candela
10-18-2002
heart of miami
mk3 TDI & mk3 cabby-ho
new ignition switch install | « » 12:10 AM 4-1-2006 | |
seems like we've all had to replace our ignition switches this year, huh? well it was time, so I did a search & found the traditional way of changing it out involving a puller, and then there's this way:| Quote, originally posted by jok3sta » | disconnect battery make sure steering wheel is locked remove the steering column surround ( 2 screws on either end ) go under dash and using a 13mm wrench and socket remove the bolt holding the steering column to the u joint unplug every plug goin into the steering column by the steering wheel including the ignition and airbag now on the left side there is a gold round headed bolt that holds the column to the dash support. use a vise grip and take that out. comes out pretty easily after the first initial turn. can do it with your fingers after.. then u can pull the steering wheel and everything comes out as one piece. now the only problem now is ur are goin to need a thin screw driver to reach the screw holding the ignition switch in.. after than just re install in reverse order and your done.. Do at your own risk though.. im not responsible if someone damages there car in the process or gets hurt this is jus a lil help for those who dont feel like pulling apart everything.. |
I snapped a few pics of the process for whoever so you'll know exactly what to look for..
here it is with the cover off..
the infamous u-joint..
it's a little tight getting in here.. hold the top bolt in place, undo the nut..
13mm, looks like this from the top..
unplug all these, including the airbag & the ignition..
this one comes out easily..
now you're ready to pull out the steering column..
now take the switch out with an eyeglass kit phillips head..
now put the new one in and put everything back together.. old switch/new switch comparison..
Modified by candela at 8:42 PM 9-4-2009
nom nom nom pinky dirty diesel 53mpg@62mph
FL 2.0L
7-31-2002
'96 Jetta GLS 236K '02 Cabrio GLX 65K
» | « » 12:11 AM 4-1-2006 | |
Beauty. Super easy that way.
luvinJesus
1-17-2003
Augusta GA
'94 GOLF MKIII 2.0
Re: (FL 2.0L) » | « » 1:11 AM 4-1-2006 | |
man put some wd40 on those joints...thats killing me
Love God, Love others, nothing else matters...well except maybe my VW!www.GizmoConnect.com
candela
10-18-2002
heart of miami
Re: (luvinJesus) » | « » 5:53 PM 4-2-2006 | |
they're rockin' mad lube bro
kewlrichie
12-30-2002
Brooklyn NY
1999 Wolfsburg Jetta III
» | « » 12:08 AM 4-5-2006 | |
this needs to be a sticky !!!,im making a PDF just incase it goes bye bye....good job man!!!, thanks alot for the pics...im about to do this install in a few days
MetroBrian
6-6-2005
Riverside Ca
1997, VW, Golf 2.0
Re: (kewlrichie) » | « » 12:24 AM 4-5-2006 | |
I just used a bearing seperator and pulled the switch housing off. then put in the new switch and put it all back together. Whole hell of a lot easier than taking the whole column out.Brian
envi
7-31-2005
east side
GTi x2
Re: (MetroBrian) » | « » 6:41 AM 4-5-2006 | |
Mine is starting to go, this really cleared things up. THank you.
Project Partout Badass Motor
Re: new ignition switch install (candela!) » | « » 8:26 AM 4-5-2006 | |
Good pics!!! Thanks!
BB 62.. bitch! BBQmotorsports - BUBENGROPEN - LOWERED CARS SAVE GAS! my DIY page -
golfgen3
5-5-2003
State College PA
1995, Golf III 2.slow
Re: new ignition switch install (Dan J Reed) » | « » 8:31 AM 4-5-2006 | |
this post came just in time too, just got the ignition switch from PAP parts  thansk for the right up def cleared up some issues I had... I got one question for everyone, is a new sheer bolt necessary for reinstalling? Im just going under the assumption no one bothers replacing such a bolt after taking the old one out because the ujoint holds eveyrthing in place after all.
Teufelhunde
1-12-2006
Ft Lauderdale FL
mk3
Re: new ignition switch install (golfgen3) » | « » 9:26 AM 4-5-2006 | |
How did you like getting that one bolt off the upper steering column?That bolt luckily didnt come on my car, mine had a hex keyed bolt there. Trying to remove that bolt from a junkyard car, lets just say, I needed them to use a torch and cut that ish off.
R.I.P. My Brother, T.K. July 25, 1982--July 8, 2006 The good always die young.  XvwX--170 c.i.
benzivr6
2-16-2001
Crooklyn NY
1992 Corrado SLC-Turbo & 2000 Passat 4motion variant
Re: new ignition switch install (candela!) » | « » 2:14 PM 5-1-2006 | |
Excellent write up bro gonna do this later this week
Before you start holding up the instructions in the manual as engineering gospel, remember that it is not the engineers who write it, nor do they have the final say on what goes in there. Technical document writers, operations management, and the legal department have more to do with a manual than the engineers do.http://www.pagparts.com
tjm0852
6-10-2004
Cortlandt Manor NY
'04 DBP R32 & '97 Jetta GL
Re: new ignition switch install (benzivr6) » | « » 2:20 PM 5-1-2006 | |
First timer here, using this method. Took about 2.5 hours from start to finish. Avoiding having to pull that 'steering wheel hub' off makes it a lot easier
-Tom-VAG-com Hex-Com-Can with laptop if you need a scan. PM me. "You ain't thinkin' of gettin' rid of the dank, are ya Moe?" "Oh, but Moe! The dank! The dank!!"
general problem
11-19-2004
time traveling NY
MK1&3x2
» | « » 2:21 PM 5-1-2006 | |
nice thread dude
Pete shut up and build
Franco...
6-18-2004
out of the gay
and in da Valley...CT
Re: (general problem) » | « » 5:28 PM 5-17-2006 | |
figured i'd bump this up, cuz i just used it and its a quality DIY.I'd like to add after you remove the bolt for the u-joint, you might need to hammer the shaft loose. thanks for the write up
autocratica 1 thirty pack at a time
tifosi2k2
4-21-2002
galion oh
91 gti 8v, 98 Jetta 2.slo
Re: (Franco...) » | « » 6:16 PM 5-17-2006 | |
| Quote, originally posted by Franco... » | | figured i'd bump this up, cuz i just used it and its a quality DIY. I'd like to add after you remove the bolt for the u-joint, you might need to hammer the shaft loose. thanks for the write up |
HA! I just finished it as well! Excellent write-up. I did however have a hard time getting that damn little screw out that was between the steering column and the actual ignition switch Had to steal a jewelers screw driver from my dad, and it was still a PITA. But it's all back together, and it works! Thanks again for the excellent write up!
http://www.cclarkphoto.com
jhayesvw
10-2-2001
Tucson AZ
1996 Golf 4 door VRT
Re: (tifosi2k2) » | « » 6:21 PM 5-17-2006 | |
i did mine the old way.but this way looks easy too.
MY CAR vwvortex is like the Hotel California, you can check out any time you like, but you can never leave. Tucson Forced Induction "The welfare of humanity is always the alibi of tyrants." - Albert Camus
totfjamie
3-25-2006
Milford CT
94"School Bus Yellow" Golf, 92 Range Rover
» | « » 6:41 PM 5-17-2006 | |
how do you tell when your ignition switch is starting to go?
Brewtech
10-6-2005
Los Angeles Ca
1974 911 1968 Ghia 1985 MK1 2000 E39
Re: (totfjamie) » | « » 6:51 PM 5-17-2006 | |
| Quote, originally posted by totfjamie » | | how do you tell when your ignition switch is starting to go? | Lights, and accesories dont work when you drive
Yo baby! Yo baby! YO!
Brewtech
10-6-2005
Los Angeles Ca
» | « » 6:54 PM 5-17-2006 | |
this should go in the DIY section. I'm serial people.
stereo
6-6-2006
Austin texas
1997, vw, cabrio
Re: (Brewtech) » | « » 12:31 AM 6-16-2006 | |
this is a vw cabrio 97.... can anyone tell me how to take this off?
stereo
6-6-2006
Austin texas
1997, vw, cabrio
Re: (Brewtech) » | « » 12:32 AM 6-16-2006 | |
trents97golf
10-16-2005
bellevue wa
1998, volkswagen k2
» | « » 5:16 PM 6-20-2006 | |
alright guys i got a 98 golf k2 and i can not get it out for the life of me i cant get the colum off. its nothing like that. i got the hex bolts out off the bag of the steering wheel now i dont know what to do there was no 13mm bolt? help plz..
heated seats are bomb... k2's rock
candela
10-18-2002
heart of miami
Re: (Brewtech) » | « » 4:37 PM 6-29-2006 | |
thanks for all the positive feedback guys.. happy to be of service to some fellow mk3ers..
sh0ter
8-28-2005
atlanta ga
98 jetta k2
» | « » 3:36 PM 6-30-2006 | |
I"m having trouble getting the shear bolts off. Anybody have any tips?
slow 2.0
10-29-2002
Levittown PA
!998 Nissan Maxima
Re: (sh0ter) » | « » 3:40 PM 6-30-2006 | |
I did that on my MKIII a while ago. if I remember, I just used my cordless dremmel and sliced the sheer bolt so I could fit a flathead screwdriver on it. Easy.
My Dads a pretty big wheel at the cracker factory.
sh0ter
8-28-2005
atlanta ga
98 jetta k2
» | « » 3:44 PM 6-30-2006 | |
Well I got the gold one. I was talking about the two bolts on either side of the sterring colum. I can't seem them in the pics above as the guy didn't take off his bottom dash.
slow 2.0
10-29-2002
Levittown PA
!998 Nissan Maxima
Re: (sh0ter) » | « » 3:47 PM 6-30-2006 | |
Sry, mang! I only remember having to get 1 off. The gold one. Not sure where your extra bolts are that you need to remove.BTW, did you guys have a ****ty time pulling the metal sleeve off of the column?? I remember that being a pain. (edit because I just realized that the whole point of this thread is to avoid the whole steering wheel puller method...sry!!)
Modified by slow 2.0 at 3:49 PM 6-30-2006
general problem
11-19-2004
time traveling NY
MK1&3x2
Re: new ignition switch install (candela!) » | « » 9:33 AM 8-10-2006 | |
Last night I did Sarahs (mkIIIcutiewithabooty's) ignition switch in her Gti using this method and it was MUCH easier than the traditional way. Whole thing only took about 30 mins, the hardest part for me was re-installing/alligning the steering column back into the U-joint. my advice is to WATCH YOUR FINGERS when doing this part  Thanks to candela and jok3sta for the pics and write up
The Stupid Police
7-20-2006
downtown NY
squad car
Re: new ignition switch install (general problem) » | « » 9:35 AM 8-10-2006 | |
| Quote, originally posted by general problem » | Last night I did Sarahs (mkIIIcutiewithabooty's) ignition switch in her Gti using this method and it was MUCH easier than the traditional way. Whole thing only took about 30 mins, the hardest part for me was re-installing/alligning the steering column back into the U-joint. my advice is to WATCH YOUR FINGERS when doing this part
hope ya got good at it cause on my way home from watchin ya at the garage my lights all turned off on the highway then flickerd back on my ignition switch is toast
FTWMoe Sizlack: i want to throw a bottle thru his window. The Stupid Police: and i want to be the getaway driver,
general problem
11-19-2004
time traveling NY
MK1&3x2
Re: new ignition switch install (The Stupid Police) » | « » 9:44 AM 8-10-2006 | |
| Quote, originally posted by The Stupid Police » | hope ya got good at it cause on my way home from watchin ya at the garage my lights all turned off on the highway then flickerd back on my ignition switch is toast |
im not your ****ing mechanic Besides I dont think you can pay me the way Sarah does
fourthchirpin
11-19-2004
EST.8/1/02
mk3gti
Re: new ignition switch install (general problem) » | « » 9:50 AM 8-10-2006 | |
| Quote, originally posted by general problem » | Last night I did Sarahs (mkIIIcutiewithabooty's) ignition switch in her Gti using this method and it was MUCH easier than the traditional way. Whole thing only took about 30 mins, the hardest part for me was re-installing/alligning the steering column back into the U-joint. my advice is to WATCH YOUR FINGERS when doing this part  Thanks to candela and jok3sta for the pics and write up
i just did mine monday and that was the hardest part realigning the u joint. i hate being i nthat position for more then 5 min. lol
FS: 02A Quaffie & 4.24 Ring/Pinion Final "RACING IMPROVES THE BREED"
West Indian Crew
antarchitect
1-17-2005
215
'02 Cabrio / '08 Rabbit
Re: new ignition switch install (fourthchirpin) » | « » 9:53 AM 8-10-2006 | |
Thanks, I'll be doing this shortly, along with 2 window regulators
flickr-last.fm-Book Shelf-Facebook Adopt a greyhound-MusicGourmets
The Stupid Police
7-20-2006
downtown NY
squad car
Re: new ignition switch install (general problem) » | « » 11:39 AM 8-10-2006 | |
| Quote, originally posted by general problem » | im not your ****ing mechanic Besides I dont think you can pay me the way Sarah does |
as her being my ex-GF, i know more kinds of payment than you do
exodub
1-5-2005
minnesnoda
1997 Jetta 2.0
Re: new ignition switch install (The Stupid Police) » | « » 12:12 PM 8-10-2006 | |
| Quote, originally posted by The Stupid Police » | as her being my ex-GF, i know more kinds of payment than you do |
lawl for shared vw girls. nice write up; i've got to do this soon. my keys are pretty loose in the ignition as it is now.
...and before my son was born i made him dance in the womb.i am adam. hello. Weitec 60/40 kit FS. --> http://forums.vwvortex.com/zerothread?id=2756520
DamnitDavee
7-12-2006
Colonia NJ
1997 2.slow Gti
» | « » 12:18 PM 8-10-2006 | |
Yea I hadda replace mine too.Got it done by myself thanks to the tex. It really is sick for a car moron like myself
Just passed 131,000. ......Windsor 2.slo...... ..........No CEL..........
