FaelinGL
11-27-2004
Charlotte NC
2000 Jetta VRT, 195,000 miles 395 hp @ 5k RPM last dyno.
 DIY: Polishing PLASTIC...like headlights and tailights!« »
POLISHING PLASTIC HEADLIGHTS / TAILIGHTS
The original inspiration for this DIY comes from the metal polishing DIY, see http://forums.vwvortex.com/zer...age=1 for details. There's also this one, http://forums.vwvortex.com/zerothread?id=2246097, but it could use some step-by-steps with pictures. I was sick and tired of my yellow, scratched, banged up headlights. Unfortunately, I was so pleased with the results that I didn't wait for my camera to come back and did the other side. Here are the results.
Keep in mind that my 2000 VR6 has 135k miles of highway driving. Yes, these are the original headlights. The DIY shots were actually taken of my g/f's Civic, so I hope I don't get flamed too badly for it. The procedure is actually easier on a VW because the headlights are a flat surface. Here is a before / after shot of the Civic headlights.
Parts
Since I didn't have any automatic tools, I simply used a lot of elbow grease. Air tools and the like may make the job easier, but I do know it works this way for sure. Net cost: Approx $25.00.
1) Clean Terry Cloths (about 3)
2) Painter's Tape
3) Cloth Applicator (like you'd use to wax)
4) 600 grit wet/dry sandpaper
5) 2000 grit wet/dry sandpaper
6) 3M Rubbing Compound
7) Plastic Polish (I used Meguiar's PlastX)
Tools
1) Some kind of squirt bottle, filled with water and dishwashing soap (do NOT use car soap, it has waxes and such)
Please be careful. Do this procedure at your own risk, I can't be held responsible if I have made a mistake in the steps.
Examining your parts
i. Before you start, make sure you have the above listed parts.
Wetsanding from 600 to 2000
1. Start by covering the edges of the flashlight with painter's tape. This protects your finish in case you are a little too agressive with the sanding process.
2. Douse the headlight with soapy water. It is always better to use too much then too little. Once the headlight is wet, start sanding the headlight using your 600 grit sandpaper, continuously adding soapy water to keep the surface wet. You want to sand in long, left to right strokes using moderate to light pressure. The point is to uniformly roughen the surface.
3. When you are done with the 600 grit, the surface should feel slightly rough, but you should not be able to see any surface blemishes. The headlight will look VERY hazy.
4. Switch over to the 2000 grit sandpaper. Repeat step 2 with the 2000 grit. When you are done, the headlight will still look hazy, but it will be a little bit clearer. However, the surface should be totally smooth and free of any imperfections. Repeat steps 2-4 if there are still some surface imperfections.
5. Dry off the headlight with a terry cloth. Here comes the magic. Using the 3M rubbing compound, apply a quarter-sized bit to a new terry cloth. Work the compound into the headlight surface using hard pressure in circular strokes. Frequently turn the cloth and continue rubbing until dry. This requires a LOT of elbow grease; you will want to work the headlight until your arm feels like it's going to fall off and then some. It doesn't hurt to go over the headlight 2-3 times.
6. Then, apply the plastic polish. Using an applicator pad, work the polish into the surface using firm pressure and circular strokes. Once you have covered the surface, wipe clean any residual with a new cloth.
7. Your headlight lens should be MUCH better then it was. I still had some slight scratches in the surface from the 600 grit wetsanding process, so I did the whole thing over again and there was nothing left.
That's it! Let me know if you have any questions!
Mike
Chapter 11 Dubs: Member 001 - "Go broke or drive tryin"
elements757
9-24-2005
Hampton
VR6
 Re: DIY: Polishing PLASTIC...like headlights and tailights! (FaelinGL) »« »
pretty cool
BHB
Global Moderator
10-26-2004
Santa Monica, CA
07 A6, 08 GTI
 Re: DIY: Polishing PLASTIC...like headlights and tailights! (elements757) »« »
great DIY.
idwurks
10-25-2003
A Starbucks Near
Walnut Creek, CA
Def. need to add this to the DIY.
EuroImageTuning |GermanPlates.Com |Idwürks Industrial Design Services
Quote, originally posted by KyleRI »
my racelands ride better than your Weitecs
BHB
Global Moderator
10-26-2004
Santa Monica, CA
07 A6, 08 GTI
 Re: DIY: Polishing PLASTIC...like headlights and tailights! (idwurks) »« »
Quote, originally posted by idwurks »
added
FaelinGL
11-27-2004
Charlotte NC
 Re: DIY: Polishing PLASTIC...like headlights and tailights! (bhb399mm) »« »
Damn that was quick....estimated turnaround time 9 minutes flat!
Mike
elements757
9-24-2005
Hampton
VR6
Quote, originally posted by bhb399mm »
added
the link is messed up
sleepygti28
2-24-2005
MD
03 cb a4 04 ls a4
great DIY.
x2
gotta vwvortex...
2Lz Clothing
i want to be on bags!!!
Elvir
10-18-2004
Bosnianville GA
I drive a Speedy VW
good job, that looks awsome
Elvir
..........................................................................|D|SPEEDY VW|
BHB
Global Moderator
10-26-2004
Santa Monica, CA
07 A6, 08 GTI
Quote, originally posted by elements757 »
really?
....checking.....
idwurks
10-25-2003
A Starbucks Near
Walnut Creek, CA
really?
....checking.....
Hahahahah I know exactly what that post was about.
BHB
Global Moderator
10-26-2004
Santa Monica, CA
07 A6, 08 GTI
fixed ... -2 user points from myself.
mujjuman
7-29-2004
Albany NY
01 Jetta VR6, 06 Jetta 2.5, 03 heated seats
nice DIY. i would hate doing that though, hopefully i will nver need it
mujjuman
2001 Volkswagen Jetta VR6 + 2006 Volkswagen Jetta 2.5
Quote, originally posted by kraut_pauer79 »
wow, junkyards look like enchanted forests where you live.
http://vwvortexsearch.webs.com/ < vwvortex search
euro-steez
10-25-2003
Georgetown, On
Coupe
 Re: DIY: Polishing PLASTIC...like headlights and tailights! (mujjuman) »« »
nice. been meaning to freshin up my lights. good write up.
I like
Maestor_Shake
5-9-2004
Syracuse
Mk5/4/2
 Re: DIY: Polishing PLASTIC...like headlights and tailights! (Sic Gti) »« »
nice man. i need to do this to my escort beater.
Cure-Stylz _._._._. Flickr
bluebora20v
6-14-2001
East Bay/Sac CA
00 Atlantic Blue 2.0 Jetta (RIP), 00 Atlantic Blue 1.8t Jetta
 Re: DIY: Polishing PLASTIC...like headlights and tailights! (Maestor_Shake) »« »
Titan Clothing Co.($3 off code: VORTEX)
Toe Out Performance|SLOVW|flickr
Fat5 Fanclub
VRsexxy
4-1-2004
Atlanta
Racked R32
 Re: DIY: Polishing PLASTIC...like headlights and tailights! (bluebora20v) »« »
good job. very nice write-up and good pics. i'm doing it on thursday.
1 cookie for you!
.:R32
Go ride a bike
Eddy
TVAdict710
1-7-2004
Syosset and Occasionally Hofstra University NY
1997 Passat VR6 (R.I.P.), 2000 Jetta 2.slow
i would do this if i werent gonna buy GLI headlights...but good writeup
/// - LI, NY
Quote, originally posted by RvErD6 »
go lower look better get chicks
bagxlee
10-5-2004
indianapolis in
1994 Audi 90S / 2002 Saab 9-5 Wagon / a bicycle
you, my friend, are awesome. thanks for a perfect diy. i'm doing this once indiana finally warms up enough to go outside for more than 5 minutes. for you.
FLeuro
http://www.bradpickensdesign.com
Raktim81
8-5-2003
Plainsboro NJ
'00 GTi VR6 - 136K miles and counting
it did this. works really well. except i started with 400 grit --> 600 --> 800 --> 1500 --> and ended with 2000
i used my porter cable random orbital polisher to polish in the rubbing compound and the plastic polish and it came out as good as new.
vwtuner4ever
2-17-2004
Gatineau Quebec
 Re: (Raktim81) »« »
Only thing missing is how to polish glass lens
RabbitsKin
2-11-2003
Winchester VA
this and that, mainly VW's
 Re: (vwtuner4ever) »« »
I'm going to do this. I bought an extra set of used lenses so I could do them off the car first to see how they turn out.
Looking for trades:
Welding or machine shop equipment
.308 rifle and ammo
parting out a 2K GTI, hit me up
tchristemac
2-4-2005
Das Geschaft NY
BAGGED MK4 Jetta 1.8T, LAND ROVER DISCOVERY HSE, 07' PASSAT AVANT 3.6 30V 4 motion
 Re: (RabbitsKin) »« »
Great DIY... looks really easy...
LAMINX...
REVO
forge
FORGELINE WHEELS
DAS JETTA
RavinJetta
3-30-2002
2000 Volkswagen Jetta GLX, 1997 Grand Cherokee 4.0, 2004 Acura TSX
Nice writeup
DubChick
Queen
Tuckahoe
08 Audi A4 S-Line RIP - OEMtastic gli
 Re: (RavinJetta) »« »
that's great! although id be petrified to do it
Herself
I Robert Kubica
AutoTastC
11-12-2005
Somewhere in NC
'03 RSX
Thanks. I was actually gonna do this to mine this weekend.
and I just realized that you're a local.
'01 Jetta GLX ~ Gone & Forgotten
Quote, originally posted by Swizz!! »
I have a small penor
FaelinGL
11-27-2004
Charlotte NC
Quote, originally posted by vwtuner4ever »
That's a difficult one. If the headlights are tempered glass like the passenger / driver side windows, then they will shatter upon application of the compound due to the heat generated by the process.
Mike
elements757
9-24-2005
Hampton
VR6
do they get cloudy?
vwtuner4ever
2-17-2004
Gatineau Quebec
 Re: (elements757) »« »
Nah not cloudy.. The idiot I purchased my headlights from tried to polish them why a compound, and its not as clear as it supposed to be. Id like to have them looking like new.
The Lamin-X guys told me that if I apply they stuff on my headlight, those small scratches should disapear.
But, yeah I think i am asking too much and will go with the lamin-x instead
spkn^GRMN
7-24-2002
Indian Trail NC
pt A to pt B, quickly
Will this get pits out of jetta plastic lights?
-Wes-
•SPKNGRMN•
There are only two reasons to be in business: Fun and profit.
And if there's no profit, it's not much fun!!
FaelinGL
11-27-2004
Charlotte NC
 Re: (SPKNGRMN) »« »
Sure will man. That's why I did it on mine. You may have to spend more time wetsanding with the 600 grit to get down to clean plastic. I would wetsand uniformly across the headlight rather then just at the gouge / pit or you may change the beam pattern on the headlights.
Mike
dragonfli_x
7-16-2002
Macon GA
2001 Jetta GLX VRBLT, 2005 Passat TDI
 Re: (FaelinGL) »« »
you could trade off and do 600-800 grit first, then 1000-1500, then final rub with the 2000 grit, but this DIY works very well stick it up at the top!
"I'm not a Lemming, not a Lemming..." just like everyone else. - euroHoH
mycar site | Where you at?
FS: 18" Oettinger REs;
Got VAGCOM? Well Register! http://www.frappr.com/vagcomlocator
silveratljetta
12-2-2004
Powder Springs GA
2000 Volkswagen Jetta 1.8t Silver Arrow
I would start with something bigger than 600 unless your headlights are really f'ed up. Start with 800-1000 if you want to be safe. if you arent satisfied then go lower.
Quote, originally posted by jetta_vrsix »
sorry to see youre losing a nice car like that...(i like how everyone says sorry to losing the car, not the wife LOL)
Quote, originally posted by slick337 »
what's sad is i miss being inside the 337 more than i do her. but i got something new to climb in.
bagxlee
10-5-2004
indianapolis in
did this today and it turned out GREAT! thanks so much for a wonderful diy
FLeuro
BoostedVeeDub
11-16-2001
Woodstock Ga
[06 Z4 3.0si] ['04.5 PL GLI]
 Re: (bagxlee) »« »
Very interesting.
Charles A&D Mafia
flickr
OUTLINE Clothing
