dangrass11
4-4-2004
Berkeley CA
2006 Mark V GTI- manual transmission
 reset service indicator« »
I've searched and searched, but to no avail. Questions:
1. Is there any way of resetting the service reminder on Mark V without the dealer tool/Vag-Com?
2. I did find this procedure for a 2000 Vanagon in my searching. Does anyone know if this (or something similar) will work for the GTI?
thx...
The Service Reminder Indicator (SRI) is fitted to all 2000 EuroVans It stores two sets of information: Oil Change and Inspection Service. Here is the method to manually reset the SRI after performing a service:
Switch ignition OFF.
Press and hold down the trip odometer reset button (at the lower right of the instrument cluster).
Switch ignition ON and release the trip odometer reset button. It is not necessary to start the engine; merely turn the key until the ignition is ON.
The trip mileage area now displays "Service OIL".
If trip odometer reset button is now pressed again, the display turns to "Service INSP". Pressing the button again will cycle the display back to "Service OIL".
When the reminder that needs to be reset (either OIL or INSP) is displayed, turn button for setting the clock (at lower left of instrument cluster) to the right. The display changes to "Service ----". That reminder is now reset.
The second reminder is unaffected unless it is displayed by pressing trip odometer reset button and the clock button is turned right again.
Switch ignition OFF and back ON to resume normal display.
heffergm
11-25-2005
Linden VA
Bump... anyone? I'll need to know as well.
dangrass11
4-4-2004
Berkeley CA
 Re: (heffergm) »« »
...and here's something similar I found for the Mark IV...
If your Mk4 is the one with Blue dash lights and Red writing it goes like this!
* Turn on ignition.
* Hold down Right trip button and continue to do so whilst turning off ignition.
* Still with Right trip button held down turn ignition back on.
* Release Right trip button.
* With ignition still on turn Left trip button to the Right and release.
* Turn off ignition.
Service reminder should now be reset when you next start the vehicle!
Edited by gbolton
meanvw
12-31-2004
I94 WI
87 Scirocco 16V G60 LTD, 83 Rabbit LS Diesel, 07 GLI 2.0T 14 second winter beater
 Re: reset service indicator (dangrass11) »« »
Bump...
Any information on how to reset service indicator on MFD display??
http://www.venommotorsports.com/
Quote, originally posted by fallsjetta »
does anyone have an answer, or are we going to play childish games?
meanvw
12-31-2004
I94 WI
 Re: reset service indicator (meanvw) »« »
Service indicator can be reset without a VAG COM.
Here's how:
1. Keys out of ignition- press and hold in trip odometer reset button "0.0" on right hand side of display
2. Still holding this button down, insert key into ignition and put to the on position without starting the car.
3. Display will read "service now"
4. let go of the "0.0" button and depress the "m" button on the left hand side of the display. this will re-set the service reminder. There is no confirmation on the display other than the words "service now" will disappear.
You can confirm that the service reminder has been reset, or check how many miles/days remain until service at any time by taking key out of the ignition and holding in the trip reset "0.0" button for between 3 and 5 seconds. The MFD will display miles and hours until next service.
Modified by meanvw at 8:58 PM 3-13-2006
dangrass11
4-4-2004
Berkeley CA
Quote, originally posted by meanvw »
Here's how:
Thanks for the info. No problem resetting the service indicator, but the holding in the trip reset button to check for remaining miles/time to next service doesn't seem to work. ('06 GTI, manual trans) Also, does the ECU know that the next service should be in 10k rather than 5k miles?
thx...
Dan
blackvento36
3-17-2003
Easton pa
06' GLI 6MT Deep Black
Is this something new? I haven't seen this on my GLI
The BEST MKV carputer
Posting in the MKV forum is like smacking yourself in the face.
chriscar
8-30-2003
Ronkonkoma NY
06 GTi Black Magic / 01 Galactic Blue Wolfsburg
 Re: (blackvento36) »« »
Just tried checking the Time To Service on my GTi. You need to have the key on, engine off, and press trip reset for a few seconds.
Thanks!
Chris
big papa
3-17-2006
Queen Creek AZ
1957 Oval Window 2004 yamaha banshee
I tried to get this info on another site. Good stuff!!
Oh yeah, I think this should be a sticky, as more people are gonna ask as they put more miles on their cars.
Modified by big papa at 12:29 AM 3-24-2006
01tj
11-8-2005
Fairmont WV
E46 330i, Modded Jeep Wrangler, Ford Freestyle AWD Limited
Great info and perfect timing
http://www.youtube.com/watch?v=sn1jELFBCns
Dub Factor8
4-12-2006
Plainfield IL
06 Candy White GTI
 Re: reset service indicator (01tj) »« »
GTI_Guy1977
1-4-2006
Richmond Hill ON
2007 Candy White GTI
 Re: reset service indicator (Dub Factor8) »« »
This is awsome.
Thanks for the photos and the step-by step. I agree this should be a sticky...since I was wondering about this...as I click over the 4000 Km mark on my GTI.
Is there any way to adjust the interval or even turn it off?
On the road of life there are passengers and there are: soccer mom's in SUV's, busses, bikes, pedestrians, people going slow in the fast lane and GTI Drivers. Which are you?
digitalhippie
4-21-2004
Stamford CT
2006 GTI 2.0T, 2001 Jetta GLS 2.0L (sold), 1993 Golf GL 2.0L (sold)
 Re: reset service indicator (GTI_Guy1977) »« »
This can also be reset using the VAG-COM.... when reset using the above method, the service indicator gets set to fixed intervals. See here: http://forums.vwvortex.com/zerothread?id=2498327
VAG-COM Scans/Mods available (HEX+CAN)
2006 GTI 2.0T, United Grey, 6MT PKG2+iPod and then some
2001 Jetta GLS 2.0L (AEG), Tornado Red - 143+k miles (sold)
1993 Golf GL 2.0L (ABA, OBD-I), Teal/Green - 158+k miles (sold)
http://www.myspace.com/digitalhippie
electricme
8-8-2005
Hershey PA
My Cars-06 SHADOW BLUE GLI...
awesome Thanks? most helpful thread ever!
To alcohol! The cause of - and solution to - all of life's problems!
CePAvw... WE ROLL DEEPER
flickr
Kid Hobo
9-4-2005
09 JSW 6MT 2.0T
"We be jammin' now, mon!" Billy said, toasting The Breeze with a slosh of the Coors.
The Breeze shook his head balefully. "Keep the can down, watch the road, let me roll the doobie," he said.
"Sorry, Breeze," Billy said. "I'm just stoked that we're on the road."
spinfunky
6-1-2005
Queens NY
2005.5 Jetta 2.5L Package 1, Reflex Silver on Anthracite Leatherette
Great info, thanks dude...
| Monster Mats | Tom Tom One 3rd Gen |
^mOrgan^
4-26-2006
Dallas Texas
06 Jetta 2.5
 Re: reset service indicator (spinfunky) »« »
great ?
thanks for the info!!!
Jonathan
First VW - '06 Jetta 2.5
Other car is '98 MB CLK 320
blackvento36
3-17-2003
Easton pa
At what point does the indicator come on? Im at 7k miles and haven't seen it.
mormonrage
2-20-2006
Ogden UT
'09 Iron Gray CC VR6 4Motion
Mine came on right at 5K and, of course, the dealer didn't reset it. I knew I could get the info here. Thanks for the pics and instructions!
Representing Deutschland.
masteryoda305
5-10-2002
Chicago Il
2006 Jetta GLI MT6
 Re: (mormonrage) »« »
Mine came on at 500 miles (for some odd reason).
I've only had the car for a short while, and there's no way it needed a oil change. The "Manufactured On" date on the side of the car says 08.05 so I'm figuring it was just the 12 month time limit clicking on..randomly. I was just in the shop to fix the radio, i doubt the two incidents are connected.
the "service now" thing is completely separate from the "check engine" light and other real notifications right? Thats what i'm figuring, hence why i just reset it.
SignalTDI
7-19-2006
Signal Mtn TN
2006 VW Jetta TDI, pkg 1
I followed these instructions. However, I don't think it worked. The reason that I think it didn't work is the following. Before my oil change yesterday, for a few seconds, I would see a small number in the place of my odometer. IOW, it would read 100 for a few seconds, then switch to 4900. After I went through the above steps, I no longer see the small number. I ONLY see the 4940 (my actual mileage).
Have I done this correctly, or do I have to find someone with a VAG-CON or go to the dealer to get it reset correctly?
Thank you in advance for your help.
GotHerFast
4-23-2003
One Sweet World MD
06 Candy White MKV GTI
 Re: reset service indicator (SignalTDI) »« »
Add to FAQ?
95' Surf Green Golf Sport/04' R32: RIP Brutus/03' GTI 1.8T/06' GTI 2.0T
My fast doesn't care about gas prices.
Quote, originally posted by SoCalDubber »
Whoa dude, calm down... You're asking what we call a "technical" question... Vortex is to show off your new "tints"
Buy my stuff!
Eurojet DV kit, like new!!
rysskii3
4-18-2006
SoCal
so this really works?
Quote, originally posted by tuddy »
“air ride functioned as it should have, everything worked good, bagyards road wonderful as they should, but the car had just lost its fun edge.”
ajz9415
2-7-2005
Bolingbrook Il
04 Passat W8 06 DSG GTI PKG 1 TORNADO RED
 Re: reset service indicator (rysskiiy3) »« »
It worked for me but of course I used my vag com thanks for the vag-com instructions. Anyone in my area that needs it reset just e-mail me I will gladly do it for you
******VAG-COM Scans/Mods available (HEX+CAN) Bolingbrook, IL******
Vag Com Requests to
Andrew_zann (at) Comcast.net
hafa_adai
11-2-2001
 Re: reset service indicator (SilverstonedOne) »« »
Quote, originally posted by SilverstonedOne »
Add to FAQ?
Get this thread pin to the FAQ. Thanks, good stuff!
JohnA83
6-18-2006
Pembroke Pines FL
'06 VW GTI
best thread, EVER! i've needed this for a while, since those batards at the dealer left the light on. I came across this by accident too hehe. thanks!
TM Tuning - South Florida Dubs
sweatyworker
5-4-2005
Melbourne
Nil
Quote, originally posted by SignalTDI »
The above reset function is in the manual/handbook. From the section in the manual it says "The next service will be displayed after (15000km/10000miles), or after one year, if you reset the service display yourself. The service interval will not be determined individually.
I think the number displayed for a few seconds could be the miles to next service (as calculated by the vehicle from driving conditions) and as you reset this is no longer being calculated. This is just a guess on my part.
10X
6-14-2006
Cincinnati OH
 Re: reset service indicator (sweatyworker) »« »
Quote, originally posted by sweatyworker »
Where is this info in the manual? I've look to no avail.
06 Jetta TDI Shadow Blue w/Beige Pack 2 DSG W/NAV
06 Jetta TDI Blue Graphite w/Gray Pack 2 DSG W/NAV
sweatyworker
5-4-2005
Melbourne
Nil
 Re: reset service indicator (10X) »« »
Mines an Aussie car and it's in a supplement dated 05.2004. The section is Controls and Equipment.
HTH
2zzge
8-16-2006
Somewhere in Hookah
2003 Jetta-base, 2007 GTI 6M 2dr pkg-0
very nice info. thank you!
boogers
VolksRacer2
8-5-2002
Moxee WA
68 Bug, 69 Bug, 81 Caddy, 82 Rabbit, 84 GTi, 98 Jetta GT, 08 Jetta Wolfsburg DSG
That is correct. once you get within 1000 miles of your sevice due it spits up a reminder every time you start the car. Since it's been reset, the reminder shouldn't re-appear until (maybe) 1000 miles before your NEXT service is due.
84 GTi: Stock CIS/2.0 ABA bottom end/JH head/Autotech 286 cam/MKIII manifolds/TT downpipe/15" glasspack/2.25" short pipe
Best 1/4 mile ET so far...13.979 @ 95.83MPH
Import Auto Parts (509)452-1533
Wolfbing
10-15-2006
ferk hugh ho CA
 Re: reset service indicator (GotHerFast) »« »
Quote, originally posted by GotHerFast »
Add to FAQ?
J_loving
8-9-2006
Orange ca
2006 VW GTI MKV 2.0T 6speed
Quote, originally posted by rysskiiy3 »
I just walked out front and did it! WORKED GREAT!!!!
MKVGTI@SBCGLOBAL.NET
I like when my car go TSSSS. It makes me happy.
Windows tinted limo baby.
First mod: 11-2-06 Resonater removed.
Jay5spikelee
9-26-2006
Hacienda Heights CA
2006 VW GTI
excellent imformation... i had to take mine in to the dealer and deal with there sh*t saying the wouldnt do it for free A**holes ... now i know how to do it myself ... THANKS!
placenta
6-2-2003
Burma NZ
2009 VW GTI
 Re: (Gkap) »« »
Quote, originally posted by Gkap »
Ok i have a dumb quick question ,.. how do u just reset ur Trip Odemeter?.. plz,, im dying here lol
r u sirus???
you hold the 0.0 button..
2009 VW GTI
2009 Nissan Xterra
FS: 2 GTI tweeters/sails, new never installed, $45 shipped USA
» Return to Golf V & Jetta V
