Boostin20v
3-22-2000
Central NY
1991 Audi V8
The Official Mk1 20V post | « » 10:50 AM 12-2-2005 | |
THIS INFO IS NO LONGER CURRENT Go to the 1.8t Swap FAQ linked in my signature for complete and up to date info!!!Official Mk1 20v Post This is meant to be a one stop shop for Mk1 20v swap info. If you have anything to add please contact me and I'll get it added to the first post. Project Pages: Rabbit --Patrick Schmidt's Swap --speeding-g60's Swap --Trevahhhh's Swap --VariantStg3/Tuners Warehouse Vehicle Info Page --1.8TRabbit's Swap Scirocco --Funksoulkitty Swap --PoloV8's Swap --Talx's Swap (thread 1)/Talx's Swap (thread 2) Cabriolet --Rolleboy's Swap Picture Posts: Engine Bay Shots Info: 1.8t swap into a1 help 1.8t swap which tranny to use 1.8t swap questions 20v 1.8T engine swap experience? Golf MK1 1.8 T questions Everybody with or installing a 20v post in here AMB 1.8T Mounts: Engine Mounts for Codes ATW/AEB/external waterpump blocks: -OE Mk1 engine mounts will bolt to these blocks, you do not need custom mounts. Engine Mount for Codes AWD/AWW/AWP/all internal waterpump blocks: -You'll need custom mounts for the engine Trans Mount for O20: -020 trans bolts right in with OE mounts Trans Mounts for O2A,O2J: -You will need custom mounts for these transmissions Who Makes Custom Engine/Trans Mounts?? -WRDUSA.com sells a O2J mount kit -Vortex user need_a_vr6 can sells O2A and O2J mounts -Vortex user Pataron can sells O2A mounts -Dan Bubb <jdbubb@verizon.net> sells O2J mounts -I(boostin20v) have one set of custom mk1 frame rails modded for mk4 mounts, PM for details Wiring Diagrams: AEB Diagram Which 20v engine should you use? Engine code AEB from the 97-99 Audi A4 and VW Passat. Benifits: -use of Mk1 motor mounts, no need for custom mounts -larger intake and exahust ports: -big intake ports: 54mm x 26mm (small ports: 43mm x 26mm) -big exhaust ports: 36mm (small ports: 33mm) -20mm wrist-pins (later engines have 19mm) Cons: -AEB engines are hard to find, and the euro versions (AGU/ADR) are difficult to find/import Forged Internals? AEB are all cast AUG auto is cast, AUG manual is forged AWD/AWW/AWP/AWM are all forged Users who've asked their names be listed for swap help/info: VariantStg3, andrew.lloyd@tunerswarehouse.com
Modified by Boostin20v at 3:55 PM 5-28-2008
FS: Mk2 Votex Console1.8t Swap FAQ
general problem
11-19-2004
time traveling NY
MK1&3x2
» | « » 10:56 AM 12-2-2005 | |
 slow day at work Stu??
Pete shut up and build
Boostin20v
3-22-2000
Central NY
1991 Audi V8
» | « » 11:09 AM 12-2-2005 | |
vortex should be my work
vdubspeed
7-18-2002
Valdosta GA
Re: (Boostin20v) » | « » 12:11 PM 12-2-2005 | |
this is better than the official 16V thread by 4 valves!
58 Beetle|70 Beetle|79 Rabbit C 20vT|84 Rabbit GTI 16vT|84 Rabbit GTI 16V|00 Passat 1.8t|02 Suburban 2500 4X4 Vdubspeed Tuning - German passion buried in the South. I'll buy your broke t-belt, sludged up, locked up VW now...CASH. Just IM me
polov8
4-14-2004
Englandcestershire
'81-Scirocco Storm (Elly) '78-Scirocco (Leela) '81-Scirocco GLS (Mona)
Re: (vdubspeed) » | « » 12:34 PM 12-2-2005 | |
Thanks for putting a link to my thread in I really will try to get the thing fired up before Christmas
Andy 20v Scirocco Storm thread (GT28RS) 20v Scirocco GLS thread (Stock K03) Leela's thread
| Quote, originally posted by My Old Roc » | | I 'm a dope. |
Boostin20v
3-22-2000
Central NY
1991 Audi V8
Re: (polov8) » | « » 11:34 PM 12-19-2005 | |
added Talx's swap
.:Carlik:.
12-19-2005
Stone Mountain GA
99 Ford Expedition 87 Golf 79 Rabbit 09 Nissan Quest 02 Vw jetta wagon
Re: (Boostin20v) » | « » 10:51 PM 1-4-2006 | |
this is great
SOUTHSIDESOWO 10'
Boostin20v
3-22-2000
Central NY
1991 Audi V8
Re: (revival) » | « » 11:56 PM 1-4-2006 | |
anyone who uses this info for a project, start a thread dedicated to it and I'll add it to the list
Todesengel.
6-16-2004
weaksauce ca
+ 1847 posts
Re: (Boostin20v) » | « » 4:56 PM 2-4-2006 | |
seriously, this needs to be sticky!!
| Quote, originally posted by (2:00 AM 9-8-2005) Paul@VWvortex: » | Post Deletion Notification Your post in thread Remember that one pool party this summer?! has been deleted. Comment: The polish mafia threatened my family so I had to delete this post. Thanks for helping me to protect the virginity of my cat. |
diabolical1
3-26-2005
spiritual disharmony
looking for a Santorin S4/S4 Avant
» | « » 8:44 PM 2-4-2006 | |
i agree ... should be a sticky!
Amsoil product pimp S4-bound or will die trying ...
mk3VRsick
1-28-2004
Somers CT
too many projects!
Re: (Todesengel.) » | « » 7:13 PM 3-14-2006 | |
| Quote, originally posted by Todesengel. » | | seriously, this needs to be sticky!! |
Rabbits don't die....they multiply
.:Carlik:.
12-19-2005
Stone Mountain GA
Re: (mk3VRsick) » | « » 5:46 PM 3-15-2006 | |
anybody want to give help on wiring to ce2 ? using AEB harness that is !
SOUTHSIDESOWO 10'
G60 CAB
10-25-2003
Beavercreek Ohio
'90 Cabby, '99 M3, '91 325i, '97 Ghetta II, '03 Jetta 1.8t, '87 420SEL, '97 Cherokee
Re: (revival) » | « » 5:53 PM 3-15-2006 | |
So the hot setup is an AEB block with AWP internals?
'87 420 SEL...on 20" D's '97 Ghetta II...Daily two-toner '99 M3...Twinscrewed and wallet hungry
Boostin20v
3-22-2000
Central NY
1991 Audi V8
Re: (redvdubvert) » | « » 9:19 PM 3-15-2006 | |
nah, keep the whole AEB. The later blocks have smaller wrist pins (19 vs 20mm)
G60 CAB
10-25-2003
Beavercreek Ohio
Re: (Boostin20v) » | « » 10:12 AM 3-16-2006 | |
But can the cast internals keep up with big turbo setups?
Boostin20v
3-22-2000
Central NY
1991 Audi V8
Re: (redvdubvert) » | « » 11:15 AM 3-16-2006 | |
the AEB uses an external water pump, an intermediate shaft....its very much like an older 8v or 16v. the newer engines are internal water pumps without the intermediate shaft.
Boostin20v
3-22-2000
Central NY
1991 Audi V8
Re: The Official Mk1 20V post (Boostin20v) » | « » 4:26 PM 4-11-2006 | |
bump as....well I dont know seems people cant find this
Boostin20v
3-22-2000
Central NY
1991 Audi V8
Re: The Official Mk1 20V post (Boostin20v) » | « » 3:35 PM 4-12-2006 | |
added AEB wiring diagram -- thanks [inser username of person I forgot]
.:Carlik:.
12-19-2005
Stone Mountain GA
Re: The Official Mk1 20V post (Boostin20v) » | « » 3:42 PM 4-12-2006 | |
LOL it was I
SOUTHSIDESOWO 10'
Boostin20v
3-22-2000
Central NY
1991 Audi V8
Re: The Official Mk1 20V post (revival) » | « » 5:48 PM 4-12-2006 | |
| Quote, originally posted by revival » | | LOL it was I |
haha sorry bout that, thanks
vdubspeed
7-18-2002
Valdosta GA
Re: The Official Mk1 20V post (Boostin20v) » | « » 10:36 PM 4-14-2006 | |
I was checking out funksoulkitty's webpage and now I have a question.If I use an AEB motor from a passat and have to switch to a golf/jetta intake manifold. What year should I use. Thanks. AWP vs. AEB
donmeister
11-29-2004
Sellwood Oregon
Type One "Deacon Blues"
Re: The Official Mk1 20V post (vdubspeed) » | « » 1:25 AM 4-15-2006 | |
sweet thread, good job
Boostin20v
3-22-2000
Central NY
1991 Audi V8
Re: The Official Mk1 20V post (vdubspeed) » | « » 9:17 AM 4-15-2006 | |
| Quote, originally posted by vdubspeed » | | If I use an AEB motor from a passat and have to switch to a golf/jetta intake manifold. What year should I use. |
I made 319whp on a dynodynamic with my OE AWD small port intake manifold on my ADR (euro equiv AEB) head. Car was running a Tec3 with a ok, not great tune. bascially my point is that you can run a small port intake manifold without too much problems (FWIW 319whp on the dynodynamic is somewhere between 360-370whp on a dynojet). Ideally you've got two options. Option one you'd buy a AGU intake manifold, the AGU is the only transversely mounted large port engine code. Problem is it was a non US only setup. From time to time they are avaliable on ebay.de and even the vortex classifieds. Option two you buy an aftermarket intake manifold (~$525-~$1000) whcih you can order with TB on either drivers or passenger side and either small or large port.
donmeister
11-29-2004
Sellwood Oregon
Re: The Official Mk1 20V post (Boostin20v) » | « » 12:38 PM 4-15-2006 | |
| Quote, originally posted by Boostin20v » | (FWIW 319whp on the dynodynamic is somewhere between 360-370whp on a dynojet). |
360whp! hopefully someday my golf will reach that
RiegerGTB1.8t
2-3-2005
nc/fl
1985 wide body gti
Re: The Official Mk1 20V post (Boostin20v) » | « » 3:43 PM 4-15-2006 | |
wow
http://riegergtb18t.bloggoing.com/ Shame on you TMT McCoy ABOSI # 12 The real rare part's whore! Folk's hate to see you ballin...theyed rather see you falling
Boostin20v
3-22-2000
Central NY
1991 Audi V8
Re: (general problem) » | « » 10:27 AM 4-16-2006 | |
Clarified/Expanded Mk1 -> 20v engine and transmission mount info
polov8
4-14-2004
Englandcestershire
Re: (Boostin20v) » | « » 10:47 AM 4-16-2006 | |
Your AEB wiring diagram link is down I really need this info for another 20v swap I'm doing
Boostin20v
3-22-2000
Central NY
1991 Audi V8
Re: (polov8) » | « » 11:36 AM 4-16-2006 | |
| Quote, originally posted by polov8 » | Your AEB wiring diagram link is down I really need this info for another 20v swap I'm doing |
doh, looks like I fuged the permissions on the file. I'll get it working tomorrow.
vdubspeed
7-18-2002
Valdosta GA
Re: (Boostin20v) » | « » 12:14 PM 4-16-2006 | |
New question: If I have use an AEB ECU...will I still be able to check the codes using a OBDII port and VAG-COM?If you can't pull the codes...how will you know what's up with the motor?
Boostin20v
3-22-2000
Central NY
1991 Audi V8
Re: (vdubspeed) » | « » 12:46 PM 4-16-2006 | |
if your going to use the AEB ecu then make sure you wiring in the OBDII port. without hte port you wont get the codes.
vdubspeed
7-18-2002
Valdosta GA
Re: (Boostin20v) » | « » 1:26 PM 4-16-2006 | |
| Quote, originally posted by Boostin20v » | | if your going to use the AEB ecu then make sure you wiring in the OBDII port. without hte port you wont get the codes. |
perfect. I'm assuming it's only a couple pins anyway to get the codes. I'd love to see that AEB wiring diagram if you get the .pdf back up.
Boostin20v
3-22-2000
Central NY
1991 Audi V8
Re: (vdubspeed) » | « » 3:11 PM 4-16-2006 | |
I swear it'll be up tomorrow!
splitmeister
8-9-2001
im real good at installing tire shine
Re: (vdubspeed) » | « » 5:24 PM 4-16-2006 | |
| Quote, originally posted by vdubspeed » | New question: If I have use an AEB ECU...will I still be able to check the codes using a OBDII port and VAG-COM?If you can't pull the codes...how will you know what's up with the motor? |
Its only 3 wires to wire up the scan port. power ground, and the harness k-wire (grey/white) the bewildered looks you get from people as you plug in your laptop to and ancient ass rabbit. always a good time.
vdubspeed
7-18-2002
Valdosta GA
Re: (splitmeister) » | « » 6:33 PM 4-16-2006 | |
| Quote, originally posted by splitmeister » | Its only 3 wires to wire up the scan port. power ground, and the harness k-wire (grey/white) the bewildered looks you get from people as you plug in your laptop to and ancient ass rabbit. always a good time. |
thanks...I was sure it was going to be about 3 wires.
oopseyesharted
3-2-2005
Hell SW FL FL
1989 Saab 900T and 85 Jetta Coupe Project(partout)
Re: (vdubspeed) » | « » 7:24 PM 4-16-2006 | |
any idea where i can get info on getting a 20v head on my aba block??? I want to run NA.
Xbox Live ID: Whozbinpharteen
