todye4
11-7-2002
San Francisco Ca
 BMW E34 540i 6 sp« »
Trying to find out some more info on these models, problems, concerns, issues. I've been finding them in my price range with the major maintinence done, usually in the 6-10k range around 95-140k miles. What are some of the things I should look out for, or should I just turn and run. Wondering if maintinence on the 540 will be more or just as much as an e36 M3????
It's an M5 but you get the idea.
search is down
thanks!
I represent from midnite to high noon......
///M5
740iS
WannaCorrado
4-30-2000
NY NY
08 GTI 4DR, 93 Corrado
 Re: BMW E34 540i 6 sp (todye4) »« »
concern #1 is the 1994-1995 nikosil issue, where the engine linings were made out of said material, which deteriorated quickly when used with US gasoline.
Make sure the engine block was replaced with alkasil-lined one. There are web sites dedicated to this issue
(OO=[][]=OO)
ilkhan_v4
3-29-2005
Coconut Creek FL
2008 Honda Pilot, 2008 BMW 535i
As with any BMW V8 of that era, check that it either has an Alusil block (ideal) or at least has good compression on all cylinders. See this page for more info: http://www.koalamotorsport.com/article-m60v8.asp
Common wear items are control arm bushings (and pretty much everything else in the suspension), control modules, door panel trim, etc. The E34 is a pretty solid car mechanically, though. Check out http://www.bmwe34.net/ for lots of repair/maintenance info.
240nut
5-16-2005
Nashville TN
Ditto on the Nikasil issue. I was offered a flawless Dinan M5 about 5 years ago for $20,000 by a close friend, and was just about ready to buy it. In fact that picture of the black car is very close to what I was looking at. It was a sweet car, with about 50,000 miles and a custom interior including 4 leather Recaros.
I contacted the service manager of John Roberts BMW in Austin, and was told that the Nikasil engines self destruct at about 5 years/70k miles on exposure to high sulfur fuels (such as we have here in Texas) and cost about $15,000 to replace, sans modifications. BMW had (and may still have) a warranty that partly covered the replacement cost to the original owner only. In the end, it would have cost me about $39,000 for a $20,000 used car, and it didn't make sense.
My friend still has the black car, though, and had the engine replaced at BMW's expense with the upgraded engine.
ilkhan_v4
3-29-2005
Coconut Creek FL
 Re: BMW E34 540i 6 sp (240nut) »« »
Quote, originally posted by 240nut »
Um, M5's never came with Nikasil engines. Unless maybe you mean an M540i, in which case it could have.
Slump
1-15-2002
Minneapolis MN
Uh, the e34 M5 had an inline six (s38b36) that was an iron block. It didn't have an 8 cylinder nikasil impregnated aluminum block.
So... um.. your friend doesn't have an M5...
Modified by Slump at 10:23 PM 4-3-2006
Quote, originally posted by jayseal22 »
and that's all that matters. If he had a magic genie in a box and said wa da ya think and the genie said tranny crapped out bam its been seen 89 dollar to zobra the great.
todye4
11-7-2002
San Francisco Ca
 Re: BMW E34 540i 6 sp (Slump) »« »
Quote, originally posted by Slump »
which brings up another interesting point....
would you take an M5 with the inline 6 or the 540i with the aluminum 4.4ltr.
you can obtain both at similar prices, hmmm.
///M5
740iS
todye4
11-7-2002
San Francisco Ca
 Re: BMW E34 540i 6 sp (ilkhan_v4) »« »
Quote, originally posted by ilkhan_v4 »
great info also, wasnt aware of this issue, thanks all, keep'em coming
///M5
740iS
Slump
1-15-2002
Minneapolis MN
Quote, originally posted by todye4 »
Oh, that's easy. M5. The 540i sport will continue to depreciate to nothing, but the M5 will bottom out around $10K and then start appreciating in a few years, if you keep it nice.
The s38 is going to be about the same cost to maintain as that big v8.
Everything else is about the same - ie. the same number of gadgets and electric motors on the inside to break.
I'd also trust the s38 to last longer then the v8. Many (most?) s38s are over 100-150k miles and still running VERY strong.
On the other hand, if it's a real 540i sport, it's a pretty rare car - even more rare then an M5, but between the two, get the real thing, not the pretender.
Edit: just remembered one other thing. If it's a real 540i sport, then it's got the 'ring suspension, which you couldn't get on a US M5 - nice suspension, but big $$ if it breaks (self levelling, etc.)
Modified by Slump at 10:45 PM 4-3-2006
Modified by Slump at 10:46 PM 4-3-2006
todye4
11-7-2002
San Francisco Ca
great points, just to clarify the 540i sport you speak of is also considered the M540i M-Sport?
http://www.roadfly.com/bmw/cla...35814
low milage, but damn that's salty.
///M5
740iS
todye4
11-7-2002
San Francisco Ca
1 of 135 produced w/6speed
///M5
740iS
Slump
1-15-2002
Minneapolis MN
Yes.
todye4
11-7-2002
San Francisco Ca
 Re: (todye4) »« »
The 1995 BMW 540i Sport (also called an M-Sport) is really a standard '95 540i with the following additions:
Various body and interior pieces from the Euro ’95 M5: mirrors, spoilers/side skirts, wheels, steering wheel, shift knob, and sill panels.
The M5’s EDC III suspension + M5 Servotronic steering.
Bigger brakes
nice website, lots of info on this topic.
http://www.kindel.com/bmw/how_to_identify.htm
///M5
740iS
lynx8489
7-29-2002
sacramento CA
///M
post up some pics of the white one in question.
916
todye4
11-7-2002
San Francisco Ca
 Re: BMW E34 540i 6 sp (lynx8489) »« »
for under 7k, not the color combo Id want but just looking, if I found one in a color combo I liked I would consider it along with the E34 M5 or E28.
ad.......
Excellent condition 540i well maintained. Car has 141,000 miles on it and as such has had a number of things recently replaced. Within the last couple of years I have replaced the clutch, brakes, shocks, radiator, water pump, valve cover gaskets, alternator, new Michelin Pilot Sport tires, and more. I am sad to sell it because I really have replaced most anything that you would need to on a car of this vintage. I had intended to have my daughter take this car but it turns out that it is a little to much car for her - if you know what I mean. This car is a blast to drive and is very comfortable. Great blend of performance and luxury. Not as electronically over the top as a lot of the newer BMW’
///M5
740iS
VW-BMW
12-18-2001
Winona Lake IN
Check that car out in real life. Worth every penny.
dastig
11-12-2004
DubC OH
E36 328is
That is where I bought my E36.
He also has another 95 540, that is a Stage 3 Dinan. Pushing 475hp.
He always has a badass inventory.
http://www.car-locators.com/inventory.html
todye4
11-7-2002
San Francisco Ca
 Re: BMW E34 540i 6 sp (dastig) »« »
Quote, originally posted by dastig »
wow, nice. there is another low milage one on there a little more resonable.
any pics of it?
///M5
740iS
todye4
11-7-2002
San Francisco Ca
found it.....
ill
///M5
740iS
TigerII
12-4-2001
LA ca
1988 jetta GL 5SP- RIP, 1997 getta GL 5SP, 1988 E30 M3, 2001 E46 325i
I would not waste a dime on a 540M over an M5.
THe M5 is a whole different ballgame. One of the most exciting cars I have ever driven.
Born
and
raised
"Jettas are safe because they make their drivers feel unsafe"
http://www.gladwell.com/2004/2004_01_12_a_suv.html
a2a4raddo
8-13-2001
New York NY
 Re: BMW E34 540i 6 sp (TigerII) »« »
Quote, originally posted by TigerII »
the u.s. spec E34 540i Sport & canadian spec M540i are virtually identical to the M5 in terms of aerodynamic bits, interior & suspension. the differance is they have a 6-speed rather then a 5-speed & a 4.0L V8 rather then a 3.6L I-6. more Torque, less HP....they are about equal in terms of accel.
-XJ: 4.5" Lift
-968: 246RWHP All Motor.
-C5 A6 4.2 Sport
Impeccable
4-16-2004
WEST PALM BEACH FL
2002 MR2 SPYDER maybe something else this year
 Re: BMW E34 540i 6 sp (a2a4raddo) »« »
I think the M5 might be a bit more reliable, even though I would trust neither
ModelCitizen
3-25-2004
Orange County CA
05 Prerunner Tacoma
ill
Pure class....
I've got the e34 535i on my shortlist.
WhitePoloCT
7-28-2005
Cape Town WC
'99 Golf Mk3.5 Cabriolet, '05 Honda S2000
found it.....
ill
Ill indeed! Very, very nice!!
BTW: Are those 7-series wheels?
Quote, originally posted by alleghenyman »
Let's just say I like my women like I like my cars - fast, cheap, kinda ugly and beaten up, unreliable, dangerous, unwanted....
4 coilpacks, 2 gearboxes and counting...
a2a4raddo
8-13-2001
New York NY
 Re: BMW E34 540i 6 sp (WhitePoloCT) »« »
Quote, originally posted by WhitePoloCT »
those wheels were first used on the canadian spec E34 M540i & euro spec E34 M5 3.8L. then later on the 740i Sport.
-XJ: 4.5" Lift
-C5 A6 4.2 Sport
» Return to The Car Lounge
