audi S4 Avant, 2001.5 Golf 1.8T 4dr
Re: Finally did it - .71 5th Gear swap... (El Romano Loco) » | « » 1:31 PM 10-19-2005 | |
Great info - thanks. I have these gears on order right now. They are currently available in the US. 1stvwparts has them for $285. Prices have definitely gone up over the recent years. Below is what I had previously recorded for pricing.As for speed/gearing, I believe my estimates (with 3.94 final) were suggesting: 85mph - was:3800, will be:3200 80mph - was:3600, will be:3000 Here's the previous pricing info I had found: For the .717 gearing you'll need: http://forums.vwvortex.com/zerothread?id=713538 (2/18/03) 02a311361M is $80.50 and 02a311158R is $122.10 I just (8/18/05) checked these sites and found: 1stvwparts.com: 02a311361M: $110 02a311158R: $174 worldimpex.com: 02a311361M: $142 02a311158R: $226
'08 Audi A3 2.0T DSG, Ibis White - S-Line (soon) '04 Porsche 911 Turbo, Speed Yellow, X50 [26k miles] '01.5 VW Golf 1.8T 4dr, Silver - website - GT28R APR Stg 3 [203k miles] '09 VW Tiguan 2.0T, Candy White [hers] Sold: '02 Audi S4 Avant, Imola Yellow - website - APR Stg 3 & '00 Audi A4 1.8T, Silver
slickfisher
10-15-2004
Asheville NC
03 Jetta 1.8T GLS, APR
Re: Finally did it - .71 5th Gear swap... (El Romano Loco) » | « » 3:00 PM 10-19-2005 | |
Congrats. Your my hero. Only when I have the money, time and energy. Big envy.
Boostin20v
3-22-2000
Central NY
1991 Audi V8
Re: Finally did it - .71 5th Gear swap... (slickfisher) » | « » 3:23 PM 10-19-2005 | |
on my AWD revs dropped roughly 500-700rpms after the install. Sorry but I cant be more specific, the car was down in '01 for 8 months and this year its been down since May.
El Romano Loco
9-8-2000
not
Mother Earth
Re: Finally did it - .71 5th Gear swap... (QuickK03Crap) » | « » 3:54 PM 10-19-2005 | |
| Quote, originally posted by QuickK03Crap » | | Any chance you could see what the rpm drop is between 4th at redline into the new 5th? Where it puts you after the shift basically. |
I will check tomorrow morning... on my way to work I usually see 130mph, and if I am running a bit late, well... you know  Schoolbus, Yeah those are old links and they don't work. I have no idea why the prices would go up ( maybe cause gas prices ). I talked to the manager of our local VW dealer and he said he would give me discount for sure if I were to buy 5 or more sets. Adrian
Modified by El Romano Loco at 9:56 PM 10-19-2005
zooyork155
11-9-2003
Durham NC
2001 Wolfsburg
» | « » 6:08 PM 10-19-2005 | |
Very interested in the MPG difference. I commute in 5th and the RPM drop should save $$$
NCDubs
Ricky_Rockstah
8-3-2003
Fayetteville AR
Black '03 WE Jetta
Re: Finally did it - .71 5th Gear swap... (QuickK03Crap) » | « » 9:52 PM 10-19-2005 | |
That's totally what I want to know as well.
KGilman
2-3-2004
North Grafton MA
2003 VW Jetta 1.8t, Honda TRX 450R
Re: Finally did it - .71 5th Gear swap... (El Romano Loco) » | « » 10:24 PM 10-19-2005 | |
K-Town ....swing by Hohenfels and say hi for me, I miss Germany.
Back to stock, no more BT for me.
| Quote, originally posted by judoGTI » | Umm I dont care what age you are impressing 17 years old girls should be a lifetime quest for any guy... And if all it takes is an exhaust.... Consider that a checkmark in the plus column..... |
