VR12V
1-9-2006
CA
1995 JETTA GLX
 SIDE MODLING adhesive!!!!!Help« »
I just cleaned and prepared my side moldings and doors, and now i need a good adhesive for my side moldings. Anyone know any good ones that wont come off in a week or two?
QuietStorm
5-24-2005
Baldwin Place NY
95 Jetta VR6
 Re: SIDE MODLING adhesive!!!!!Help (VR12V) »« »
gorilla glue
Oettinger Wheels for sale!
http://forums.vwvortex.com/zerothread?id=4473812
AC Compressor for sale
http://forums.vwvortex.com/zer...d=810
EazEonMahJetta
9-1-2002
95 Jetta GLX, 88 GLI 2.0L 16v, 91 GTI 2.0, 86 Porsche 944,
 Re: SIDE MODLING adhesive!!!!!Help (QuietStorm) »« »
there's really strong double sided tape from home depot, it works wonders, we use it at the shop all the time
"VW is really a tool company that just happens to sell cars"
http://www.tcbautobrokers.com
Where takin care of business is only the beginning
http://video.google.com/videop...+fast -My FAST has a problem with authority
Rat4Life
10-13-2004
clifton nj
87 golf gt sold, 85 bmw 318i totaled, 93 golf 1.8t sold, 2001 golf gl Flat blue, 2002 gti 1.8t wifes
i used windshield urethane to glue them on my friends car about 3 years ago , still holding up with no problem, just make sure to clean the surface before. you will need to get a caulking gun for that .
Air ride installs & frame notching in NJ
http://www.VWRIDER.com
Low.Life.Society. http://www.youtube.com/watch?v..._page
http://img187.imageshack.us/im...1.jpg
Nolig23
4-21-2005
Edison NJ
98 GTI
 Re: (russiandub) »« »
Just go to an autozone or pepboys and get 3M Double sided Molding tape. It's red and dark grey colored. Make sure you cut it into little strips.
Quote, originally posted by _pineapplegti_ »
put a 45 in your mouth.. pull the trigger.. The mess will look better than the car you want to build.
Coolwater VW Club
mikcuz
9-25-2005
Green Bay WI
1995 Gti vr6/2003 Golf 1.8t/2000 Dodge Dakota Quad Cab!
 Re: (Nolig23) »« »
Quote, originally posted by Nolig23 »
thats the best way. just make sure both contact points r cleaned with acetone or something. the problem with adhesive is when they fall off, and they will fall off, that adhesive is a batch to clean off for a new contact! adhesive suckss!! thats why they call it molding tape!
MADSPEED
BENS VEE DUB SHOP.com
Madison , Wi
wannabeMKIII
8-1-2005
menands NY
99.5 VR jetta, 96 2.0 jetta
 Re: (mikcuz) »« »
i will be epoxying mine on this week...
96 Jetta 2.Slow
99.5 Jetta VR6
Soren
10-31-2000
Miami to L.A.
98 GTI VR6
 Re: (wannabeMKIII) »« »
woah, brave! Watch out, some epoxies can eat straight through your paint!
i just use the molding tape and use heat and a little adhesive remover to clean it up. I've only had to do it twice over 8 years so it's not that bad, but it is 2 times too many I suppose.
```__|__' ' '
*---o0o---*
DTMVDUB
6-4-2003
Long Branch NJ
98 Silver Arrow MKIII GLX & IY 20AE
I used the 3M double side tape for outdoor use. Excellent, with no problems.
Breezy.
10-14-2005
I hear of this stuff 3M VHB (very high bond) double-sided tape. Going to look for it soon. That 3M regular double-sided tape didn't work well for me. It came back off weeks later. I didn't cut them into little strips, but whatever.
Vayastyle
1-25-2005
33OH
rubbercity
 Re: SIDE MODLING adhesive!!!!!Help (Breezy.) »« »
im pretty sure everyone here who has responded is talking about the same tape...
its the 3M VHB double sided outdoor use mounting tape. its red/grey and its sold at office max or home depot or any equivilent. i think its between 3-6 dollars. not bad at all, really easy fix.
Kyle I didn't mean to
LbC - Grassroots.
PM me if you need the Ksport hookup
Soren
10-31-2000
Miami to L.A.
98 GTI VR6
 Re: SIDE MODLING adhesive!!!!!Help (keelay) »« »
yup, the red grey is the stuff to use!
```__|__' ' '
*---o0o---*
DTMVDUB
6-4-2003
Long Branch NJ
Quote, originally posted by Breezy. »
Pep Boys has it.
vwdr1ver
6-17-2002
YORK, PA
'84 Diesel Bunny - '01 BMW 330i
Quote, originally posted by wannabeMKIII »
dont do it...
OddJobb
11-6-2004
Orlando Fl
1995 Volkswagen Golf 2.0L/2004 Volkswagen GLI
 Re: SIDE MODLING adhesive!!!!!Help (DTMVDUB) »« »
3M also makes side trim adhesive. Black tube with white/yellow lettering. Worked good for me.
dublinerie
1-7-2006
Rome GA
 Re: SIDE MODLING adhesive!!!!!Help (OddJobb) »« »
I agree about using the epoxy or glue. Don't do it!!!!! The 3M VHB does an excellent job.....IF the surface is properly prepped before you use it. The reason why the original 3M stuff came off early on our 96-99 cars was because the factory did NOT properly prep the two surfaces. Both the painted door and the rubber trim should be free of debris and other adhesive remains wipe the rubber and door with alcohol let dry and then scuff with a medium grade sand paper. Then wipe again with iso alcohol. Appy. Success!
Modified by dublinerie at 5:55 PM 1-21-2006
Modified by dublinerie at 6:53 PM 1-21-2006
AaronD
5-4-2002
Wayne NJ
'04 DBP R32
 Re: SIDE MODLING adhesive!!!!!Help (dublinerie) »« »
3M super heavy duty
ixmxm
4-19-2005
Pomona/Mission Viejo CA
S/C Mark3 GLX
 Re: SIDE MODLING adhesive!!!!!Help (AaronD) »« »
shoe goo, if you have that laying around. otherwise, 3m doublesided molding tape.
Cybersombosis
9-20-2005
Victoria BC
Canada
I went in to the local auto shop (Lordco) and the tape was $40 a roll I decided to head up to see if my friend at a body shop would sell me a length so that I could do it myself. He ended up doing the work for free and he didn't charge me which was a surprise.
They used the 3M grey double sided tape protected by red plastic as everyone has mentioned here. Right after cutting the old double sided tape off the piece of moulding with a razor knife (note he did not remove all the tape completely which suprised me but just cut as much off as he could with the razor which was white btw), they prepped it with a solvent that was made specifically for this purpose. He said that without this, it wouldn't bond properly and fall off prematurely. It could have been just alcohol but it was a tin with a screw on cap that had a cotton ball type of applicator. He rubbed it on and let it dry then applied a full length of tape to the top and bottom part of the moulding.
He then went out to the car and just rolled the old stuck on adhesive with his thumb. It came off very easily. After finishing that he just re-applied the moulding starting at the front and working his way back. Well that's my experience. Hope it helps.
Doug
Modified by Cybersombosis at 3:19 PM 1-21-2006
96 Jetta GLS 2.0 Auto-Desert Wind-Current
K&N Dropin air filter,Magnaflow cat-back,Black Widow 2800 alarm,Premier DEH-P850MP,Boston Accoustic Pro Series,Pheonix Gold,Retrofit glove box,Falken Ziex 512 205/50/15,Hella Optilux 1180 Projection Foggies,Stubby antenna mod,HID Retrofit,City light mod,3rd&4th running light mod,Side marker blinker mod,Mk4 Switchblade alarm keyfob retrofit.
dr_spock
2-16-1999
Canada
 Re: SIDE MODLING adhesive!!!!!Help (Cybersombosis) »« »
I found that grey 3M tape at Home Depot. I stuck it on my car a few years ago and it is still holding. Really good stuff.
WNDSR VR6
5-29-2005
Myrtle Beach SC
1996 Jetta GLX VR6 Windsor Blue
you can find rolls of the 3m that are like 100 feet at body shop supply houses. its alot cheaper than buying like 10 of the smaller rolls. also, before you put the moldings on, i suggest heat then up a bit ON THE BACK SIDE and let them sit somewhere completely flat. ovr time they warp and stuff. the flatter they are the better and longer they will stay. i gotta take off my drivers side one of these days it has a little bend in it that doesnt stay stuck down.
Windsor Blue 1996 VR6 GLX (current)
Candy White 1997 VW Jetta 2.0, 5-Speed, (sold and missed)
"...they giveth, and they taketh, life is cruel that way. but even a broken clock is right, at least two times a day..." Jay-Z
The dubber formerly known as "njl_dubbin"
VWGolfDriv3r
7-26-2005
Boston MA
'96 Golf, e30 325is, Bianchi Via Nirone
 Re: (WNDSR VR6) »« »
Any suggestions on getting rid of some extra glue left by the PO...I think they did use Gorilla glue . A bit of it has always shown and it's really frustrating.
Quote, originally posted by Egz »
You must have some interesting answers for ink-blot tests... LOL
Quote, originally posted by Thomas Alva Edison (1931) »
I'd put my money on the sun and solar energy. What a source of power! I hope we don't have to wait until oil and coal run out before we tackle that.
Gibson5469
10-11-2005
1994, VW Jetta
 Re: (VWGolfDriv3r) »« »
goo gone, goof off, or similar products work really well.
pm for prices
LED swap LED swap
Danbury GTG
94 Jetta ~ Gone
03' Civic - 36mpg stylez
WNDSR VR6
5-29-2005
Myrtle Beach SC
 Re: (Gibson5469) »« »
Quote, originally posted by Gibson5469 »
i dunno about that gorilla glue is the dogs balls as far as adhesion. i would try a plastic putty scraper to get as much of it off as possible...but be careful obviously as it will scratch your paint. after that, i think maybe some lacquer thinner would get the remainder off.
CAUTION ! lacqer thinner is bad for paint. dont use it unless you wont be able to see the spot that needs it as it WILL dull your paint. i would suggest using painters tape around the area in case of drips, etc. and make sure to wipe and clean it off good. it will work the easiest and best, but just be friggin careful with it. put a LITTLE on a rag and do tiny spots at a time.
VWGolfDriv3r
7-26-2005
Boston MA
Thanks for the suggestion. Goo-off or similar hasn't really done the trick. I'll try using the laquer thinner when I get a chance, clean it off well and wash wax it right afterwards.
Quote, originally posted by QuietStorm »
gorilla glue
No never... my Step-Dad... er whatever... used this... ran down the side of his GrandMarqis... worst idea ever... Stuff looks like snot, and I am going to have to grind it off and repaint part of his car..
3M VHB tape (Gray w/ red).
(ps, I know you are J/K...)
Edit, Ive done this now on both of my MKIIIs.. one black, the other white.
0 - Take you time, this is not a 15 min, job...
1 - wash car. I kid you not.
2 - Peel off offending trim. Use a heatgun, don't blister paint, or do it in the sun on a warm day.
3 - Wash car again. Wash trim off.
4 - Clay bar vehicle @ trim spot. I used Goof-Off on a small rag... Don't go nuts. Sit down and do some work.
4 - Wash it, dry it. Wipe it down with 91% iso. alch. Let it dry.
5 - Working on a flat clean surface remove the old tape from the trim. I used - yes a razor blade to carefully peel off some of it, I then used Goof-Off, my thumb, and some blisters to get the surface near perfect.
6 - Wash trim/Dry w/air
7 - Wipe off with alch.
8 - Lay 2 stips of 3M VHB tape down on trim.
9 - Line up trim with dip on sidebelt line. Move trim "onto" door starting from the bottom up. Take your time.
10 - Rub trim into place.
11 - It should last another 10 years.
Modified by Dan J Reed at 6:18 PM 1-22-2006
BB 62.. bitch!
BBQmotorsports - BUBENGROPEN - LOWERED CARS SAVE GAS! my DIY page -
WNDSR VR6
5-29-2005
Myrtle Beach SC
dan has a DIY for pretty much everything....hell of a guy
dirk_diggler
6-14-2004
Calgary AB
97 Jetta VR
 Re: SIDE MODLING adhesive!!!!!Help (Dan J Reed) »« »
Quote, originally posted by Dan J Reed »
you can also heat up the molding once you put it on with double end tape... this will make it stick a little better
'd
"She was voted by Almaty Chamber of Commerce as best sex in mouth. She is number 2, or 3, best prostitute in the country of Kazakhstan."
Jacon
9-23-2002
Kennewick WA
B8 A4, 98 Black VR
Quote, originally posted by DTMVDUB »
Audi
Jetta
Myspace
UnOFFICIAL BUYER / SELLER FEEDBACK THREAD
VPI 4/16/07
Clean PG
5-9-2005
Wausau WI
03 PGrey Jetta 2.slow enough that the ladies can watch me go by
the type of adhesive used isnt as important as how well you clean the area before resetting the molding. carefully use some acetone to get the last little bit of leftoever adhesive off. make SURE you do 1 hell of a cleaning job and when you reglue that stuff shouldnt come off again. cleaning is the important step in redoing sidemoldings.
ADD YOUR CAR! | FS: 12" Hip-Hop Vinyl
I blame my lack of engine knowledge on the fact that I have a 2.0. It lacks engine, so I lack knowledge.
eurodad
3-24-2004
Latrobe, Pa
97 Golf
 Re: (dv_death3x) »« »
i bought double sided tape from napa, it had a green backing, that was 3 years ago and it's still holding.
chamaco77
1-13-2005
North Haven CT
1998 VW Golf 2.0T
 Re: (eurodad) »« »
I used GOOP it's specifically for this and other weather stripping, it's water proof and doesn't require much, it also is cheap, like $6 a tube. Water proof and dries clear.
I've haven't touched my moulding since it's been at least 3 years and I didn't even get all the old adhesive off, I'm sure if you take your time and clean everything up nice it will be the last time you have to do it.
Prestige World-WIDE...wide...WIDE...wide...
FlyersFn32
5-14-2004
Shoemakersville and Annville PA
1996 VW Jetta Trek Edition and 1991 VW Corrado VR6 (finally done)
I used it, my trim is still sticking, and nothing has become damaged. As long as you read the directions on the bottle and apply SPARINGLY (very sparingly, as it expands a lot when it drys), you should have no problems with it.
Chase-B
1-20-2007
Winthrop Maine
97 Red Jetta VR6, 95 Green Jetta GLS, 96 Jetta VR6
 Re: SIDE MODLING adhesive!!!!!Help (FlyersFn32) »« »
using for future reference
Quote, originally posted by Shawn W. »
bubble wrap doesn't prefent internal damage from being throw around like a used whore at a gang bang.
DoQ Danny
10-27-2007
DoQueens, NYC
EUROM3DIAN
where can i get replacement side moldings??
Dubs of Queens | EuroMedian
you're visual addiction
» Return to Golf III & Jetta III
