Shifty
3-25-2004
OKC OK
1967 SO-42 Microbus / 2010 Genesis Coupe Track / 2001 Jetta 16v(!) / '05 Ducati Monster 620
 Question to those who have shaved and molded bumpers...« »
After doing the work to this bumper (the first mkIV shave/mold I have done), everything looked terriffic. Once I got it in the sun though, the worked areas shrunk in and you can see the area around the moldings and valence.
I have seen this happen before, and I really tried to avoid this. I used the reccomended Duramix and very little filler. Then shot and blocked 2 coats of ZChrome, 2 coats 2K, and applied a coat of sealer prior to the basecoat.
What products have you guys used to avoid the shrinking? It appears my materials were incorrect. Pre-emptive thanks!!
Robert Lackey
Shifty's Spraywerkz
Oklahoma City, OK. 405-474-7551
Shop pics updated daily at: fotki.com/spraywerkz
Mrs.Shifty's MkIV 16v Build: http://forums.vwvortex.com/zerothread?id=4402884
boostedglx
7-27-2004
Poconos Pa
2001 .5 S4 AVANT silver/black (SOLD)
Actually .. EVERY one ive ever seen done has done this. When I did mine I filled it with Duramix and put it in the sun for a few days. I then put the skimcoat on and again put it in the sun .. once I put a few coats of 2K I blocked it down and again baked it in the sun...
primed it once again .. and then I felt comfortable enough to spray them...
Took me too long to do but .. I had NO problems at all
Jamie
Shifty
3-25-2004
OKC OK
 Re: (boostedglx) »« »
Thanks man. I thought about blocking it while in the sun and reshooting. that might happen later.
Robert Lackey
Shifty's Spraywerkz
Golf13
10-16-2005
DUB L IN OH
04 Golf 2dr, 84 2dr project
 Re: (Shifty) »« »
guide coat it, block it, fill it, block it, then respray it and it should be good
Looks nice though
Quote, originally posted by SRSVW »
I am after all the one that started the front bar removal.
Dick Shine
lolzzz
vwman099
9-26-2002
Owings Mills MD
06 TSX, 66 Bug
 Re: Question to those who have shaved and molded bumpers... (Shifty) »« »
I apply extra filler past the worked area and then block/feather the edges in (usually helps keep those edges out).
Block one coat of 2k primer with 220... Then shoot a lighter layer of primer and block with an old piece of 220 and finishing blocking with 500 (around).
I just follow the dry times on the spec sheets for the 2k.
Kemper
3-7-2005
Troy NY
'93 Passat, Metro, '05 Prius, '97 Dodge Caravan
Looks Great Props to taming the unknown i wish i had the balls and the know how to do that,
Quote, originally posted by athenaMKIV1.8T »
It took so long because they had trouble getting it up
RJ Photography | Alaska Airlines, North of Expected
Shifty
3-25-2004
OKC OK
 Re: Question to those who have shaved and molded bumpers... ('93 Passat GLX) »« »
Thanks! Actually seems like the shrinkage decreased over the past week. Like it baked a little more and now it doesn't move as much. Who knows? Anyway heres some more pix.
Robert Lackey
Shifty's Spraywerkz
Sjnbracr
7-7-2003
san jose ca
what is the zchrome stuff u used? also what kind of filler did u use over the duramix? was it a polyester filler?
If you used a Polyester filler over a urathane filler then u will experence Bubbling and shrinking. Also did u also use all the recomended adhesion promoters before applying dura mix?? my main intrest in knowing what the zhrome stuff is,.
-Dan
Sold the Corrado and bought a Dodge, But im still vortex addicted I should probably just go to the dodgforums.com
Danny
Shifty
3-25-2004
OKC OK
 Re: Question to those who have shaved and molded bumpers... (Sjnbracr) »« »
Quote, originally posted by Sjnbracr »
what is the zchrome stuff u used? also what kind of filler did u use over the duramix? was it a polyester filler? Also did u also use all the recomended adhesion promoters before applying dura mix?? my main intrest in knowing what the zhrome stuff is,.
-Dan
Z Chrome is a sprayable filler. This stuff is great - it's labeled as a rust defender, sealer, primer, and filler. I use it for things like this where I don't want a bunch of poly filler to come back and haunt me. The stuff sprays on transparent orange, but very thick. Hard to explain, but by looking at it you would definetly not expect it to be filling anything. Once you start sanding the guide coat off though, you realize how much this stuff rocks.
I use a few good coats of ZChrome on aftermarket parts (like DubTechnik skirts and Euro Gear bumpers) and most of the imperfections block right out the first time.
I did use poly filler on this one, but VERY little. I was able to epoxy the moldings at just the right height to the bumper face. I then 2K'd the epoxy and added a very thin skim coat of Rage filler over that. The Z Chrome took care of the rest. Most of the filler went into the area where the valence was molded to make the radius there.
I did try doing a test fascia without the adhesion promoter and it DID NOT work! I used the adhesion promoter on the main bumper and had no issues.
Some pics of the trimmed-down moldings:
Modified by Shifty at 5:38 PM 4-9-2006
Robert Lackey
Shifty's Spraywerkz
Kemper
3-7-2005
Troy NY
wow man thats so sweet, but i just dont think i could go through with sanding down my paint, uggh gives me the chills
VWChimera
7-8-2004
Richfield MN
1991 GTI VRT
Quote, originally posted by Shifty »
Did you just trim down the rubstrips and then smooth/mold over them? I had always figured you needed to fill the whole area in with filler or something? This seems like it would be simpler and makes a lot more sense. Do you happen to have anymore pictures of how much you took off the strips and how you set them into the grooves. I'm an absolute novice so please forgive me if these questions are off base. Thanks, Dave
Lock-to-Lock Racing: Replacing perfectly good parts since 2006
Shifty
3-25-2004
OKC OK
 Re: Question to those who have shaved and molded bumpers... (detailer03) »« »
Quote, originally posted by detailer03 »
I have more pix, but I dropped my cam and broke it and can't get them to upload - yet. Anyway, if you remove the strip you'll see there is a pretty large lip under it. I trimmed the lip completely off EXCEPT for the clips that lock the strip on. I left them for locating and holding the strip during bonding.
Once you do this, the strip can almost lie completely flat on the bumper. But you still have to: A.) cut the ends of the rubstrip since the new height will make them longer around the corners, and B.) grind off some material behind the rubstrip mounting area for clearance.
At this point I layed a few beads of Duramix inside the strip and installed them, holding them in place with large C-clamp ViseGrips. I ran the bead of Duramix around the moldings and let them dry, then began bodywork from there. I did have to grind a bit more material from the face of the moldings during the bodyworking process, but I figured it'd be better to take material off the plastic pieces than add more epoxy and filler (as long as I didn't sand through).
IMO, filling the molding openings any other way would be either way too time consuming and/or expensive (lots more material used), and/or not nearly as durable in the long run. I figure if he bumps something with the strips in place they will still give a little and worst case scenario a little filler cracks. I researched quite a bit and kept coming back to this method. I don't know how others are doing it, but I'd certainly recommend this way.
Modified by Shifty at 11:07 PM 4-12-2006
Robert Lackey
Shifty's Spraywerkz
vwman099
9-26-2002
Owings Mills MD
06 TSX, 66 Bug
Your prep and work sounds good.... I'm surprised that any shrinking occured...
With today's products you shouldn't have major issues with dry times (to where you should have to leave it dry for days). Heck, I have sprayed a "QuiK" clear that was sandable the same day without force drying (company claimed in a matter of hours).
Looks good!
What base and clear did you spray?
formerly vr6 karl
1-25-2003
nowheresville yeah
dissappointing loved ones since 78
 Re: Question to those who have shaved and molded bumpers... (vwman099) »« »
i did mine different, i stripped all the paint to bare plastic, laid a layer of duramix, then a layer of nylon mesh, then layered the rest with the duramix (i took @ 8 tubes for the front bumper alone).........the bumper is still in a unpainted state but havent experienced any cracking or shrinking---------these bumpers have been sitting in the socal sun for about 2 years and have been tossed around without a second though that they might get damaged and crack
anyway thanks for the little bit of info for the primer
get butt-naked and rock these!!! http://forums.vwvortex.com/zerothread?id=4423438
buy this or ill put your cat in the microwave http://forums.vwvortex.com/zerothread?id=4741459
TMTuned99.5Golf
1-27-2004
Hiding next to a tree in Oregon
'99.75 2dr Bolf '85 4dr Golf '92 2dr Golf (Diesel)
 Re: Question to those who have shaved and molded bumpers... (formerly vr6 karl) »« »
WOW!! Beautiful work you did there!! I'll be rereading this when I shave the rub strip on my front bumper later this term in autobody.
What's the part number for the Duramix? Just want to be able to get the same stuff you did if there's a multitude of choices. That and I'll prolly be following the EXACT same procedure you did with the materials. Make sure I do it right the first time.
As my autobody instructor says:
"There's never enough time or money to do it right the first time but there is always enough time and money to fix it."
Modified by TMTuned99.5Golf at 4:14 PM 4-14-2006
Ported MK4 AEG and 1.8T intakes
Quote, originally posted by tdogg74 »
Powered By Ignorance
Some people need that vinyled to their windshield.
VWChimera
7-8-2004
Richfield MN
1991 GTI VRT
If you don't mind me asking I'd like to know how much it cost the customer to have all of this done. I'm looking at splitting some of the work between two different shops and it would be good to get a brake down from you as to how many hours you charged for the molding? How much you spent on materials? And how much was billed out for paint? Not to pry but this could really help me get an estimate of how much I should expect my upcoming work to cost.
Shifty
3-25-2004
OKC OK
Thanks for the compliments guys!
Lots of questions there, I'll try and answer them all...
Someone asked about price - this was a sponsorship deal so the customer really got hooked up. The upside is I get to slap Spraywerkz decals all over it! I have quoted two others for this same job since completeing these, and I came up with $1020 per fascia. That's $720 in labor (19 @ $45/hr) and $300 in materials. Prices will likely vary greatly from shop-to-shop. Some shops probably won't even touch this job.
I used DuPont Chromabase/Clear to finish the fascias. I love the stuff. In the past I have shot PPG, R-M Diamont (good stuff as well), and Spies-Hecker.
As for the Duramix part number, I have it at the shop. I would not recommend the type I used, however. It bonds well enough but does not sand well at all. The edges peel right up and you cannot feather it out. There is another number which I understand sands and feathers much better. This is what the 3M reps are telling me anyway. Duramix distributors should have a chart that shows all the PPO-compatible products and their sanding characteristics. I'd check that out.
Modified by Shifty at 6:06 PM 4-14-2006
Robert Lackey
Shifty's Spraywerkz
boostedglx
7-27-2004
Poconos Pa
I used 4040 and 4041 .. the 4041 is the the ont that skims and feathers.. the 4040 is the filler .. and thats not a bad price to do the jod correctly.
Sjnbracr
7-7-2003
san jose ca
 Re: Question to those who have shaved and molded bumpers... (boostedglx) »« »
if the edges are chipping and feathering it meens there was a prep problem..... I use to have that same problem.
So one day i decided to do everything but the technical Data Sheets and no problems after that....
Right now i switched over from Duramix to the Evercoat Maxim plastic repair. Really good system and Very easy to use. Also no special gun is needed. Just any regular calking gun works...
-Dan
Danny
formerly vr6 karl
1-25-2003
nowheresville yeah
i used 4036
Shifty
3-25-2004
OKC OK
-Dan
That's what I thought. I tried prepping with 40 grit then 80, with and without adhesion promoter, called 3M, etc... finally discovered that the type I used just does not sand well. This is straight from the 3M help line people.
Robert Lackey
Shifty's Spraywerkz
Sjnbracr
7-7-2003
san jose ca
next time you do Plasatic work, try this new stuff from Evercoat called Maxim plastic repair.... So simple to use and follow all directions... Use all the Correct panel prep and adhesion promoters..... Then use there special 2 part 1:1 final sand stuff and it makes the repair so good....... Never will i use Duramix or anyother product.. Evercoat just makes great quality products that are affordable..
-Dan
Danny
Shifty
3-25-2004
OKC OK
I use Evercoat Rage fillers with nice results. I'll have to check into their plastic bonding products. Thanks for the heads-up.
Robert Lackey
Shifty's Spraywerkz
andyveedub
3-22-2001
Carlsbad CA
64 lowlow
im actually nearing the final stages of this on my own car and i am curious as to whether or not you guys are using a DA with the final or sanding of if youre doing it all by hand, mine still feel pretty wavy and im afraid when i go to paint them you will surely notice that, thanks for any advice
club.broke.status - Just as broke at the next guy.
I've been around more than ya mom
http://www.vwparadise.com
Shifty
3-25-2004
OKC OK
 Re: Question to those who have shaved and molded bumpers... (andyveedub) »« »
Block block block block block!
I used a DA only in the very first stages. Everything beyond the first coat of filler was done with a paintstick and 220/360.
Robert Lackey
Shifty's Spraywerkz
Sjnbracr
7-7-2003
san jose ca
Well Rage on plastic surfaces will fail over time.... It will crack first then look god awefull... Only use plastic repair products on Bumpers and any other plastic parts.... Regular body filler will fail. Also im suprised you get adhesion with rage on bumpers..
-Dan
Danny
Shifty
3-25-2004
OKC OK
-Dan
Hmmm. Something to look forward to. This is how I was told to do it by many different people. Paint store reps said I'd be fine as long as I put down 2k before filler. Might explain my shrinking issue.
Robert Lackey
Shifty's Spraywerkz
boostedglx
7-27-2004
Poconos Pa
I wouldnt worry to much.. My bumpers are done the same way and I have had them done for 3 years now with no problrems.with rage and evercoat
Shifty
3-25-2004
OKC OK
^^^Rad.
BTW, I went ahead and posted a how-to on this for anyone interested. I had a few requests and a few spare minutes, so here it is:
http://forums.vwvortex.com/zer...d=148
Robert Lackey
Shifty's Spraywerkz
vwman099
9-26-2002
Owings Mills MD
06 TSX, 66 Bug
I wouldn't worry either.....
I am a firm believer in poly fillers and use them accordingly.
ReverendHorton
9-27-2000
Utica NY
2001 GTI 1.8t
^^^Rad.
that link doesn't work... not that it was hard to find the topic but here is a working link:
Shaving and Molding DIY
my Xbox Live gamertag: vroompsht
2001 GTI 1.8t - bolt-ons for autox fun 1998 Jetta VR6 - her daily driver
FS: GIAC OBDII cam chip for K ecu 1996
Shifty
3-25-2004
OKC OK
 Re: Question to those who have shaved and molded bumpers... (ReverendHorton) »« »
Thank you sir.
Robert Lackey
Shifty's Spraywerkz
» Return to Body Work, Body Styling and Body Kits
