.:Ryan
8-8-2005
860 CT
01 Solara SEV6 MT
DIY: De-ambering your smoked lighting... for GLX tails and Euro smoked turn signals | « » 5:58 PM 2-11-2006 | |
For all of you who have smoked lighting (turn signals and GLX tails specifically), you know that if you really take a close look at the turn signals or your GLX tails, you'll see an orange glow to them.... which doesn't look good. So here is a DIY to get rid of that orange glow. This isn't a new subject, but I thought it would be good to put it alltogether in one thread. So here we go:Can't really tell here, but you can in person, and that's where it counts.
 GLX tails before: notice the amber glow on the passenger side
 What I started with:
) European specification turn signals with no amber lense, orange bulbs, and retro-fitted to use the U.S. specification 3 prong plug. ) GLX tail lights with normal white bulbs and connections. What you will need:
) 4 stealth bulbs (1 pair 1157, 1 pair 1156, that appear silver but light up orange)
 I got these on ebay for $6.49 a pair shipped. From this ebay member: "galagolo" ) Dremel tool
 ) Regular screwdriver ) Needle-nose plyers ) Hammer ) Vacuum ) (optional) narrow, hollow tube) ) Safety Goggles Smoked Turn signals:
This part takes 5 minutes. Take the screw driver, pop out the dummy panel and remove the turn signal. Disconnect the plug, push down on the plug and twist to the left and take it out. Swap out the regular bulb for the stealth bulb....... and you're done. Put that back together and be careful not to break any of the tabs while putting the dummy panel back in. Comparison shot. Ambered on the left, finished product on the right
 (being lower does have its disadvantages ) Finished:
 (Lip mended too )
 Hella Jetta GLX tails:
This part takes a little longer. Open your trunk, turn to the left or right and peel back the carpet in the corner behind the outer tail lamps (the carpet that is against the backside is behind the carpet against the sides of the car). Remove the lighting harness carefully, so you don't break the bulbs. Take the 8mm deep socket and remove the 3 nuts that hold the tail lamp in place. Take out the outer tail lamp. Now, if you look inside the turn signal housing, you'll see a little orange cup that surrounds the bulb, which not only dims the light, but makes it cast an orange light (and the orange glow when they're not on). Take the screw driver, put in in the hole of the the housing against the amber cup and LIGHTLY tap the screwdriver with a hammer to pop it out of position. I cannot stress enough how important it is to be very gentle with that step; you do not need a lot of force to separate the glue (or whatever), and if you apply too much, you can break the tail light!. It should be just floating about freely in there now. So you should be really motivated to get this done! . So here's where it gets "fun". Grab the amber cup withe the needle-nose plyers and have at it with the dremel!
 I recommend to take off small chunks at a time and just pull them out with the needle-nose plyers.
 So, work your way around the cup, taking off small chunks at a time. then when you've taken off about half the cups height, go around again, doing the exact same thing.
 Soon, you'll be left with a little amber disk.
 So, take the dremel and cut it in half. You can only cut so much at once, so attack it from the top and from the bottom.
 Now you should end up with something like this:
So Vacuum all the chips up. To get to the inside of the housing, what I did was attach a narrow piece of tubing to the end of my vacuum hose with duct tape and used that. You may have to tap the tail lamp against something hard, but not too hard, to get the chips out if they went around the corner. So now that you've done one side, reinstall the tail lamp in the reverse order that you took it out, and do the other side. Comparison shots:
 ***Important*** DO NOT do this without putting some sort of amber bulb in the tail lights!!!
Feel free to ask questions
EDIT: Put all the pictures in Cardomain so they won't disappear
Modified by SSjetta at 12:35 AM 2-19-2006
Der Golf KartFS: Brand New Miro M02 FS/FT: Kuhmo V710 on snowflakes
soccergk
4-19-2005
Manchester NH
95 Jetta 2.0T, 93 SLC, Futura GTI, B3 Wagon
Re: DIY: De-ambering your smoked lighting... for GLX tails and Euro smoked turn signals (SSjetta) » | « » 6:00 PM 2-11-2006 | |
great writeup Ryan!!! i wonder who told you about this
ReflexTuning.com NH's REVO Dealer RT Skid Plates keysforvw.com Ebay Auction
vwmk1gti
4-29-2003
Victoria BC
1979 Rabbit GTI, 1995 Jetta VR6
Re: DIY: De-ambering your smoked lighting... for GLX tails and Euro smoked turn signals (soccergk) » | « » 6:04 PM 2-11-2006 | |
nice now i have a project for this weekend
| Quote, originally posted by Vortexpert » | just for kicks... i wanna see the 1.8 20V non turbo hump a VRT. i bet it would have some weird ass baby engines... i would adopt 1.
SnubbedMK3
8-27-2004
Huntsville TX
1995 Mulberry VR6
» | « » 6:10 PM 2-11-2006 | |
You rock SSJetta!!
Mattro
1-31-2003
Dieppe NB
2000 Audi A4 1.8TQ - 1994 GTI VR6T
Re: (SnubbedMK3) » | « » 6:15 PM 2-11-2006 | |
looks really great !! the tails match a lot better with the inner partsI wish it was like this on the GTI tail lights, but the whole exterior plastic looks orange
Vorsprung durch Technik2000 Audi A4 1.8TQ 94 GTI VR6T ... gone in pieces
wob_vento
1-12-2004
Md
Re: (SparkonGTI) » | « » 6:33 PM 2-11-2006 | |
good write up. do you have a link to the person's ebay store, i tried searching it but couldnt find them.
Franco...
6-18-2004
out of the gay
and in da Valley...CT
Re: (SparkonGTI) » | « » 6:35 PM 2-11-2006 | |
i thought the turns had orange reflector inside, i'm confused
autocratica 1 thirty pack at a time
.:Ryan
8-8-2005
860 CT
01 Solara SEV6 MT
Re: (Franco...) » | « » 6:41 PM 2-11-2006 | |
| Quote, originally posted by Franco... » | | i thought the turns had orange reflector inside, i'm confused |
Some do, some don't. mine don't. *shrugs*
Franco...
6-18-2004
out of the gay
Re: (SSjetta) » | « » 6:46 PM 2-11-2006 | |
i didn't know
altitude
1-27-2004
santa monica ca
97 Jetta Vr6 - 'MMM VR6'
Re: DIY: De-ambering your smoked lighting... for GLX tails and Euro smoked turn signals (SSjetta) » | « » 6:54 PM 2-11-2006 | |
awesome good pictures thanks for this!
Yan is my dj! Mk3 DIY Guide(very helpful!)
.:Ryan
8-8-2005
860 CT
01 Solara SEV6 MT
Re: (wob_vento) » | « » 7:06 PM 2-11-2006 | |
| Quote, originally posted by wob_vento » | | good write up. do you have a link to the person's ebay store, i tried searching it but couldnt find them. |
I just checked his name and he doesn't have any up for sale, so I asked if he could put more up for sale for you guys "1156 / 1157 SILVER VISION BULBS(CHROME) FREE S&H" ^that was the title of the item that I bought.
Modified by SSjetta at 7:07 PM 2-11-2006
euronated
11-22-2004
By da Beach Boy 732
1998 Jetta GLX
Re: (SSjetta) » | « » 7:37 PM 2-11-2006 | |
i am definatly doing this ....that amber look pisses me off good write up
hateraide.
.:Ryan
8-8-2005
860 CT
01 Solara SEV6 MT
Re: (euronated) » | « » 8:02 PM 2-11-2006 | |
http://cgi.ebay.com/ebaymotors...03305Ok, there is the Ebay item..... but don't buy it! email him first. That's only so the auction stays up there. you'll need 2 pairs of 1157 amber bulbs.
Midnight_Jetta
10-2-2005
Atlanta GA
1995 Volkswagen Jetta GL MT
Re: (SSjetta) » | « » 8:16 PM 2-11-2006 | |
Nice job Now I can go do this to my JDM lights on the Mazda
1995 Volkswagen Jetta GL 2.0L MT
gti_r_done
10-7-2004
findlay ohio
99.5 A4 Avant
Re: (SSjetta) » | « » 8:17 PM 2-11-2006 | |
sweet write-up mang
flickr
KBofMontclair
7-25-2005
Montclair NJ
98 VeeReihenmotor A2 GLi-VR6 (wanted) mkIV R32 in the yard
Re: DIY: De-ambering your smoked lighting... for GLX tails and Euro smoked turn signals (SSjetta) » | « » 8:27 PM 2-11-2006 | |
great write-up, im going to be doing this as soon as the snow stops. (and when it get warmer otside )
soon to be underway, "operation dumb-funky-fast"oh and, where's punjeb?
CoolJetta3
6-28-2001
Norwich CT
1997 Cabrio, 1998 Jetta
Re: DIY: De-ambering your smoked lighting... for GLX tails and ... (KBofMontclair) » | « » 10:42 AM 2-12-2006 | |
Nice job! I no longer have this problem but maybe my gf might want to have this done since she has my GLX tails now. The M3 tails have no amber lens inside them so I had to put those silver stealth bulbs in them so they don't flash white.
OSD Keep on with the force don't stop, don't stop til you get enough Swift Vids
jron
11-10-2003
norf jursey
Re: DIY: De-ambering your smoked lighting... for GLX tails and ... (CoolJetta3) » | « » 10:49 AM 2-12-2006 | |
Nice writeup Ryan, but I have a ghetto method for your ghetto DIY. You saw that envelope...Jersey has no shame  No need to buy those $7 bulbs! for my FK smoked tails, they came with orange signal bulbs that reflected all over that section of the tailight, and looked like doo doo(since they're crystal inside) I just took some silver model paint, put it on the bulbs, let 'em dry, and that's it. I've got no pics of the 'before + after'.... but if you're gonna try it my way, use very little silver paint. I didn't have to coat the entire bulb, just the top, and made rings around it to let enough light out. They are just as visible as they were, and the tails look 10x better without the orange. Plus I saved $15 If i had my car, i'd take pics....
Modified by JRon24 at 10:51 AM 2-12-2006
.:Ryan
8-8-2005
860 CT
01 Solara SEV6 MT
Re: DIY: De-ambering your smoked lighting... for GLX tails and ... (JRon24) » | « » 11:52 AM 2-12-2006 | |
hmmm.... yea because that's basically what these stealth bulbs are.. just a regular orange bulb that's covered in that mirror paint. You know, those mirrors that you can see through from one side? It's like that.
jron
11-10-2003
norf jursey
Re: DIY: De-ambering your smoked lighting... for GLX tails and ... (SSjetta) » | « » 12:05 PM 2-12-2006 | |
yeah. i almost ordered some, then thought it's just silver paint
.:Ryan
8-8-2005
860 CT
01 Solara SEV6 MT
Re: DIY: De-ambering your smoked lighting... for GLX tails and ... (JRon24) » | « » 12:08 PM 2-12-2006 | |
good thinking, but they were pretty cheap so I didn't really mind.But definetely take some pictures when you get your car back
treehouseman
8-26-2003
Jacksonville Riverside FL
Mk3 gti 8v
Re: (SparkonGTI) » | « » 12:27 PM 2-12-2006 | |
| Quote, originally posted by SparkonGTI » | I wish it was like this on the GTI tail lights, but the whole exterior plastic looks orange |
Yeah, it sure does. Has anyone tried to do anything like this to the GTI tails?
Mex gti
9-18-2001
Mexico Maxed Out Pothole state
1997 Golf GTI ...
Re: (treehouseman) » | « » 12:46 PM 2-12-2006 | |
Im interested in doing this to the OEM GTI tails too, i have all red Hella colour magics currently but would still like to try Any input?
MEXICO"This is for the people of the sun!" Zack De LaRocha
Venkman
6-24-2005
Harrisburg or Shippensburg PA
Re: (Mex gti) » | « » 12:52 PM 2-12-2006 | |
That is awesome I always wondered about this...great job man!!
So the space in my head isn't enough... everybody likes photos fs:polished merc wheels
dankvwguy
7-23-2005
DUBlin Ga
97 Jetta VRT Hybrid/Electric
» | « » 1:16 PM 2-12-2006 | |
now if i was not to buy the orange bulbs im guessing my blinkers would be clear or smoked on the rear correct....not orange?..i have a feeling this is illegal but MANY MANY MANY cars in my town including many Mercs have em like that and never get tickets
- TJ boost is overrated and so is ride height Add the Bill of Rights, subtract the wrongs...there's no answers! - NOFX CBOX KREW FTW 2pc 17" BBS Moda M2 FS
.:Ryan
8-8-2005
860 CT
01 Solara SEV6 MT
Re: (dankvwguy) » | « » 1:25 PM 2-12-2006 | |
yea, DO NOT do this without putting in some sort of orange bulb in the rear!!!If you keep the white bulbs in, they'll light up as bright as your reverse lights, and all hell WILL break loose.
Modified by SSjetta at 1:31 PM 2-12-2006
marcusmaximus
2-6-2006
Markham ON
Rust/Black 97 Jolf
Re: (dankvwguy) » | « » 1:29 PM 2-12-2006 | |
| Quote, originally posted by dankvwguy » | | now if i was not to buy the orange bulbs im guessing my blinkers would be clear or smoked on the rear correct....not orange?..i have a feeling this is illegal but MANY MANY MANY cars in my town including many Mercs have em like that and never get tickets |
I am pretty sure it's illegal in my town... I gotta get me some of those stealth mofo's!!! Thats badass. Nice write up, and thanks for the tip!
[marcusmaximus]
KBofMontclair
7-25-2005
Montclair NJ
Re: DIY: De-ambering your smoked lighting... for GLX tails and Euro smoked turn signals (SSjetta) » | « » 7:59 PM 2-12-2006 | |
are these bulbs the same for the glx front bumper turn and rear turns? 1157 also, are there any silver outside that flash yellow?
.:Ryan
8-8-2005
860 CT
01 Solara SEV6 MT
Re: DIY: De-ambering your smoked lighting... for GLX tails and ... (KBofMontclair) » | « » 8:08 PM 2-12-2006 | |
yea, they aren't are same, they are dual filament.The rears are single filament though... so what I did was I shaved down the top nub and put them in... but you have have to note which way you put them in because there are 2 ways to put them in. one way will make them blink faster, because it will light up the dimmer filament, and the other way will be normal because it lights up the brighter filament. And yea, they appear to be silver, but they light up orange/amber
vwjettalikewhoa
9-3-2003
01002 MA
16v/ABA MK3 and a scene MK2
Re: (Franco...) » | « » 8:09 PM 2-12-2006 | |
the US spec HELLA smoked turns (now discontinued) have the orange reflector inside which are hard as fuck to find (luckly i got a set woo!).
 anyways most companys today sell the ones w/ out the orange reflector, its the bulb that makes them orange
| Quote, originally posted by vwjettalikewhoa » | | i thought we were doing pretty good for the MKIII forum |
| Quote, originally posted by King » | | yeah.....no. |
jron
11-10-2003
norf jursey
Re: (vwjettalikewhoa) » | « » 8:11 PM 2-12-2006 | |
i've got hella turns, but the orange was taken out of 'em
KBofMontclair
7-25-2005
Montclair NJ
Re: (JRon24) » | « » 8:18 PM 2-12-2006 | |
| Quote, originally posted by JRon24 » | | i've got hella turns, but the orange was taken out of 'em |
same here but, i cant look at the bulbs righ tnow because its cold as hell outside. does anyone know what size the front &rear turns are? or what site i can view our cars bulbs sizes. also, does anyone know if they come in silver/yellow?
.:Ryan
8-8-2005
860 CT
01 Solara SEV6 MT
Re: (KBofMontclair) » | « » 8:27 PM 2-12-2006 | |
the fronts are 1157, but they will work in the rear if you what I did.
Mintdub
1-15-2004
Bradenton FL
2002 Passat 1.8t
Re: (SSjetta) » | « » 8:36 PM 2-12-2006 | |
sick wrightup man..
DUBOCR/\CY 2002 Mint green Passat 1.8t Pic of my Car and Previous Cars
CoolJetta3
6-28-2001
Norwich CT
Re: (dankvwguy) » | « » 4:25 PM 2-13-2006 | |
Your rear turnsignal lights can be red, white or amber. They cannot be blue because thats used by service vehicles. Your fronts can be white or amber but not red or blue.
